path: root/MAINTAINERS
2011-02-21Pantheon: Add Board Support for Marvell dkb boardLei Wen
DKB is a Development Board for PANTHEON TD/TTC(pxa920/pxa910) with * Processor upto 806Mhz * LPDDR1/2 * x8/x16 SLC/MLC NAND * Footprints for eMMC & MMC x8 card With Peripherals: * Parallel LCD I/F * Audio codecs (88PM8607) * MIPI CSI-2 camera * Marvell 88W8787 802.11n/BT module * Marvell 2G/3G RF * Dual analog mics & speakers, headset jack, LED, ambient * USB2.0 HS host, OTG (mini AB) * GPIO, GPIO expander with DIP switches for easier selection * UART serial over USB, CIR This patch adds basic board support with DRAM and UART functionality Signed-off-by: Lei Wen <leiwen@marvell.com> Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2011-02-21arm: Tegra2: Add support for NVIDIA Seaboard boardTom Warren
Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-02-21arm: Tegra2: Add support for NVIDIA Harmony boardTom Warren
2011-02-09Merge branch 'master' of git://git.denx.de/u-boot-ppc4xxWolfgang Denk
2011-02-07ppc4xx: Add DLVision-10G board supportDirk Eibach
Board support for the Guntermann & Drunck DLVision-10G. Adds support for multiple FPGAs per board for gdsys 405ep architecture. Adds support for dual link osd hardware for gdsys 405ep. Signed-off-by: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Stefan Roese <sr@denx.de>
2011-02-04Merge branch 'master' of git://git.denx.de/u-boot-shWolfgang Denk
2011-02-02Merge branch 'master' of /home/wd/git/u-boot/custodiansWolfgang Denk
2011-02-02change email address in MAINTAINERSYoshihiro Shimoda
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-02-02sh: add support for sh7757lcr boardYoshihiro Shimoda
The R0P7757LC0030RL board has SH7757, 256MB DDR3-SDRAM, SPI ROM, Ethernet, and more. This patch supports the following functions: - 256MB DDR3-SDRAM - SPI ROM - Ethernet Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-02-02armv7: add support for s5pc210 universal boardMinkyu Kang
This patch adds support for Samsung s5pc210 universal board Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2011-02-02OMAP3: add CM-T35 boardMike Rapoport
This patch adds support for CM-T35 board Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-02-02Add support for Freescale's mx35pdk board.Stefano Babic
The patch adds suupport for the Freescale's mx35pdk board (known as well as mx35_3stack). The board boots from the NOR flash. Following devices are supported: - two ethernet devices (FEC and SMC911x on debug board) - I2C - PMIC (MC13892) via I2C interface - UART - NOR flash (64MB) - NAND flash (2GB) - basic access to mc9sdz60 registers via I2C interface Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-02-02iMX5: EfikaMX: Preliminary board supportMarek Vasut
Supported: MMC IDE PMIC SPI flash LEDs I can boot the kernel supplied by freescale/genesi with this from MMC card and/or PATA disk. Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
2011-02-02MX5:MX53: add initial support for MX53EVK boardLiu Hui-R64343
Add initial support for MX53EVK board support. FEC, SD/MMC, UART, I2C, have been supported. Signed-off-by: Jason Liu <r64343@freescale.com>
2011-01-26mpq101: initial support for Mercury Computer Systems MPQ101 boardAlex Dubov
Mpq101 is a RapidIO development board in AMC form factor, featuring MPC8548 processor, 512MB of hardwired DDR2 RAM, 128MB of hardwired NAND flash memory, real time clock and additional serial EEPROM on i2c bus (enabled). USB controller is available, but not presently enabled. Additional board information is available at: http://www.mc.com/products/boards/ensemble_mpq101_rapidio_powerquicc_iii.aspx Environment is configured to precede the actual u-boot image so that it's located at the beginning of flash erase block (made necessary by the recent changes to the embedded environment handling). This is achieved by means of custom ld script. Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-18mpc5200, digsy_mtc: add support for rev5 board versionHeiko Schocher
