path: root/Kconfig
2020-02-04Kconfigs: layerscape: use a convenient default value for SYS_MALLOC_F_LENBiwen Li
The default value of CONFIG_SYS_MALLOC_F_LEN (0x400) leaves U-Boot with not enough memory to load i2c driver before relocate, causing it to hang. Change the default value of CONFIG_SYS_MALLOC_F_LEN for below SoCs, - LS1012A - LS1021A - LS1043A - LS1046A Signed-off-by: Biwen Li <biwen.li@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-01-17mkimage: fit: add support to encrypt image with aesPhilippe Reynes
This commit add the support of encrypting image with aes in mkimage. To enable the ciphering, a node cipher with a reference to a key and IV (Initialization Vector) must be added to the its file. Then mkimage add the encrypted image to the FIT and add the key and IV to the u-boot device tree. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com>
2020-01-14arm64: zynqmp: Add support for u-boot.itb generation with ATFMichal Simek
Follow i.MX, Sunxi, RISC-V and Rockchip to generate u-boot.itb which includes U-Boot proper, ATF and DTBs in FIT format. ZynqMP supports FIT for quite a long time but with using out of tree solution. The patch is filling this gap. Tested on zcu102, zcu104 and zcu100/Ultra96. zcu100/Ultra96 v2.2 ATF build by: make DEBUG=0 ZYNQMP_CONSOLE=cadence1 RESET_TO_BL31=1 PLAT=zynqmp bl31 Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2020-01-07spl: fit: allocate a temporary buffer to load the overlaysJean-Jacques Hiblot
If the node describing an overlay does not specify a load address, it will be loaded at the address previously used. Fixing it by allocating a temporary buffer that will be used as a default load address. By default, the size of the buffer is 64kB which should be plenty for most use cases. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-01-07spl: fit: Add support for applying DT overlayMichal Simek
doc/uImage.FIT/overlay-fdt-boot.txt is describing how to create FIT image with DT overlays in it. Add support for this feature to SPL. Here is the ZynqMP fragment where dtb points to full DT and dtbo is overlay which should be applied on the top of dtb. config { description = "ATF with full u-boot overlay"; firmware = "atf"; loadables = "uboot"; fdt = "dtb", "dtbo"; }; The whole feature depends on OF_LIBFDT_OVERLAY which is adding +4kB code and 0 for platforms which are not enabling this feature. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-12-15x86: Add an option to control the position of U-BootSimon Glass
The existing work-around for positioning U-Boot in the ROM when it actually runs from RAM still exists and there is not obvious way to change this. Add a proper Kconfig option to handle this case. This also adds a new bool property to indicate whether CONFIG_SYS_TEXT_BASE exists. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-12-06cmd: sysboot: Create a sysboot command dedicated filePatrice Chotard
Extract all sysboot command related code from pxe.c to new sysboot.c Update Kconfig to insure that DISTRO_DEFAULT select new CMD_SYSBOOT command. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2019-11-23Kconfig: Enable building of u-boot.itb on Rockchip platformKever Yang
For all the Rockchip SoCs with SPL_LOAD_FIT enable, we need to build u-boot.itb with U-Boot proper and ATF/OPTEE. All the Rockchip boards with SPL_LOAD_FIT now supports FIT generator to get ATF/OPTEE binary path from environment and pass the build even if no ATF/OPTEE binary exist, so we can enable this feature for the rockchip platform. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-11-07Kconfig add config ERR_PTR_OFFSETSimon Goldschmidt
Some U-Boot pointers have redundant information, so we can use a scheme where we can return either an error code or a pointer with the same return value. The default implementation just casts the pointer to a number, however, this may fail on platforms where the end of the address range is used for valid pointers (e.g. 0xffffff00 is a valid heap pointer in socfpga SPL). For such platforms, this value provides an upper range of those error pointer values - up to 'MAX_ERRNO' bytes below this value must be unused/invalid addresses. Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
2019-10-08Kconfig: Set default BUILD_TARGET for ARCH_MX6 with SPLStefan Roese
Use BUILD_TARGET to automatically build "u-boot-with-spl.imx" on MX6 targets with SPL. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Fabio Estevam <festevam@gmail.com> Cc: Stefano Babic <sbabic@denx.de>
