Fix LCD logo for lwmon board which got lost in the merge of 8xx and PXA LCD code
Fix PHY addresses for PPChameleon and CATcenter boards
Change MAINTAINER for most esd boards
add support for the KS8695P (ARM 922 based) CPU
* Patch by Steven Scholz, 19 May 2005:
Add support for CONFIG_SERIAL_TAG on ARM boards
Add support for Analogue & Micro Rattler boards.
Tested on Rattler8248.
* Patch by Andre Renaud, 08 Nov 2004:
Fix watchdog support in common/lcd.c
* Patch by Marc Leeman, 05 Nov 2003:
Enable all 4 PCMBRW buffers for the MPC8245 processor since the CPU
bug only affects the XPC8245 processors
- Add support for HIDDEN_DRAGON board
- fix endianess problem in driver/rtl1839.c
* Patch by Allen Curtis, 21 Oct 2004:
support multiple serial ports
Add support for Wind River sbc405 board
* Patch by Rainer Brestan, 12 Oct 2004:
Make examples/Makefile more robust
add support for the TI OMAP2420 processor and its H4 reference
board
* Patch by Christian Pellegrin, 24 Sep 2004:
Added support for NE2000 compatible (DP8390, DP83902) NICs.
* Update MAINTAINERS file
* Fix bug in MPC823 LCD driver
- Add support for Altera Nios-II processors.
- Add support for Psyent PCI-5441 board.
- Add support for Psyent PK1C20 board.
- add empty include/asm-microblaze/processor.h
- add to CREDITS and MAINTAINERS
- add gd initialization
- add MicroBlaze and SUZAKU board to MAKEALL script
- add reset support for SUZAKU
- add flush_cache() for MicroBlaze
- add CFG_FLASH_SIZE to include/configs/suzaku.h since we have fixed
size flash memory on SUZAKU
Completion of the 8540ADS/8560ADS updates:
Fix some PCI and Rapid I/O memory maps,
Initialize both TSEC 1 and 2,
Initialize SDRAM
Update MAINTAINER for 85xx boards and README.mpc85xxads
Remove obsolete AdderII port which was superseded by unified
AdderII/Adder87x port
* Patch by Ladislav Michl, 16 Jun 2004:
Fix gcc-3.3.3 warnings for smc91111.c
Update for PPChameleon board:
- support for SysClk @ 25MHz
- support for Silicon Motion SM712 VGA controller
- some clean ups
Add support for Analogue&Micro Adder87x and the older AdderII board.
* Patch by Ming-Len Wu, 09 Jun 2004:
Add suppport for MC9328 (Dargonball) CPU and Motorola MX1ADS board
Add support for Interphase iSPAN boards.
Add support for Cogent CSB472 board (8MB Flash Rev)
Add support for TI OMAP5912 OSK Board
* Patch by Sam Song May, 07 May 2004:
Fix typo of UPM table for rmu board
Add support for OMAP730 Perseus2 Development board
* Patch by Alan J. Luse, 29 Apr 2004:
Fix flash chip-select (OR0) option register setting on FADS boards.
Report MII network speed and duplex setting properly when
auto-negotiate is not enabled.
* Patch by Jarrett Redd, 29 Apr 2004:
Fix hang on reset on Ocotea board due to flash in wrong mode.
Add Nios GDB/JTAG Console support:
- Add stubs to support gdb via JTAG.
- Add support for console over JTAG.
- Minor cleanup.
Enable ranges in mii command, e.g. mii read 0-1f 0 or
mii read 4-7 18-1a. Also add mii dump subcommand for
pretty-printing standard regs 0-5.
* Patch by Stephen Williams, 16 April 2004:
fix typo in JSE.h; update MAINTAINERS
- Add support for RPC/STx GP3, Motorola 8560 board
- Update 85xx TSEC driver so it searches MII for first available PHY
and uses that one.
- Add functions to support console MII commands.