difference to previous board version: - M29W128GH flash from Numonyx - SDRAM ISSI IS45S16800 (Option A2 105°C) - rev5 uses RTC RV-3029-C2 - update cs0 and cs1 baseaddr and length depending on the detected flash size. - added Werner Pfister <Pfister_Werner@intercontrol.de> as maintainer for the digsy board variants - As the M29W128GH needs a special flash_cmd_reset() document that in the new file doc/README.cfi. - move "#endif /* CONFIG_CMD_IDE */" to the right place - remove LOWBOOT config option for digsy_mtc and digsy_mtc_rev5 boards - change doc/README.cfi as Stefan Roese suggested Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Detlev Zundel <dzu@denx.de> cc: Wolfgang Denk <hs@denx.de> cc: Stefan Roese <sr@denx.de> cc: Werner Pfister <Pfister_Werner@intercontrol.de> cc: Detlev Zundel <dzu@denx.de>
2011-01-18ppc, 8xx: remove obsolete km8xx boards from keymileHolger Brunck
The MPC852 based mgsuvd and kmsupx4 boards from keymile were initially ported but later on not developed further. So the respective files were removed to avoid unneeded merging and maintenance. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Acked-by: Heiko Schocher<hs@denx.de>
2011-01-14MPC8xxx: Update maintainer entry for Wind River sbc8xxx boardsPaul Gortmaker
I've probably got the best chance of getting access to these boards in order to test things, and since Joe's e-mail is bouncing, update the MAINTAINERS entry to reflect this. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-14powerpc/85xx: Removed support for ATUM8548 boardKumar Gala
The ATUM8548 board is no longer maintained and thus we are removing support for it. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-11sh: Add support shmin boardNobuhiro Iwamatsu
This adds support for the SHMIN SH7706 board(T-SH7706LAN). The CPU of this board is SH7706. There are SDRAM of 32M byte, Flash memory of 512K byte, Serial, 10Base Ether and MMC. http://web.kyoto-inet.or.jp/people/takagaki/T-SH7706/T-SH7706.htm Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-01-09MAINTAINERS: sort Blackfin entriesMike Frysinger
2010-12-16MAINTAINERS: Transfer openrd_base maintainership to Prafulla WadaskarSimon Kagstrom
Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net>
2010-12-16Armada100: Add Board Support for Marvell Aspenite-DBPrafulla Wadaskar
Aspenite is a Development Board for ASPEN/ARMADA168(88AP168) with * Processor upto 1.2GHz * Parallel 1Gb x8 DDR2-1066 MHz * 16 Mb x16 NOR, 4Gb x8 SLC NAND, footprint for SPI NOR * Footprints for eMMC/eSD NAND & MMC x8 card * 4-in-1 card reader (xD, MMC/SD/MS Pro), CF True IDE socket * SEAF memory board, subset of PISMO2 With Peripherals: * 4.3” WVGA 24-bit LCD * Audio codecs (AC97 & I2S), TSI * VGA camera * Video in via 3 RCA jacks, and HDMI type C out * Marvell 88W8688 802.11bg/BT module * GPS RF IC * Dual analog mics & speakers, headset jack, LED, ambient light sensor * USB2.0 HS host (A), OTG (micro AB) * FE PHY, PCIE Mini Card slot * GPIO, GPIO expander with DIP switches for easier selection UART serial over USB, CIR This patch adds basic board support with DRAM and UART functionality The patch is tested for boot from DRAM using XDB Signed-off-by: Mahavir Jain <mjain@marvell.com> Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2010-12-16Merge branch 'master' of ../master into nextWolfgang Denk
2010-12-16mpc52xx: add support for tqm52xx based board charonHeiko Schocher
- serial console in PSC1 - 128MiB DRAM - 32MiB Flash - FEC Ethernet - 2 I2C busses - FPGA on CS3 - IDE - VGA SMI501 Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-12-07AT91: add TOP9000 supportReinhard Meyer
Adds support for the EMK TOP9000 CPU Module which is based on ATMELs ARM926EJS AT91SAM9XE SoC. Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-11-30Davinci: add support for the ea20 boardStefano Babic
