path: root/MAINTAINERS
2011-06-01Merge branch 'master' of /home/wd/git/u-boot/custodiansWolfgang Denk
* 'master' of /home/wd/git/u-boot/custodians: SMDKV310: Fix incorrect conditional compilation for MIU linear mapping SMDKV310: CPU fequency and mmc_pre_ratio modified armv7: Add support for ST-Ericsson U8500 href platform I2C: Add driver for ST-Ericsson U8500 i2c armv7: Add ST-Ericsson u8500 arch Kirkwood: boards cleanup for deprecated CONFIG_CMD_AUTOSCRIPT ARMV7: Vexpress: Add missing MMC header arm/km: update mgcoge3un board support mvgbe: enable configurability of PORT_SERIAL_CONTROL_VALUE arm/km: rename mgcoge2un to mgcoge3un arm/km: add second serial interface for kirkwood arm/km: disable ls (through jffs2 support) arm/km: introduce bootcount env variable and clean km_arm arm/km: move CONFIG_EXTRA_ENV_SETTINGS from board to km_arm file arm/km: remove CONFIG_SYS_KWD_CONFIG from keymile-common.h ARMV7: MMC SPL Boot support for SMDKV310 board ARMV7: Add support for Samsung SMDKV310 Board S5PC2XX: clock: support pwm clock for evt1 (cpu revision 1) S5P: add set_mmc_clk for external clock control S5PC2XX: Support the cpu revision S5P:SROM config code moved to s5p-common directory Add _end for the end of u-boot image for SMDK6400 MMC S5P: Fix typo S5P: GPIO Macro Values Corrected. SMDK2410: various cleanup/code style fixes SMDK2410: use the CFI driver (and remove the old one) SMDK2410: remove unneeded config.mk SMDK2410: activate ARM relocation feature BeagleBoard: fixed typo in typecast mvsata: issue hard reset on initialization VCMA9: use ARM relocation feature to fix build error MX31: drop warnings due to missing prototype for mxc_watchdog_reset() MX5: drop config.mk from efikamx board MX31: Make get_reset_cause() static and drop unreachable code MX53: Remove CONFIG_SYS_BOOTMAPSZ from mx53 config files. MX53: Handle silicon revision 2.1 case mx5: board: code clean up for checkboard code MX51: vision2: Fix build for vision2 board. MX51: vision: Let video mode struct be independant of watchdog. MX53: Add initial support for MX53SMD board. MX53: support for freescale MX53LOCO board mx5: Fix CONFIG_OF_LIBFDT redefined warning mx5: Remove unnecessary CONFIG_SYS_BOOTMAPSZ definition mx31pdk: Clean up mx31pdk.h file
2011-06-01Move wepep250,delta,xsengine to scrapyardMarek Vasut
Drop wepep250 board from MAINTAINERS and add all these three boards to doc/README.scrapyard Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
2011-05-31arm/km: rename mgcoge2un to mgcoge3unValentin Longchamp
The mgcoge2un target was only an intermediate step to mgcoge3un. For this reason the mgcoge2un support was moved to mgcoge3un, because it isn't needed to support both targets. We add the BootROM init file for the mgcoge3un memphis RAM. We also move the suen3 and suen8 boards into the correct category in the MAINTAINERS file. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Acked-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de> cc: Prafulla Wadaskar <prafulla@marvell.com>
2011-05-26ARMV7: Add support for Samsung SMDKV310 BoardChander Kashyap
SMDKV310 board is based on Samsung S5PV310 SOC. This SOC is very much similar to S5PC210. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Tushar Behera <tushar.behera@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-05-23MX53: Add initial support for MX53SMD board.Fabio Estevam
2011-05-23MX53: support for freescale MX53LOCO boardJason Liu
This patch add initial support for freescale MX53LOCO board. Network(FEC),SD/MMC,UART have been supported by this patch Signed-off-by: Jason Liu <jason.hui@linaro.org>
2011-05-10powerpc/km82xx: add mgcoge3ne and remove mgcoge2ne supportHolger Brunck
This patch adds support for the MPC8247 based board mgcoge3ne. Additionaly mgcoge2ne board supprot was removed, because due to the mgcoge3ne, this board is obsolete and not longer maintained. The board is similar to mgcoge. The difference is that a NUMONYX flash is used and a different SDRAM (256MB). Also introduce CONFIG_KM_82XX to collect ppc82xx common settings and remove staticness from the common set_pin function. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Acked-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de>
