The IGEP module is a low-power, high performance production-ready
system-on-module (SOM) based on TI's OMAP3 family.The IGEP module
solution based upon TI OMAP3 provides a low-power/low-cost platform
for a variety of consumer/industrial/medical devices.
Signed-off-by: Enric Balletbo i Serra <eballetbo@gmail.com>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
The IGEP v2 board is a low-cost, fan-less and industrial temperature
range single board computer that unleashes laptop-like performance and
expandability without the bulk, expense, or noise of typical desktop
machines. Its architecture shares much in common with other OMAP3 boards.
Acked-by: Steve Sakoman <steve.sakoman@linaro.org>
Tested-by: Steve Sakoman <steve.sakoman@linaro.org>
Adds support for the ARM quad-core Cortex-A9 processor
This system includes a motherboard(Versatile Express), daughterboard
(Coretile), and SOC(Cortex-A9 quad core). The serial port, ethernet,
and flash systems work with these additions. The naming convention
is:
SOC -> CortexA9 quad core = ca9x4
daughterboard -> Coretile = ct
motherboard -> Versatile Express = vxp
This gives ca9x4_ct_vxp.c as the board support file.
Signed-off-by: Matt Waddel <matt.waddel@linaro.org>
This patch provides support for the A4M072 board with the following features:
UART
NOR flash
FEC Ethernet
External SRAM
I2C EEPROM
CompactFlash cards on IDE/ATA port
USB Host
PCI initialization
The 7-segment LED indicator is not yet supported.
Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com>
The patch adds support for TTECH vision2 board.
The board has 512MB RAM, SDHC slot and 4MB SPI
device from StMicron.
The CCM board has long reached EOL, and support for it is no longer
relevant in current versions of U-Boot. Remove it.
The PCU_E board has long reached EOL, and support for it is no longer
Add support code for bluestone board wth APM821XX processor based.
This patch includes early board init, misc init, configure EBC,
initializes UIC, MAKEALL, board.cfg and MAINTAINERS file.
Signed-off-by: Tirumala R Marri <tmarri@apm.com
The board includes:
* ADSP-BF561 rev. 0.5
* 32-bit SDRAM (2 * MT48LC16M16A2TG or MT48LC32M16A2TG)
* Gigabit Ether AX88180 (ASIX) + 88E1111 rev. B2 (Marvell)
* SPI boot flash on PF2 (M25P64 8MB, or M25P128 16 MB)
* FPGA boot flash on PF3 (M25P64 8MB, or M25P128 16 MB)
* Spartan6-LX150 (memory-mapped; both PPIs also connected)
* See http://www.skutek.com/
Signed-off-by: Wojtek Skulski <skulski@pas.rochester.edu>
Signed-off-by: Peter Meerwald <pmeerw@pmeerw.net>
Support for the Blackfin System Development Platform (SDP) base module.
This patch provides support for MPC8308 P1M board with the following
set of features:
Dual UART is supported
NOR flash is supported
Both TSEC Ethernet controllers are supported
PCI Express initialization is supported
Both I2C controllers are supported
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
This patch adds support for the jadecpu board using the
MB86R01 'Jade' SoC from Fujitsu.
Signed-off-by: Matthias Weisser <weisserm@arcor.de>
The board maintainer states:
The GTH board is obsolete and has not been manufactured for
several years.
To my knowledge, no recent U-Boot build has been tested on that
card.
So drop support for this board.
Cc: Thomas Lange <thomas@corelatus.se>
Acked-by: Thomas Lange<thomas@corelatus.se>
Specifics:
1) 36-bit only
2) Booting from NOR flash only
3) Environment stored in NOR flash only
4) No SPI support
5) No DIU support
Support the new AD7160 eval board.
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
The example configuration files of nios2-generic board can generated
binary to run on the EP1C20, EP1S10, and EP1S40 boards. So the three
boards can be removed.
With nios2-generic approach, the fpga parameter header file can
be generated from hardware designs using tools. Porting u-boot for
nios2 boards is simplified. Vendors can supply their fpga parameter
file or patches to add a new nios2-generic board instance. There is
no need to include other boards support for nios2 in the u-boot
mainline.
Signed-off-by: Scott McNutt <smcnutt@psyent.com>
This patch add support for the ve8313 board based on
Freescale MPC8313 CPU.
- serial console on UART 1
- 128 MB DDR RAM
- 32 MB NOR Flash
- 16 MB NAND Flash
- Ethernet MII Mode over on TSEC0
- micrel ksz804 phy
- Hardware WDT MAX824
changes since v1
- Environment size = sector size
- use red. environment
- add comments from Kim Phillips
- add MAKEALL, MAINTAINERS entry
- Codingstyle issues fixed
- inserted original Copyrights
- PCI subsys vendor ID changed from 0x1057 (Motorola)
to 0x1957 (Freescale)
changes since v2
- add comments from Wolfgang Denk
- fix Codingstyle and some comments
- reworked WDT reset (just toggling the WD_TRIG pin)
- Environment size now 16KiB
- fixed RAMBOOT version
- fixed CONFIG_SYS_LOAD_ADDR
- renamed CONFIG_TSEC1_NAME to TSEC1
This patch provides support for MPC8308RDB development board from
Freescale with a minimal set of features:
The following features are enabled in configuration but not fully tested:
I2C (used to get the board revision)
I2C-connected RTC
VSC7385 switch
There is one (hopefully) minor issue: on soft reset the board sometimes
resets twice. I've not managed to find the fix for this problem yet.
