path: root/MAINTAINERS
2013-09-12Merge and reformat boards.cfg and MAINTAINERSAlbert ARIBAUD
Put all informations about targets, including state (active or orphan) and maintainers, in boards.cfg; remove MAINTAINERS; adjust the build system accordingly. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-09-11Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: tools/Makefile
2013-09-04Merge branch 'u-boot-ti/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-08-30exynos5250: Add arndale board supportChander Kashyap
Arndale board is based on samsung's exynos5250 soc. Signed-off-by: Inderpal Singh <inderpal.singh@linaro.org> Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-08-28arm, am335x: add support for 3 siemens boardsHeiko Schocher
add support for the am335x based boards from siemens: dxr2: - DDR3 128MiB - NAND 256MiB - Ethernet with external Switch SMSC LAN9303 - no PMIC - internal Watchdog - DFU support pxm2: - DDR2 512 MiB - NAND 1024 MiB - PMIC - PHY atheros ar803x - USB Host - internal Watchdog - DFU support rut: - DDR3 256 MiB - NAND 256 MiB - PMIC - PHY natsemi dp83630 - external Watchdog - DFU support Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Roger Meier <r.meier@siemens.com> Signed-off-by: Samuel Egli <samuel.egli@siemens.com> Cc: Pascal Bach <pascal.bach@siemens.com> Cc: Tom Rini <trini@ti.com>
2013-08-20ppc4xx: Remove CANBT boardMatthias Fuchs
This board and especially the CPU (PPC405CR) is EOL. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Acked-by: Wolfgang Denk <wd@denx.de>
2013-08-18Merge branch 'master' of git://88.191.163.10/u-boot-armTom Rini
Fixup an easy conflict over adding the clk_get prototype and USB_OTG defines for am33xx having moved. Conflicts: arch/arm/include/asm/arch-am33xx/hardware.h Signed-off-by: Tom Rini <trini@ti.com>
2013-08-17Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-08-15Add TI816X evm board supportTENART Antoine
Signed-off-by: Antoine Tenart <atenart@adeneo-embedded.com> [trini: Change to SPDX, fix a few compiler warnings, adapt to CONFIG_OMAP_COMMON] Signed-off-by: Tom Rini <trini@ti.com>
2013-08-15arm, da850: add ipam390 board supportHeiko Schocher
add the am1808 based ipam390 board from Barix. - 128MByte, DDR2, synchronous RAM 16bit databus to SDRAM interface - 128MByte, NAND Flash, 8bit databus to the NANDFlash Interface - Ethernet PHY Micrel KSZ8051R via RMII - Console on UART 0 - booting fron nand flash - spl falcon bootmode Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Tom Rini <trini@ti.com>
2013-08-13Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxTom Rini
2013-08-09powerpc/c29xpcie: add support for C29XPCIE boardMingkai Hu
C29XPCIE board is a series of Freescale PCIe add-in cards to perform as public key crypto accelerator or secure key management module. It includes C293PCIE board, C293PCIE board and C291PCIE board. - 512KB platform SRAM in addition to 512K L2 Cache/SRAM - 512MB soldered DDR3 32bit memory - CPLD System Logic - 64MB x16 NOR flash and 4GB x8 NAND flash - 16MB SPI flash Signed-off-by: Mingkai Hu <Mingkai.Hu@freescale.com> Singed-off-by: Po Liu <Po.Liu@freescale.com> [yorksun: Fixup include/configs/C29XPCIE.h] Signed-off-by: York Sun <yorksun@freescale.com>
2013-08-09powerpc/T4240EMU: Add T4240EMU targetYork Sun
Add emulator support for T4240. Emulator has limited peripherals and interfaces. Difference between emulator and T4240QDS includes: ECC for DDR is disabled due the procedure to load images No board FPGA (QIXIS) NOR flash has 32-bit port for higher loading speed IFC and I2C timing don't really matter, so set them fast No ethernet Signed-off-by: York Sun <yorksun@freescale.com>
2013-08-09nds32: Change of NDS32 CustodianAndes
Signed-off-by: Andes <uboot@andestech.com> Cc: Macpaul Lin <macpaul@gmail.com> Cc: Kuan-Yu Kuo <ken.kuoky@gmail.com>
2013-07-26mx6qsabrelite: Remove mx6qsabrelite code in favor of nitrogen6xFabio Estevam