2011-04-30powerpc, 83xx: add kmsupx5 board supportHeiko Schocher
The Keymile SUPx5 board series is based on a PBEC8321 but contains an additional PBUS FPGA (LPXF) on local bus CS2. Signed-off-by: Thomas Reufer <thomas.reufer@keymile.com> Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Kim Phillips <kim.phillips@freescale.com> cc: Wolfgang Denk <wd@denx.de> cc: Kim Phillips <kim.phillips@freescale.com> cc: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Holger Brunck <holger.brunck@keymile.com>
2011-04-30ppc: add support for ppc based board mgcoge2neHeiko Schocher
The mgcoge2 board from keymile deploys two different processors. An ARM based Kirkwood for the "unit" part of the SW and a PPC for the "ne" part of the SW. Therefore in Linux and U-Boot the names for the board are mgcoge2un and mgcoge2ne. This patch adds the mgcoge2ne part of the board. The ppc part of mgboge2 is quite similar to mgcoge, therefore a generic header km82xx-common.h was introduced to collect all similiarities. Currently the only difference is that mgcoge2ne has a 64 MB numonyx NOR flash with a single die. The mgcoge has a dual die flash 2*32MB from spansion. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Valentin Longchamp <valentin.longchamp@keymile.com>
2011-04-30arm: add support of Kirkwood based board SUEN8Heiko Schocher
The Kirwood based SUEN8 board from Keymile is at this stage the same than the suen3 board. This patch adds the board support for the suen8. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Heiko Schocher <hs@denx.de> cc: Prafulla Wadaskar <prafulla@marvell.com>
2011-04-30arm: add support for kirkwood based mgcoge2un boardHeiko Schocher
This board is similar to keymile suen3. Signed-off-by: Clive Stubbings <clive.stubbings@xentech.co.uk> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Heiko Schocher <hs@denx.de> cc: Prafulla Wadaskar <prafulla@marvell.com>
2011-04-30mpc832x: add support for mpc8321 based tuda1 boardHeiko Schocher
This board is similar to suvd3 board. So most initialisation topics are taken from suvd3 (UART1, Ethernet, piggy PHY, flash, ram) only the application specific chip selects differ. Signed-off-by: Lukas Roggli <lukas.roggli@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Kim Phillips <kim.phillips@freescale.com> cc: Kim Phillips <kim.phillips@freescale.com> cc: Valentin Longchamp <valentin.longchamp@keymile.com>
2011-04-30mpc832x: add support for mpc8321 based tuxa1 boardHeiko Schocher
2011-04-30mpc832x: add support for the mpc8321 based suvd3 boardHeiko Schocher
- serial console on UART1 - Ethernet RMII over UCC4 - PHY SMSC LAN8700 - 64MB Flash - 128 MB DDR2 RAM - I2C - bootcount This board is similiar to the kmeter1 (8360) board, so common config options are extracted into the include/configs/km83xx-common.h file. Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Kim Phillips <kim.phillips@freescale.com> cc: Kim Phillips <kim.phillips@freescale.com> cc: Holger Brunck <holger.brunck@keymile.com> cc: Valentin Longchamp <valentin.longchamp@keymile.com>
2011-04-27ARMV7: OMAP3: Add support for Comelit DIG297 boardLuca Ceresoli
Board support for the DIG297 board manufactured by Comelit Group SpA. It is a custom board based on the BeagleBoard <http://beagleboard.org/> by Texas Instruments. The board support is based on the BeagleBoard implementation. Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de> Cc: Albert Aribaud <albert.aribaud@free.fr> Cc: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-04-27Replace obsolete e-mail addressAlbert ARIBAUD
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-04-27OMAP3: CM-T35: update MAINTAINERS fileIgor Grinberg
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-04-27ARMV7: AM3517/05: Add support for CraneBoard.Srinath
It is a low cost reference design based on Sitara AM3517 SoC from Texas Instruments Please refer to <www.craneboard.org> for more details. Signed-off-by: Srinath <srinath@mistralsolutions.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-04-13MAINTAINERS: fix email address caseFabio Estevam
2011-04-13x86: Update MAINTAINERS and delete README filesGraeme Russ
The README files are totally out-of-date to the point where they do more harm than good Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2011-04-08Blackfin: bf506f-ezkit: new board portMike Frysinger
