path: root/Kconfig
2019-07-11configs: Rename CONFIG_IMAGE_FORMAT_LEGACY to CONFIG_LEGACY_IMAGE_FORMATTom Rini
The name CONFIG_LEGACY_IMAGE_FORMAT reads slightly better along with allowing us to avoid a rather nasty Kbuild/Kconfig issue down the line with CONFIG_IS_ENABLED(IMAGE_FORMAT_LEGACY). In a few places outside of cmd/ switch to using CONFIG_IS_ENABLED() to test what is set. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-06-26Kconfig: Add u-boot.itb BUILD_TARGET for RockchipJagan Teki
Add u-boot.itb BUILD_TARGET for Rockchip platform when SPL_LOAD_FIT is being used. This can get rid of building itb explicitly with 'make u-boot.itb' so, from now all required images will build just by make. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-06-17Merge branch 'master' of git://git.denx.de/u-boot-spiTom Rini
- Drop zipitz2 board (Tom) - Add DEPRECATED option (Tom) - Mark legacy or non-dm drivers as DEPRECATED (Jagan)
2019-06-14configs: Migrate CONFIG_SYS_LDSCRIPT to KconfigTom Rini
In order to migrate this symbol to Kconfig introduce a new symbol to guard it, CONFIG_SYS_CUSTOM_LDSCRIPT. When that is set we can then provide the exact final location o the script. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-06-13Kconfig: Add DEPRECATED optionTom Rini
Add a new option, CONFIG_DEPRECATED, for code that relies on deprecated functionality and has not been converted past the deadline for conversion. Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
2019-06-11imx: Use a convenient default value for SYS_MALLOC_F_LENFabio Estevam
Commit 3a7c45f6a772 ("simple-bus: add DM_FLAG_PRE_RELOC flag to simple-bus driver") causes some i.MX boards that were converted to DM, such as warp7, to fail to boot. As explained by Lukas Auer: "With the patch, U-Boot probes the drivers for devices under simple-bus device tree nodes in the pre-relocation device model. The default value of CONFIG_SYS_MALLOC_F_LEN (0x400) leaves U-Boot with not enough memory to do this, causing it to hang." Fix this problem by providing a convenient default value for CONFIG_SYS_MALLOC_F_LEN. Reported-by: Pierre-Jean Texier <pjtexier@koncepto.io> Suggested-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de> Signed-off-by: Fabio Estevam <festevam@gmail.com> Tested-by: Pierre-Jean Texier <pjtexier@koncepto.io> Tested-by: Bryan O'Donoghue <bryan.odonoghue@linaro.org> Reviewed-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de> Reviewed-by: Peng Fan <peng.fan@nxp.com> Tested-by: Heiko Schocher <hs@denx.de>
2019-05-28Kconfig: Fix SPL_LOAD_FIT descriptionMarek Vasut
Both the SPL_LOAD_FIT and SPL_LOAD_FIT_FULL have the same description. Adjust the description to make it clear which one is which. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@konsulko.com>
2019-05-26Merge branch 'master' of git://git.denx.de/u-boot-shTom Rini
- Gen3 PCIe driver + enablement on Salvator-X platforms. - Gen3 recovery SPL used to reload ATF/OpTee/U-Boot instead of minimon. - SDHI HS400 fixes ported from latest BSP and datasheet.
