path: root/MAINTAINERS
2011-09-04ARM: remove broken "at91cap9adk" boardWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stelian Pop <stelian.pop@leadtechdesign.com>
2011-09-04ARM: remove broken "smdk2400" boardWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Gary Jennejohn <garyj@denx.de>
2011-09-04ARM: remove broken "B2" boardWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Andrea Scian <andrea.scian@dave-tech.it>
2011-09-04ARM: remove broken "armadillo" boardWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Rowel Atienza <rowel@diwalabs.com>
2011-09-04ARM: remove broken "assabet" boardWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: George G. Davis <gdavis@mvista.com>
2011-08-22sh: Add Renesas rsk7264 boardPhil Edworthy
The rsk7264 (also know as rsk2+sh7264) is an SH2A based board with 64MB NAND flash and 64MB SDRAM. It is very similar to the rsk7203 board. Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-08-04Convert ISO-8859 files to UTF-8Albert ARIBAUD
There was a mix of UTF-8 and ISO-8859 files in the U-Boot source tree, which could cause issues with the patchwork review system. This commit converts all ISO-8859 files to UTF-8. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-08-04Armada100: Add Board Support for Marvell GuruPlug-DisplayAjay Bhargav
This patch adds basic board support with DRAM and UART functionality Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com> Acked-by: Tanmay Upadhyay <tanmay.upadhyay@einfochips.com>
2011-08-03avr32: add grasshopper (ICnova AP7000) boardAndreas Bießmann
The grasshopper board is a neat avr32 evaluation kit produced by In-Circuit GmbH. See http://www.ic-board.de/product_info.php?info=p75_ICnova-AP7000-Base.html for detailed information about this device. Signed-off-by: Andreas Bießmann <biessmann@corscience.de> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2011-07-28Removed obsolete Netstal boardsNiklaus Giger
Signed-off-by: Niklaus Giger <niklaus.giger@member.fsf.org>
2011-07-28MAINTAINERS: integrator+versatile boardsLinus Walleij
- Take maintainership of the unlisted integratorap board - Orphan the boards maintained by Peter Pearse, as he has retired from ARM Cc: Philippe Robin <philippe.robin@arm.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-07-14imx: Add support for zmx25 boardMatthias Weisser
zmx25 is a board based on imx25 SoC, 64 Megs of LPDDR, 32 Megs of NOR flash, an optional NAND flash. Signed-off-by: Matthias Weisser <weisserm@arcor.de>
2011-07-14ARM: Update maintainer of board scb9328Torsten Koschorrek
Signed-off-by: Torsten Koschorrek <koschorrek@synertronixx.de>
2011-07-11powerpc/85xx: Add basic support for P1023RDS boardRoy Zang
The P1023RDS board is the reference board for the P1023 SoC. Add support for booting it from NOR or NAND, with fixed 2G of DDR, PCIe, UART, I2C, etc. Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Chunhe Lan <Chunhe.Lan@freescale.com> Signed-off-by: Lei Xu <B33228@freescale.com> Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-06mpc83xx: Add support for MergerBox boardAndre Schwarz
Includes board config file, documentation, maintainer and boards.cfg entries, and board specific files in vendor dir. Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2011-07-04Add support for Network Space v2 and parentsSimon Guinot
This patch add support for the Network Space v2 board and parents, based on the Marvell Kirkwood 6281 SoC. This include Network Space (Max) v2 and Internet Space v2. Additional information is available at: http://lacie-nas.org/doku.php?id=network_space_v2 Signed-off-by: Simon Guinot <sguinot@lacie.com>
2011-07-04arm/km: add support for portl2 boardValentin Longchamp
This adds support for the keymile Kirkwood BEC portl2 board. This board relies on the km_arm (km_kirkwood) BEC. The egiga driver is configured for a 100M full-duplex, A/N off connnection to the backplane. This board has always ethernet present, because it is connected to the marvell switch similar to mgcoge3un. The reset_phy functionality is also the same to mgcoge3un. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> cc: Prafulla Wadaskar <prafulla@marvell.com> cc: Heiko Schocher <hs@denx.de>