mx6qsabrelite and nitrogen6q boards are hardware compatible, so let's avoid the code duplication and only use the nitrogen6x source code to make board code maintainance easier. Tested booting a mainline device tree kernel on a mx6qsabrelite board. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-07-16mpc85xx: Add gdsys ControlCenter Digital boardDirk Eibach
The gdsys ControlCenter Digital board is based on a Freescale P1022 QorIQ SOC. It boots from SPI-Flash but can be configured to boot from SD-card for factory programming and testing. On board peripherals include: - 2x GbE - Lattice ECP3 FPGA connected via PCIe - mSATA RAID1 - USB host - DisplayPort video output - Atmel TPM Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Reinhard Pfau <reinhard.pfau@gdsys.cc> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-07-15Revert "MIPS: Jz4740: Add qi_lb60 board support"Tom Rini
The files board/qi/qi_lb60/qi_lb60.c and include/configs/qi_lb60.h were licensed under the GPL v3 or later, and not v2 or later. As this is incompatible with the project, revert this board support until the responsible parties are available to re-license (if so desired) under GPL v2. Signed-off-by: Tom Rini <trini@ti.com>
2013-06-28Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-06-28MAINTAINERS: Add an entry to the mx6q wandboard variantFabio Estevam
Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Otavio Salvador <otavio@ossystems.com.br>
2013-06-26imx: Add support for the SabreSD shipped with i.MX6DLPierre Aubert
The SabreSD platform is available with i.MX6Q or i.MX6DL. This patch adds the support of the i.MX6DL. The config file and the board directory are renamed to remove the reference to the MX6Q. Signed-off-by: Pierre Aubert <p.aubert@staubli.com> CC: Stefano Babic <sbabic@denx.de> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-06-22pxa: add support for palmtreo680 boardMike Dunn
This patch adds support for the Palm Treo 680 smartphone. A quick overview of u-boot implementation on the treo 680... The treo 680 has a Diskonchip G4 nand flash chip. This device has a 2k region that maps to the system bus at the reset vector in a NOR-like fashion so that it can be used as the boot device. The phone is shipped with this 2k region configured as write-protected (can't be modified) and programmed with an initial program loader (IPL). At power-up, this IPL loads the contents of two flash blocks to SDRAM and jumps to it. The capacity of the two blocks is not large enough to hold all of u-boot, so a u-boot SPL is used. To conserve flash space, these two blocks and the necessary number of subsequent blocks are programmed with a concatenated spl + u-boot image. That way, the IPL will also load a portion of u-boot proper, and when the spl runs, it relocates the portion of u-boot that the IPL has already loaded, and then resumes loading the remaining part of u-boot before jumping to it. The default_environment is used (CONFIG_ENV_IS_NOWHERE) because I didn't think that having a writable environment was worth the cost of a flash block, although adding it would be straightforward. I abuse the CONFIG_EXTRA_ENV_SETTINGS option to specify the usbtty for the console (CONFIG_SYS_CONSOLE_IS_IN_ENV). Support for the LCD is included, but currently it is only useful for displaying the u-boot splash screen. But if u-boot is built without the usbtty console, it does display the auto-boot progress nicely. Signed-off-by: Mike Dunn <mikedunn@newsguy.com>
2013-06-12arm: pxa: Add support for ICP DAS LP-8x4xSergey Yanovich
LP-8x4x is a programmable automation controller by ICP DAS. It is shipped with outdated U-Boot v1.3.0 This patch adds enough supports to boot the board: - 128M of 128M SDRAM - 32M of 48M NOR Flash memory - 1 of 4 Serial consoles (PXA FFUART) - 2 of 2 Ethernet controllers (DM9000) Signed-off-by: Sergey Yanovich <ynvich@gmail.com> Series-to: u-boot Series-cc: marex