2019-05-23stm32mp1: Move config SYS_MALLOC_LEN to KconfigPatrick Delaunay
This patch moves the the config SYS_MALLOC_LEN to Kconfig as it is already done for zynq arch in commit 01aa5b8f0503 ("Kconfig: Move config SYS_MALLOC_LEN to Kconfig for zynq") Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2019-05-21ARM: rmobile: Add recovery SPL for R-Car Gen3Marek Vasut
Build an SPL which can be started via SCIF download mode on R-Car Gen3 and allows loading and executing U-Boot uImage with the next stage code. This is also useful for starting e.g. ATF BL2, which inits the hardware and returns to the U-Boot SPL, which can then load e.g. U-Boot proper. The H3, M3-W, M3-N SoCs have plenty of SRAM for storing the U-Boot SPL while the payload, e.g. ATF BL2, executes, so there is no problem here. However, E3 and D3 have much less SRAM, hence the loader uses a trick where it copies itself beyond the area used by BL2 and executes from there. That area is 32kiB large and not enough to hold U-Boot SPL, BSS, stack and malloc area, so the later two are placed at +0x4000 offset from start of SRAM, another area not used by ATF BL2. To make things even more complicated, the SCIF loader cannot load to the upper 32kiB of the SRAM directly, hence the copying approach. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2019-05-21mpc83xx: Get rid of CONFIG_83XX_CLKINMario Six
MPC83xx uses CONFIG_83XX_CLKIN instead of CONFIG_SYS_CLK_FREQ to set the system clock. To migrate the architecture, we can replace CONFIG_83XX_CLKIN with CONFIG_SYS_CLK_FREQ. To do this * replace all occurrences of CONFIG_83XX_CLKIN with CONFIG_SYS_CLK_FREQ * set CONFIG_SYS_CLK_FREQ to the old value of CONFIG_83XX_CLKIN in all MPC83xx config files Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-18Kconfig: fix FIT offset prompt textIbai Erkiaga
The current prompt text for FIT external offset is identical to SYS_TEXT_BASE which might confuse the users. Provided more accurate description for the prompt text. Signed-off-by: Ibai Erkiaga <ibai.erkiaga-elorza@xilinx.com> Reviewed-by: Marek Vasut <marex@denx.de>
2019-05-08Kconfig: Add default SPL_FIT_GENERATOR for rockchipJagan Teki
Add default SPL_FIT_GENERATOR py script for rockchip platforms if specific target enabled SPL_LOAD_FIT. So, this would help get rid of explicitly mentioning the default SPL FIT generator in defconfigs. however some targets, like puma_rk3399 still require their own FIT generator so in those cases the default will override with defconfig defined generator. Reviewed-by: Paul Kocialkowski <paul.kocialkowski@bootlin.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-04-09Makefile: Add Kconfig option CONFIG_SPL_IMAGE to select the SPL binaryStefan Roese
This patch adds the CONFIG_SPL_IMAGE option to select the SPL image that shall be used to generate the combined SPL + U-Boot image. The default value is the current value "spl/u-boot-spl.bin". This patch also sets CONFIG_SPL_IMAGE to "spl/boot.bin" for AT91 targets which use SPL NAND support (boot from NAND). For these build targets the combined image "u-boot-with-spl.bin" is now automatically generated and can be programmed into NAND as one single image (vs. SPL image and U-Boot as 2 separate images). Signed-off-by: Stefan Roese <sr@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Andreas Bießmann <andreas@biessmann.org> Cc: Eugen Hristev <eugen.hristev@microchip.com>
2019-03-21ARM: socfpga: Build sfp image only for Gen5 and Arria10 devicesDalon Westergreen
The sfp file is only valid for Gen5 (Cyclone5 & Arria5) and Arria10 devices. The file should only be built for these devices. Signed-off-by: Dalon Westergreen <dalon.westergreen@intel.com>
2019-02-11Kconfig: fix BUILD_TARGET for ARCH_MVEBUBaruch Siach
Commit dc146ca11187 ("Kconfig: Migrate CONFIG_BUILD_TARGET") made the mvebu default build target depend on CONFIG_SPL_BUILD. Unfortunately, there is no such Kconfig symbol. Use the CONFIG_SPL symbol instead to fix that. Cc: Jagan Teki <jagan@amarulasolutions.com> Signed-off-by: Baruch Siach <baruch@tkos.co.il> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com> Signed-off-by: Stefan Roese <sr@denx.de>
2019-02-02Kconfig: set default BUILD_TARGET for kirkwoodChris Packham
Now that BUILD_TARGET is in Kconfig we can define a default for boards using the Kirkwood SoC. Signed-off-by: Chris Packham <judge.packham@gmail.com> Cc: Jagan Teki <jagan@amarulasolutions.com>
2019-02-02Kconfig: Migrate CONFIG_BUILD_TARGETJagan Teki
Migrate CONFIG_BUILD_TARGET into Kconfig. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2019-01-18Kconfig: fix spellingChris Packham
Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-01-01Merge tag 'u-boot-imx-20190101' of git://www.denx.de/git/u-boot-imxTom Rini