2011-04-08Blackfin: bf525-ucr2: new board portChong Huang
Signed-off-by: Chong Huang <chuang@ucrobotics.com> Signed-off-by: Haitao Zhang <minipanda@linuxrobot.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-08Blackfin: dnp5370: new board portAndreas Schallenberg
Info about the hardware can be found here: http://www.dilnetpc.com/dnp0086.htm Signed-off-by: Andreas Schallenberg <Andreas.Schallenberg@3alitydigital.de> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-02MIPS: Purple: Remove Purple supportDaniel Schwierzeck
The Purple SoC and eval board are not actively maintained since years. This patch removes the support completely as aggreed with Wolfgang Denk. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Cc: Wolfgang Denk <wd@denx.de> Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2011-02-21Pantheon: Add Board Support for Marvell dkb boardLei Wen
DKB is a Development Board for PANTHEON TD/TTC(pxa920/pxa910) with * Processor upto 806Mhz * LPDDR1/2 * x8/x16 SLC/MLC NAND * Footprints for eMMC & MMC x8 card With Peripherals: * Parallel LCD I/F * Audio codecs (88PM8607) * MIPI CSI-2 camera * Marvell 88W8787 802.11n/BT module * Marvell 2G/3G RF * Dual analog mics & speakers, headset jack, LED, ambient * USB2.0 HS host, OTG (mini AB) * GPIO, GPIO expander with DIP switches for easier selection * UART serial over USB, CIR This patch adds basic board support with DRAM and UART functionality Signed-off-by: Lei Wen <leiwen@marvell.com> Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2011-02-21arm: Tegra2: Add support for NVIDIA Seaboard boardTom Warren
Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-02-21arm: Tegra2: Add support for NVIDIA Harmony boardTom Warren
2011-02-09Merge branch 'master' of git://git.denx.de/u-boot-ppc4xxWolfgang Denk
2011-02-07ppc4xx: Add DLVision-10G board supportDirk Eibach
Board support for the Guntermann & Drunck DLVision-10G. Adds support for multiple FPGAs per board for gdsys 405ep architecture. Adds support for dual link osd hardware for gdsys 405ep. Signed-off-by: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Stefan Roese <sr@denx.de>
2011-02-04Merge branch 'master' of git://git.denx.de/u-boot-shWolfgang Denk
2011-02-02Merge branch 'master' of /home/wd/git/u-boot/custodiansWolfgang Denk
2011-02-02change email address in MAINTAINERSYoshihiro Shimoda
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-02-02sh: add support for sh7757lcr boardYoshihiro Shimoda
The R0P7757LC0030RL board has SH7757, 256MB DDR3-SDRAM, SPI ROM, Ethernet, and more. This patch supports the following functions: - 256MB DDR3-SDRAM - SPI ROM - Ethernet Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-02-02armv7: add support for s5pc210 universal boardMinkyu Kang
This patch adds support for Samsung s5pc210 universal board Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2011-02-02OMAP3: add CM-T35 boardMike Rapoport
This patch adds support for CM-T35 board Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-02-02Add support for Freescale's mx35pdk board.Stefano Babic
The patch adds suupport for the Freescale's mx35pdk board (known as well as mx35_3stack). The board boots from the NOR flash. Following devices are supported: - two ethernet devices (FEC and SMC911x on debug board) - I2C - PMIC (MC13892) via I2C interface - UART - NOR flash (64MB) - NAND flash (2GB) - basic access to mc9sdz60 registers via I2C interface Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-02-02iMX5: EfikaMX: Preliminary board supportMarek Vasut
Supported: MMC IDE PMIC SPI flash LEDs I can boot the kernel supplied by freescale/genesi with this from MMC card and/or PATA disk. Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
2011-02-02MX5:MX53: add initial support for MX53EVK boardLiu Hui-R64343
Add initial support for MX53EVK board support. FEC, SD/MMC, UART, I2C, have been supported. Signed-off-by: Jason Liu <r64343@freescale.com>
2011-01-26mpq101: initial support for Mercury Computer Systems MPQ101 boardAlex Dubov