2019-08-26riscv: set default FIT generator script and build target for SPL buildsLukas Auer
Now that we have a generic FIT generator script for RISC-V, set it as the default. To also build the FIT image by default, set the default build target to "u-boot.itb" if CONFIG_SPL_LOAD_FIT is enabled. Signed-off-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Anup Patel <anup.patel@wdc.com>
2019-08-24Merge tag 'u-boot-rockchip-20190823' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-rockchip - remove rk3288 fennec board - remove SPL raw image support for Rockchip SoCs - add common misc_init_r() for ethaddr from cpuid - enable USB HOST support for rk3328 - unify code for finding a valid gpt in part driver
2019-08-23Kconfigs: Various: Fix some SPL, TPL and ARM64 dependenciesAdam Ford
Several options are presenting themselves on a various boards where the options are clearly not used. (ie, arm64 options on arm9, or SPL/TPL options when SPL or TPL are not defined) This patch is not attempting to be a complete list of items, but more like low hanging fruit. This patch attempts to reduce some of the menuconfig noise by defining dependencies so they don't appear when not used. Signed-off-by: Adam Ford <aford173@gmail.com>
2019-08-23rockchip: Move config SYS_MALLOC_LEN to KconfigKever Yang
Use Kconfig for option SYS_MALLOC_LEN and default to 0x2000000. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-07-11configs: Rename CONFIG_IMAGE_FORMAT_LEGACY to CONFIG_LEGACY_IMAGE_FORMATTom Rini
The name CONFIG_LEGACY_IMAGE_FORMAT reads slightly better along with allowing us to avoid a rather nasty Kbuild/Kconfig issue down the line with CONFIG_IS_ENABLED(IMAGE_FORMAT_LEGACY). In a few places outside of cmd/ switch to using CONFIG_IS_ENABLED() to test what is set. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-06-26Kconfig: Add u-boot.itb BUILD_TARGET for RockchipJagan Teki
Add u-boot.itb BUILD_TARGET for Rockchip platform when SPL_LOAD_FIT is being used. This can get rid of building itb explicitly with 'make u-boot.itb' so, from now all required images will build just by make. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-06-17Merge branch 'master' of git://git.denx.de/u-boot-spiTom Rini
- Drop zipitz2 board (Tom) - Add DEPRECATED option (Tom) - Mark legacy or non-dm drivers as DEPRECATED (Jagan)
2019-06-14configs: Migrate CONFIG_SYS_LDSCRIPT to KconfigTom Rini
In order to migrate this symbol to Kconfig introduce a new symbol to guard it, CONFIG_SYS_CUSTOM_LDSCRIPT. When that is set we can then provide the exact final location o the script. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-06-13Kconfig: Add DEPRECATED optionTom Rini
Add a new option, CONFIG_DEPRECATED, for code that relies on deprecated functionality and has not been converted past the deadline for conversion. Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
2019-06-11imx: Use a convenient default value for SYS_MALLOC_F_LENFabio Estevam
Commit 3a7c45f6a772 ("simple-bus: add DM_FLAG_PRE_RELOC flag to simple-bus driver") causes some i.MX boards that were converted to DM, such as warp7, to fail to boot. As explained by Lukas Auer: "With the patch, U-Boot probes the drivers for devices under simple-bus device tree nodes in the pre-relocation device model. The default value of CONFIG_SYS_MALLOC_F_LEN (0x400) leaves U-Boot with not enough memory to do this, causing it to hang." Fix this problem by providing a convenient default value for CONFIG_SYS_MALLOC_F_LEN. Reported-by: Pierre-Jean Texier <pjtexier@koncepto.io> Suggested-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de> Signed-off-by: Fabio Estevam <festevam@gmail.com> Tested-by: Pierre-Jean Texier <pjtexier@koncepto.io> Tested-by: Bryan O'Donoghue <bryan.odonoghue@linaro.org> Reviewed-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de> Reviewed-by: Peng Fan <peng.fan@nxp.com> Tested-by: Heiko Schocher <hs@denx.de>
2019-05-28Kconfig: Fix SPL_LOAD_FIT descriptionMarek Vasut
Both the SPL_LOAD_FIT and SPL_LOAD_FIT_FULL have the same description. Adjust the description to make it clear which one is which. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@konsulko.com>
2019-05-26Merge branch 'master' of git://git.denx.de/u-boot-shTom Rini
- Gen3 PCIe driver + enablement on Salvator-X platforms. - Gen3 recovery SPL used to reload ATF/OpTee/U-Boot instead of minimon. - SDHI HS400 fixes ported from latest BSP and datasheet.
