path: root/MAINTAINERS
2005-08-22Add esd cpci5200 and pf5200 boardsStefan Roese
Patch by Reinhard Arlt, 22 Aug 2005
2005-08-15Coding style cleanupWolfgang Denk
2005-08-15Add support for Silicon Turnkey eXpress XTc (mpc87x/88x) board.Wolfgang Denk
Patch by Dan Malek and Pantelis Antoniou, 15 Aug 2005
2005-08-15Add Sandburst Metrobox and Sandburst Karef board support packages.Stefan Roese
Second serial port on 440GX now defined as a system device. Add 'Short Etch' code for Cicada PHY within 440gx_enet.c Patch by Travis B. Sawyer, 12 Jul 2005 Check return value of malloc in 440gx_enet.c Patch by Travis B. Sawyer, 18 Jul 2005
2005-08-12Fix Murray Jensen's mail address.Wolfgang Denk
Patch by Murray Jensen, 30 Jun 2005
2005-08-12Move the AT91RM9200DK to the ARM Systems list.Wolfgang Denk
Patch by Anders Larsen, 26 Apr 2005
2005-08-06Add support for ep8248 boardWolfgang Denk
Patch by Yuli Barcohen, 12 Dec 2004 Minor code cleanup.
2005-08-03Cleanup build problems (on Fedora Core x86_64 build host)Wolfgang Denk
2005-08-03Update MAINTAINERS fileWolfgang Denk
2005-08-02Changed maintainer for all AMCC eval boards to Stefan Roese <sr@denx.de>.Stefan Roese
Patch by Stefan Roese, 2 Aug 2005
2005-08-01Major cleanup for AMCC PPC4xx eval boards.Stefan Roese
Patch by Stefan Roese, 01 Aug 2005
2005-07-04* Patch by Detlev Zundel, 30 Jun 2005:LABEL_2005_07_04_0202wdenk
Fix LCD logo for lwmon board which got lost in the merge of 8xx and PXA LCD code
2005-06-30* Patch by Stefan Roese, 30 Jun 2005:stroese
Fix PHY addresses for PPChameleon and CATcenter boards Change MAINTAINER for most esd boards
2005-05-19* Patch by Greg Ungerer, 19 May 2005:wdenk
add support for the KS8695P (ARM 922 based) CPU * Patch by Steven Scholz, 19 May 2005: Add support for CONFIG_SERIAL_TAG on ARM boards
2005-04-03* Patch by Yuli Barcohen, 08 Nov 2004:wdenk
Add support for Analogue & Micro Rattler boards. Tested on Rattler8248. * Patch by Andre Renaud, 08 Nov 2004: Fix watchdog support in common/lcd.c * Patch by Marc Leeman, 05 Nov 2003: Enable all 4 PCMBRW buffers for the MPC8245 processor since the CPU bug only affects the XPC8245 processors
2005-04-03* Patch by Yusdi Santoso, 22 Oct 2004:wdenk
- Add support for HIDDEN_DRAGON board - fix endianess problem in driver/rtl1839.c * Patch by Allen Curtis, 21 Oct 2004: support multiple serial ports
2005-01-10Coding Style cleanupwdenk
2005-01-09* Patch by Daniel Poirot, 10 Oct 2004:wdenk
Add support for Wind River sbc405 board * Patch by Rainer Brestan, 12 Oct 2004: Make examples/Makefile more robust
2005-01-09* Patches by Richard Woodruff, 01 Oct 2004:wdenk
add support for the TI OMAP2420 processor and its H4 reference board * Patch by Christian Pellegrin, 24 Sep 2004: Added support for NE2000 compatible (DP8390, DP83902) NICs.
2004-12-16some new esd boards addedstroese
2004-12-10* Clean up CMC PU2 flash driverwdenk
* Update MAINTAINERS file * Fix bug in MPC823 LCD driver
2004-10-10Patches by Scott McNutt, 24 Aug 2004:wdenk
- Add support for Altera Nios-II processors. - Add support for Psyent PCI-5441 board. - Add support for Psyent PK1C20 board.
