The DFU Kconfig menu entries should be part of the SPL
Kconfig file. Also avoid using the top level Makefile by
moving the config dependent build artifacts to the driver/
and driver/usb/gadget/ Makfiles.
With that, DFU can be built again in SPL if
CONFIG_SPL_DFU_SUPPORT is enabled.
Fixes: 6ad6102246d8 ("usb:gadget: Disallow DFU in SPL for now")
Acked-by: Lukasz Majewski <l.majewski@samsung.com>
(cherry picked from commit 5991703e88f320767d9390d64a6a9bd62560696b)
Traditionally the DFU support is available only
as part 2nd stage boot loader(u-boot) and DFU
is not supported in SPL.
The SPL-DFU feature is useful for boards which
does not have MMC/SD, ethernet boot mechanism
to boot the board and only has USB inteface.
This patch add DFU support in SPL with RAM
memory device support to load and execute u-boot.
And then leverage full functionality DFU in
u-boot to flash boot inital binary images to
factory or bare-metal boards to memory devices
like SPI, eMMC, MMC/SD card using USB interface.
This SPL-DFU support can be enabled through
Menuconfig->Boot Images->Enable SPL-DFU support
Signed-off-by: Ravi Babu <ravibabu@ti.com>
This reverts commit 90c08d9e08c7a108ab904f3bbdeb558081757892.
I took a closer look at this after the commit was applied, and found
CONFIG_SYS_MALLOC_F_LEN=0x2000 was too much. 8KB memory for SPL is
actually too big for some boards. Perhaps 0x800 is enough, but the
situation varies board by board.
Let's postpone our decision until we come up with a better idea.
Move the SPL settings into common/spl where most of the SPL code is kept.
If both SPL_DM and SPL_OF_CONTROL are enabled, SPL needs to bind
several devices, but CONFIG_SYS_MALLOC_F_LEN=0x400 is apparently
not enough. Increase the default to 0x2000 for the case. This
will be helpful for shorter defconfigs.
The 'bootz' command is really only for ARM32 Linux Kernel 'zImage' files
but has also been adapted for testing with sandbox. Given that sandbox
is a test platform, don't add that logic under DISTRO_DEFAULTS.
Cc: Hans de Goede <hdegoede@redhat.com>
This command is used to boot ARM64 Linux.
I made DISTRO_DEFAULTS select this option for ARM64 to respect
include/config_distro_defaults.h.
This commit allows injecting a board/platform/device-specific post-
processing function into the FIT image data loading process, which can
include modifying the size and altering the starting source address of
an image data artifact. This might be desired to do things like strip
headers or footers attached to the images before they were packaged into
the FIT, or to perform operations such as decryption or authentication.
Introduce new configuration option CONFIG_FIT_IMAGE_POST_PROCESS to
allow controlling this feature. If enabled, a platform-specific post-
process function must be provided.
Signed-off-by: Andreas Dannenberg <dannenberg@ti.com>
We need to ensure that CONFIG_PHYS_64BIT is configured via Kconfig so
that it is always available to the build system. Otherwise we can run
into cases where we have inconsistent sizes of certain attributes.
Ravi Babu reported offset mismatch of struct dwc3 across files since
commit 95ebc253e6d4 ("types.h: move and redefine resource_size_t").
Since the commit, resource_addr_t points to phys_addr_t, whose size
is dependent on CONFIG_PHYS_64BIT for ARM architecture.
I tried my best to use "select" where possible (for example, ARMv8
architecture) because I think this kind of option is generally user-
unconfigurable. However, I see some of PowerPC boards have 36BIT
defconfigs as well as 32BIT ones. I moved CONFIG_PHYS_64BIT to the
defconfigs for such boards.
CONFIG_36BIT is no longer referenced, so all of the defines were
removed from CONFIG_SYS_EXTRA_OPTIONS.
