path: root/MAINTAINERS
2011-12-02Merge branch 'master' of git://git.denx.de/u-boot-ppc4xxWolfgang Denk
* 'master' of git://git.denx.de/u-boot-ppc4xx: ppc4xx: Add Io64 board support ppc4xx: fix PMC440 painit command ppc4xx: remove invalid access to PCI_BRDGOPT2 register ppc4xx: use CONFIG_PCI_BOOTDELAY instead of private implementation
2011-12-01ppc4xx: Add Io64 board supportDirk Eibach
Board support for the Guntermann & Drunck Io64. Signed-off-by: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Stefan Roese <sr@denx.de>
2011-11-29mpc85xx: support for Freescale COM Express P2020Ira W. Snyder
This adds support for the Freescale COM Express P2020 board. This board is similar to the P1_P2_RDB, but has some extra (as well as missing) peripherals. Unlike all other mpc85xx boards, it uses a watchdog timeout to reset. Using the HRESET_REQ register does not work. This board has no NOR flash, and can only be booted via SD or SPI. This procedure is documented in Freescale Document Number AN3659 "Booting from On-Chip ROM (eSDHC or eSPI)." Some alternative documentation is provided in Freescale Document Number P2020RM "P2020 QorIQ Integrated Processor Reference Manual" (section 4.5). Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-11-27Fix Stelian's email addressStelian Pop
Change my old email address which is no longer valid. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-11-16Orphan EVB64260_750CX boardWolfgang Denk
The last maintainer (Eran Man) cannot be reached any more. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-11-16Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
* 'master' of git://git.denx.de/u-boot-arm: arm, davinci: add DAVINCI_MMC_CLKID arm, davinci_emac: fix driver bug if more then 3 PHYs are detected arm, davinci: da850/dm365 lowlevel cleanup omap5: Add omap5_evm board build support. omap4/5: Add support for booting with CH. omap5: emif: Add emif/ddr configurations required for omap5 evm omap5: clocks: Add clocks support for omap5 platform. omap5: Add minimal support for omap5430. omap: Checkpatch fixes omap4: make omap4 code common for future reuse GCC4.6: Squash warnings in onenand_base.c GCC4.6: Fix common/usb.c on xscale OneNAND: Add simple OneNAND SPL PXA: vpac270: Enable the new generic MMC driver PXA: Cleanup serial_pxa PXA: Drop csb226 and innokom boards (unmaintained) m28evk: Fix comment about the number of RAM banks mx31: Fix checkpatch warnings in generic.c mx31: Use proper IO accessor for GPR register mx31: Remove duplicate definition for GPR register qong: Use generic function for configuring GPR register M28EVK: Enable USB HOST support iMX28: Add USB HOST driver iMX28: Add USB and USB PHY register definitions M28: Add memory detection into SPL iMX28: Fix ARM vector handling M28: Add doc/README.m28 documentation M28: Add MMC SPL iMX28: Add support for DENX M28EVK board iMX28: Add u-boot.sb target to Makefile iMX28: Add image header generator tool iMX28: Add driver for internal RTC iMX28: Add GPMI NAND driver iMX28: Add APBH DMA driver iMX28: Add SPI driver iMX28: Add GPIO control iMX28: Add I2C bus driver iMX28: Add PINMUX control FEC: Add support for iMX28 quirks iMX28: Add SSP MMC driver iMX28: Initial support for iMX28 CPU MX25: zmx25: GCC4.6 fix build warnings da850: add new config file for AM18xx BeagleBoard: config: Switch to ttyO2 OMAP3: Change omap3_evm maintainer devkit8000: Fix NAND SPL on boards with 256MB NAND integrator: enable Vpp and disable flash protection integrator: add system controller header integrator: make flash writeable on boot integrator: use io-accessors for board init integrator: move text offset to config integrator: pass configs for core modules ARM: remove superfluous setting of arch_number in board specific code. SPL: Allow ARM926EJS to avoid compiling in the CPU support code integrator: do not test first part of the memory arm: a320: fix broken timer ARM: define CONFIG_MACH_TYPE for all ronetix boards dm646x: pass board revision info to kernel dm646x: add new configuration for dm6467T arm, davinci: Fix setting of the SDRAM configuration register arm, davinci: Remove the duplication of LPSC functions arm, davinci: Rename AM1808 lowlevel functions to DA850 da8xxevm: fix build error ARM: re-add MACH_TYPE_XXXXXX for VCMA9 board and add CONFIG_MACH_TYPE
2011-11-15omap5: Add minimal support for omap5430.Sricharan
This patch adds the minimal support for OMAP5. The platform and machine specific headers and sources updated for OMAP5430. OMAP5430 is Texas Instrument's SOC based on ARM Cortex-A15 SMP architecture. It's a dual core SOC with GIC used for interrupt handling and SCU for cache coherency. Also moved some part of code from the basic platform support that can be made common for OMAP4/5. Rest is kept out seperately. The same approach is followed for clocks and emif support in the subsequent patches. Signed-off-by: sricharan <r.sricharan@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-15PXA: Drop csb226 and innokom boards (unmaintained)Marek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Robert Schwebel <robert@schwebel.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-11-11iMX28: Add support for DENX M28EVK boardMarek Vasut
