path: root/MAINTAINERS
2011-12-24tegra2: Add Avionic Design Medcom support.Thierry Reding
The Medcom is a 16:9 15" terminal that is used for patient infotainment in hospitals. Changes in v3: * Remove unused implementation of gpio_config_uart(). * Implement MMC/SD card detection. * Drop board_mmc_getcd() which is now implemented by common Tegra2 code. * Add MAINTAINERS entry. Changes in v2: * No longer override the default CONFIG_SYS_TEXT_BASE setting. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-24tegra2: Add Avionic Design Plutux support.Thierry Reding
The Plutux is a set-top box device based on the Tamonten processor module. It can be connected to a display via an HDMI output. Changes in v3: * Remove unused implementation of gpio_config_uart(). * Implement MMC/SD card detection. * Drop board_mmc_getcd() which is now implemented by common Tegra2 code. * Add MAINTAINERS entry. Changes in v2: * No longer override the default CONFIG_SYS_TEXT_BASE setting. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-24ARM: omap3: add support to Technexion twister boardStefano Babic
The twister board is a development board using the TAM3517 SOM. Support for NAND, 2 Ethernet (EMAC and SMC911), USB (EHCI_OMAP). Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Tapani Utrianen <tapani@technexion.com> CC: Tom Rini <tom.rini@gmail.com> CC: Sandeep Paulraj <s-paulraj@ti.com>
2011-12-10Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
* 'master' of git://git.denx.de/u-boot-arm: M28: Cleanup memsize.o OOT build i.MX28: Move SPL to arch/arm/cpu/arm926ejs/mx28 M28: Fix typo M28: Document that units has to be set to sectors on SD bootcard i.mx: i.mx6q: add the initial support for i.mx6q ARM2 board i.mx: mxc_gpio: add the i.mx6q support i.mx: add the initial support for freescale i.MX6Q processor i.mx: introduce the armv7/imx-common folder S5PC2XX: Rename S5pc2XX to exynos tegra2: Don't use board pointer before it is set up tegra2: Remove unneeded 'dynamic ram size' message tegra2: Remove unused low-level Tegra2 UART code tegra2: Remove unneeded config option tegra2: Remove unneeded boot code tegra2: Enable instruction cache arm: Move CP15 init out of cpu_init_crit() tegra2: Simplify tegra_start() boot path tegra2: Add arch_cpu_init() to fire up Cortex-A9 tegra2: Use new GPIO APIs in gpio_config_uart() tegra2: Add support for Ventana tegra2: Modify MMC driver to handle power and cd GPIOs tegra2: Move board_mmc_init into board files
2011-12-09i.mx: i.mx6q: add the initial support for i.mx6q ARM2 boardJason Liu
Add the initial support for Freescale i.MX6Q Armadillo2 board Support: MMC boot from slot 0/1, debug UART(UART4), usdhc. There is two MMC slots on the boards: mmc dev 0 -> connect USDHC3 -> the lower slot on the board, mmc dev 1 -> connect USDHC4 -> the upper slot on the board, Signed-off-by: Jason Liu <jason.hui@linaro.org> Cc: Stefano Babic <sbabic@denx.de> Tested-by: Dirk Behme <dirk.behme@de.bosch.com>
2011-12-09S5PC2XX: Rename S5pc2XX to exynosChander Kashyap
As per new naming convention for Samsung SoC's, all Cortex-A9 and Cortex-A15 based SoC's will be classified under the name Exynos. Cortex-A9 and Cortex-A15 based SoC's will be sub-classified as Exynos4 and Exynos5 respectively. In order to better adapt and reuse code across various upcoming Samsung Exynos based boards, all uses of s5pc210 prefix/suffix/directory-names are renamed in this patch. s5pc210 is renamed as exynos4210 and S5PC210/s5pc210 suffix/prefix are renamed as exynos4/EXYNOS4. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-12-09tegra2: Add support for VentanaStephen Warren