2011-07-04arm/km: replace suenx targets with km_kirkwoodHolger Brunck
suen3 and suen8 were in first HW version quite different, but now they are from a u-boot point of view similar. So these two boards can use the same header file. Other keymile boards differ only in the usage of the PCI interface. Therefore a target km_kirkwood_pci was introduced. All targets use the same header file. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Prafulla Wadaskar <prafulla@marvell.com> cc: Heiko Schocher <hs@denx.de>
2011-07-04MX53: Add initial support for MX53ARDFabio Estevam
2011-06-23Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
* 'master' of git://git.denx.de/u-boot-arm: run arm_pci_init after relocation IXP42x PCI rewrite update/fix PDNB3 board update/fix IXDP425 / IXDPG425 boards add dvlhost (dLAN 200 AV Wireless G) board IXP NPE: add support for fixed-speed MII ports update/fix AcTux4 board update/fix AcTux3 board update/fix AcTux2 board update/fix AcTux1 board use -ffunction-sections / --gc-sections on IXP42x support CONFIG_SYS_LDSCRIPT on ARM fix "depend" target in npe directory Fix IXP code to work after relocation was added trigger hardware watchdog in IXP42x serial driver add support for IXP42x Rev. B1 and newer add XScale sub architecture (IXP/PXA) to maintainer list Conflicts: arch/arm/lib/board.c Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-06-23add dvlhost (dLAN 200 AV Wireless G) boardMichael Schwingen
Signed-off-by: Michael Schwingen <michael@schwingen.org>
2011-06-23add XScale sub architecture (IXP/PXA) to maintainer listMichael Schwingen
2011-06-22ARM: drop unsupported 'trab' boardWolfgang Denk
The 'trab' board configuration is broken, and there is nobody who is interested and willing to fix it. Drop it. This includes support for VFD displays which have always been used by this board only. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-06-21Add support for Bluewater Systems Snapper 9260/9G20 modulesRyan Mallon
Add support for Bluewater Systems AT91 based Snapper 9260 and 9G20 single board computer modules. Includes NAND flash and Ethernet support. Signed-off-by: Ryan Mallon <ryan@bluewatersys.com>
2011-06-01Merge branch 'master' of /home/wd/git/u-boot/custodiansWolfgang Denk
* 'master' of /home/wd/git/u-boot/custodians: SMDKV310: Fix incorrect conditional compilation for MIU linear mapping SMDKV310: CPU fequency and mmc_pre_ratio modified armv7: Add support for ST-Ericsson U8500 href platform I2C: Add driver for ST-Ericsson U8500 i2c armv7: Add ST-Ericsson u8500 arch Kirkwood: boards cleanup for deprecated CONFIG_CMD_AUTOSCRIPT ARMV7: Vexpress: Add missing MMC header arm/km: update mgcoge3un board support mvgbe: enable configurability of PORT_SERIAL_CONTROL_VALUE arm/km: rename mgcoge2un to mgcoge3un arm/km: add second serial interface for kirkwood arm/km: disable ls (through jffs2 support) arm/km: introduce bootcount env variable and clean km_arm arm/km: move CONFIG_EXTRA_ENV_SETTINGS from board to km_arm file arm/km: remove CONFIG_SYS_KWD_CONFIG from keymile-common.h ARMV7: MMC SPL Boot support for SMDKV310 board ARMV7: Add support for Samsung SMDKV310 Board S5PC2XX: clock: support pwm clock for evt1 (cpu revision 1) S5P: add set_mmc_clk for external clock control S5PC2XX: Support the cpu revision S5P:SROM config code moved to s5p-common directory Add _end for the end of u-boot image for SMDK6400 MMC S5P: Fix typo S5P: GPIO Macro Values Corrected. SMDK2410: various cleanup/code style fixes SMDK2410: use the CFI driver (and remove the old one) SMDK2410: remove unneeded config.mk SMDK2410: activate ARM relocation feature BeagleBoard: fixed typo in typecast mvsata: issue hard reset on initialization VCMA9: use ARM relocation feature to fix build error MX31: drop warnings due to missing prototype for mxc_watchdog_reset() MX5: drop config.mk from efikamx board MX31: Make get_reset_cause() static and drop unreachable code MX53: Remove CONFIG_SYS_BOOTMAPSZ from mx53 config files. MX53: Handle silicon revision 2.1 case mx5: board: code clean up for checkboard code MX51: vision2: Fix build for vision2 board. MX51: vision: Let video mode struct be independant of watchdog. MX53: Add initial support for MX53SMD board. MX53: support for freescale MX53LOCO board mx5: Fix CONFIG_OF_LIBFDT redefined warning mx5: Remove unnecessary CONFIG_SYS_BOOTMAPSZ definition mx31pdk: Clean up mx31pdk.h file
