path: root/Kconfig
2017-07-27spl: make SPL and normal u-boot stage use independent SYS_MALLOC_F_LENAndy Yan
Some platforms have very limited SRAM to run SPL code, so there may not be the same amount space for a malloc pool before relocation in the SPL stage as the normal U-Boot stage. Make SPL and (the full) U-Boot stage use independent SYS_MALLOC_F_LEN, so the size of pre-relocation malloc pool can be configured memory space independently. Signed-off-by: Andy Yan <andy.yan@rock-chips.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> [fixed up commit-message:] Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-05-22Merge git://git.denx.de/u-boot-sunxiTom Rini
trini: Make Kconfig SPL_xxx entires only show if SPL, so that we don't get Kconfig errors on platforms without SPL, ie sandbox (without SPL). Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-22lib: move hash CONFIG options to KconfigTom Rini
Commit 94e3c8c4fd7b ("crypto/fsl - Add progressive hashing support using hardware acceleration.") created entries for CONFIG_SHA1, CONFIG_SHA256, CONFIG_SHA_HW_ACCEL, and CONFIG_SHA_PROG_HW_ACCEL. However, no defconfig has migrated to it. Complete the move by first adding additional logic to various Kconfig files to select this when required and then use the moveconfig tool. In many cases we can select these because they are required to implement other drivers. We also correct how we include the various hashing algorithms in SPL. This commit was generated as follows (after Kconfig additions): [1] tools/moveconfig.py -y SHA1 SHA256 SHA_HW_ACCEL [2] tools/moveconfig.py -y SHA_PROG_HW_ACCEL Note: We cannot move SHA_HW_ACCEL and SHA_PROG_HW_ACCEL simultaneously because there is dependency between them. Cc: Poonam Aggrwal <poonam.aggrwal@freescale.com> Cc: Naveen Burmi <NaveenBurmi@freescale.com> Cc: Po Liu <po.liu@freescale.com> Cc: Shengzhou Liu <Shengzhou.Liu@freescale.com> Cc: Priyanka Jain <Priyanka.Jain@freescale.com> Cc: Shaohui Xie <Shaohui.Xie@freescale.com> Cc: Chunhe Lan <Chunhe.Lan@freescale.com> Cc: Chander Kashyap <k.chander@samsung.com> Cc: Steve Rae <steve.rae@raedomain.com> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Feng Li <feng.li_2@nxp.com> Cc: Alison Wang <alison.wang@freescale.com> Cc: Sumit Garg <sumit.garg@nxp.com> Cc: Mingkai Hu <Mingkai.Hu@freescale.com> Cc: York Sun <york.sun@nxp.com> Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Cc: Jaehoon Chung <jh80.chung@samsung.com> Cc: Akshay Saraswat <akshay.s@samsung.com> Cc: Heiko Schocher <hs@denx.de> Cc: Jagan Teki <jagan@amarulasolutions.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-22FIT: Rename FIT_DISABLE_SHA256 to FIT_ENABLE_SHA256_SUPPORTTom Rini
We rename CONFIG_FIT_DISABLE_SHA256 to CONFIG_FIT_ENABLE_SHA256_SUPPORT which is enabled by default and now a positive option. Convert the handful of boards that were disabling it before to save space. Cc: Dirk Eibach <eibach@gdsys.de> Cc: Lukasz Dalek <luk0104@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-17sunxi: enable automatic FIT build for 64-bit SoCsAndre Przywara
The Allwinner SoCs with 64-bit cores use an ARM Trusted Firmware binary, which needs to be loaded alongside U-Boot proper. Set the respective Kconfig options to let them select this feature and also automatically build the FIT image. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> [Rename Kconfig path to arch/arm/mach-sunxi/Kconfig] Signed-off-by: Jagan Teki <jagan@openedev.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-05-17Makefile: add rules to generate SPL FIT imagesAndre Przywara
Some platforms require more complex U-Boot images than we can easily generate via the mkimage command line, for instance to load additional image files. Introduce a CONFIG_SPL_FIT_SOURCE and CONFIG_SPL_FIT_GENERATOR symbol, which can either hold an .its source file describing the image layout, or, in the second case, a generator tool (script) to create such a source file. This script gets passed the list of device tree files from the CONFIG_OF_LIST variable. A platform or board can define either of those in their defconfig file to allow an easy building of such an image. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-05-17Kconfig: fix SPL_FIT dependencyAndre Przywara
SPL_FIT obviously requires libfdt in SPL, so let Kconfig express that by selecting SPL_OF_LIBFDT. Also make the actual options that users want (SPL signature and SPL FIT loading) visible in the menu and let them select the SPL_FIT as a requirement. Also remove the now redundant SPL_OF_LIBFDT from those Kconfigs that had it in for the SPL FIT loading feature. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Simon Glass <sjg@chromium.org> [Remove change from configs/evb-rk3399_defconfig] Signed-off-by: Jagan Teki <jagan@openedev.com>