2004-08-28Add support for IDS "NC650" boardLABEL_2004_08_29_0045wdenk
2004-07-11Add cerf250 to MAINTAINERS and READMEwdenk
2004-07-10Patches by Yasushi Shoji, 29 Jun 2004:wdenk
- add empty include/asm-microblaze/processor.h - add to CREDITS and MAINTAINERS - add gd initialization - add MicroBlaze and SUZAKU board to MAKEALL script - add reset support for SUZAKU - add flush_cache() for MicroBlaze - add CFG_FLASH_SIZE to include/configs/suzaku.h since we have fixed size flash memory on SUZAKU
2004-07-09Patch by Jon Loeliger, 17 June 2004:wdenk
Completion of the 8540ADS/8560ADS updates: Fix some PCI and Rapid I/O memory maps, Initialize both TSEC 1 and 2, Initialize SDRAM Update MAINTAINER for 85xx boards and README.mpc85xxads
2004-07-09* Patch by Yuli Barcohen, 16 Jun 2004:wdenk
Remove obsolete AdderII port which was superseded by unified AdderII/Adder87x port * Patch by Ladislav Michl, 16 Jun 2004: Fix gcc-3.3.3 warnings for smc91111.c
2004-07-01Patch by Andrea Marson, 11 Jun 2004:wdenk
Update for PPChameleon board: - support for SysClk @ 25MHz - support for Silicon Motion SM712 VGA controller - some clean ups
2004-06-24Add MicroSys maintainer.LABEL_2004_06_24_1800wdenk
2004-06-09* Patch by Yuli Barcohen, 09 Jun 2004:wdenk
Add support for Analogue&Micro Adder87x and the older AdderII board. * Patch by Ming-Len Wu, 09 Jun 2004: Add suppport for MC9328 (Dargonball) CPU and Motorola MX1ADS board
2004-06-09Patch by Yuli Barcohen, 20 May 2004:wdenk
Add support for Interphase iSPAN boards.
2004-06-09Patch by Tolunay Orkun, 14 May 2004:wdenk
Add support for Cogent CSB472 board (8MB Flash Rev)
2004-06-08* Patch by Rishi Bhattacharya, 08 May 2004:wdenk
Add support for TI OMAP5912 OSK Board * Patch by Sam Song May, 07 May 2004: Fix typo of UPM table for rmu board
2004-06-06* Patch by Dave Peverley, 30 Apr 2004:wdenk
Add support for OMAP730 Perseus2 Development board * Patch by Alan J. Luse, 29 Apr 2004: Fix flash chip-select (OR0) option register setting on FADS boards. * Patch by Alan J. Luse, 29 Apr 2004: Report MII network speed and duplex setting properly when auto-negotiate is not enabled. * Patch by Jarrett Redd, 29 Apr 2004: Fix hang on reset on Ocotea board due to flash in wrong mode.
2004-05-19Patch by Scott McNutt, 25 Apr 2004:LABEL_2004_05_19_2335wdenk
Add Nios GDB/JTAG Console support: - Add stubs to support gdb via JTAG. - Add support for console over JTAG. - Minor cleanup.
2004-04-18* Patch by John Kerl, 16 Apr 2004:wdenk
Enable ranges in mii command, e.g. mii read 0-1f 0 or mii read 4-7 18-1a. Also add mii dump subcommand for pretty-printing standard regs 0-5. * Patch by Stephen Williams, 16 April 2004: fix typo in JSE.h; update MAINTAINERS
2004-04-18* Patch by Dan Malek, 07 Apr 2004:wdenk
- Add support for RPC/STx GP3, Motorola 8560 board - Update 85xx TSEC driver so it searches MII for first available PHY and uses that one. - Add functions to support console MII commands. * Patch by Tolunay Orkun, 07 Apr 2004: Move initialization of bi_iic_fast[] from board_init_f() to board_init_r() * Patch by Yasushi Shoji, 07 Apr 2004: Cleanup microblaze port * Patch by Sangmoon Kim, 07 Apr 2004: Add auto SDRAM module detection for Debris board
2004-04-15* Patch by George G. Davis, 02 Apr 2004:wdenk
add support for Intel Assabet board
2004-04-15* Patches by Pantelis Antoniou, 30 Mar 2004:wdenk
- add auto-complete support to the U-Boot CLI - add support for NETTA and NETPHONE boards; fix NETVIA board * Patch by Yuli Barcohen, 28 Mar 2004: - Add support for MPC8272 family including MPC8247/8248/8271/8272 - Add support for MPC8272ADS evaluation board (another flavour of MPC8260ADS) - Change configuration method for MPC8260ADS family
2004-03-25* Patch by Klaus Heydeck, 13 Mar 2003:wdenk
Add support for KUP4X Board
2004-03-23* Patch by Phillippe Robin, 16 Mar 2004:wdenk
avoid dereferencing NULL pointer in lib_arm/armlinux.c * Patch by Stephen Williams, 15 Mar 2004: Fix CONFIG_SERIAL_SOFTWARE_FIFO documentation * Patch by Tolunay Orkun, 15 Mar 2004: Initialize bi_opbfreq to real OPB frequency via get_OPB_freq() * Patch by Travis Sawyer, 15 Mar 2004: Update CREDITS & MAINTAINERS files for PPC440GX & Ocotea port
2004-03-14* Patch by Stephan Linz, 09 Mar 2004wdenk
- Add support for the SSV ADNP/ESC1 (Nios Softcore) * Patch by George G. Davis, 9 Mar 2004: fix recent build failure for SA1100 target * Patch by Travis Sawyer, 09 Mar 2004: Support native interrupt mode for the IBM440GX. Previously it was running in 440GP compatibility mode.