* Patch by Tolunay Orkun, 07 Apr 2004:
Move initialization of bi_iic_fast[]
from board_init_f() to board_init_r()
* Patch by Yasushi Shoji, 07 Apr 2004:
Cleanup microblaze port
* Patch by Sangmoon Kim, 07 Apr 2004:
Add auto SDRAM module detection for Debris board
add support for Intel Assabet board
- add auto-complete support to the U-Boot CLI
- add support for NETTA and NETPHONE boards; fix NETVIA board
* Patch by Yuli Barcohen, 28 Mar 2004:
- Add support for MPC8272 family including MPC8247/8248/8271/8272
- Add support for MPC8272ADS evaluation board (another flavour of MPC8260ADS)
- Change configuration method for MPC8260ADS family
Add support for KUP4X Board
avoid dereferencing NULL pointer in lib_arm/armlinux.c
* Patch by Stephen Williams, 15 Mar 2004:
Fix CONFIG_SERIAL_SOFTWARE_FIFO documentation
* Patch by Tolunay Orkun, 15 Mar 2004:
Initialize bi_opbfreq to real OPB frequency via get_OPB_freq()
* Patch by Travis Sawyer, 15 Mar 2004:
Update CREDITS & MAINTAINERS files for PPC440GX & Ocotea port
- Add support for the SSV ADNP/ESC1 (Nios Softcore)
* Patch by George G. Davis, 9 Mar 2004:
fix recent build failure for SA1100 target
* Patch by Travis Sawyer, 09 Mar 2004:
Support native interrupt mode for the IBM440GX.
Previously it was running in 440GP compatibility mode.
NS9750 DevBoard added
* Patch by Pierre AUBERT, 24 Feb 2004
add USB support for MPC5200
* Patch by Steven Scholz, 24 Feb 2004:
- fix MII commands to use values from last command
* Patch by Torsten Demke, 24 Feb 2004:
Add support for the eXalion platform (SPSW-8240, F-30, F-300)
- update board/emk tree; use common flash driver
- Corrected tested bits in machine check exception in cpu/mpc5xxx/traps.c
[adapted for other PPC CPUs -- wd]
- Added support for the M48T08 on the EVAL5200 board in rtc/mk48t59.c
* Patch by Jon Diekema, 13 Feb 2004:
Call show_boot_progress() whenever POST "FAILED" is printed.
* Patch by Nishant Kamat, 13 Feb 2004:
Add support for TI OMAP1610 H2 Board
Fixes for cpu/arm926ejs/interrupt.c
(based on Richard Woodruff's patch for arm925, 16 Oct 03)
Fix for a timer bug in OMAP1610 Innovator
Add support for CS0 (ROM)/CS3 (Flash) boot in OMAP1610 Innovator and H2
* Patches by Stephan Linz, 12 Feb 2004:
- add support for NIOS timer with variable period preload counter value
- prepare POST framework support for NIOS targets
* Patch by Denis Peter, 11 Feb 2004:
add POST support for the MIP405 board
- more documentation for NIOS port
- new struct nios_pio_t, struct nios_spi_t
- Reconfiguration for NIOS Development Kit DK1C20:
o move board related code from board/dk1c20
to board/altera/dk1c20
o create a new common source path board/altera/common
and move generic flash access stuff into it
o change/expand configuration file DK1C20.h
- Add support for NIOS Development Kit DK1S10
- Add status LED support for NIOS systems
- Add dual 7-segment LED support for Altera NIOS DevKits
* Minor code cleanup (coding style)
* Patch by Reinhard Meyer, 30 Dec 2003:
- cpu/mpc5xxx/fec.c: added CONFIG_PHY_ADDR, added CONFIG_PHY_TYPE,
- added CONFIG_PHY_ADDR to include/configs/IceCube.h,
- turned debug print of PHY registers into a function (called in two places)
- added support for EMK MPC5200 based modules
* Fix MPC8xx PLPRCR_MFD_SHIFT typo
* Add support for TQM866M modules
* Fixes for TQM855M with 4 MB flash (Am29DL163 = _no_ mirror bit flash)
* Fix a few compiler warnings
- Added Motorola CPU 8540/8560 support (cpu/85xx)