2017-04-08Kconfig: Adds SYS_TEXT_BASE config option for Keystone2Madan Srinivas
This patch makes SYS_TEXT_BASE a config option for Keystone2 so that it can be used to load u-boot at different addresses on secure and non-secure Keystone2 devices. Signed-off-by: Madan Srinivas <madans@ti.com> Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2017-04-05SPARC: RemoveTom Rini
The SPARC architecture is currently unmaintained, remove. Cc: Francois Retief <fgretief@spaceteq.co.za> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-03-17Kconfig: define MD5 dependency for FIT supportAndre Przywara
FIT images require MD5 support to verify image checksums. So far this was expressed by defining a CPP symbol in image.h. Since MD5 is now a first class Kconfig citizen, express that in Kconfig instead. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-02-08kconfig: Add API kconfig fileEmmanuel Vadot
Add kconfig file to enable API support Signed-off-by: Emmanuel Vadot <manu@bidouilliste.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-02-08cmd: add a new command "config" to show .config contentsMasahiro Yamada
This feature is inspired by /proc/config.gz of Linux. In Linux, if CONFIG_IKCONFIG is enabled, the ".config" file contents are embedded in the kernel image. If CONFIG_IKCONFIG_PROC is also enabled, the ".config" contents are exposed to /proc/config.gz. Users can do "zcat /proc/config.gz" to check which config options are enabled on the running kernel image. The idea is almost the same here; if CONFIG_CMD_CONFIG is enabled, the ".config" contents are compressed and saved in the U-Boot image, then printed by the new command "config". The usage is quite simple. Enable CONFIG_CMD_CONFIG, then run > config from the command line interface. The ".config" contents will be printed on the console. This feature increases the U-Boot image size by about 4KB (this is mostly due to the gzip-compressed .config file). By default, it is enabled only for Sandbox because we do not care about the memory footprint on it. Of course, this feature is architecture agnostic, so you can enable it on any board if the image size increase is acceptable for you. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-01-28disk: convert CONFIG_PARTITIONS to KconfigPatrick Delaunay
2017-01-20odroid-c2: Enable distro bootAndreas Färber
Use the generic "distro" boot framework to enable automatic DHCP boot. MMC and USB are not yet implemented, so this is the only boot option. The fdt and kernel addresses are adopted from downstream; ramdisk and scriptaddr addresses were chosen arbitrarily. Signed-off-by: Andreas Färber <afaerber@suse.de> Reviewed-by: Alexander Graf <agraf@suse.de>
2017-01-14Kconfig: Refactoring of top-level Kconfig fileRobert P. J. Day
Some refactoring of the top-level Kconfig file which includes: * using "if" to remove numerous identical dependency tests * reordering config entries to group related ones * spelling and grammar fixes There should be no functional changes, only aesthetic ones. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2017-01-11Enable DISTRO_DEFAULTS for Rockchip platformsRomain Perier
This enables suitable commands needed for booting general purpose Linux distribution. This is required for example if we want to use PXE or DHCP as default boot targets, symbols no longer enabled by config_distro_defaults.h . Signed-off-by: Romain Perier <romain.perier@collabora.com>
2017-01-10ARM: zynq: Move CONFIG_SYS_TEXT_BASE to KconfigMichal Simek
Enable CONFIG_SYS_TEXT_BASE via Kconfig. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-12-03Merge branch 'master' of git://www.denx.de/git/u-boot-dmTom Rini
2016-12-03cmd: move CMD_PXE to KconfigYann E. MORIN
Currently, CMD_PXE is forcibly enabled in config_distro_defaults.h, so that general purpose distributions can rely on it being defined. This header is included, under conditions or not, by various archs or famillies of archs / SoCs. However, it is very possible that boards based on those SoCs will not have a physical ethernet connector at all, even if the have a MAC; for example, the Nanopi Neo AIR (sunxi H3) does not. It is also possible that network booting is absolutely not necessary for a device. However, it is not possible to disable the PXE command, as it is forcibly enabled and is non-configurable. But it turns out we already have a config option to build a distro-ready image, in the name of DISTRO_DEFAULTS. Move CMD_PXE out of the hard-coded config_distro_defaults.h into a Kconfig option, that gets selected by DISTRO_DEFAULTS when it is set. Signed-off-by: "Yann E. MORIN" <yann.morin.1998@free.fr> Cc: Joe Hershberger <joe.hershberger@ni.com> [trini: Make it select MENU, run moveconfig.py] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-12-03Enable DISTRO_DEFAULT on platforms that missed it beforeTom Rini