imx for 2019.01 - introduce support for i.MX8M - fix size limit for Vhybrid / pico boards - several board fixes - w1 driver for MX2x / MX5x
2019-01-01Introduce CONFIG_FIT_EXTERNAL_OFFSETPeng Fan
Introduce CONFIG_FIT_EXTERNAL_OFFSET to give user a choice to choose where to put the external data. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2018-12-13sandbox: Increase the pre-relocation memorySimon Glass
This is close to full now, so increase it to avoid problems with adding more devices. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-12-03Merge tag 'signed-efi-next' of git://github.com/agraf/u-bootTom Rini
Patch queue for efi - 2018-12-03 This release is fully packed with lots of glorious improvements in UEFI land again! - Make PE images more standards compliant - Improve sandbox support - Improve correctness - Fix RISC-V execution on virt model - Honor board defined top of ram (fixes a few boards) - Imply DM USB access when distro boot is available - Code cleanups
2018-12-03rsa: add support of padding pssPhilippe Reynes
We add the support of the padding pss for rsa signature. This new padding is often recommended instead of pkcs-1.5. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-12-02distro: Imply USB_STORAGE when USB is availableAlexander Graf
When you support distro boot and you support USB, you usually want to also support booting from USB storage. Reflect that in the Kconfig, so that we don't have to explicitly add USB storage support to every defconfig individually. Reported-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-10-16arm64: versal: Add support for new Xilinx Versal ACAPsMichal Simek
Xilinx is introducing Versal, an adaptive compute acceleration platform (ACAP), built on 7nm FinFET process technology. Versal ACAPs combine Scalar Processing Engines, Adaptable Hardware Engines, and Intelligent Engines with leading-edge memory and interfacing technologies to deliver powerful heterogeneous acceleration for any application. The Versal AI Core series has five devices, offering 128 to 400 AI Engines. The series includes dual-core Arm Cortex™-A72 application processors, dual-core Arm Cortex-R5 real-time processors, 256KB of on-chip memory with ECC, more than 1,900 DSP engines optimized for high-precision floating point with low latency. The patch is adding necessary infrastructure in place without enabling platform which is done in separate patch. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-09-11arm: K3: Add initial support for TI's K3 generation of SoCsLokesh Vutla
Add support for Texas Instruments' K3 Generation Processor families. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-08-16Kconfig: Migrate CONFIG_NR_DRAM_BANKSRamon Fried
Move CONFIG_NR_DRAM_BANKS from headers to Kconfig. Signed-off-by: Ramon Fried <ramon.fried@gmail.com>
2018-08-06Kconfig: Move config SYS_MALLOC_LEN to Kconfig for zynqSiva Durga Prasad Paladugu
This patch moves the the config SYS_MALLOC_LEN to Kconfig. It will be just for Zynq arch and to do will be for all other archs. Signed-off-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com> Signed-off-by: Vipul Kumar <vipul.kumar@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-08-03kconfig: Replace spaces with tabsMichal Simek
Trivial Kconfig cleanup. Use tabs instead of spaces. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2018-07-30Kconfig: Sort bool, default, select and imply optionsMichal Simek
Another round of sorting Kconfig entries aplhabetically. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Alexey Brodkin <abrodkin@synopsys.com> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2018-07-10vboot: Add FIT_SIGNATURE_MAX_SIZE protectionTeddy Reed
This adds a new config value FIT_SIGNATURE_MAX_SIZE, which controls the max size of a FIT header's totalsize field. The field is checked before signature checks are applied to protect from reading past the intended FIT regions. This field is not part of the vboot signature so it should be sanity checked. If the field is corrupted then the structure or string region reads may have unintended behavior, such as reading from device memory. A default value of 256MB is set and intended to support most max storage sizes. Suggested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Teddy Reed <teddy.reed@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-05-23spl: Add full fitImage supportMarek Vasut
Add support for loading U-Boot and optionally FDT from a fitImage in SPL by using the full fitImage support from U-Boot. While we do have limited SPL loading support in SPL with a small footprint, it is missing a lot of important features, like checking signatures. This support has all the fitImage features, while the footprint is obviously larger. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Pantelis Antoniou <pantelis.antoniou@konsulko.com> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-05-23fit: Fix CONFIG_FIT_SPL_PRINTMarek Vasut
