path: root/MAINTAINERS
2015-11-13sparc: Update the maintainer for SPARC architectureFrancois Retief
Signed-off-by: Francois Retief <fgretief@spaceteq.co.za>
2015-05-16MAINTAINERS, git-mailrc: Update Jagan's name and e-mailJagan Teki
Signed-off-by: Jagan Teki <jteki@openedev.com>
2015-05-08Remove non-working address from MAINTAINERPavel Machek
I checked with Detlev, and sadly removing that maintainers entry is right thing to do. Signed-off-by: Pavel Machek <pavel@denx.de>
2015-04-20Update MAINTAINERS and git-mailrc for netJoe Hershberger
Update to my corporate email and make the supported filter and aliases more accurate. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2015-04-09MAINTAINERS: fix TI DaVinci directory path and add KeyStoneMasahiro Yamada
2015-03-15MAINTAINERS: update Masahiro's email addressMasahiro Yamada
I have transferred to Socionext Inc. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-03-05MAINTAINERS: add Driver Model repository informationMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-03-02Merge branch 'xnext/zynqmp' of git://www.denx.de/git/u-boot-microblazeTom Rini
2015-03-02arm64: Add Xilinx ZynqMP supportMichal Simek
Add basic Xilinx ZynqMP arm64 support. Serial and SD is supported. It supports emulation platfrom ep108 and QEMU. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-03-02MAINTAINERS, git-mailrc: Update my email addressTom Rini
2015-03-01Merge branch 'master' of git://git.denx.de/u-boot-uniphierTom Rini
2015-03-01ARM: UniPhier: move SoC headers to mach-uniphier/include/machMasahiro Yamada
Move arch/arm/include/asm/arch-uniphier/* -> arch/arm/mach-uniphier/include/mach/* Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-03-01ARM: UniPhier: move SoC sources to mach-uniphierMasahiro Yamada
Move arch/arm/cpu/armv7/uniphier/* -> arch/arm/mach-uniphier/* Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-02-26MAINTAINERS: Add F: drivers/usb/gadget to DFU custodian responsibilityLukasz Majewski
After discussion during the last u-boot mini summit with USB maintainer - Marek Vasut - it has been decided, that gadget development should be coordinated by DFU custodian. Such patch formalizes current development status. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
2015-02-21ARM: kirkwood: move SoC headers to mach-kirkwood/include/machMasahiro Yamada
Move arch/arm/include/asm/arch-kirkwood/* -> arch/arm/mach-kirkwood/include/mach/* Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Stefan Roese <sr@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Luka Perkov <luka.perkov@sartura.hr>
2015-02-21ARM: at91: move SoC headers to mach-at91/include/machMasahiro Yamada
Move arch/arm/include/asm/arch-at91/* -> arch/arm/mach-at91/include/mach/* Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-02-21ARM: kirkwood: move SOC sources to mach-kirkwoodMasahiro Yamada
Move arch/arm/cpu/arm926ejs/kirkwood/* -> arch/arm/mach-kirkwood/* Note: Perhaps, can we merge arch/arm/mach-kirkwood and arch/arm/mvebu-common into arch/arm/mach-mvebu, like Linux? Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Stefan Roese <sr@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Luka Perkov <luka.perkov@sartura.hr>
2015-02-21ARM: tegra: collect SoC sources into mach-tegraMasahiro Yamada
This commit moves files as follows: arch/arm/cpu/arm720t/tegra20/* -> arch/arm/mach-tegra/tegra20/* arch/arm/cpu/arm720t/tegra30/* -> arch/arm/mach-tegra/tegra30/* arch/arm/cpu/arm720t/tegra114/* -> arch/arm/mach-tegra/tegra114/* arch/arm/cpu/arm720t/tegra124* -> arch/arm/mach-tegra/tegra124/* arch/arm/cpu/arm720t/tegra-common/* -> arch/arm/mach-tegra/* arch/arm/cpu/armv7/tegra20/* -> arch/arm/mach-tegra/tegra20/* arch/arm/cpu/armv7/tegra30/* -> arch/arm/mach-tegra/tegra30/* arch/arm/cpu/armv7/tegra114/* -> arch/arm/mach-tegra/tegra114/* arch/arm/cpu/armv7/tegra124/* -> arch/arm/mach-tegra/tegra124/* arch/arm/cpu/armv7/tegra-common/* -> arch/arm/mach-tegra/* arch/arm/cpu/tegra20-common/* -> arch/arm/mach-tegra/tegra20/* arch/arm/cpu/tegra30-common/* -> arch/arm/mach-tegra/tegra30/* arch/arm/cpu/tegra114-common/* -> arch/arm/mach-tegra/tegra114/* arch/arm/cpu/tegra124-common/* -> arch/arm/mach-tegra/tegra124/* arch/arm/cpu/tegra-common/* -> arch/arm/mach-tegra/* Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Simon Glass <sjg@chromium.org> [ on nyan-big ] Cc: Stephen Warren <swarren@nvidia.com> Cc: Tom Warren <twarren@nvidia.com>
2015-02-21ARM: at91: collect SoC sources into mach-at91Masahiro Yamada