Fixes: 95ebc253e6d4 ("types.h: move and redefine resource_size_t")
Reported-by: Ravi Babu <ravibabu@ti.com>
Reviewed-by: York Sun <york.sun@nxp.com>
Add new Kconfig option to disable arch_fixup_fdt() calls for cases where
U-Boot shouldn't update memory setup in DTB file.
One example of usage of this option is to boot OS with different memory
setup than U-Boot use.
Sometimes it is useful to build tools with debugging information included so
that line-number information is available when run under gdb. Add a Kconfig
option to support this.
The next stage boot loader image and the selected FDT can be post-
processed by board/platform/device-specific code, which can include
modifying the size and altering the starting source address before
copying these binary blobs to their final destination. This might be
desired to do things like strip headers or footers attached to the
images before they were packaged into the FIT, or to perform operations
such as decryption or authentication. Introduce new configuration
option CONFIG_SPL_FIT_IMAGE_POST_PROCESS to allow controlling this
feature. If enabled, a platform-specific post-process function must
be provided.
Signed-off-by: Daniel Allred <d-allred@ti.com>
DISTRO_DEFAULTS is intended to mirror / replace
The intend is for boards which include this file to select this from
their Kconfig files and when moving setting to Kconfig which are #define-ed
in config_distro_defaults.h to select this from DISTRO_DEFAULTS so that
boards which have selected DISTRO_DEFAULTS will keep the same configuration
as before without needing any defconfig file changes.
The initial list of selected things matches all settings recently removed
from config_distro_defaults.h because they have been converted to Kconfig,
with the exception of CMD_ELF and CMD_NET, which have a default of y, if
the default of these ever changes they should be selected by DISTRO_DEFAULTS
too.
For testing and example purposes this commit also converts ARCH_SUNXI
to use DISTRO_DEFAULT instead of selecting everything it needs itself.
This allows a board to configure verified boot within the SPL using
a FIT or FIT with external data. It also allows the SPL to perform
signature verification without needing relocation.
The board configuration will need to add the following feature defines:
CONFIG_SPL_CRYPTO_SUPPORT
CONFIG_SPL_HASH_SUPPORT
CONFIG_SPL_SHA256
In this example, SHA256 is the only selected hashing algorithm.
And the following booleans:
CONFIG_SPL=y
CONFIG_SPL_DM=y
CONFIG_SPL_LOAD_FIT=y
CONFIG_SPL_FIT=y
CONFIG_SPL_OF_CONTROL=y
CONFIG_SPL_OF_LIBFDT=y
CONFIG_SPL_FIT_SIGNATURE=y
Signed-off-by: Teddy Reed <teddy.reed@gmail.com>
Acked-by: Andreas Dannenberg <dannenberg@ti.com>
Acked-by: Sumit Garg <sumit.garg@nxp.com>
Move CONFIG_SYS_TEXT_BASE to Kconfig, and add default values in board
Kconfig files matching what was present in their config headers. This
will make it cleaner to conditionalise the value for Malta based on 32
vs 64 bit builds.
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
This provides a way to load a FIT containing U-Boot and a selection of device
tree files. The board can select the correct device tree by probing the
hardware. Then U-Boot is started with the selected device tree.
There are already two FIT options in Kconfig but the CONFIG options are
still in the header files. We need to do a proper move to fix this.
Move these options to Kconfig and tidy up board configuration:
CONFIG_FIT
CONFIG_OF_BOARD_SETUP
CONFIG_OF_SYSTEM_SETUP
CONFIG_FIT_SIGNATURE
CONFIG_FIT_BEST_MATCH
CONFIG_FIT_VERBOSE
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_RSA
Unfortunately the first one is a little complicated. We need to make sure
this option is not enabled in SPL by this change. Also this option is
enabled automatically in the host builds by defining CONFIG_FIT in the
image.h file. To solve this, add a new IMAGE_USE_FIT #define which can
be used in files that are built on the host but must also build for U-Boot
and SPL.