2013-06-10ARM: DRA7: Add MaintainerLokesh Vutla
Adding Maintainer for DRA7xx. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2013-06-10arm: Remove OMAP2420H4 and all omap24xx supportTom Rini
The omap2420H4 was the only mainline omap24xx board. Prior to being fixed by Jon Hunter in time for v2013.04 it had been functionally broken for a very long time. Remove this board as there's not been interest in it in U-Boot for quite a long time. Signed-off-by: Tom Rini <trini@ti.com>
2013-06-08Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: drivers/serial/Makefile
2013-06-04Add support for Congatec Conga-QEVAl boardSARTRE Leo
Add minimal support (only boot from mmc device) for the Congatec Conga-QEVAl Evaluation Carrier Board with conga-Qmx6q (i.MX6 Quad processor) module. Signed-off-by: Leo Sartre <lsartre@adeneo-embedded.com> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Otavio Salvador <otavio@ossystems.com.br>
2013-06-03arm: vf610: Add basic support for Vybrid VF610TWR boardAlison Wang
VF610TWR is a board based on Vybrid VF610 SoC. This patch adds basic support for Vybrid VF610TWR board. Signed-off-by: Alison Wang <b18965@freescale.com> Signed-off-by: Jason Jin <Jason.jin@freescale.com> Signed-off-by: TsiChung Liew <tsicliew@gmail.com> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-05-30Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: common/cmd_fpga.c drivers/usb/host/ohci-at91.c
2013-05-23ARM: Add Seagate GoFlex Home supportSuriyan Ramasami
Add Seagate GoFlex Home support Start with dockstar configuration define support for RTC, DATE, SATA and EXT4FS Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com>
2013-05-23ARM: vexpress: create A5 specific board configRyan Harkin
This patch creates a new config for the A5 dual core tile that includes the generic config for the Versatile Express platform. The generic config has been modified to provide support for the Extended Memory Map, as used on the A5 core tile. A5 does not support the legacy memory map. Signed-off-by: Ryan Harkin <ryan.harkin@linaro.org> Signed-off-by: Andre Przywara <andre.przywara@linaro.org>
2013-05-23ARM: vexpress: refactoring of Versatile Express CA9x4 supportRyan Harkin
The current ca9x4_ct_vxp platform contains support for a Versatile Express motherboard with a quad core A9 core tile. This patch separates the Versatile Express motherboard code and the A9 specific code, to ease supporting more core tiles in the next patches. Andre: merged the first two of Ryan's original patches and did some checkpatch fixes. Signed-off-by: Ryan Harkin <ryan.harkin@linaro.org> Signed-off-by: Andre Przywara <andre.przywara@linaro.org>
2013-05-21ARM: atmel: add sama5d3xek supportBo Shen
Add sama5d3xek support with following feature - boot from NAND flash, PMECC support, 4bit ECC @ 512 bytes sector - boot from SPI flash support - boot from SD card support - LCD support - EMAC support - USB OHCI support Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-05-17Update MAINTAINERS file for sandboxSimon Glass
This currently has no maintainer listed. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-05-17Update MAINTAINERS file for x86Simon Glass
This still shows the previous maintainer. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-05-12arm: at91: add at91sam9n12ek board supportWu, Josh
Add support for following features: - nand boot, with PMECC 2bit ECC for 512 bytes sector - SPI flash boot - SD card boot - LCD support Signed-off-by: Josh Wu <josh.wu@atmel.com> [fix -Wimplicit-function-declaration for at91_lcd_hw_init()] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-05-11Merge branch 'u-boot-ti/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-05-10MAINTAINERS: fix the cm-t35 board nameIgor Grinberg