2019-05-23stm32mp1: Move config SYS_MALLOC_LEN to KconfigPatrick Delaunay
This patch moves the the config SYS_MALLOC_LEN to Kconfig as it is already done for zynq arch in commit 01aa5b8f0503 ("Kconfig: Move config SYS_MALLOC_LEN to Kconfig for zynq") Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-05-21ARM: rmobile: Add recovery SPL for R-Car Gen3Marek Vasut
Build an SPL which can be started via SCIF download mode on R-Car Gen3 and allows loading and executing U-Boot uImage with the next stage code. This is also useful for starting e.g. ATF BL2, which inits the hardware and returns to the U-Boot SPL, which can then load e.g. U-Boot proper. The H3, M3-W, M3-N SoCs have plenty of SRAM for storing the U-Boot SPL while the payload, e.g. ATF BL2, executes, so there is no problem here. However, E3 and D3 have much less SRAM, hence the loader uses a trick where it copies itself beyond the area used by BL2 and executes from there. That area is 32kiB large and not enough to hold U-Boot SPL, BSS, stack and malloc area, so the later two are placed at +0x4000 offset from start of SRAM, another area not used by ATF BL2. To make things even more complicated, the SCIF loader cannot load to the upper 32kiB of the SRAM directly, hence the copying approach. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2019-05-21mpc83xx: Get rid of CONFIG_83XX_CLKINMario Six
MPC83xx uses CONFIG_83XX_CLKIN instead of CONFIG_SYS_CLK_FREQ to set the system clock. To migrate the architecture, we can replace CONFIG_83XX_CLKIN with CONFIG_SYS_CLK_FREQ. To do this * replace all occurrences of CONFIG_83XX_CLKIN with CONFIG_SYS_CLK_FREQ * set CONFIG_SYS_CLK_FREQ to the old value of CONFIG_83XX_CLKIN in all MPC83xx config files Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-18Kconfig: fix FIT offset prompt textIbai Erkiaga
The current prompt text for FIT external offset is identical to SYS_TEXT_BASE which might confuse the users. Provided more accurate description for the prompt text. Signed-off-by: Ibai Erkiaga <ibai.erkiaga-elorza@xilinx.com> Reviewed-by: Marek Vasut <marex@denx.de>
2019-05-08Kconfig: Add default SPL_FIT_GENERATOR for rockchipJagan Teki
Add default SPL_FIT_GENERATOR py script for rockchip platforms if specific target enabled SPL_LOAD_FIT. So, this would help get rid of explicitly mentioning the default SPL FIT generator in defconfigs. however some targets, like puma_rk3399 still require their own FIT generator so in those cases the default will override with defconfig defined generator. Reviewed-by: Paul Kocialkowski <paul.kocialkowski@bootlin.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-04-09Makefile: Add Kconfig option CONFIG_SPL_IMAGE to select the SPL binaryStefan Roese
This patch adds the CONFIG_SPL_IMAGE option to select the SPL image that shall be used to generate the combined SPL + U-Boot image. The default value is the current value "spl/u-boot-spl.bin". This patch also sets CONFIG_SPL_IMAGE to "spl/boot.bin" for AT91 targets which use SPL NAND support (boot from NAND). For these build targets the combined image "u-boot-with-spl.bin" is now automatically generated and can be programmed into NAND as one single image (vs. SPL image and U-Boot as 2 separate images). Signed-off-by: Stefan Roese <sr@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Andreas Bießmann <andreas@biessmann.org> Cc: Eugen Hristev <eugen.hristev@microchip.com>
2019-03-21ARM: socfpga: Build sfp image only for Gen5 and Arria10 devicesDalon Westergreen
The sfp file is only valid for Gen5 (Cyclone5 & Arria5) and Arria10 devices. The file should only be built for these devices. Signed-off-by: Dalon Westergreen <dalon.westergreen@intel.com>
2019-02-11Kconfig: fix BUILD_TARGET for ARCH_MVEBUBaruch Siach
Commit dc146ca11187 ("Kconfig: Migrate CONFIG_BUILD_TARGET") made the mvebu default build target depend on CONFIG_SPL_BUILD. Unfortunately, there is no such Kconfig symbol. Use the CONFIG_SPL symbol instead to fix that. Cc: Jagan Teki <jagan@amarulasolutions.com> Signed-off-by: Baruch Siach <baruch@tkos.co.il> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com> Signed-off-by: Stefan Roese <sr@denx.de>
2019-02-02Kconfig: set default BUILD_TARGET for kirkwoodChris Packham
Now that BUILD_TARGET is in Kconfig we can define a default for boards using the Kirkwood SoC. Signed-off-by: Chris Packham <judge.packham@gmail.com> Cc: Jagan Teki <jagan@amarulasolutions.com>
2019-02-02Kconfig: Migrate CONFIG_BUILD_TARGETJagan Teki
Migrate CONFIG_BUILD_TARGET into Kconfig. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2019-01-18Kconfig: fix spellingChris Packham
Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-01-01Merge tag 'u-boot-imx-20190101' of git://www.denx.de/git/u-boot-imxTom Rini
imx for 2019.01 - introduce support for i.MX8M - fix size limit for Vhybrid / pico boards - several board fixes - w1 driver for MX2x / MX5x
2019-01-01Introduce CONFIG_FIT_EXTERNAL_OFFSETPeng Fan
Introduce CONFIG_FIT_EXTERNAL_OFFSET to give user a choice to choose where to put the external data. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2018-12-13sandbox: Increase the pre-relocation memorySimon Glass
This is close to full now, so increase it to avoid problems with adding more devices. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-12-03Merge tag 'signed-efi-next' of git://github.com/agraf/u-bootTom Rini