Mpq101 is a RapidIO development board in AMC form factor, featuring MPC8548 processor, 512MB of hardwired DDR2 RAM, 128MB of hardwired NAND flash memory, real time clock and additional serial EEPROM on i2c bus (enabled). USB controller is available, but not presently enabled. Additional board information is available at: http://www.mc.com/products/boards/ensemble_mpq101_rapidio_powerquicc_iii.aspx Environment is configured to precede the actual u-boot image so that it's located at the beginning of flash erase block (made necessary by the recent changes to the embedded environment handling). This is achieved by means of custom ld script. Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-18mpc5200, digsy_mtc: add support for rev5 board versionHeiko Schocher
difference to previous board version: - M29W128GH flash from Numonyx - SDRAM ISSI IS45S16800 (Option A2 105°C) - rev5 uses RTC RV-3029-C2 - update cs0 and cs1 baseaddr and length depending on the detected flash size. - added Werner Pfister <Pfister_Werner@intercontrol.de> as maintainer for the digsy board variants - As the M29W128GH needs a special flash_cmd_reset() document that in the new file doc/README.cfi. - move "#endif /* CONFIG_CMD_IDE */" to the right place - remove LOWBOOT config option for digsy_mtc and digsy_mtc_rev5 boards - change doc/README.cfi as Stefan Roese suggested Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Detlev Zundel <dzu@denx.de> cc: Wolfgang Denk <hs@denx.de> cc: Stefan Roese <sr@denx.de> cc: Werner Pfister <Pfister_Werner@intercontrol.de> cc: Detlev Zundel <dzu@denx.de>
2011-01-18ppc, 8xx: remove obsolete km8xx boards from keymileHolger Brunck
The MPC852 based mgsuvd and kmsupx4 boards from keymile were initially ported but later on not developed further. So the respective files were removed to avoid unneeded merging and maintenance. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Acked-by: Heiko Schocher<hs@denx.de>
2011-01-14MPC8xxx: Update maintainer entry for Wind River sbc8xxx boardsPaul Gortmaker
I've probably got the best chance of getting access to these boards in order to test things, and since Joe's e-mail is bouncing, update the MAINTAINERS entry to reflect this. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-14powerpc/85xx: Removed support for ATUM8548 boardKumar Gala
The ATUM8548 board is no longer maintained and thus we are removing support for it. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-11sh: Add support shmin boardNobuhiro Iwamatsu
This adds support for the SHMIN SH7706 board(T-SH7706LAN). The CPU of this board is SH7706. There are SDRAM of 32M byte, Flash memory of 512K byte, Serial, 10Base Ether and MMC. http://web.kyoto-inet.or.jp/people/takagaki/T-SH7706/T-SH7706.htm Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-01-09MAINTAINERS: sort Blackfin entriesMike Frysinger
2010-12-16MAINTAINERS: Transfer openrd_base maintainership to Prafulla WadaskarSimon Kagstrom
Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net>
2010-12-16Armada100: Add Board Support for Marvell Aspenite-DBPrafulla Wadaskar
Aspenite is a Development Board for ASPEN/ARMADA168(88AP168) with * Processor upto 1.2GHz * Parallel 1Gb x8 DDR2-1066 MHz * 16 Mb x16 NOR, 4Gb x8 SLC NAND, footprint for SPI NOR * Footprints for eMMC/eSD NAND & MMC x8 card * 4-in-1 card reader (xD, MMC/SD/MS Pro), CF True IDE socket * SEAF memory board, subset of PISMO2 With Peripherals: * 4.3” WVGA 24-bit LCD * Audio codecs (AC97 & I2S), TSI * VGA camera * Video in via 3 RCA jacks, and HDMI type C out * Marvell 88W8688 802.11bg/BT module * GPS RF IC * Dual analog mics & speakers, headset jack, LED, ambient light sensor * USB2.0 HS host (A), OTG (micro AB) * FE PHY, PCIE Mini Card slot * GPIO, GPIO expander with DIP switches for easier selection UART serial over USB, CIR This patch adds basic board support with DRAM and UART functionality The patch is tested for boot from DRAM using XDB Signed-off-by: Mahavir Jain <mjain@marvell.com> Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2010-12-16Merge branch 'master' of ../master into nextWolfgang Denk
2010-12-16mpc52xx: add support for tqm52xx based board charonHeiko Schocher
- serial console in PSC1 - 128MiB DRAM - 32MiB Flash - FEC Ethernet - 2 I2C busses - FPGA on CS3 - IDE - VGA SMI501 Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Wolfgang Denk <wd@denx.de>