- Added Motorola MPC8540ADS board support (board/mpc8540ads)
- Added Motorola MPC8560ADS board support (board/mpc8560ads)
* Make 5200 reset command _really_ reset the board, without running
any other code after it
* Fix flash mapping and display on P3G4 board
* Patch by Kyle Harris, 15 Jul 2003:
- add support for Intel IXP425 CPU
- add support for IXDP425 eval board
- Add support for Altera FPGA ACEX1K
* Patches by Thomas Lange, 09 Oct 2003:
- Endian swap ATA identity for all big endian CPUs, not just PPC
- MIPS only: New option CONFIG_MEMSIZE_IN_BYTES for passing memsize
args to linux
- add support for dbau1x00 board (MIPS32)
- fix cmd_ide.c for non ppc boards (read/write functions did not
add ATA base address)
- fix for shannon board
- #ifdef CONFIG_IDE_8xx_DIRECT some otherwise unused code
* Patch by Sangmoon Kim, 07 Oct 2003:
add support for debris board
- add support for Altera Nios-32 CPU
- add support for Nios Cyclone Development Kit (DK-1C20)
* Patch by Steven Scholz, 29 Sep 2003:
- A second parameter for bootm overwrites the load address for
"Standalone Application" images.
- bootm sets environment variable "filesize" to the resulting
(uncompressed) data length for "Standalone Application" images
when autostart is set to "no". Now you can do something like
if bootm $fpgadata $some_free_ram ; then
fpga load 0 $some_free_ram $filesize
fi
* Patch by Denis Peter, 25 Sept 2003:
add support for the MIP405 Rev. C board
add FAT support for IDE, SCSI and USB
* Patches by Gleb Natapov, 2 Sep 2003:
- cleanup of POST code for unsupported architectures
- MPC824x locks way0 of data cache for use as initial RAM;
this patch unlocks it after relocation to RAM and invalidates
the locked entries.
* Patch by Gleb Natapov, 30 Aug 2003:
new I2C driver for mpc107 bridge. Now works from flash.
* Patch by Dave Ellis, 11 Aug 2003:
- JFFS2: fix typo in common/cmd_jffs2.c
- JFFS2: fix CFG_JFFS2_SORT_FRAGMENTS option
- JFFS2: remove node version 0 warning
- JFFS2: accept JFFS2 PADDING nodes
- SXNI855T: add AM29LV800 support
- SXNI855T: move environment from EEPROM to flash
- SXNI855T: boot from JFFS2 in NOR or NAND flash
* Patch by Bill Hargen, 11 Aug 2003:
fixes for I2C on MPC8240
- fix i2c_write routine
- fix iprobe command
- eliminates use of global variables, plus dead code, cleanup.
(tested with USB memory sticks only)
* Avoid flicker on TRAB's VFD
* Add support for P3G4 board
* Fix problem with MGT5100 FEC driver: add "early" MAC address
initialization
fix TI Innovator/OMAP1510 pin configs
* Patches by Kshitij, 18 Aug 2003
- add support for arm926ejs cpu core
- add support for TI OMAP 1610 Innovator Board
- added support for arm925t cpu core
- added support for TI OMAP 1510 Innovator Board
- Correct flash and JFFS2 support for MPC8260ADS
- fix PVR values and clock generation for PowerQUICC II family
(8270/8275/8280)
* Patch by Bernhard Kuhn, 08 Jul 2003:
- add support for M68K targets
* Patch by Ken Chou, 3 Jul:
- Fix PCI config table for A3000
- Fix iobase for natsemi.c
(PCI_BASE_ADDRESS_0 is the IO base register for DP83815)
* Allow to enable "slow" POST routines by key press on power-on
* Fix temperature dependend switching of LCD backlight on LWMON
* Tweak output format for LWMON
- Allow to call sysmon function interactively
- PIC on LWMON board needs delay after power-on
- Add missing RSR definitions for MPC8xx
- Improve log buffer handling: guarantee clean reset after power-on
- Add support for EXBITGEN board
- Add support for SL8245 board