Note: Masahiro's moveconfig.py script is amazing.
[trini: Add microblaze change, various configs/ re-applies]
There are a lot of unrelated files in common, including all of the commands.
Moving them into their own directory makes them easier to find and is more
logical.
Some commands include non-command code, such as cmd_scsi.c. This should be
sorted out at some point so that the function can be enabled with or without
the associated command.
Unfortunately, with m68k I get this error:
m68k: + M5329AFEE
+arch/m68k/cpu/mcf532x/start.o: In function `_start':
+arch/m68k/cpu/mcf532x/start.S:159:(.text+0x452): relocation truncated to fit: R_68K_PC16 against symbol `board_init_f' defined in .text.board_init_f section in common/built-in.o
I hope someone can shed some light on what this means. I hope it isn't
depending on the position of code in the image.
Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
This is how CONFIG options are defined by Kconfig.
Acked-by: Michal Simek <michal.simek@xilinx.com>
For historical reason, CONFIG_SYS_TEXT_BASE has been specified
in various ways:
[1] by board/${VENDOR}/${BOARD}/config.mk
[2] by CONFIG_SYS_EXTRA_OPTIONS
(This was "options" field of boards.cfg before Kconfig conversion)
[3] by include/configs/${BOARD}.h
[4] by configs/${BOARD}_defconfig
Most of M68K boards use either [1] or [2], both of which we want to
deprecate. Switch them into [4], which is the newest way (Kconfig).
We still allow [3] too, because it is still used by many boards and
we expect much time for conversion.
Acked-by: Angelo Dureghello <angelo at sysam.it>
At present in SPL we place the device tree immediately after BSS. This
avoids needing to copy it out of the way before BSS can be used. However on
some boards BSS is not placed with the image - e.g. it can be in RAM if
available.
Add an option to tell U-Boot that the device tree should be placed at the
end of the image binary (_image_binary_end) instead of at the end of BSS.
Note: A common reason to place BSS in RAM is to support the FAT filesystem.
We should update the code so that it does not use so much BSS.
malloc_simple uses a part of the stack as heap, initially it uses
SYS_MALLOC_F_LEN bytes which typically is quite small as the initial
stacks sits in SRAM and we do not have that much SRAM to work with.
When DRAM becomes available we may switch the stack from SRAM to DRAM
to give use more room. This commit adds support for also switching to
a new bigger malloc_simple heap located in the new stack.
Note that this requires spl_init to be called before spl_relocate_stack_gd
which in practice means that spl_init must be called from board_init_f.
common/dlmalloc.c is quite big, both in .text and .data usage, therefor
on some boards the SPL is build to use only malloc_simple.c and not the
dlmalloc.c code. This is done in various include/configs/foo.h with the
following construct:
#ifdef CONFIG_SPL_BUILD
#define CONFIG_SYS_MALLOC_SIMPLE
#endif
This commit introduces a SPL_MALLOC_SIMPLE Kconfig bool which allows
selecting this functionality through Kconfig instead.
Fix typo in CONFIG_FIT description - remove the accidentially added
redundand 'the'.
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
When U-Boot runs as an EFI application is does not have a definition of
CONFIG_SYS_TEXT_BASE. U-Boot is a relocatable application and the relocation
is done by EFI. U-Boot can be loaded at any address.
Ensure that this CONFIG option is not set in this case.
Signed-off-by: Ben Stoltz <stoltz@google.com>
Move CONFIG_SYS_TEXT_BASE of ZynqMP_ep to its
respective defconfig
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
Currently all x86 boards still use CONFIG_SYS_EXTRA_OPTIONS to define
the text base address. Since it is deprecated, just remove it and use
CONFIG_SYS_TEXT_BASE directly.
make the CPU clock selectable via Kconfig
this removes the sunxi specific CONFIG_CLK_FULL_SPEED defined in each
soc header and replaces it's use in board/sunxi/board.c with
CONFIG_SYS_CLK_FREQ from Kconfig which allows us to configure board
specific frequency on boot
Signed-off-by: Iain Paton <ipaton0@gmail.com>
[hdegoede@redhat.com s/CONFIG_SYS_CLK_FREQ/CONFIG_TIMER_CLK_FREQ/ for the
arch-timer clk speed on sun7i to fix mis-compile on sun7i]
Acked-by: Hans de Goede <hdegoede@redhat.com>
This option has a bool type, not hex.