"cm-t35" in U-Boot source code is called "cm_t35". Make the change "cm-t35" -> "cm_t35" for better greppability. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2013-05-10ARM: Add support for IGEP COM AQUILA/CYGNUSEnric Balletbo i Serra
The IGEP COM AQUILA and CYGNUS are industrial processors modules with following highlights: o AM3352/AM3354 Texas Instruments processor o Cortex-A8 ARM CPU o 3.3 volts Inputs / Outputs use industrial o 256 MB DDR3 SDRAM / 128 Megabytes FLASH o MicroSD card reader on-board o Ethernet controller on-board o JTAG debug connector available o Designed for industrial range purposes Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com>
2013-05-05arm: mx5: Add support for DENX M53EVKMarek Vasut
Add basic support for the DENX M53EVK board. Currently supported is: MMC (incl. booting) NAND (incl. booting) Ethernet, I2C, USB, SATA, RTC. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Scott Wood <scottwood@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de>
2013-04-22imx: Add titanium board support (i.MX6 based)Stefan Roese
Titanium is a i.MX6 based board from ProjectionDesign / Barco. This patch adds support for this board with the newly introduced NAND support for i.MX6. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com>
2013-04-22mx6sl: Add initial support for mx6slevk boardFabio Estevam
mx6slevk board is a development board from Freescale based on the mx6 solo-lite processor. For details about mx6slevk, please refer to: http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=IMX6SLEVK&parentCode=i.MX6SL&fpsp=1 Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-04-15Tegra: T30: Beaver board support.Tom Warren
Beaver is a Tegra30 board that is nearly 100% compatible w/Cardhu. Add a Beaver build so it can begin to be differentiated, if need be. Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-04-12arm: Remove support for smdk6400Benoît Thébaudeau
The migration of boards from Makefile to boards.cfg was due for v2012.03, but smdk6400 did not follow, and it does not build, so move it to scrapyard. It will still be possible to restore it from the Git history before fixing it. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-04Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-03-28Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: drivers/spi/tegra20_sflash.c include/fdtdec.h lib/fdtdec.c
2013-03-27apx4devkit: change maintainerVeli-Pekka Peltola
As I am no longer working for Bluegiga I will pass apx4devkit maintenance to Lauri. Signed-off-by: Veli-Pekka Peltola <veli-pekka.peltola@iki.fi> Acked-by: Lauri Hintsala <lauri.hintsala@bluegiga.com>
2013-03-26Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-03-24ti814x_evm: add ti814x evm board supportMatt Porter
Add TI814X EVM board directory, config file, and MAINTAINERS entry. Enable build. Signed-off-by: Matt Porter <mporter@ti.com> Reviewed-by: Tom Rini <trini@ti.com> [trini: Adapt to recent omap_hsmmc requirements, Matt re-tested] Signed-off-by: Tom Rini <trini@ti.com>
2013-03-20Add initial support for Wandboard dual lite and solo.Fabio Estevam
Wandboard is a development board that has two variants: one version based on mx6 dual lite and another one based on mx6 solo. For more details about Wandboard, please refer to: http://www.wandboard.org/ Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-03-18Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Albert's rework of the linker scripts conflicted with Simon's making everyone use __bss_end. We also had a minor conflict over README.scrapyard being added to in mainline and enhanced in u-boot-arm/master with proper formatting. Conflicts: arch/arm/cpu/ixp/u-boot.lds arch/arm/cpu/u-boot.lds arch/arm/lib/Makefile board/actux1/u-boot.lds board/actux2/u-boot.lds board/actux3/u-boot.lds board/dvlhost/u-boot.lds board/freescale/mx31ads/u-boot.lds doc/README.scrapyard include/configs/tegra-common.h Build tested for all of ARM and run-time tested on am335x_evm. Signed-off-by: Tom Rini <trini@ti.com>