This contains support for the following components: - DUART - MMC - Both FEC interfaces - NAND - I2C (RTC, EEPROM) - SPI (FLASH) Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de>
2011-11-10OMAP3: Change omap3_evm maintainerTom Rini
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Tom Rini <trini@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-10adp-ag101p: add product into MAINTAINERS listMacpaul Lin
Add ADP-AG101P into MAINTAINERS list. Add ADP-AG101P into boards.cfg. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-11-04OMAP3: mvblx: Initial support for mvBlueLYNX-XMichael Jones
Add support for the MATRIX VISION mvBlueLYNX-X, an OMAP3-based intelligent camera. Signed-off-by: Michael Jones <michael.jones@matrix-vision.de> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-03arm, davinci: add cam_enc_4xx supportHeiko Schocher
- DM368 SOC - booting with spl not with UBL from TI - before loading u-boot from NAND into RAM, test the RAM with the post memory test. If error is found, switch all LEDs on and halt system. - SPI Flash Dataflash Typ: M25PE80 - Ethernet DM9161BI - MMC - USB Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Sandeep Paulraj <s-paulraj@ti.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-03mx31: Add board support for HALE TT-01Helmut Raiger
This adds basic board support for TT-01 based on the Bluetechnix i.MX31 SOM. Currently only NOR-Flash boot is implemented. Signed-off-by: Helmut Raiger <helmut.raiger@hale.at> Acked-by: Stefano Babic <sbabic@denx.de>
2011-11-03MX35: add support for flea3 boardStefano Babic
The flea3 board is a custom board by CarMediaLab used in automotive. Network (FEC), NOR, NAND and SPI are supported. Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-10-27ARM: Add Calxeda Highbank platformRob Herring
Add basic support for Calxeda Highbank platform. Only minimal support with serial and SATA are included. Signed-off-by: Jason Hobbs <jason.hobbs@calxeda.com> Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-10-27ARM:AM33XX: Add support for TI AM335X EVMChandan Nath
This patch adds basic support for booting the board. This patch adds support for the UART necessary to get to the u-boot prompt. Signed-off-by: Chandan Nath <chandan.nath@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-10-27dreamplug: initial board support.Jason Cooper
Copied wholeheartedly from board/Marvell/guruplug and modified to add support for SPI NOR flash. CONFIG_MACH_DREAMPLUG defined in include/configs/dreamplug.h until Linus's kernel.org tree adds it to mach-types.h. Once it trickles down, the definition can be removed from include/configs/dreamplug.h. Signed-off-by: Jason Cooper <u-boot@lakedaemon.net>
2011-10-23MPC85xx: remove broken "mpq101" boardWolfgang Denk
The board stopped building some time ago, and the board maintainer agrtees to drop it - see http://article.gmane.org/gmane.comp.boot-loaders.u-boot/112674 Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Alex Dubov <oakad@yahoo.com> Cc: Andy Fleming <afleming@gmail.com> Cc: Kumar Gala <galak@kernel.crashing.org>
2011-10-22adp-ag101: add board adp-ag101 supportMacpaul Lin
Add evaluation board "adp-ag101" configuration file adp-ag101.h. Add adp-ag101.c board config and related settings. Add board adp-ag101 into boards.cfg Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-10-12MIPS: Jz4740: Add qi_lb60 board supportXiangfu Liu
Add support for the qi_lb60 (a.k.a QI Ben NanoNote) clamshell device from Qi hardware: http://en.qi-hardware.com/wiki/Ben_NanoNote http://en.qi-hardware.com/wiki/Main_Page http://en.wikipedia.org/wiki/Qi_hardware This Jz4740-based clamshell device does not use NOR flash to boot. The initial bring-up assumes that U-Boot is directly loaded into SDRAM using USB boot tool, and starts from 0x80100000. About USB boot tool ------------------- Jz4740 is one of the XBurst processors with USB boot functionality supported. The CPU can boot from a small ROM in the LSI, initialize CPU and USB module, then wait for USB commands from the USB host. We can send 8 KB binary data to the CPU cache using USB boot tool. USB boot tool is available to the public at Ingenic website. Also there is an alternative Debian package named xburst-tools. Signed-off-by: Xiangfu Liu <xiangfu@openmobilefree.net> Acked-by: Daniel <zpxu@ingenic.cn> Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2011-10-01sbc82xx: delete support for obsolete SBC8240/SBC8260Paul Gortmaker
The EST SBC8260 is over 10 years old, and the SBC8240 older than that. With the tiny amount of RAM (by today's standards), there really isn't anyone interested in running the latest U-boot on these EOL products anymore. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> CC: jon.diekema@smiths-aerospace.com
2011-10-01MAINTAINERS: delete stale entry for EOL Wind River boardsPaul Gortmaker