Ventana is a board which is very similar to Seaboard. Support it by re-using board/nvidia/seaboard/seaboard.c with minor run-time conditionals. v5: Makefile: Use cmd_link_o_target, remove unused clean/distclean targets. v6: Make gpio_config_uart_seaboard() static. v7: Add MAINTAINERS entry for Ventana. Tom Warren doesn't have Ventana, so he asked me to add myself for this board. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-09mpc85xx: Add board support for the eXMeritus HWW-1U-1A devicesKyle Moffett
The eXMeritus HWW-1U-1A unit is a DO-160-certified 13lb 1U chassis with 3 independent TEMPEST zones. Two independent P2020 computers may be found inside each zone. Complete hardware support is included. High-level hardware overview: * DO-160 certified for passenger aircraft (noncritical) * TEMPEST ceritified for RED/BLACK separation * 3 zones per chassis, 2 computers per zone (total of 6) * Dual-core 1.066GHz P2020 per computer * One 2GB DDR2 SO-RDIMM module per computer (upgradable to 4GB) * Removable 80GB or 160GB Intel X18-M SSD per computer * Front-accessible dual-port E1000E per computer * Front-accessible serial console per computer * Front-accessible USB port per computer * Internal Gigabit crossover within each TEMPEST zone * Internal unidirectional fiber links across TEMPEST zones * Battery-backed DS1339 I2C RTC on each CPU. Combined, each 13lb 1U chassis contains 12GB RAM, 12 cores @ 1.066GHz, 12 front-accessible Gigabit Ethernet ports and 960GB of solid-state storage with a total power consumption of ~200W. Additional notes: * SPD detection is only known to work with the DO-160-certified DIMMs * CPU reset is a little quirky due to hardware misfeature. Proper support for the hardware reset mechanism has been left for a later patch series to address. Signed-off-by: Kyle Moffett <Kyle.D.Moffett@boeing.com> Cc: Andy Fleming <afleming@gmail.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-12-08MPC850: remove obsolete "rmu" BoardWolfgang Denk
The "rmu" board has long been unmaintained, and is broken. Remove it. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-12-08MPC7xx: remove obsolete "BAB7xx" boardWolfgang Denk
The BAB7xx boards are almost deceased. They cause build warnings, an it's not worth the effort to fix these. Remove the dead body. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Frank Gottschling <fgottschling@eltec.de>
2011-12-06arm, davinci: add support for am1808 based enbw_cmc boardHeiko Schocher
- booting from NOR Flash with direct boot method - POST support - LOGBUF support Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Paulraj Sandeep <s-paulraj@ti.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Christian Riesch <christian.riesch@omicron.at>
2011-12-06PXA: Drop CRADLE boardMarek Vasut
The board is unmaintained and maintainer doesn't respond. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Simon Glass <sjg@chromium.org> Cc: Anatolij Gustschin <agust@denx.de>
2011-12-06PXA: Drop CERF250 boardMarek Vasut
2011-12-06Ethernut 5 board supportTim Schendekehl
Add support for the Ethernut 5 open hardware design, based on Atmel's AT91SAM9XE512 SoC. V4 - Fix several coding style issues. - Move machine type to config file. - Remove use of CONFIG_ATMEL_LEGACY. Signed-off-by: Tim Schendekehl <tim.schendekehl@egnite.de>
2011-12-06ARM: add support for LaCie 2Big Network v2Simon Guinot
This patch adds support for the LaCie 2Big Network v2 board, based on the Marvell Kirkwood 6281 SoC. Additional information is available at: http://lacie-nas.org/doku.php?id=2big_network_v2 Signed-off-by: Simon Guinot <simon.guinot@sequanux.org>
2011-12-06OMAP3: Change devkit8000 maintainerThomas Weber
Signed-off-by: Thomas Weber <weber@corscience.de>
2011-12-02sh: Add support for ecovec boardNobuhiro Iwamatsu
The ecovec board has SH7724, 256MB DDR2-SDRAM, USB, Ethernet, and more. This patch supports the following functions: - 256MB DDR2-SDRAM - USB - I2C - Ethernet Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-12-02Merge branch 'master' of git://git.denx.de/u-boot-ppc4xxWolfgang Denk