Fix it and enable it if CONFIG_DM is on because Driver Model always
requires malloc memory. Devices are scanned twice, before/after
relocation. CONFIG_SYS_MALLOC_F should be enabled to use malloc
memory before relocation. As it is board-independent, handle it
globally.
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
Acked-by: Robert Baldyga <r.baldyga@samsung.com>
This commit introduces new config: CONFIG_SYS_MALLOC_CLEAR_ON_INIT.
This config is an expert option and is enabled by default.
The all amount of memory reserved for the malloc, is by default set
to zero in mem_malloc_init(). When the malloc reserved memory exceeds
few MiB, then the boot process can slow down.
So disabling this config, is an expert option to reduce the boot time,
and can be disabled by Kconfig.
Note:
After disable this option, only calloc() will return the pointer
to the zeroed memory area. Previously, without this option,
the memory pointed to untouched malloc memory region, was filled
with zeros. So it means, that code with malloc() calls should
be reexamined.
Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com>
At present SPL uses a single stack, either CONFIG_SPL_STACK or
CONFIG_SYS_INIT_SP_ADDR. Since some SPL features (such as MMC and
environment) require a lot of stack, some boards set CONFIG_SPL_STACK to
point into SDRAM. They then set up SDRAM very early, before board_init_f(),
so that the larger stack can be used.
This is an abuse of lowlevel_init(). That function should only be used for
essential start-up code which cannot be delayed. An example of a valid use is
when only part of the SPL code is visible/executable, and the SoC must be set
up so that board_init_f() can be reached. It should not be used for SDRAM
init, console init, etc.
Add a CONFIG_SPL_STACK_R option, which allows the stack to be moved to a new
address before board_init_r() is called in SPL.
The expected SPL flow (for CONFIG_SPL_FRAMEWORK) is documented in the README.
For version 1:
Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
Tested-by: Bo Shen <voice.shen@atmel.com>
Acked-by: Bo Shen <voice.shen@atmel.com>
Acked-by: Heiko Schocher <hs@denx.de>
Tested-by: Heiko Schocher <hs@denx.de>
Currently only normal hashing is supported using hardware acceleration.
Added support for progressive hashing using hardware.
Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com>
Signed-off-by: Gaurav Rana <gaurav.rana@freescale.com>
CC: Simon Glass <sjg@chromium.org>
Reviewed-by: York Sun <yorksun@freescale.com>
Now CONFIG_SPL_BUILD is not defined in Kconfig, so
"!depends on SPL_BUILD" and "if !SPL_BUILD" are redundant.
When Kconfig for U-boot was examined, one of the biggest issues was
how to support multiple images (Normal, SPL, TPL). There were
actually two options, "single .config" and "multiple .config".
After some discussions and thought experiments, I chose the latter,
i.e. to create ".config", "spl/.config", "tpl/.config" for Normal,
SPL, TPL, respectively.
It is true that the "multiple .config" strategy provided us the
maximum flexibility and helped to avoid duplicating CONFIGs among
Normal, SPL, TPL, but I have noticed some fatal problems:
[1] It is impossible to share CONFIG options across the images.
If you change the configuration of Main image, you often have to
adjust some SPL configurations correspondingly. Currently, we
cannot handle the dependencies between them. It means one of the
biggest advantages of Kconfig is lost.
[2] It is too painful to change both ".config" and "spl/.config".
