path: root/Documentation
2018-11-14misc: Add IHS FPGA driverMario Six
Add a driver for gdsys IHS (Integrated Hardware Systems) FPGAs, which supports initialization of the FPGA, as well as information gathering. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-11-14misc: Add gdsys_soc driverMario Six
This patch adds a driver for the bus associated with a IHS FPGA. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-09-29board: Add gazerbeam driverMario Six
Add a board driver for the upcoming gdsys Gazerbeam board. Signed-off-by: Mario Six <mario.six@gdsys.cc> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-09-18misc: Add MPC83xx serdes driverMario Six
Add a driver to configure the SerDes (Serializer/Deserializer) lanes on the MPC83xx architecture. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-09-18cpu: Add MPC83xx CPU driverMario Six
Add a CPU driver for the MPC83xx architecture. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-09-18timer: Add MPC83xx timer driverMario Six
Add a timer driver for the MPC83xx architecture. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-09-18clk: Add MPC83xx clock driverMario Six
Add a clock driver for the MPC83xx architecture. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-09-18ram: Add driver for MPC83xxMario Six
Add a RAM driver for the MPC83xx architecture. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-08-11Merge branch 'agust@denx.de' of git://git.denx.de/u-boot-stagingTom Rini
2018-08-11Merge branch 'master' of git://git.denx.de/u-boot-videoTom Rini
2018-08-11misc: Add gdsys_ioep driverMario Six
Add driver for the IHS IO endpoint on IHS FPGAs. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-08-11axi: Add ihs_axi driverMario Six
Add a driver for the gdsys IHS AXI bus used on IHS FPGAs. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-08-10doc: add structure to Sphinx generated docsHeinrich Schuchardt
Create separate html pages for linker lists, the serial subsystem, and the EFI subsystem. Add a table of content. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2018-07-24doc: Move device tree bindings documentation to doc/device-tree-bindingsBreno Lima
Currently the U-Boot project contains 2 documentation directories: - doc/ - Documentation/ The Documentation directory only contains device tree bindings related content, so move the 3 files to doc/device-tree-bindings/. Signed-off-by: Breno Lima <breno.lima@nxp.com>
2018-07-23doc: Replace DocBook with sphinx-based docsMario Six
The Linux kernel moved to sphinx-based documentation and got rid of the DocBook based documentation quite a while ago. Hence, the DocBook documentation for U-Boot should be converted as well. To achieve this, import the necessary files from Linux v4.17, and convert the current DocBook documentation (three files altogether) to sphinx/reStructuredText. For now, all old DocBook documentation was merged into a single handbook, tentatively named "U-Boot Hacker Manual". For some source files, the documentation style was changed to comply with kernel-doc; no functional changes were applied. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-05-18phy: add support for STM32 usb phy controllerPatrice Chotard
This patch adds phy tranceiver driver for STM32 USB PHY Controller (usbphyc) that provides dual port High-Speed phy for OTG (single port) and EHCI/OHCI host controller (two ports). One port of the phy is shared between the two USB controllers through a UTMI+ switch. Signed-off-by: Christophe Kerello <christophe.kerello@st.com> Signed-off-by: Amelie Delaunay <amelie.delaunay@st.com> Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2017-07-28phy: add a NO-OP phy driverJean-Jacques Hiblot
This driver is used to stub PHY operations in a driver (USB, SATA). This is useful when the 'client' driver (USB, SATA, ...) uses the PHY framework and there is no actual PHY harwdare to drive. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2017-07-12dt-bindings: Document the Broadcom STB wake-up timer nodeFlorian Fainelli
Document the binding for the Broadcom STB SoCs wake-up timer node allowing the system to generate alarms and exit low power states. Acked-by: Rob Herring <robh@kernel.org> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2005-08-19Fix erroneous commitWolfgang Denk
2005-08-19Fix MPC52xx watchdog driverWolfgang Denk
- make watchdog driver work on systems with an IPB clock frequency of 133 MHz (watchdog expired to fast there). - now all three watchdog chain entries could be used. - fix some typos. Patch by Martin Krause, 23 Jun 2005