* 'master' of git://git.denx.de/u-boot-ppc4xx: ppc4xx: Add Io64 board support ppc4xx: fix PMC440 painit command ppc4xx: remove invalid access to PCI_BRDGOPT2 register ppc4xx: use CONFIG_PCI_BOOTDELAY instead of private implementation
2011-12-01ppc4xx: Add Io64 board supportDirk Eibach
Board support for the Guntermann & Drunck Io64. Signed-off-by: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Stefan Roese <sr@denx.de>
2011-11-29mpc85xx: support for Freescale COM Express P2020Ira W. Snyder
This adds support for the Freescale COM Express P2020 board. This board is similar to the P1_P2_RDB, but has some extra (as well as missing) peripherals. Unlike all other mpc85xx boards, it uses a watchdog timeout to reset. Using the HRESET_REQ register does not work. This board has no NOR flash, and can only be booted via SD or SPI. This procedure is documented in Freescale Document Number AN3659 "Booting from On-Chip ROM (eSDHC or eSPI)." Some alternative documentation is provided in Freescale Document Number P2020RM "P2020 QorIQ Integrated Processor Reference Manual" (section 4.5). Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-11-27Fix Stelian's email addressStelian Pop
Change my old email address which is no longer valid. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-11-16Orphan EVB64260_750CX boardWolfgang Denk
The last maintainer (Eran Man) cannot be reached any more. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-11-16Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
* 'master' of git://git.denx.de/u-boot-arm: arm, davinci: add DAVINCI_MMC_CLKID arm, davinci_emac: fix driver bug if more then 3 PHYs are detected arm, davinci: da850/dm365 lowlevel cleanup omap5: Add omap5_evm board build support. omap4/5: Add support for booting with CH. omap5: emif: Add emif/ddr configurations required for omap5 evm omap5: clocks: Add clocks support for omap5 platform. omap5: Add minimal support for omap5430. omap: Checkpatch fixes omap4: make omap4 code common for future reuse GCC4.6: Squash warnings in onenand_base.c GCC4.6: Fix common/usb.c on xscale OneNAND: Add simple OneNAND SPL PXA: vpac270: Enable the new generic MMC driver PXA: Cleanup serial_pxa PXA: Drop csb226 and innokom boards (unmaintained) m28evk: Fix comment about the number of RAM banks mx31: Fix checkpatch warnings in generic.c mx31: Use proper IO accessor for GPR register mx31: Remove duplicate definition for GPR register qong: Use generic function for configuring GPR register M28EVK: Enable USB HOST support iMX28: Add USB HOST driver iMX28: Add USB and USB PHY register definitions M28: Add memory detection into SPL iMX28: Fix ARM vector handling M28: Add doc/README.m28 documentation M28: Add MMC SPL iMX28: Add support for DENX M28EVK board iMX28: Add u-boot.sb target to Makefile iMX28: Add image header generator tool iMX28: Add driver for internal RTC iMX28: Add GPMI NAND driver iMX28: Add APBH DMA driver iMX28: Add SPI driver iMX28: Add GPIO control iMX28: Add I2C bus driver iMX28: Add PINMUX control FEC: Add support for iMX28 quirks iMX28: Add SSP MMC driver iMX28: Initial support for iMX28 CPU MX25: zmx25: GCC4.6 fix build warnings da850: add new config file for AM18xx BeagleBoard: config: Switch to ttyO2 OMAP3: Change omap3_evm maintainer devkit8000: Fix NAND SPL on boards with 256MB NAND integrator: enable Vpp and disable flash protection integrator: add system controller header integrator: make flash writeable on boot integrator: use io-accessors for board init integrator: move text offset to config integrator: pass configs for core modules ARM: remove superfluous setting of arch_number in board specific code. SPL: Allow ARM926EJS to avoid compiling in the CPU support code integrator: do not test first part of the memory arm: a320: fix broken timer ARM: define CONFIG_MACH_TYPE for all ronetix boards dm646x: pass board revision info to kernel dm646x: add new configuration for dm6467T arm, davinci: Fix setting of the SDRAM configuration register arm, davinci: Remove the duplication of LPSC functions arm, davinci: Rename AM1808 lowlevel functions to DA850 da8xxevm: fix build error ARM: re-add MACH_TYPE_XXXXXX for VCMA9 board and add CONFIG_MACH_TYPE