This commit moves source files as follows: arch/arm/cpu/arm920t/at91/* -> arch/arm/mach-at91/arm920t/* arch/arm/cpu/arm926ejs/at91/* -> arch/arm/mach-at91/arm926ejs/* arch/arm/cpu/armv7/at91/* -> arch/arm/mach-at91/armv7/* arch/arm/cpu/at91-common/* -> arch/arm/mach-at91/* Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Andreas Bießmann <andreas.devel@googlemail.co>
2015-02-07MAINTAINERS: claim maintainership of files with "uniphier" patternMasahiro Yamada
The pattern "N: uniphier" can cover - drivers/serial/serial_uniphier.c - drivers/i2c/i2c-uniphier.c - drivers/i2c/i2c-uniphier-f.c - arch/arm/dts/uniphier-* Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-01-16powerpc: 74xx_7xx: remove 74xx_7xx cpu supportMasahiro Yamada
All the 74xx_7xx boards are still non-generic boards: P3G4, ZUMA, ppmc7xx, ELPPC, mpc7448hpc2 Acked-by: Marek Vasut <marex@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: York Sun <yorksun@freescale.com> Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Nye Liu <nyet@zumanetworks.com> Cc: Roy Zang <tie-fei.zang@freescale.com>
2015-01-08MAINTAINERS: add me as a co-maintainer of KIRKWOODLuka Perkov
Signed-off-by: Luka Perkov <luka.perkov@sartura.hr> CC: Prafulla Wadaskar <prafulla@marvell.com> CC: Wolfgang Denk <wd@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2014-12-09stv0991: Add basic stv0991 architecture supportVikas Manocha
stv0991 architecture support added. It contains the support for following blocks - Timer - uart Signed-off-by: Vikas Manocha <vikas.manocha@st.com> [trini: Add arch/arm/cpu/armv7/Makefile hunk] Signed-off-by: Tom Rini <trini@ti.com>
2014-12-08Add custodians to the m68k subsystem.angelo@sysam.it
2014-12-08MAINTAINERS: add me as a maintainer of UBIHeiko Schocher
Add me for UBI custodian. Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Kyungmin Park <kyungmin.park@samsung.com>
2014-11-07MAINTAINERS: CFI flash maintainership only includes the CFI related filesStefan Roese
All the other files in drivers/mtd/* are not really CFI related. So lets only include the files that are CFI specific. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Scott Wood <scottwood@freescale.com> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Jagan Teki <jagannadh.teki@gmail.com> Acked-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com> Acked-by: Heiko Schocher <hs@denx.de>
2014-11-04MAINTAINERS: fix Pantelis Antoniou email addressIgor Grinberg
Trivial fix (unless Pantelis has a new email address): Pantelis Antoniou <panto.antoniou-consulting.com> ^ make it: Pantelis Antoniou <panto@antoniou-consulting.com> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Cc: Pantelis Antoniou <panto@antoniou-consulting.com>
2014-10-11arm: socfpga: add MAINTAINERS entryPavel Machek
Add MAINTAINERS entry. Signed-off-by: Pavel Machek <pavel@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Pavel Machek <pavel@denx.de>
2014-10-05MAINTAINERS: add me as a maintainer of UniPhier platformMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Acked-by: Michal Simek <monstr@monstr.eu>
2014-08-09MAINTAINERS: add initial versionDaniel Schwierzeck
MAINTAINERS contains all currently known custodians based on infos from wiki [1] and u-boot git forks [2]. [1] http://www.denx.de/wiki/U-Boot/Custodians [2] http://git.denx.de/?p=u-boot.git;a=forks Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2013-09-12Merge and reformat boards.cfg and MAINTAINERSAlbert ARIBAUD
Put all informations about targets, including state (active or orphan) and maintainers, in boards.cfg; remove MAINTAINERS; adjust the build system accordingly. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-09-11Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: tools/Makefile
2013-09-04Merge branch 'u-boot-ti/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-08-30exynos5250: Add arndale board supportChander Kashyap
Arndale board is based on samsung's exynos5250 soc. Signed-off-by: Inderpal Singh <inderpal.singh@linaro.org> Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-08-28arm, am335x: add support for 3 siemens boardsHeiko Schocher
add support for the am335x based boards from siemens: dxr2: - DDR3 128MiB - NAND 256MiB - Ethernet with external Switch SMSC LAN9303 - no PMIC - internal Watchdog - DFU support pxm2: - DDR2 512 MiB - NAND 1024 MiB - PMIC - PHY atheros ar803x - USB Host - internal Watchdog - DFU support rut: - DDR3 256 MiB - NAND 256 MiB - PMIC - PHY natsemi dp83630 - external Watchdog - DFU support Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Roger Meier <r.meier@siemens.com> Signed-off-by: Samuel Egli <samuel.egli@siemens.com> Cc: Pascal Bach <pascal.bach@siemens.com> Cc: Tom Rini <trini@ti.com>