A number of platforms had been using the distro default feature before it was moved to Kconfig but did not enable the new Kconfig option when it was enabled. This caused a regression in terms of features and this introduces breakage when more things move to Kconfig. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-12-02libfdt: replace ARCH_FIXUP_FDT with ARCH_FIXUP_FDT_MEMORYMasahiro Yamada
Commit e2f88dfd2d96 ("libfdt: Introduce new ARCH_FIXUP_FDT option") allows us to skip memory setup of DTB, but a problem for ARM is that spin_table_update_dt() and psci_update_dt() are skipped as well if CONFIG_ARCH_FIXUP_FDT is disabled. This commit allows us to skip only fdt_fixup_memory_banks() instead of the whole of arch_fixup_fdt(). It will be useful when we want to use a memory node from a kernel DTB as is, but need some fixups for Spin-Table/PSCI. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Alexey Brodkin <abrodkin@synopsys.com> Acked-by: Simon Glass <sjg@chromium.org> Fixed build error for x86: Signed-off-by: Simon Glass <sjg@chromium.org>
2016-11-28spl: dfu: move DFU Kconfig to SPL KconfigStefan Agner
The DFU Kconfig menu entries should be part of the SPL Kconfig file. Also avoid using the top level Makefile by moving the config dependent build artifacts to the driver/ and driver/usb/gadget/ Makfiles. With that, DFU can be built again in SPL if CONFIG_SPL_DFU_SUPPORT is enabled. Fixes: 6ad6102246d8 ("usb:gadget: Disallow DFU in SPL for now") Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Lukasz Majewski <l.majewski@samsung.com>
2016-11-17ls2080ardb: Convert to distro bootAlexander Graf
Most new systems in U-Boot these days make use of the generic "distro" framework which allows a user to have U-Boot scan for a bootable OS on all available media types. This patch extends the LS2080ARDB board to use that framework if the hard coded NOR flash location does not contain a bootable image. Signed-off-by: Alexander Graf <agraf@suse.de>
2016-09-27spl: dfu: add dfu support in SPLB, Ravi
Traditionally the DFU support is available only as part 2nd stage boot loader(u-boot) and DFU is not supported in SPL. The SPL-DFU feature is useful for boards which does not have MMC/SD, ethernet boot mechanism to boot the board and only has USB inteface. This patch add DFU support in SPL with RAM memory device support to load and execute u-boot. And then leverage full functionality DFU in u-boot to flash boot inital binary images to factory or bare-metal boards to memory devices like SPI, eMMC, MMC/SD card using USB interface. This SPL-DFU support can be enabled through Menuconfig->Boot Images->Enable SPL-DFU support Signed-off-by: Ravi Babu <ravibabu@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-19Revert "Increase default of CONFIG_SYS_MALLOC_F_LEN for SPL_OF_CONTROL"Masahiro Yamada
This reverts commit 90c08d9e08c7a108ab904f3bbdeb558081757892. I took a closer look at this after the commit was applied, and found CONFIG_SYS_MALLOC_F_LEN=0x2000 was too much. 8KB memory for SPL is actually too big for some boards. Perhaps 0x800 is enough, but the situation varies board by board. Let's postpone our decision until we come up with a better idea. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-09-07Increase default of CONFIG_SYS_MALLOC_F_LEN for SPL_OF_CONTROLMasahiro Yamada
If both SPL_DM and SPL_OF_CONTROL are enabled, SPL needs to bind several devices, but CONFIG_SYS_MALLOC_F_LEN=0x400 is apparently not enough. Increase the default to 0x2000 for the case. This will be helpful for shorter defconfigs. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-08-20Kconfig: DISTRO_DEFAULTS: Only enable CMD_BOOTZ for ARMTom Rini
The 'bootz' command is really only for ARM32 Linux Kernel 'zImage' files but has also been adapted for testing with sandbox. Given that sandbox is a test platform, don't add that logic under DISTRO_DEFAULTS. Cc: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2016-08-20cmd: booti: move CONFIG_CMD_BOOTI to KconfigMasahiro Yamada
This command is used to boot ARM64 Linux. I made DISTRO_DEFAULTS select this option for ARM64 to respect include/config_distro_defaults.h. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2016-08-12common: image: Add support for post-processing of imagesAndreas Dannenberg
