path: root/Kconfig
2014-10-27kconfig: add CONFIG_SUPPORT_TPLMasahiro Yamada
CONFIG_TPL should not be enabled for boards that do not have TPL. CONFIG_SUPPORT_TPL introduced by this commit should be "select"ed by boards with TPL support and CONFIG_TPL should depend on it. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-10-27kconfig: add CONFIG_SUPPORT_SPLMasahiro Yamada
CONFIG_SPL should not be enabled for boards that do not have SPL. CONFIG_SUPPORT_SPL introduced by this commit should be "select"ed by boards with SPL support and CONFIG_SPL should depend on it. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-09-25kconfig: move CONFIG_OF_* to KconfigMasahiro Yamada
This commit moves: CONFIG_OF_CONTROL CONFIG_OF_SEPARATE CONFIG_OF_EMBED CONFIG_OF_HOSTFILE Because these options are currently not supported for SPL, the "Device Tree Control" menu does not appear in the SPL configuration. Note: zynq-common.h should be adjusted so as not to change the default value of CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@nvidia.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Acked-by: Michal Simek <michal.simek@xilinx.com>
2014-09-24kconfig: add blank Kconfig filesMasahiro Yamada
This would be useful to start moving various config options. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-08-28kconfig: add CONFIG_CC_OPTIMIZE_FOR_SIZEMasahiro Yamada
Copy the Kconfig option from "init/Kconfig" of Linux v3.16 tag and adjust the help document. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-08-28kconfig: add CONFIG_LOCALVERSION and CONFIG_LOCALVERSION_AUTOMasahiro Yamada
Copy Kconfig options from "init/Kconfig" of Linux v3.16 tag and adjust some parts of the help document. Move CONFIG_SPL, CONFIG_TPL, ... etc. to "Boot images" menu. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-08-21kconfig: remove DEFCONFIG_LISTMasahiro Yamada
CONFIG_DEFCONFIG_LIST specifies the default defconfig. It is used by "make savedefconfig" when .config is missing. But that's it. I could not find other useful cases. As a side effect, CONFIG_DEFCONFIG_LIST="configs/sandbox_defconfig" is contained in .config of every target board, which some people think is odd. So, let's remove it. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Michal Simek <michal.simek@xilinx.com> Acked-by: Michal Simek <michal.simek@xilinx.com>
2014-07-30kconfig: add basic Kconfig filesMasahiro Yamada
This commit adds more Kconfig files, which were written by hand. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