Sunxi guys started to work around this problem by creating a new
configuration target. Commit cbdd9a9737cc (sunxi: kconfig: Add
%_felconfig rule to enable FEL build of sunxi platforms.) added
"make *_felconfig" to enable CONFIG_SPL_FEL on both images.
Changing the configuration of multiple images in one command is a
generic demand. The current implementation cannot propose any
good solution about this.
[3] Kconfig files are getting ugly and difficult to understand.
Commit b724bd7d6349 (dm: Kconfig: Move CONFIG_SYS_MALLOC_F_LEN to
Kconfig) has sprinkled "if !SPL_BUILD" over the Kconfig files.
[4] The build system got more complicated than it should be.
To adjust Linux-originated Kconfig to U-Boot, the helper script
"scripts/multiconfig.sh" was introduced. Writing a complicated
text processor is a shell script sometimes caused problems.
Now I believe the "single .config" will serve us better. With it,
all the problems above would go away. Instead, we will have to add
some CONFIG_SPL_* (and CONFIG_TPL_*) options such as CONFIG_SPL_DM,
but we will not have much. Anyway, this is what we do now in
scripts/Makefile.spl.
I admit my mistake with my apology and this commit switches to the
single .config configuration.
It is not so difficult to do that:
- Remove unnecessary processings from scripts/multiconfig.sh
This file will remain for a while to support the current defconfig
format. It will be removed after more cleanups are done.
- Adjust some makefiles and Kconfigs
- Add some entries to include/config_uncmd_spl.h and the new file
scripts/Makefile.uncmd_spl. Some CONFIG options that are not
supported on SPL must be disabled because one .config is shared
between SPL and U-Boot proper going forward. I know this is not
a beautiful solution and I think we can do better, but let's see
how much we will have to describe them.
- update doc/README.kconfig
More cleaning up patches will follow this.
At present defaults in arch-specific Kconfig files are ignored if the
top-level item comes ahead of it in include order. This means that it is
not possible to have a U-Boot default that architectures and boards can
override. This does not seem very useful.
Move the include earlier to support this.
Reported-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
Move this option to Kconfig and update all boards.
Add a file to control driver model test features.
Discovered while experimenting with signature checking on vexpress
which doesn't typically use DM.
Following SPARK ARC now has SYS_MONITOR_BASE setup via Kconfig.
This makes "include/configs/*.h" cleaner and more flexible.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
For FIT signature based approach to work, RSA library needs to be selected.
The FIT_SIGNATURE option in Kconfig is modified to automatically select RSA.
Selecting RSA compiles the RSA library required for image verification.
It makes sense to specify CONFIG_SYS_CLK_FREQ in "configs/xx_defconfig"
instead of "include/configs/xxx.h" because then header will be reusable
across boards with different CPU clocks.
Also this nice to have an ability for end user to tune this value
himself via "menuconfig".
For now I'm only applying this change to all ARC configs because
otherwise scope of change will be huge.
Cc: Tom Rini <trini@ti.com>
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
cc: Simon Glass <sjg@chromium.org>
Reviewed-by: Tom Rini <trini@ti.com>
Make it a sub-menu of "General setup" like Linux Kernel.
For similar reasons to why the Linux Kernel has an EXPERT option, we too
want an option to allow for tweaking of some options that while normally
should remain hidden, may need to be changed in some cases.
Acked-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
Defining CONFIG_SYS_TEXT_BASE in config.mk is very old style.
Create CONFIG_SYS_TEXT_BASE option in Kconfig, but let it
depend on CONFIG_SPARC because we do not want to disturb
the other architectures that still define CONFIG_SYS_TEXT_BASE
in their header files.
Cc: Daniel Hellstrom <daniel@gaisler.com>
CONFIG_TPL should not be enabled for boards that do not have TPL.
CONFIG_SUPPORT_TPL introduced by this commit should be "select"ed
by boards with TPL support and CONFIG_TPL should depend on it.