This board uses the OMAP-L138 SOM stacked on a custom baseboard. It supports SPI Flash, Ethernet with RMII. Signed-off-by: Stefano Babic <sbabic@denx.de> Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-30Add board support for hawkboardSughosh Ganu
The patch adds basic board support for TI's OMAP-L138 based Hawkboard. This board is pretty similar to the da850 EVM. Support for nand and network access is added in this version. The following bootup procedure is used. At reset, the Rom Boot Loader(RBL), initialises the ddr and the nand controllers and copies the second stage bootloader(nand_spl) to RAM. The secondary bootloader then copies u-boot from a predefined location in the nand flash to the RAM, and passes control to the u-boot image. Three config options are supported * hawkboard_config - Used to create the u-boot.bin. Tftp the u-boot.bin image to the RAM from u-boot, and flash to the nand flash at address 0xe0000. * hawkboard_nand_config - Used to generate the secondary bootloader(nand_spl) image. This creates an elf file u-boot-spl under nand_spl/. Create an AIS signed image using this file, and flash it to the nand flash at address 0x20000. The ais file should fit in one block. * hawkboard_uart_config - This is same as the first image, but with the TEXT_BASE as expected by the RBL(0xc1080000). Create the AIS Signed-off-by: Sughosh Ganu <urwithsughosh@gmail.com> Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-26ERIC: drop unsupported board configurationWolfgang Denk
The ERIC board appears to be unmaintained for more than 9 years. The environment location has probably never been correct, and has been definitely broken since for at least a year. Drop it. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Swen Anderson <sand@peppercon.de> Acked-by: Stefan Roese <sr@denx.de>
2010-11-26Seagate FreeAgent DockStar supportEric Cooper
start with sheevaplug configuration add modifications by Alexander Holler <holler@ahsoftware.de> change RAM definitions to one bank (128 MB) change ident string and prompt define MTD partitions and default environment variables add support for LEDs Signed-off-by: Eric Cooper <ecc@cmu.edu>
2010-10-25ppc4xx: Add Io and IoCon 405EP board supportDirk Eibach
Board support for the Guntermann & Drunck CATCenter Io. Board support for the Guntermann & Drunck IoCon. Signed-off-by: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Stefan Roese <sr@denx.de>
2010-10-22XPedite5500 board supportJohn Schmoller
Initial support for Extreme Engineering Solutions XPedite5500 - a P2020-based PMC/XMC single board computer. Signed-off-by: John Schmoller <jschmoller@xes-inc.com> Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-22xes: Make X-ES board names more genericPeter Tyser
Some U-Boot images for X-ES boards support multiple products in the same family. For example, the XPedite5370, XPedite5371, and XPedite5372 are similar enough that one U-Boot image can work on all 3 cards. To make it clear that a U-Boot image can work on boards of the same family, rename the boards with the least significant digit of 'x'. While we're at it, change the board config file and make targets to be lowercase. Also change the default uImage and fdt filenames to "board.uImage" and "board.dtb" to be more generic. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-20Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2010-10-19Add support for HP Jornada flashrom boardsKristoffer Ericson
This patch adds support for the HP Jornada flashboards that were made in 2008. Older flashroms should work if memory registers are adjusted. Signed-off-by: Kristoffer Ericson <kristoffer.ericson@gmail.com> Adpted for TEXT_BASE -> CONFIG_SYS_TEXT_BASE rename. Removed now redundant board/jornada/config.mk file. Removed unused empty jornada_init() function to silence "jornada.c:35: warning: 'jornada_init' defined but not used" Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-10-19PXA: Add missing MAINTAINERS entriesMarek Vasut
2010-10-19PXA: Balloon3 board supportMarek Vasut
