In master we had already taken a patch to fix the davinci GPIO code for
CONFIG_SOC_DM646X and in u-boot-ti we have additional patches to support
DA830 (which is CONFIG_SOC_DA8XX && !CONFIG_SOC_DA850). Resolve these
conflicts manually and comment the #else/#endif lines for clarity.
arch/arm/include/asm/arch-davinci/gpio.h
drivers/gpio/da8xx_gpio.c
Board and config header files for bf609-ezkit support.
Signed-off-by: Bob Liu <lliubbo@gmail.com>
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
Signed-off-by: Sonic Zhang <sonic.adi@gmail.com>
The IGEP COM PROTON is a new ultra compact module design with an
on-board ethernet controller.
Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com>
The board is named pcm051 and has this hardware:
SOC: TI AM3359
DDR3-RAM: 2x MT41J256M8HX-15EIT:D 512MiB
ETH 1: LAN8710AI
SPI-Flash: W25Q64BVSSIG
RTC: RV-4162-C7
I2C-EEPROM: CAT32WC32
NAND: MT29F4G08_VFPGA63
PMIC: TPS65910A3
LCD
Supported:
UART 1
MMC/SD
ETH 1
USB
I2C
SPI
Not yet supported:
NAND
RTC
LCD
Signed-off-by: Lars Poeschel <poeschel@lemonage.de>
[trini: Add #define CONFIG_PHY_ADDR 0 to config]
BSC9132QDS is a Freescale reference design board for BSC9132 SoC.
BSC9132 SOC is an integrated device that targets the evolving Microcell,
Picocell, and Enterprise-Femto base station market subsegments.
It combines Power Architecture e500v2 and DSP StarCore SC3850 core
technologies with MAPLE-B2F baseband acceleration processing elements.
BSC9132QDS Overview
2Gbyte DDR3 (on board DDR), Dual Ranki
32Mbyte 16bit NOR flash
128Mbyte 2K page size NAND Flash
256 Kbit M24256 I2C EEPROM
128 Mbit SPI Flash memory
SD slot
USB-ULPI
eTSEC1: Connected to SGMII PHY
eTSEC2: Connected to SGMII PHY
PCIe
CPRI
SerDes
I2C RTC
DUART interface: supports one UARTs up to 115200 bps for console display
Apart from the above it also consists various peripherals to support DSP
functionalities.
This patch adds support for mainly Power side functionalities and peripherals
Signed-off-by: Naveen Burmi <NaveenBurmi@freescale.com>
Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com>
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
Signed-off-by: Andy Fleming <afleming@freescale.com>
The following features are supported:
* 128 MB DDR1 SDRAM
* DUART
* SD/MMC Card Socket
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
This patch adds support for MX23-based Olinuxino board.
Cc: Fabio Estevam <fabio.estevam@freescale.com>
Cc: Otavio Salvador <otavio@ossystems.com.br>
The R0P7752C00000RZ board has SH7752, 512MB DDR3-SDRAM, SPI ROM,
Gigabit Ethernet, and eMMC.
This patch supports the following functions:
- 512MB DDR3-SDRAM, SCIF4, SPI ROM, Gigabit Ethernet, eMMC
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
README
board/samsung/universal_c210/universal.c
drivers/misc/Makefile
drivers/power/power_fsl.c
include/configs/mx35pdk.h
include/configs/mx53loco.h
include/configs/seaboard.h
Change e-mail address of Luka Perkov.
Signed-off-by: Luka Perkov <luka@openwrt.org>
CC: Luka Perkov <uboot@lukaperkov.net>
Since there's no obvious mention, add a brief reference to the
custodians page at www.denx.de
This patch adds support for the a3m071 board based on the
MPC5200.
Signed-off-by: Raphael Assenat <raph@8d.com>
[trini: Squash boards.cfg / MAINTAINERS change into main patch]
Based on previous work by: Alistair Buxton <a.j.buxton@gmail.com>
Signed-off-by: Pali Rohár <pali.rohar@gmail.com>
Cc: Ивайло Димитров <freemangordon@abv.bg>
This adds board support for the Toradex Colibri T20 module.
Working functions:
- SD card boot
- USB boot
- Network
- NAND environment
Signed-off-by: Lucas Stach <dev@lynxeye.de>
Signed-off-by: Tom Warren <twarren@nvidia.com>
These boards have long reached EOL, and there has been no indication
of any active users of such hardware for years. Get rid of the dead
weight.
Cc: Wolfgang Grandegger <wg@denx.de>
The woodburn board is based on the MX35 SOC.
Support for both external (NOR) and internal
(SD Card) boot mode are added. It uses the
generic SPL framework to implement the internal boot
mode.
The following peripherals are supported:
- Ethernet (FEC)
- SD Card
- NAND (512 MB)
- NOR Flash
In the internal boot mode, a simple imximage header
is generated to set the address in internal RAM
where the SOC must copy the SPL code. The initial setup
is then demanded to the SPL itself.
drivers/serial/serial_lh7a40x.c
The sbc8548/60 (both similar, just variations in UART hardware)
support has been removed from the linux kernel as of v3.6-rc1~132
so lets also now remove it from the u-boot tree as well.