2004-02-26* Patch by Markus Pietrek, 24 Feb 2004:wdenk
NS9750 DevBoard added * Patch by Pierre AUBERT, 24 Feb 2004 add USB support for MPC5200 * Patch by Steven Scholz, 24 Feb 2004: - fix MII commands to use values from last command * Patch by Torsten Demke, 24 Feb 2004: Add support for the eXalion platform (SPSW-8240, F-30, F-300)
2004-02-23* Patches by Reinhard Meyer, 14 Feb 2004:wdenk
- update board/emk tree; use common flash driver - Corrected tested bits in machine check exception in cpu/mpc5xxx/traps.c [adapted for other PPC CPUs -- wd] - Added support for the M48T08 on the EVAL5200 board in rtc/mk48t59.c * Patch by Jon Diekema, 13 Feb 2004: Call show_boot_progress() whenever POST "FAILED" is printed. * Patch by Nishant Kamat, 13 Feb 2004: Add support for TI OMAP1610 H2 Board Fixes for cpu/arm926ejs/interrupt.c (based on Richard Woodruff's patch for arm925, 16 Oct 03) Fix for a timer bug in OMAP1610 Innovator Add support for CS0 (ROM)/CS3 (Flash) boot in OMAP1610 Innovator and H2 * Patches by Stephan Linz, 12 Feb 2004: - add support for NIOS timer with variable period preload counter value - prepare POST framework support for NIOS targets * Patch by Denis Peter, 11 Feb 2004: add POST support for the MIP405 board
2004-01-03Patches by Stephan Linz, 11 Dec 2003:wdenk
- more documentation for NIOS port - new struct nios_pio_t, struct nios_spi_t - Reconfiguration for NIOS Development Kit DK1C20: o move board related code from board/dk1c20 to board/altera/dk1c20 o create a new common source path board/altera/common and move generic flash access stuff into it o change/expand configuration file DK1C20.h - Add support for NIOS Development Kit DK1S10 - Add status LED support for NIOS systems - Add dual 7-segment LED support for Altera NIOS DevKits
2004-01-02* Cleanup lowboot code for MPC5200wdenk
* Minor code cleanup (coding style) * Patch by Reinhard Meyer, 30 Dec 2003: - cpu/mpc5xxx/fec.c: added CONFIG_PHY_ADDR, added CONFIG_PHY_TYPE, - added CONFIG_PHY_ADDR to include/configs/IceCube.h, - turned debug print of PHY registers into a function (called in two places) - added support for EMK MPC5200 based modules * Fix MPC8xx PLPRCR_MFD_SHIFT typo * Add support for TQM866M modules * Fixes for TQM855M with 4 MB flash (Am29DL163 = _no_ mirror bit flash) * Fix a few compiler warnings
2003-12-09BUBINGA405EP added.stroese
2003-10-14* Make sure HUSH is initialized for running auto-update scriptsLABEL_2003_10_14_2140wdenk
* Make 5200 reset command _really_ reset the board, without running any other code after it * Fix flash mapping and display on P3G4 board * Patch by Kyle Harris, 15 Jul 2003: - add support for Intel IXP425 CPU - add support for IXDP425 eval board
2003-10-09* Patch by Steven Scholz, 10 Oct 2003LABEL_2003_10_09_2320wdenk
- Add support for Altera FPGA ACEX1K * Patches by Thomas Lange, 09 Oct 2003: - Endian swap ATA identity for all big endian CPUs, not just PPC - MIPS only: New option CONFIG_MEMSIZE_IN_BYTES for passing memsize args to linux - add support for dbau1x00 board (MIPS32)
