Add the DM_MMC-compatible DesignWare MMC driver support for Synopsys
ARC devboards. It is created to switch ARC devboards to use DM_MMC.
It required information such as clocks (Bus Interface Unit clock,
Card Interface Unit clock) and SDIO bus width.
Signed-off-by: Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com>
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
arch/arm/dts/armada-385-amc.dts
arch/arm/dts/armada-xp-theadorable.dts
arch/arm/dts/stm32mp157c-ev1-u-boot.dtsi
Alignment with kernel driver name & binding
introduced by https://patchwork.kernel.org/cover/10761943/
to use the final marketing name = STPMIC1.
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Missed few mails from openedev, since most of the day I look at
amarulasolutions mail so update the same.
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Signed-off-by: Lukasz Majewski <lukma@denx.de>
The EFI PAYLOAD will use git://git.denx.de/u-boot-efi.git in future.
This patch does the following changes to the u-boot-marvell maintainers
entry:
- Add Armada-7k/8k to the list
- Remove Prafulla and Luka since they have been silent on the list for
a long time. Please speak up, if you would like to continue or better
start maintaining.
- Add multiple Marvell / MVEBU related driver directories and files
Cc: Prafulla Wadaskar <prafulla@marvell.com>
Cc: Luka Perkov <luka.perkov@sartura.hr>
Acked-by: Luka Perkov <luka.perkov@sartura.hr>
The MAINTAINERS file was copied from Linux Kernel along with all its
statuses of maintainership. However tools/genboardscfg.py accepts only
Maintained, Supported and Orphan. Remove then the Odd Fixes and
Obsolete from MAINTAINERS file to avoid confusion.
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
Currently, there is no easy way to add or modify UEFI variables.
In particular, bootmgr supports BootOrder/BootXXXX variables, it is
quite hard to define them as u-boot variables because they are represented
in a complicated and encoded format.
The new command, efidebug, helps address these issues and give us
more friendly interfaces:
* efidebug boot add: add BootXXXX variable
* efidebug boot rm: remove BootXXXX variable
* efidebug boot dump: display all BootXXXX variables
* efidebug boot next: set BootNext variable
* efidebug boot order: set/display a boot order (BootOrder)
Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
"env [print|set] -e" allows for handling uefi variables without
knowing details about mapping to corresponding u-boot variables.
Heinrich is going to take over maintainership of the efi_loader tree
going forward.
To ensure that I will still receive review mails at least, add me as
reviewer with a stable email address.
Matthias Brugger agreed to take over maintainership from me for the
Raspberry Pi tree. Add him to the MAINTAINERS file instead.
Add a new defconfig file for the AM57xx High Security EVM. This config
is specific for the case of USB/UART booting.
Signed-off-by: Andrew F. Davis <afd@ti.com>
Add a new defconfig file for the DRA7xx High Security EVM. This config
is specific for the case of USB booting.
- SPI-NOR support
Add myself as co-maintainer for U-Boot SPI NOR subsystem.
Signed-off-by: Vignesh R <vigneshr@ti.com>
Reviewed-by: Jagan Teki <jagan@openedev.com>
[jagan: drop mtd/spi file from SPI entry]
Update Atmel AT91 maintainership
Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
Acked-by: Nicolas Ferre <nicolas.ferre@microchip.com>
Change maintainers to Prabhakar Kushwaha for fsl-qoriq, mpc85xx
and mpc86xx.
Signed-off-by: York Sun <york.sun@nxp.com>
Acked-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
Move file ocelot_switch to mscc_eswitch to prepare to add
new net drivers for other MSCC SoCs.
Signed-off-by: Horatiu Vultur <horatiu.vultur@microchip.com>
Add entry for Amlogic SoC maintained files and the freshly
created mailing-list.
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
For 2019.04
I prefer to use my personal email address for U-Boot related work.
Signed-off-by: Fabio Estevam <festevam@gmail.com>
Handle correctly directory arch/arm/mach-stm32mp/ :
Add a trailing slash to include all files
and subdirectory files.
Similar changes was done for Zynq in past and this patch just follow
this pattern to separate cpu code from SoC code.
Move arch/arm/cpu/armv8/zynqmp/* -> arch/arm/mach-zynqmp/*
And also fix references to these files.
Based on
"ARM: zynq: move SoC sources to mach-zynq"
(sha1: 0107f2403669f764ab726d0d404e35bb9447bbcc)
This patch adds support for the Microsemi Ethernet switch present on
Ocelot SoCs.
Signed-off-by: Gregory CLEMENT <gregory.clement@bootlin.com>
Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Add myself as the maintainer of CZ.NIC's Turris Omnia and Turris Mox
projects.
Signed-off-by: Marek Behún <marek.behun@nic.cz>
- MIPS: mscc: various enhancements for Luton and Ocelot platforms
- MIPS: mscc: added support for Jaguar2 platform
- MIPS: optimised SPL linker script
- MIPS: bcm6368: fix restart flow issues
- MIPS: fixed CONFIG_OF_EMBED warnings for all MIPS boards
- MIPS: mt7688: small fixes and enhancements
- mmc: compile-out write support if disabled
Add device tree based on evaluation board pcb112.