Rename CONFIG_FIT_SPL_PRINT to CONFIG_SPL_FIT_PRINT and add Kconfig entry for it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Pantelis Antoniou <pantelis.antoniou@konsulko.com> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-05-06Kconfig: Add dependency on HASH to verified bootKelvin Cheung
Building with verified boot support requires hash, add that dependency here. Otherwise the following build error will come out without crc command. LD u-boot lib/built-in.o: In function `hash_calculate': lib/rsa/rsa-checksum.c:29: undefined reference to `hash_progressive_lookup_algo' ... make[1]: *** [u-boot] Error 1 Signed-off-by: Kelvin Cheung <keguang.zhang@gmail.com> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2018-04-28distro: select CMD_ENV_EXISTSMasahiro Yamada
'env exists' is used for scripting in include/config_distro_bootcmd.h This command is available only when CONFIG_CMD_ENV_EXISTS is enabled. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Alexander Graf <agraf@suse.de>
2018-04-28distro: use imply to enable DISTRO_DEFAULTS as SoC defaultMasahiro Yamada
The default of DISTRO_DEFAULTS is messy. Using the 'imply' keyword is equivalent and cleaner. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-04-28Migrate IMAGE_FORMAT_LEGACY to KconfigAlex Kiernan
This converts IMAGE_FORMAT_LEGACY to Kconfig Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-04-16Kconfig: Enlarge default SYS_MALLOC_F_LEN for AM33XXSjoerd Simons
Since commit 8e14ba7bd524 ("gpio: omap_gpio: Add DM_FLAG_PRE_RELOC flag") omap GPIO gets bound before relocation. Unfortunately due to this, on at least the beaglebone black, the pre-relocation memory pool gets exhausted before probing the serial port. This then causes u-boot to panic as CONFIG_REQUIRE_SERIAL_CONSOLE is set... Resolve this by resizing the default size of the pre-relocation malloc pool for AM335X platforms. Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
2018-04-15Merge git://git.denx.de/u-boot-netTom Rini
2018-04-13Revert "Kconfig: cmd: Make networking command dependent on NET"Joe Hershberger
This reverts the parts of commit 3b3ea2c56ec4bc5588281fd103c744e608f8b25c where it changed the EFI dependency on NET. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Duncan Hare <dh@synoia.com>
2018-04-13net: Make the BOOTP options defaultJoe Hershberger
The BOOTP options used to be and should still be default for all boards with CMD_NET enabled. One should not be forced to use DISTRO_DEFAULTS to get them. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Duncan Hare <dh@synoia.com>
2018-04-13net: Fix distro default dependenciesJoe Hershberger
PING requires CMD_NET, not NET. Also, CMD_NET already depends on NET, so no need to directly depend on it. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2018-04-13kconfig: add CONFIG_CC_COVERAGEChristian Gmeiner
Make it possible to use gcc code coverage analysis. v1 -> v2: - Kconfig: remove not needed 'default n' - Makefile: use consistent spacing Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-03-14sunxi: move CONFIG_SYS_TEXT_BASE out of defconfigsAndre Przywara
Commit 278b90ce786f ("configs: Migrate CONFIG_SYS_TEXT_BASE") made CONFIG_SYS_TEXT_BASE a proper Kconfig variable, with the consequence of moving the common definition shared by almost every sunxi board into 123 individual defconfig files. But the U-Boot start address for Allwinner boards is a platform decision which has been around for ages, so defining it in each *board* config file seems a bit over the top. Define the standard values (160MB into DRAM for most SoCs, with two SoC exceptions) if ARCH_SUNXI is selected, and delete the lines from the individual defconfigs. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2018-02-27Kconfig: cmd: Make networking command dependent on NETMichal Simek
Enable networking command only when NET is enabled. And remove selecting NET for CMD_NET Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-23configs: Re-sync with CONFIG_DISTRO_DEFAULTSTom Rini
A number of platforms include config_distro_defaults.h but do not enable CONFIG_DISTRO_DEFAULTS. As they plainly intended to, set that flag and re-sync config files. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-08Kconfig: Select networking commands only when NET is enabledMichal Simek
There is no reason to unconditially select network commands as distro defaults without networking enable. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