The following hardware is currently supported: - UART - USB Host - FPGA Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
2010-10-19PXA: Voipac270 improvementsMarek Vasut
128MB NOR module support. Define __io to get harddrive working. Fix saving of environment into OneNAND. Boot from harddrive when possible. Add missing MAINTAINERS entry. Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
2010-10-19PXA: Add initial Palm LifeDrive supportMarek Vasut
2010-10-19PXA: Palm Tungsten|C SupportMarek Vasut
This patch adds support for the Palm Tungsten|C PXA255 board. The support includes: - LCD - MMC - UART - NOR Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
2010-10-19at91rm9200ek: convert to at91Andreas Bießmann
This patch removes some functionality from at91rm9200ek board but the remaining functionality does now work with newer at91 code and arm-relocation. Currently missing features are: - dataflash booting (due to missing HW for testing) - MMC/SD-Card - first stage bootloader support is completely removed (not needed for NOR) Cause this board was (some days ago) reference for all at91rm9200 based boards this should be a good starting point to convert all remaining at91rm9200 borads to at91 code. Aside from that this is a good base to get some drivers between at91sam/at91rm/avr32 merged. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-10-19NC650/CP850: remove code for yet another corpseWolfgang Denk
The NC650 / CP850 boards have long been unmaintained and left broken. As obviously nobody is interested in that code any more, we may as well remove it. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-10-18MAINTAINERS: Fix alphabetical order in ARM subsectionEnric Balletbo i Serra
I'm noticed that IGEP maintainer isn't in the correct place within the ARM subsection: it's supposed to be in alphabetical order by maintainer. This patch fix this. Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com>
2010-10-17OMAP3: Add support for the OMAP3 IGEP module.Enric Balletbo i Serra
The IGEP module is a low-power, high performance production-ready system-on-module (SOM) based on TI's OMAP3 family.The IGEP module solution based upon TI OMAP3 provides a low-power/low-cost platform for a variety of consumer/industrial/medical devices. Signed-off-by: Enric Balletbo i Serra <eballetbo@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-10-17OMAP3: Add support for the IGEP v2 board.Enric Balletbo i Serra
The IGEP v2 board is a low-cost, fan-less and industrial temperature range single board computer that unleashes laptop-like performance and expandability without the bulk, expense, or noise of typical desktop machines. Its architecture shares much in common with other OMAP3 boards. Signed-off-by: Enric Balletbo i Serra <eballetbo@gmail.com> Acked-by: Steve Sakoman <steve.sakoman@linaro.org> Tested-by: Steve Sakoman <steve.sakoman@linaro.org> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-10-13Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2010-10-13ARMV7: Versatile Express Coretile CortexA9x4 supportMatt Waddel
Adds support for the ARM quad-core Cortex-A9 processor This system includes a motherboard(Versatile Express), daughterboard (Coretile), and SOC(Cortex-A9 quad core). The serial port, ethernet, and flash systems work with these additions. The naming convention is: SOC -> CortexA9 quad core = ca9x4 daughterboard -> Coretile = ct motherboard -> Versatile Express = vxp This gives ca9x4_ct_vxp.c as the board support file. Signed-off-by: Matt Waddel <matt.waddel@linaro.org>
2010-10-12A4M072: Added support for the board.Sergei Poselenov
This patch provides support for the A4M072 board with the following features: UART NOR flash FEC Ethernet External SRAM I2C EEPROM CompactFlash cards on IDE/ATA port USB Host PCI initialization The 7-segment LED indicator is not yet supported. Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com>
2010-10-11Merge branch 'master' of git://git.denx.de/u-boot-imxWolfgang Denk
