Board support for the Guntermann & Drunck PowerPC 440 ETX module.
Based on the AMCC Yosemite board support by Stefan Roese.
Signed-off-by: Dirk Eibach <eibach@gdsys.de>
This patch will create a new board, SIMPC8313, from Sheldon Instruments. This
board boots from NAND devices and is configureable for either large or small
page devices. The board supports non-soldered DDR2, one ethernet port, a
Marvell 88E1118 PHY, and PCI host support. The board also has a FPGA connected
to the eLBC providing glue logic to a TMS320C67xx DSP.
Signed-off-by: Ron Madrid <ron_madrid@sbcglobal.net>
Initial support for Extreme Engineering Solutions XPedite5200 -
a MPC8548-based PMC single board computer.
Initial support for Extreme Engineering Solutions XPedite5370 -
a MPC8572-based 3U VPX single board computer with a PMC/XMC
site.
Microblaze platforms use generic settings and to have
many platforms is confusing that's why I decided to remove this
platform from U-BOOT. ml401 tree is sufficient for covering
all Microblaze platforms.
This change will go through microblaze custodian tree.
This patch adds support for the kmeter1 board from Keymile,
based on a Freescale MPC8360 CPU.
- serial console on UART 1
- 256 MB DDR2 RAM
- 64 MB NOR Flash
- Ethernet RMII Mode over UCC4
- PHY SMSC LAN8700
This patch provides support for AFEB9260 board, a product of
OpenSource hardware and software. Some commertial projects
are made with this design. A board is basically AT91SAM9260-EK
with some modifications and different peripherals and different
parts used. Main purpose of this project is to gain experience in
hardware design.
More info: http://groups.google.com/group/arm9fpga-evolution-board
(In Russian only, sorry).
Subversion repository: svn://194.85.238.22/home/users/george/svn/arm9eb
Signed-off-by: Sergey Lapin <slapin@ossfans.org>
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
This patch adds support for the avnet fx12 minimodul.
It needs the "ppc4xx: Generic architecture for xilinx ppc405"
patch from Ricardo.
Signed-off-by: Georg Schardt <schardt@team-ctech.de>
Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@uam.es>
As "ppc44x: Unification of virtex5 pp440 boards" did for the xilinx
ppc440 boards, this patch presents a common architecture for all the
xilinx ppc405 boards.
Any custom xilinx ppc405 board can be added very easily with no code
duplicity.
This patch also adds a simple generic board, that can be used on almost
any design with xilinx ppc405 replacing the file ppc405-generic/xparameters.h
This patch is prepared to work with the latest version of EDK (10.1)
Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com>
This patch provides an unificated way of handling xilinx v5 ppc440 boards.
It unificates 3 different things:
1) Source code
A new board called ppc440-generic has been created. This board includes
a generic tlb initialization (Maps the whole memory into virtual) and
defines board_pre_init, checkboard, initdram and get_sys_info weakly,
so, they can be replaced by specific functions.
If a new board needs to redefine any of the previous functions
(specific initialization) it can create a new directory with the
specific initializations needed. (see the example ml507 board).
2) Configuration file
Common configurations are located under configs/xilinx-ppc440.h, this
header file interpretes the xparameters file generated by EDK and
configurates u-boot in correspondence. Example: if there is a Temac,
allows CMD_CONFIG_NET
Specific configuration are located under specific configuration file.
3) Makefile
Some work has been done in order to not duplicate work in the Main
Makefile. Please see the attached code.
In order to support new boards they can be implemented in the next way:
a) Simple Generic Board (90% of the time)
Using EDK generates a new xparameters.h file, replace
ppc440-generic/xparameters.h and run make xilinx-ppc440-generic_config
&& make
b) Simple Boards with special u-boot parameters (9 % of the time)
Create a new file under configs for it (use ml507.h as example) and
change your paramaters. Create a new Makefile paragraph and compile
c) Complex boards (1% of the time)
Create a new folder for the board, like the ml507
Finally, it adds support for the Avnet FX30T Evaluation board, following
the new generic structure:
Cheap board by Avnet for evaluating the Virtex5 FX technology.
This patch adds support for:
- UartLite
- 16MB Flash
- 64MB RAM
Prior using U-boot in this board, read carefully the ERRATA by Avnet
to solve some memory initialization issues.