This commit allows injecting a board/platform/device-specific post- processing function into the FIT image data loading process, which can include modifying the size and altering the starting source address of an image data artifact. This might be desired to do things like strip headers or footers attached to the images before they were packaged into the FIT, or to perform operations such as decryption or authentication. Introduce new configuration option CONFIG_FIT_IMAGE_POST_PROCESS to allow controlling this feature. If enabled, a platform-specific post- process function must be provided. Signed-off-by: Andreas Dannenberg <dannenberg@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-08-05treewide: move CONFIG_PHYS_64BIT to KconfigMasahiro Yamada
We need to ensure that CONFIG_PHYS_64BIT is configured via Kconfig so that it is always available to the build system. Otherwise we can run into cases where we have inconsistent sizes of certain attributes. Ravi Babu reported offset mismatch of struct dwc3 across files since commit 95ebc253e6d4 ("types.h: move and redefine resource_size_t"). Since the commit, resource_addr_t points to phys_addr_t, whose size is dependent on CONFIG_PHYS_64BIT for ARM architecture. I tried my best to use "select" where possible (for example, ARMv8 architecture) because I think this kind of option is generally user- unconfigurable. However, I see some of PowerPC boards have 36BIT defconfigs as well as 32BIT ones. I moved CONFIG_PHYS_64BIT to the defconfigs for such boards. CONFIG_36BIT is no longer referenced, so all of the defines were removed from CONFIG_SYS_EXTRA_OPTIONS. Fixes: 95ebc253e6d4 ("types.h: move and redefine resource_size_t") Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reported-by: Ravi Babu <ravibabu@ti.com> Acked-by: Stefan Roese <sr@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-07-31libfdt: Introduce new ARCH_FIXUP_FDT optionMichal Simek
Add new Kconfig option to disable arch_fixup_fdt() calls for cases where U-Boot shouldn't update memory setup in DTB file. One example of usage of this option is to boot OS with different memory setup than U-Boot use. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-07-14tools: Allow building with debug enabledSimon Glass
Sometimes it is useful to build tools with debugging information included so that line-number information is available when run under gdb. Add a Kconfig option to support this. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-07-14spl: fit: add support for post-processing of imagesDaniel Allred
The next stage boot loader image and the selected FDT can be post- processed by board/platform/device-specific code, which can include modifying the size and altering the starting source address before copying these binary blobs to their final destination. This might be desired to do things like strip headers or footers attached to the images before they were packaged into the FIT, or to perform operations such as decryption or authentication. Introduce new configuration option CONFIG_SPL_FIT_IMAGE_POST_PROCESS to allow controlling this feature. If enabled, a platform-specific post-process function must be provided. Signed-off-by: Daniel Allred <d-allred@ti.com> Signed-off-by: Andreas Dannenberg <dannenberg@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-06-20Kconfig: Add a new DISTRO_DEFAULTS Kconfig optionHans de Goede
DISTRO_DEFAULTS is intended to mirror / replace include/config_distro_defaults.h. The intend is for boards which include this file to select this from their Kconfig files and when moving setting to Kconfig which are #define-ed in config_distro_defaults.h to select this from DISTRO_DEFAULTS so that boards which have selected DISTRO_DEFAULTS will keep the same configuration as before without needing any defconfig file changes. The initial list of selected things matches all settings recently removed from config_distro_defaults.h because they have been converted to Kconfig, with the exception of CMD_ELF and CMD_NET, which have a default of y, if the default of these ever changes they should be selected by DISTRO_DEFAULTS too. For testing and example purposes this commit also converts ARCH_SUNXI to use DISTRO_DEFAULT instead of selecting everything it needs itself. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-06-12verified-boot: Minimal support for booting U-Boot proper from SPLTeddy Reed
This allows a board to configure verified boot within the SPL using a FIT or FIT with external data. It also allows the SPL to perform signature verification without needing relocation. The board configuration will need to add the following feature defines: CONFIG_SPL_CRYPTO_SUPPORT CONFIG_SPL_HASH_SUPPORT CONFIG_SPL_SHA256 In this example, SHA256 is the only selected hashing algorithm. And the following booleans: CONFIG_SPL=y CONFIG_SPL_DM=y CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_FIT=y CONFIG_SPL_OF_CONTROL=y CONFIG_SPL_OF_LIBFDT=y CONFIG_SPL_FIT_SIGNATURE=y Signed-off-by: Teddy Reed <teddy.reed@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Andreas Dannenberg <dannenberg@ti.com> Acked-by: Sumit Garg <sumit.garg@nxp.com>