2013-08-20ppc4xx: Remove CANBT boardMatthias Fuchs
This board and especially the CPU (PPC405CR) is EOL. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Acked-by: Wolfgang Denk <wd@denx.de>
2013-08-18Merge branch 'master' of git://88.191.163.10/u-boot-armTom Rini
Fixup an easy conflict over adding the clk_get prototype and USB_OTG defines for am33xx having moved. Conflicts: arch/arm/include/asm/arch-am33xx/hardware.h Signed-off-by: Tom Rini <trini@ti.com>
2013-08-17Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-08-15Add TI816X evm board supportTENART Antoine
Signed-off-by: Antoine Tenart <atenart@adeneo-embedded.com> [trini: Change to SPDX, fix a few compiler warnings, adapt to CONFIG_OMAP_COMMON] Signed-off-by: Tom Rini <trini@ti.com>
2013-08-15arm, da850: add ipam390 board supportHeiko Schocher
add the am1808 based ipam390 board from Barix. - 128MByte, DDR2, synchronous RAM 16bit databus to SDRAM interface - 128MByte, NAND Flash, 8bit databus to the NANDFlash Interface - Ethernet PHY Micrel KSZ8051R via RMII - Console on UART 0 - booting fron nand flash - spl falcon bootmode Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Tom Rini <trini@ti.com>
2013-08-13Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxTom Rini
2013-08-09powerpc/c29xpcie: add support for C29XPCIE boardMingkai Hu
C29XPCIE board is a series of Freescale PCIe add-in cards to perform as public key crypto accelerator or secure key management module. It includes C293PCIE board, C293PCIE board and C291PCIE board. - 512KB platform SRAM in addition to 512K L2 Cache/SRAM - 512MB soldered DDR3 32bit memory - CPLD System Logic - 64MB x16 NOR flash and 4GB x8 NAND flash - 16MB SPI flash Signed-off-by: Mingkai Hu <Mingkai.Hu@freescale.com> Singed-off-by: Po Liu <Po.Liu@freescale.com> [yorksun: Fixup include/configs/C29XPCIE.h] Signed-off-by: York Sun <yorksun@freescale.com>
2013-08-09powerpc/T4240EMU: Add T4240EMU targetYork Sun
Add emulator support for T4240. Emulator has limited peripherals and interfaces. Difference between emulator and T4240QDS includes: ECC for DDR is disabled due the procedure to load images No board FPGA (QIXIS) NOR flash has 32-bit port for higher loading speed IFC and I2C timing don't really matter, so set them fast No ethernet Signed-off-by: York Sun <yorksun@freescale.com>
2013-08-09nds32: Change of NDS32 CustodianAndes
Signed-off-by: Andes <uboot@andestech.com> Cc: Macpaul Lin <macpaul@gmail.com> Cc: Kuan-Yu Kuo <ken.kuoky@gmail.com>
2013-07-26mx6qsabrelite: Remove mx6qsabrelite code in favor of nitrogen6xFabio Estevam
mx6qsabrelite and nitrogen6q boards are hardware compatible, so let's avoid the code duplication and only use the nitrogen6x source code to make board code maintainance easier. Tested booting a mainline device tree kernel on a mx6qsabrelite board. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-07-16mpc85xx: Add gdsys ControlCenter Digital boardDirk Eibach
The gdsys ControlCenter Digital board is based on a Freescale P1022 QorIQ SOC. It boots from SPI-Flash but can be configured to boot from SD-card for factory programming and testing. On board peripherals include: - 2x GbE - Lattice ECP3 FPGA connected via PCIe - mSATA RAID1 - USB host - DisplayPort video output - Atmel TPM Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Reinhard Pfau <reinhard.pfau@gdsys.cc> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-07-15Revert "MIPS: Jz4740: Add qi_lb60 board support"Tom Rini
The files board/qi/qi_lb60/qi_lb60.c and include/configs/qi_lb60.h were licensed under the GPL v3 or later, and not v2 or later. As this is incompatible with the project, revert this board support until the responsible parties are available to re-license (if so desired) under GPL v2. Signed-off-by: Tom Rini <trini@ti.com>
2013-06-28Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-06-28MAINTAINERS: Add an entry to the mx6q wandboard variantFabio Estevam
Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Otavio Salvador <otavio@ossystems.com.br>
2013-06-26imx: Add support for the SabreSD shipped with i.MX6DLPierre Aubert
The SabreSD platform is available with i.MX6Q or i.MX6DL. This patch adds the support of the i.MX6DL. The config file and the board directory are renamed to remove the reference to the MX6Q. Signed-off-by: Pierre Aubert <p.aubert@staubli.com> CC: Stefano Babic <sbabic@denx.de> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