As a workaround instruction cache can be disabled.
OMAP4 Panda is a reference board based on OMAP4430, an ARMV7 Cortex A9 CPU
This patch adds basic support for booting the board. It includes i2c and mmc
support. It assumes U-boot is loaded to SDRAM with the help of another small
bootloader (x-load) running from SRAM. U-boot currently relies on x-load for
clock, mux, and SDRAM initialization
Signed-off-by: Steve Sakoman <steve@sakoman.com>
OMAP4430 SDP is a reference board based on OMAP4430, an ARMV7 Cortex A9 CPU
Signed-off-by: Aneesh V <aneesh@ti.com>
The purpose of this patch is to prepare for adding the OMAP4 architecture, which is Cortex A9
Cortex A8 and A9 both belong to the armv7 architecture, hence the name change.
The two architectures are similar enough that substantial code can be shared.
This patch adds support for the T3CORP board, based on the
AppliedMicro (APM) PPC460GT.
Since I haven't been actively maintaining these boards for a long while,
keeping myself as their maintainer makes no sense.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
CONFLICT (rename/add): Rename
board/davinci/da830evm/Makefile->board/ti/tnetv107xevm/Makefile
in 89b765c7f6ddfde07ba673dd4adbeb5da391a81b.
board/ti/tnetv107xevm/Makefile added in HEAD
But files were identical, so no problem.
This patch adds support for the LaCie ED Mini V2 product
which is based on the Marvell Orion5x SoC.
Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
This patch adds support for the Samsung Goni board (S5PC110 SoC)
Provides initial support for TI OMAP-L138/DA850 SoC devices on
a Logic PD EVM board.
Provides:
Initial boot and configuration.
Support for i2c.
UART support (console).
Signed-off-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
Acked-by: Ben Gardiner <bengardiner@nanometrics.ca>
Reviewed-by: Wolfgang Denk <wd@denx.de>
This patch adds basic support for the AM3517EVM.
It includes:
- Board files (.c and .h)
- Default configuration file
- Updates for Makefile
Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com>
Signed-off-by: Sanjeev Premi <premi@ti.com>
TNETV107X is a Texas Instruments SoC based on an ARM1176 core, and with a
bunch on on-chip integrated peripherals. This patch adds support for the
TNETV107X EVM board.
Signed-off-by: Cyril Chemparathy <cyril@ti.com>
It includes:
Add the new board PM9G45 from Ronetix GmbH.
* AT91SAM9G45 MCU at 400Mhz.
* 128MB DDR2 SDRAM
* 256MB NAND
* 10/100 MBits Ethernet DP83848
* Serial number chip DS2401
The board is made as SODIMM200 module.
For more info www.ronatix.at or info@ronetix.at.
Signed-off-by: Asen Dimov <dimov@ronetix.at>
The nios-32 arch is obsolete and broken. So it is removed.
GuruPlug Standard: 1 Gb Ethernet, 2 USB 2.0
GuruPlug Plus: 2 Gb Ethernet, 2 USB 2.0, 1 eSATA, 1 uSD slot
References:
http://www.globalscaletechnologies.com/t-guruplugdetails.aspx
http://plugcomputer.org
This patch is for GuruPlug Plus, but it supports Standard version
as well.
Signed-off-by: Siddarth Gore <gores@marvell.com>
This patch adds support for the magnesium board from
projectiondesign. This board uses i.MX27 SoC and has
8MB NOR flash, 128MB NAND flash, FEC ethernet controller
integrated into i.MX27. As this port is based on
the imx27lite port, common config options are collected
in include/configs/imx27lite-common.h
This patch adds support for the Mosaix Technologies, Inc. ICON board,
based on the AppliedMicro (AMCC) PPC440SPe. It's equipped with an SODIMM
(512MB standard) and 64MByte of NOR FLASH.
Support for the onboard SM502 will be added later.
This is a generic approach to port u-boot for nios2 boards.
You may find the usage of this approach on the nioswiki,
http://nioswiki.com/DasUBoot
A fpga parameter file, which contains base address information
and drivers declaration, is generated from Altera's hardware system
description sopc file using tools.
The example fpga parameter file is compatible with EP1C20, EP1S10
and EP1S40 boards. So these boards can be removed after this commit.
Though epcs controller is removed to cut the dependency of altera_spi
driver.