Patch queue for efi - 2018-12-03 This release is fully packed with lots of glorious improvements in UEFI land again! - Make PE images more standards compliant - Improve sandbox support - Improve correctness - Fix RISC-V execution on virt model - Honor board defined top of ram (fixes a few boards) - Imply DM USB access when distro boot is available - Code cleanups
2018-12-03rsa: add support of padding pssPhilippe Reynes
We add the support of the padding pss for rsa signature. This new padding is often recommended instead of pkcs-1.5. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-12-02distro: Imply USB_STORAGE when USB is availableAlexander Graf
When you support distro boot and you support USB, you usually want to also support booting from USB storage. Reflect that in the Kconfig, so that we don't have to explicitly add USB storage support to every defconfig individually. Reported-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-10-16arm64: versal: Add support for new Xilinx Versal ACAPsMichal Simek
Xilinx is introducing Versal, an adaptive compute acceleration platform (ACAP), built on 7nm FinFET process technology. Versal ACAPs combine Scalar Processing Engines, Adaptable Hardware Engines, and Intelligent Engines with leading-edge memory and interfacing technologies to deliver powerful heterogeneous acceleration for any application. The Versal AI Core series has five devices, offering 128 to 400 AI Engines. The series includes dual-core Arm Cortex™-A72 application processors, dual-core Arm Cortex-R5 real-time processors, 256KB of on-chip memory with ECC, more than 1,900 DSP engines optimized for high-precision floating point with low latency. The patch is adding necessary infrastructure in place without enabling platform which is done in separate patch. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-09-11arm: K3: Add initial support for TI's K3 generation of SoCsLokesh Vutla
Add support for Texas Instruments' K3 Generation Processor families. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-08-16Kconfig: Migrate CONFIG_NR_DRAM_BANKSRamon Fried
Move CONFIG_NR_DRAM_BANKS from headers to Kconfig. Signed-off-by: Ramon Fried <ramon.fried@gmail.com>
2018-08-06Kconfig: Move config SYS_MALLOC_LEN to Kconfig for zynqSiva Durga Prasad Paladugu
This patch moves the the config SYS_MALLOC_LEN to Kconfig. It will be just for Zynq arch and to do will be for all other archs. Signed-off-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com> Signed-off-by: Vipul Kumar <vipul.kumar@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-08-03kconfig: Replace spaces with tabsMichal Simek
Trivial Kconfig cleanup. Use tabs instead of spaces. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2018-07-30Kconfig: Sort bool, default, select and imply optionsMichal Simek
Another round of sorting Kconfig entries aplhabetically. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Alexey Brodkin <abrodkin@synopsys.com> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2018-07-10vboot: Add FIT_SIGNATURE_MAX_SIZE protectionTeddy Reed
This adds a new config value FIT_SIGNATURE_MAX_SIZE, which controls the max size of a FIT header's totalsize field. The field is checked before signature checks are applied to protect from reading past the intended FIT regions. This field is not part of the vboot signature so it should be sanity checked. If the field is corrupted then the structure or string region reads may have unintended behavior, such as reading from device memory. A default value of 256MB is set and intended to support most max storage sizes. Suggested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Teddy Reed <teddy.reed@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-05-23spl: Add full fitImage supportMarek Vasut
Add support for loading U-Boot and optionally FDT from a fitImage in SPL by using the full fitImage support from U-Boot. While we do have limited SPL loading support in SPL with a small footprint, it is missing a lot of important features, like checking signatures. This support has all the fitImage features, while the footprint is obviously larger. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Pantelis Antoniou <pantelis.antoniou@konsulko.com> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-05-23fit: Fix CONFIG_FIT_SPL_PRINTMarek Vasut
Rename CONFIG_FIT_SPL_PRINT to CONFIG_SPL_FIT_PRINT and add Kconfig entry for it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Pantelis Antoniou <pantelis.antoniou@konsulko.com> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-05-06Kconfig: Add dependency on HASH to verified bootKelvin Cheung
Building with verified boot support requires hash, add that dependency here. Otherwise the following build error will come out without crc command. LD u-boot lib/built-in.o: In function `hash_calculate': lib/rsa/rsa-checksum.c:29: undefined reference to `hash_progressive_lookup_algo' ... make[1]: *** [u-boot] Error 1 Signed-off-by: Kelvin Cheung <keguang.zhang@gmail.com> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2018-04-28distro: select CMD_ENV_EXISTSMasahiro Yamada
'env exists' is used for scripting in include/config_distro_bootcmd.h This command is available only when CONFIG_CMD_ENV_EXISTS is enabled. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Alexander Graf <agraf@suse.de>