2011-11-15omap5: Add minimal support for omap5430.Sricharan
This patch adds the minimal support for OMAP5. The platform and machine specific headers and sources updated for OMAP5430. OMAP5430 is Texas Instrument's SOC based on ARM Cortex-A15 SMP architecture. It's a dual core SOC with GIC used for interrupt handling and SCU for cache coherency. Also moved some part of code from the basic platform support that can be made common for OMAP4/5. Rest is kept out seperately. The same approach is followed for clocks and emif support in the subsequent patches. Signed-off-by: sricharan <r.sricharan@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-15PXA: Drop csb226 and innokom boards (unmaintained)Marek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Robert Schwebel <robert@schwebel.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-11-11iMX28: Add support for DENX M28EVK boardMarek Vasut
This contains support for the following components: - DUART - MMC - Both FEC interfaces - NAND - I2C (RTC, EEPROM) - SPI (FLASH) Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de>
2011-11-10OMAP3: Change omap3_evm maintainerTom Rini
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Tom Rini <trini@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-10adp-ag101p: add product into MAINTAINERS listMacpaul Lin
Add ADP-AG101P into MAINTAINERS list. Add ADP-AG101P into boards.cfg. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-11-04OMAP3: mvblx: Initial support for mvBlueLYNX-XMichael Jones
Add support for the MATRIX VISION mvBlueLYNX-X, an OMAP3-based intelligent camera. Signed-off-by: Michael Jones <michael.jones@matrix-vision.de> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-03arm, davinci: add cam_enc_4xx supportHeiko Schocher
- DM368 SOC - booting with spl not with UBL from TI - before loading u-boot from NAND into RAM, test the RAM with the post memory test. If error is found, switch all LEDs on and halt system. - SPI Flash Dataflash Typ: M25PE80 - Ethernet DM9161BI - MMC - USB Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Sandeep Paulraj <s-paulraj@ti.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-03mx31: Add board support for HALE TT-01Helmut Raiger
This adds basic board support for TT-01 based on the Bluetechnix i.MX31 SOM. Currently only NOR-Flash boot is implemented. Signed-off-by: Helmut Raiger <helmut.raiger@hale.at> Acked-by: Stefano Babic <sbabic@denx.de>
2011-11-03MX35: add support for flea3 boardStefano Babic
The flea3 board is a custom board by CarMediaLab used in automotive. Network (FEC), NOR, NAND and SPI are supported. Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-10-27ARM: Add Calxeda Highbank platformRob Herring
Add basic support for Calxeda Highbank platform. Only minimal support with serial and SATA are included. Signed-off-by: Jason Hobbs <jason.hobbs@calxeda.com> Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-10-27ARM:AM33XX: Add support for TI AM335X EVMChandan Nath
This patch adds basic support for booting the board. This patch adds support for the UART necessary to get to the u-boot prompt. Signed-off-by: Chandan Nath <chandan.nath@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-10-27dreamplug: initial board support.Jason Cooper
Copied wholeheartedly from board/Marvell/guruplug and modified to add support for SPI NOR flash. CONFIG_MACH_DREAMPLUG defined in include/configs/dreamplug.h until Linus's kernel.org tree adds it to mach-types.h. Once it trickles down, the definition can be removed from include/configs/dreamplug.h. Signed-off-by: Jason Cooper <u-boot@lakedaemon.net>