Add device tree based on evaluation board pcb110.
The Jaguar2 SOC family has 63 gpio pins therefore I extended mscc-common
to support new numbe of pins and remove any platform dependency from
mscc-common.
This patch add a new SPI driver for MSCC SOCs that does not sport the
designware SPI hardware controller.
Performance gain: 7.664 seconds vs. 17.633 for 1 Mbyte write.
Signed-off-by: Lars Povlsen <lars.povlsen@microchip.com>
This add support for the the MSCC serial GPIO driver in MSCC
VCoreIII-based SOCs.
By using a serial interface, the SIO controller significantly extends
the number of available GPIOs with a minimum number of additional pins
on the device. The primary purpose of the SIO controller is to connect
control signals from SFP modules and to act as an LED controller.
This adds the base driver.
This patch adds new file entries for MediaTek SoCs
Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
Update NXP i.MX mail list address
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Add initial support for the Ingenic JZ47xx MIPS SoC.
Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
Signed-off-by: Ezequiel Garcia <ezequiel@collabora.com>
Adding the support for the Luton boards PCB91 which share common code with
the Ocelots boards, including board code, device tree and configuration.
Adding the support for 2 boards sharing common code for Ocelot chip:
PCB120 and PCB123
This family of SoCs are found in the Microsemi Switches solution and have
already a support in the linux kernel.
The motivation for this is to allow distributions to distribute all
possible tools in a generic way, avoiding the need of specific tools
building for each machine.
Especially on OpenEmbedded / Yocto Project ecosystem, it is very
common each BSP to end providing their specific tools when they need
to generate images for some SoC (e.g MX23 / MX28 in meta-freescale
case).
Using this, we can package the tools doing:
$: make tools-only_defconfig
$: make tools-only
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
[trini: Add MAINTAINERS entry for myself, add to .travis.yml, make
U-Boot itself buildable to not trip up other frameworks]
Add an entry for my maintainership of this tool.
Alex suggested to add me as a reviewer for the EFI subsystem.
The patch also adds a description for R: entries.
This patch adds an entry for MediaTek.
Signed-off-by: Ryder Lee <ryder.lee@mediatek.com>
Add mailing list for stm32mp architecture and board.
Add NXP linux team upstream maillist as reviewer
Xilinx changes for v2018.11-rc2-v2
FPGA:
- Fix SPL fpga loading from FIT
ARM64:
- Fix gic accesses in EL2/EL1
Xilinx:
- Add dlc20 board support
- Add Versal board support
- Sync defconfigs
- Enable MP via Kconfig
- Add missing efuse node
- Enable CDC for zcu100
cmd:
- Fix kgdb Kconfig dependency
Xilinx is introducing Versal, an adaptive compute acceleration platform
(ACAP), built on 7nm FinFET process technology. Versal ACAPs combine
Scalar Processing Engines, Adaptable Hardware Engines, and Intelligent
Engines with leading-edge memory and interfacing technologies to deliver
powerful heterogeneous acceleration for any application. The Versal AI
Core series has five devices, offering 128 to 400 AI Engines. The series
includes dual-core Arm Cortex™-A72 application processors, dual-core Arm
Cortex-R5 real-time processors, 256KB of on-chip memory with ECC, more
than 1,900 DSP engines optimized for high-precision floating point with
low latency.
The patch is adding necessary infrastructure in place without enabling
platform which is done in separate patch.
accidentially while fixing merge errors for patch:
https://lists.denx.de/pipermail/u-boot/2018-September/342278.html
missed to add files:
MAINTAINERS
drivers/i2c/Kconfig
drivers/i2c/Makefile
add them with this patch.
Acked-by: Liviu Dudau <liviu.dudau@foss.arm.com>
Adds configuration option OPTEE_TA_AVB and a header file describing the
interface to the Android Verified Boot 2.0 (AVB) trusted application
provided by OP-TEE.
Tested-by: Igor Opaniuk <igor.opaniuk@linaro.org>
Reviewed-by: Igor Opaniuk <igor.opaniuk@linaro.org>
Signed-off-by: Jens Wiklander <jens.wiklander@linaro.org>
Adds a uclass to interface with a TEE (Trusted Execution Environment).
A TEE driver is a driver that interfaces with a trusted OS running in
some secure environment, for example, TrustZone on ARM cpus, or a
separate secure co-processor etc.
The TEE subsystem can serve a TEE driver for a Global Platform compliant
TEE, but it's not limited to only Global Platform TEEs.
The over all design is based on the TEE subsystem in the Linux kernel,
tailored for U-Boot.
Add support for the Arm Versatile Express config bus that is
being used for exposing various subsystems via a generic
configuration bus. This driver adds support for generating
transactions on this configuration bus and can be used by
other drivers to abstract the communication with the actual
function providers.
Signed-off-by: Liviu Dudau <liviu.dudau@foss.arm.com>