Add basic support for HP iPAQ h2200 palmtop. h2200 palmtop was targeted
to general consumers. It has 64 MB of RAM, 32 MB flash. No intergrated
Wi-Fi nor Ethernet. Based on Intel PXA255 processor. It was shipped with
Windows CE 4.2 operating system.
Signed-off-by: Lukasz Dalek <luk0104@gmail.com>
mx6qsabreauto is a board based on mx6q SoC with the following features:
- 2GB of DDR3
- 2 USB ports
- 1 HDMI output port
- SPI NOR
- 2 LVDS LCD ports
- Gigabit Ethernet
- Camera
- eMMC and SD card slot
- Multichannel Audio
- CAN
- SATA
- NAND
- PCIE
- Video Input
Add very basic support for it.
mx6qsabresd is a board based on mx6q SoC with the following features:
- 1GB of DDR3
- 1 USB OTG port
- SPI NOR
- LVDS panel
- Gigabit Ethernet
- Camera Connector
- Audio
Medcom is the marketing name for an older, PXA-based version of the same
device. In order to avoid confusion, rename the Tegra-based version to
the new marketing name.
Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
As the board seems to be unmaintained for some time, lets remove
the support in mainline completely.
Cc: Peter De Schrijver <p2@mind.be>
Since the IOP480 (PPC401/3 variant from PLX) is only used on 2
boards that are not actively maintained, lets remove support
for it completely. This way the ppc4xx code will get a bit cleaner.
Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu>
The former maintainer is no longer interested, move to orphaned. Patch
is from the former maintainer.
After taking with the former maintainer, delete this platform. The
patch is from the former maintainer.
Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp>
Due to grown code sizes the TQM85xx boards don't build any more with
some older tool chains (like ELDK 4.2). As these boards have long
reached EOL it seems a waste of effort trying to fix them. The vendor
has agreed to drop support for them, too. So let's get rid of them.
Cc: Stefan Roese <sr@denx.de>
cc: Kim Phillips <kim.phillips@freescale.com>
Add minimal support for Altera's SOCFPGA Cyclone 5 hardware.
Signed-off-by: Dinh Nguyen <dinguyen@altera.com>
Signed-off-by: Chin Liang See <clsee@altera.com>
Signed-off-by: Pavel Machek <pavel@denx.de>
Acked-by: Tom Trini <trini@ti.com>
Cc: Wolfgang Denx <wd@denx.de>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
v8: Remove no_return attribute for reset_cpu
Based on v2012.10-rc2
Add support for Xilinx Zynq board.
CC: Joe Hershberger <joe.hershberger@gmail.com>
This patch adds support for the X600 SPEAr600 based board. Its also
the first SPEAr600 board that uses the newly introduced SPEAr600
SPL support. Xloader is not necessary any more. By using the new
"u-boot.spr" make target, one image will generated containing both,
U-Boot SPL (with mkimage header as needed by the SPEAr BootROM, and
the main U-Boot with mkimage header.
Cc: Amit Virdi <amit.virdi@st.com>
Cc: Vipin Kumar <vipin.kumar@st.com>
Add support for new board iConnect from Iomega.
More information about the device can be found here:
http://go.iomega.com/en/products/network-storage-desktop/wireless-data-station/network-hard-drive-iconnect/?partner=4735
Signed-off-by: Luka Perkov <uboot@lukaperkov.net>
Tested-by: Wojciech Dubowik <wojciech.dubowik@neratec.com>
Tested-by: Tim Fletcher <tim@night-shade.org.uk>
Support of the MINI2440 board from FriendlyARM from
an old version of u-boot :
http://repo.or.cz/r/u-boot-openmoko/mini2440.git
Currently, supporting only boot from NOR.
Signed-off-by: Gabriel Huau <contact@huau-gabriel.fr>
The Armadillo-800EVA board has Renesas R-Mobile R8A7740, 512MB DDR3-SDRAM,
Ethernet, and more.
- 512MB DDR3-SDRAM
- Serial console (SCIF)
- Ethernet MAC(MII) & PHY(SMSC)
Signed-off-by: Hideyuki Sano <hideyuki.sano.dn@renesas.com>
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
The KZM-A9-GT board has Renesas R-Mobile SH73A0, 512MB DDR2-SDRAM,
USB, Ethernet, and more.
- 512MB DDR2-SDRAM
- 16MB NOR Flash memory
- Ethernet (SMSC)
- I2C
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
This board is the only board that still sticks to OneNAND IPL.
Remove this board, since we have SPL around for a while and
OneNAND is well supported in the SPL framework. The board can
be revived if necessary.
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Cc: Tom Rini <trini@ti.com>
This patch is derived from an older patch provided by atmel in its
buildroot-avr32-v3.0.0.tar.bz2
cc: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no>
As the maintainer for at91sam9g10ek and at91sam9m10g45ek can not reach
any more.
So I wish to take over the maintainer for sam9g10 and sam9m10g45
Signed-off-by: Bo Shen <voice.shen@atmel.com>
Update maintainer for "efikamx" and "efikasb" to myself.
Signed-off-by: Matt Sealey <matt@genesi-usa.com>