2011-10-23MPC85xx: remove broken "mpq101" boardWolfgang Denk
The board stopped building some time ago, and the board maintainer agrtees to drop it - see http://article.gmane.org/gmane.comp.boot-loaders.u-boot/112674 Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Alex Dubov <oakad@yahoo.com> Cc: Andy Fleming <afleming@gmail.com> Cc: Kumar Gala <galak@kernel.crashing.org>
2011-10-22adp-ag101: add board adp-ag101 supportMacpaul Lin
Add evaluation board "adp-ag101" configuration file adp-ag101.h. Add adp-ag101.c board config and related settings. Add board adp-ag101 into boards.cfg Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-10-12MIPS: Jz4740: Add qi_lb60 board supportXiangfu Liu
Add support for the qi_lb60 (a.k.a QI Ben NanoNote) clamshell device from Qi hardware: http://en.qi-hardware.com/wiki/Ben_NanoNote http://en.qi-hardware.com/wiki/Main_Page http://en.wikipedia.org/wiki/Qi_hardware This Jz4740-based clamshell device does not use NOR flash to boot. The initial bring-up assumes that U-Boot is directly loaded into SDRAM using USB boot tool, and starts from 0x80100000. About USB boot tool ------------------- Jz4740 is one of the XBurst processors with USB boot functionality supported. The CPU can boot from a small ROM in the LSI, initialize CPU and USB module, then wait for USB commands from the USB host. We can send 8 KB binary data to the CPU cache using USB boot tool. USB boot tool is available to the public at Ingenic website. Also there is an alternative Debian package named xburst-tools. Signed-off-by: Xiangfu Liu <xiangfu@openmobilefree.net> Acked-by: Daniel <zpxu@ingenic.cn> Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2011-10-01sbc82xx: delete support for obsolete SBC8240/SBC8260Paul Gortmaker
The EST SBC8260 is over 10 years old, and the SBC8240 older than that. With the tiny amount of RAM (by today's standards), there really isn't anyone interested in running the latest U-boot on these EOL products anymore. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> CC: jon.diekema@smiths-aerospace.com
2011-10-01MAINTAINERS: delete stale entry for EOL Wind River boardsPaul Gortmaker
This e-mail address is no longer valid, and the boards are long since EOL. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-09-30EfikaMX: Add imximage config for Efika SBMarek Vasut
2011-09-30MX25: Add initial support for MX25PDKFabio Estevam
Add the initial support for MX25PDK booting from SD card via internal boot. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-09-30omap4: update maintainer for omap4 boardsAneesh V
Steve wants to transfer maintainership of OMAP4 boards to me as he is not working on these boards lately. CC: Steve Sakoman <steve@sakoman.com> CC: Sandeep Paulraj <s-paulraj@ti.com> CC: Albert Aribaud <albert.u.boot@aribaud.net> CC: Wolfgang Denk <wd@denx.de> Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-27ARM: remove broken "ixdp425" and "ixpdg425" boardsAlbert ARIBAUD
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Acked-by: Stefan Roese <sr@denx.de>
2011-09-07ARM: remove broken "shannon" board.Wolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Rolf Offermanns <rof@sysgo.de>
2011-09-07ARM: remove broken "modnet50" board.Wolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Thomas Elste <info@elste.org>
2011-09-07ARM: remove broken "lart" board.Wolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Alex Züpke <azu@sysgo.de>
2011-09-07ARM: remove broken "impa7" board.Wolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Marius Gröger <mag@sysgo.de>
2011-09-07ARM: remove broken "gcplus" board.Wolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: George G. Davis <gdavis@mvista.com>
2011-09-07ARM: remove broken "ep7312" board.Wolfgang Denk