2011-06-01Move wepep250,delta,xsengine to scrapyardMarek Vasut
Drop wepep250 board from MAINTAINERS and add all these three boards to doc/README.scrapyard Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
2011-05-31arm/km: rename mgcoge2un to mgcoge3unValentin Longchamp
The mgcoge2un target was only an intermediate step to mgcoge3un. For this reason the mgcoge2un support was moved to mgcoge3un, because it isn't needed to support both targets. We add the BootROM init file for the mgcoge3un memphis RAM. We also move the suen3 and suen8 boards into the correct category in the MAINTAINERS file. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Acked-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de> cc: Prafulla Wadaskar <prafulla@marvell.com>
2011-05-26ARMV7: Add support for Samsung SMDKV310 BoardChander Kashyap
SMDKV310 board is based on Samsung S5PV310 SOC. This SOC is very much similar to S5PC210. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Tushar Behera <tushar.behera@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-05-23MX53: Add initial support for MX53SMD board.Fabio Estevam
2011-05-23MX53: support for freescale MX53LOCO boardJason Liu
This patch add initial support for freescale MX53LOCO board. Network(FEC),SD/MMC,UART have been supported by this patch Signed-off-by: Jason Liu <jason.hui@linaro.org>
2011-05-10powerpc/km82xx: add mgcoge3ne and remove mgcoge2ne supportHolger Brunck
This patch adds support for the MPC8247 based board mgcoge3ne. Additionaly mgcoge2ne board supprot was removed, because due to the mgcoge3ne, this board is obsolete and not longer maintained. The board is similar to mgcoge. The difference is that a NUMONYX flash is used and a different SDRAM (256MB). Also introduce CONFIG_KM_82XX to collect ppc82xx common settings and remove staticness from the common set_pin function. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Acked-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de>
2011-04-30powerpc, 83xx: add kmsupx5 board supportHeiko Schocher
The Keymile SUPx5 board series is based on a PBEC8321 but contains an additional PBUS FPGA (LPXF) on local bus CS2. Signed-off-by: Thomas Reufer <thomas.reufer@keymile.com> Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Kim Phillips <kim.phillips@freescale.com> cc: Wolfgang Denk <wd@denx.de> cc: Kim Phillips <kim.phillips@freescale.com> cc: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Holger Brunck <holger.brunck@keymile.com>
2011-04-30ppc: add support for ppc based board mgcoge2neHeiko Schocher
The mgcoge2 board from keymile deploys two different processors. An ARM based Kirkwood for the "unit" part of the SW and a PPC for the "ne" part of the SW. Therefore in Linux and U-Boot the names for the board are mgcoge2un and mgcoge2ne. This patch adds the mgcoge2ne part of the board. The ppc part of mgboge2 is quite similar to mgcoge, therefore a generic header km82xx-common.h was introduced to collect all similiarities. Currently the only difference is that mgcoge2ne has a 64 MB numonyx NOR flash with a single die. The mgcoge has a dual die flash 2*32MB from spansion. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Valentin Longchamp <valentin.longchamp@keymile.com>
2011-04-30arm: add support of Kirkwood based board SUEN8Heiko Schocher
The Kirwood based SUEN8 board from Keymile is at this stage the same than the suen3 board. This patch adds the board support for the suen8. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Heiko Schocher <hs@denx.de> cc: Prafulla Wadaskar <prafulla@marvell.com>
2011-04-30arm: add support for kirkwood based mgcoge2un boardHeiko Schocher
This board is similar to keymile suen3. Signed-off-by: Clive Stubbings <clive.stubbings@xentech.co.uk> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Heiko Schocher <hs@denx.de> cc: Prafulla Wadaskar <prafulla@marvell.com>