AP325RXA is SH7723's reference board.
This has SCIF, NOR Flash, Ethernet, USB host, LCDC, SD Host, Camera and other.
In this patch, support SCIF, NOR Flash, and Ethernet.
Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com>
This adds initial support for the RTE RSK+ SH7203 board.
This board has SH7785, 512MB DDR2-SDRAM, NOR Flash,
Graphic, Ethernet, USB, SD, RTC, and I2C controller.
This patch supports the following functions:
- 128MB DDR2-SDRAM (29-bit address mode only)
- NOR Flash
- USB host
- Ethernet
Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com>
SMDK6400 can only boot U-Boot from NAND-flash. This patch adds a nand_spl
driver for it too. The board can also boot from the NOR flash, but due to
hardware limitations it can only address 64KiB on it, which is not enough
for U-Boot. Based on the original sources by Samsung for U-Boot 1.1.6.
Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
MVS1 board has reached end-of-life and can be removed completely.
Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de>
MAINTAINERS
The rest of the MAINTAINERS file appears to be sorted
almost-alphabetically, but entries for the newly added AVR32 boards were
added somewhat randomly. This patch sorts the list alphabetically again.
Also update my e-mail address. The old one still works, but it may not
work forever.
Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
MAKEALL
Makefile
The MIMC200 board is based on Atmel's NGW100 dev kit, but with an extra
8MByte FLASH and 128KByte FRAM.
Signed-off-by: Mark Jackson <mpfj@mimc.co.uk>
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
MAINTAINERS
MAKEALL
Makefile
This patch adds support for the Favr-32 board made by EarthLCD.
This kit, which is also called ezLCD-101 when running with EarthLCD firmware,
has a 10.4" touch screen LCD panel, 16 MB 32-bit SDRAM, 8 MB parallel flash,
Ethernet, audio out, USB device, SD-card slot, USART and various other
connectors for cennecting stuff to SPI, I2C, GPIO, etc.
Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
The Hammerhead platform is built around a AVR32 32-bit microcontroller
from Atmel. It offers versatile peripherals, such as ethernet, usb
device, usb host etc.
The board also incooperates a power supply and is a Power over Ethernet
(PoE) Powered Device (PD).
Additonally, a Cyclone III FPGA from Altera is integrated on the board.
The FPGA is mapped into the 32-bit AVR memory bus. The FPGA offers two
DDR2 SDRAM interfaces, which will cover even the most exceptional need
of memory bandwidth. Together with the onboard video decoder the board
is ready for video processing.
For more information see: http:///www.miromico.com/hammerhead
Signed-off-by: Julien May <mailinglist@miromico.ch>
[haavard.skinnemoen@atmel.com: various small fixes and adaptions]
The Xilinx ML507 Board is a Virtex 5 prototyping board that includes,
among others:
-Virtex 5 FX FPGA (With a ppc440x5 in it)
-256MB of SDRAM2
-32MB of Flash
-I2C Eeprom
-System ACE chip
-Serial ATA connectors
-RS232 Level Conversors
-Ethernet Transceiver
This patch gives support to a standard design produced by EDK for this
board: ppc440, uartlite, xilinx_int and flash
- Includes Changes propossed by Stefan Roese and Michal Simek
The MVBC_P is a MPC5200B based camera system with Intel Gigabit ethernet
controller (using e1000) and custom Altera Cyclone-II FPGA on PCI.
Mail to kharris@nexus-tech.net bounces because the user doesn't exist
anymore. You can't be a maintainer without a valid e-mail address, so
move all boards that used to be maintained by Kyle Harris to the
"orphaned" list.
Currently, only PowerPC has a list of orphaned boards, so this patch
creates one for ARM as well.
Add AMCC Redwood reference board that uses the latest
PPC 464 CPU processor combined with a rich mix of peripheral
controllers. The board will support PCIe, mutiple Gig ethernet
ports, advanced hardware RAID assistance and IEEE 1588.
Signed-off-by: Feng Kan <fkan@amcc.com>
Add MPC8343 based board mvBlueLYNX-M7.
It's a single board stereo camera system.
Please read doc/README.mvblm7 for details.
SH7763RDP has SCIF, NOR Flash, Ethernet, USB host, LCDC and MMC.