2016-05-26MIPS: Move CONFIG_SYS_TEXT_BASE to KconfigPaul Burton
Move CONFIG_SYS_TEXT_BASE to Kconfig, and add default values in board Kconfig files matching what was present in their config headers. This will make it cleaner to conditionalise the value for Malta based on 32 vs 64 bit builds. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2016-04-18Kconfig: Simple aesthetic/grammar fixes to top-level KconfigRobert P. J. Day
2016-03-14spl: Add an option to load a FIT containing U-BootSimon Glass
This provides a way to load a FIT containing U-Boot and a selection of device tree files. The board can select the correct device tree by probing the hardware. Then U-Boot is started with the selected device tree. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-25Move all command code into its own directorySimon Glass
There are a lot of unrelated files in common, including all of the commands. Moving them into their own directory makes them easier to find and is more logical. Some commands include non-command code, such as cmd_scsi.c. This should be sorted out at some point so that the function can be enabled with or without the associated command. Unfortunately, with m68k I get this error: m68k: + M5329AFEE +arch/m68k/cpu/mcf532x/start.o: In function `_start': +arch/m68k/cpu/mcf532x/start.S:159:(.text+0x452): relocation truncated to fit: R_68K_PC16 against symbol `board_init_f' defined in .text.board_init_f section in common/built-in.o I hope someone can shed some light on what this means. I hope it isn't depending on the position of code in the image. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
2016-01-20microblaze: move CONFIG_SYS_TEXT_BASE to defconfigMasahiro Yamada
This is how CONFIG options are defined by Kconfig. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Michal Simek <michal.simek@xilinx.com>
2015-11-04dm: spl: Support device tree when BSS is in a different sectionSimon Glass
At present in SPL we place the device tree immediately after BSS. This avoids needing to copy it out of the way before BSS can be used. However on some boards BSS is not placed with the image - e.g. it can be in RAM if available. Add an option to tell U-Boot that the device tree should be placed at the end of the image binary (_image_binary_end) instead of at the end of BSS. Note: A common reason to place BSS in RAM is to support the FAT filesystem. We should update the code so that it does not use so much BSS. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-10-20malloc_simple: Add support for switching to DRAM heapHans de Goede
malloc_simple uses a part of the stack as heap, initially it uses SYS_MALLOC_F_LEN bytes which typically is quite small as the initial stacks sits in SRAM and we do not have that much SRAM to work with. When DRAM becomes available we may switch the stack from SRAM to DRAM to give use more room. This commit adds support for also switching to a new bigger malloc_simple heap located in the new stack. Note that this requires spl_init to be called before spl_relocate_stack_gd which in practice means that spl_init must be called from board_init_f. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-10-20malloc_simple: Add Kconfig option for using only malloc_simple in the SPLHans de Goede
common/dlmalloc.c is quite big, both in .text and .data usage, therefor on some boards the SPL is build to use only malloc_simple.c and not the dlmalloc.c code. This is done in various include/configs/foo.h with the following construct: #ifdef CONFIG_SPL_BUILD #define CONFIG_SYS_MALLOC_SIMPLE #endif This commit introduces a SPL_MALLOC_SIMPLE Kconfig bool which allows selecting this functionality through Kconfig instead. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-09-28Kconfig: fix typo in CONFIG_FIT descriptionIgor Grinberg
Fix typo in CONFIG_FIT description - remove the accidentially added redundand 'the'. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-08-05efi: Drop CONFIG_SYS_TEXT_BASE for EFIBen Stoltz
When U-Boot runs as an EFI application is does not have a definition of CONFIG_SYS_TEXT_BASE. U-Boot is a relocatable application and the relocation is done by EFI. U-Boot can be loaded at any address. Ensure that this CONFIG option is not set in this case. Signed-off-by: Ben Stoltz <stoltz@google.com> Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-07-28Kconfig: zynqmp: Move CONFIG_SYS_TEXT_BASE to defconfigSiva Durga Prasad Paladugu
Move CONFIG_SYS_TEXT_BASE of ZynqMP_ep to its respective defconfig Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