2011-04-30mpc832x: add support for mpc8321 based tuda1 boardHeiko Schocher
This board is similar to suvd3 board. So most initialisation topics are taken from suvd3 (UART1, Ethernet, piggy PHY, flash, ram) only the application specific chip selects differ. Signed-off-by: Lukas Roggli <lukas.roggli@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Kim Phillips <kim.phillips@freescale.com> cc: Kim Phillips <kim.phillips@freescale.com> cc: Valentin Longchamp <valentin.longchamp@keymile.com>
2011-04-30mpc832x: add support for mpc8321 based tuxa1 boardHeiko Schocher
2011-04-30mpc832x: add support for the mpc8321 based suvd3 boardHeiko Schocher
- serial console on UART1 - Ethernet RMII over UCC4 - PHY SMSC LAN8700 - 64MB Flash - 128 MB DDR2 RAM - I2C - bootcount This board is similiar to the kmeter1 (8360) board, so common config options are extracted into the include/configs/km83xx-common.h file. Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Kim Phillips <kim.phillips@freescale.com> cc: Kim Phillips <kim.phillips@freescale.com> cc: Holger Brunck <holger.brunck@keymile.com> cc: Valentin Longchamp <valentin.longchamp@keymile.com>
2011-04-27ARMV7: OMAP3: Add support for Comelit DIG297 boardLuca Ceresoli
Board support for the DIG297 board manufactured by Comelit Group SpA. It is a custom board based on the BeagleBoard <http://beagleboard.org/> by Texas Instruments. The board support is based on the BeagleBoard implementation. Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de> Cc: Albert Aribaud <albert.aribaud@free.fr> Cc: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-04-27Replace obsolete e-mail addressAlbert ARIBAUD
2011-04-27OMAP3: CM-T35: update MAINTAINERS fileIgor Grinberg
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-04-27ARMV7: AM3517/05: Add support for CraneBoard.Srinath
It is a low cost reference design based on Sitara AM3517 SoC from Texas Instruments Please refer to <www.craneboard.org> for more details. Signed-off-by: Srinath <srinath@mistralsolutions.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-04-13MAINTAINERS: fix email address caseFabio Estevam
2011-04-13x86: Update MAINTAINERS and delete README filesGraeme Russ
The README files are totally out-of-date to the point where they do more harm than good Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2011-04-08Blackfin: bf506f-ezkit: new board portMike Frysinger
2011-04-08Blackfin: bf525-ucr2: new board portChong Huang
Signed-off-by: Chong Huang <chuang@ucrobotics.com> Signed-off-by: Haitao Zhang <minipanda@linuxrobot.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-08Blackfin: dnp5370: new board portAndreas Schallenberg
Info about the hardware can be found here: http://www.dilnetpc.com/dnp0086.htm Signed-off-by: Andreas Schallenberg <Andreas.Schallenberg@3alitydigital.de> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-02MIPS: Purple: Remove Purple supportDaniel Schwierzeck
The Purple SoC and eval board are not actively maintained since years. This patch removes the support completely as aggreed with Wolfgang Denk. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Cc: Wolfgang Denk <wd@denx.de> Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2011-02-21Pantheon: Add Board Support for Marvell dkb boardLei Wen
DKB is a Development Board for PANTHEON TD/TTC(pxa920/pxa910) with * Processor upto 806Mhz * LPDDR1/2 * x8/x16 SLC/MLC NAND * Footprints for eMMC & MMC x8 card With Peripherals: * Parallel LCD I/F * Audio codecs (88PM8607) * MIPI CSI-2 camera * Marvell 88W8787 802.11n/BT module * Marvell 2G/3G RF * Dual analog mics & speakers, headset jack, LED, ambient * USB2.0 HS host, OTG (mini AB) * GPIO, GPIO expander with DIP switches for easier selection * UART serial over USB, CIR This patch adds basic board support with DRAM and UART functionality Signed-off-by: Lei Wen <leiwen@marvell.com> Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2011-02-21arm: Tegra2: Add support for NVIDIA Seaboard boardTom Warren
Signed-off-by: Tom Warren <twarren@nvidia.com>