This e-mail address is no longer valid, and the boards are long since EOL. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-09-30EfikaMX: Add imximage config for Efika SBMarek Vasut
2011-09-30MX25: Add initial support for MX25PDKFabio Estevam
Add the initial support for MX25PDK booting from SD card via internal boot. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-09-30omap4: update maintainer for omap4 boardsAneesh V
Steve wants to transfer maintainership of OMAP4 boards to me as he is not working on these boards lately. CC: Steve Sakoman <steve@sakoman.com> CC: Sandeep Paulraj <s-paulraj@ti.com> CC: Albert Aribaud <albert.u.boot@aribaud.net> CC: Wolfgang Denk <wd@denx.de> Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-27ARM: remove broken "ixdp425" and "ixpdg425" boardsAlbert ARIBAUD
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Acked-by: Stefan Roese <sr@denx.de>
2011-09-07ARM: remove broken "shannon" board.Wolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Rolf Offermanns <rof@sysgo.de>
2011-09-07ARM: remove broken "modnet50" board.Wolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Thomas Elste <info@elste.org>
2011-09-07ARM: remove broken "lart" board.Wolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Alex Züpke <azu@sysgo.de>
2011-09-07ARM: remove broken "impa7" board.Wolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Marius Gröger <mag@sysgo.de>
2011-09-07ARM: remove broken "gcplus" board.Wolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: George G. Davis <gdavis@mvista.com>
2011-09-07ARM: remove broken "ep7312" board.Wolfgang Denk
2011-09-07ARM: remove broken "dnp1110" board.Wolfgang Denk
2011-09-04MAINTAINERS: fix integrator and versatileLinus Walleij
- Take maintainership of the integratorcp board - Remove the double entry for the versatile board it has two variants but only one board folder Cc: Philippe Robin <philippe.robin@arm.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-09-04ARMV7: Add support for Samsung ORIGEN boardChander Kashyap
Origen board is based upon S5PV310 SoC which is similiar to S5PC210 SoC. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-09-04ARM: remove broken "at91cap9adk" boardWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stelian Pop <stelian.pop@leadtechdesign.com>
2011-09-04ARM: remove broken "smdk2400" boardWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Gary Jennejohn <garyj@denx.de>
2011-09-04ARM: remove broken "B2" boardWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Andrea Scian <andrea.scian@dave-tech.it>
2011-09-04ARM: remove broken "armadillo" boardWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Rowel Atienza <rowel@diwalabs.com>
2011-09-04ARM: remove broken "assabet" boardWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: George G. Davis <gdavis@mvista.com>
2011-08-22sh: Add Renesas rsk7264 boardPhil Edworthy
The rsk7264 (also know as rsk2+sh7264) is an SH2A based board with 64MB NAND flash and 64MB SDRAM. It is very similar to the rsk7203 board. Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-08-04Convert ISO-8859 files to UTF-8Albert ARIBAUD
There was a mix of UTF-8 and ISO-8859 files in the U-Boot source tree, which could cause issues with the patchwork review system. This commit converts all ISO-8859 files to UTF-8. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-08-04Armada100: Add Board Support for Marvell GuruPlug-DisplayAjay Bhargav
This patch adds basic board support with DRAM and UART functionality Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com> Acked-by: Tanmay Upadhyay <tanmay.upadhyay@einfochips.com>
2011-08-03avr32: add grasshopper (ICnova AP7000) boardAndreas Bießmann
The grasshopper board is a neat avr32 evaluation kit produced by In-Circuit GmbH. See http://www.ic-board.de/product_info.php?info=p75_ICnova-AP7000-Base.html for detailed information about this device. Signed-off-by: Andreas Bießmann <biessmann@corscience.de> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2011-07-28Removed obsolete Netstal boardsNiklaus Giger
Signed-off-by: Niklaus Giger <niklaus.giger@member.fsf.org>
2011-07-28MAINTAINERS: integrator+versatile boardsLinus Walleij
- Take maintainership of the unlisted integratorap board - Orphan the boards maintained by Peter Pearse, as he has retired from ARM Cc: Philippe Robin <philippe.robin@arm.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-07-14imx: Add support for zmx25 boardMatthias Weisser
zmx25 is a board based on imx25 SoC, 64 Megs of LPDDR, 32 Megs of NOR flash, an optional NAND flash. Signed-off-by: Matthias Weisser <weisserm@arcor.de>
2011-07-14ARM: Update maintainer of board scb9328Torsten Koschorrek
Signed-off-by: Torsten Koschorrek <koschorrek@synertronixx.de>
2011-07-11powerpc/85xx: Add basic support for P1023RDS boardRoy Zang
The P1023RDS board is the reference board for the P1023 SoC. Add support for booting it from NOR or NAND, with fixed 2G of DDR, PCIe, UART, I2C, etc. Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Chunhe Lan <Chunhe.Lan@freescale.com> Signed-off-by: Lei Xu <B33228@freescale.com> Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
