Patch by Thomas Lange, Aug 11 2005
Patch by Martin Krause, 8 Jun 2006
This patch supports two serial consoles on boards with
a MPC5xxx CPU. The console can be switched at runtime
by setting stdin, stdout and stderr to the desired serial
interface (serial0 or serial1). The PSCs to be used as
console port are definded by CONFIG_PSC_CONSOLE
and CONFIG_PSC_CONSOLE2.
See README.serial_multi for details.
If the bus is blocked because of a previously interrupted
transfer, up to eleven clocks are generated on the I2CSCL
line to complete the transfer and to free the bus.
With this fix pin I2CSCL (PG6) is really configured as GPIO
so the clock pulses are really generated.
Patch by Martin Krause, 04 Apr 2006
Patch by Thomas Waehner, 07 Mar 2006
Patch by Martin Krause, 11 Jan 2006
Patch by Martin Krause, 17 Nov 2005
Patch by Martin Krause, 07 Nov 2005
Tested on a STK85XX baseboard. Make sure the PS/2 controller
has been programmed. Jumper Settings: X66 1-2, 9-10; X61 2-3
Patch by Martin Krause, 08 Nov 2005
In tsc2000_read_channel() the delay after setting the multiplexer
to a temperature channel is increased from 1,5 ms to 10 ms. This
is to allow the multiplexer inputs to stabilize after huge steps
of the input signal level.
Make the automatic CS configuration the default.
The dedicated configurations CONFIG_TQM5200_AA, CONFIG_TQM5200_AB
and CONFIG_TQM5200_AC are removed.
"TQM5200_config" is now the default for STK52XX.200 base boards.
On a STK52XX.100 base board "TQM5200_STK100_config" must be used.
The environment variable "ver" is now set before
do_auto_update() is called, so that "ver" can be used
in USB update scripts.
Patch by Martin Krause, 27 Oct 2005
Patch by Scott McNutt, 08 Jun 2006
-When booting from an epcs controller, the epcs bootrom may leave the
slave select in an asserted state causing soft reset hang. This
patch ensures slave select is negated at reset.
-Update base addresses for standard configuration
-Eliminate use of CACHE_BYPASS in board code
-Fix asm/io.h macros
-Eliminate use of CACHE_BYPASS in cpu code
-Eliminate assembler warnings
-Fix mini-app stubs and force no small data
Patch by Stefan Roese, 06 Jun 2006
Patch by Stefan Roese, 02 Jun 2006
Just use udelay() when waiting for status changes which will
implicitely trigger the watchdog.
We use the "automatic" mode that was used for the MPC8266ADS and
MPC8272 boards. Eventually this should be used on all boards?]
Patch by Wolfgang Grandegger, 17 Jan 2006
Patch by Stefan Roese, 29 May 2006
- Add IXP4xx NPE ethernet MAC support
- Add support for Intel IXDPG425 board
- Add support for Prodrive PDNB3 board
- Add IRQ support
Patch by Stefan Roese, 23 May 2006
[This patch does not include cpu/ixp/npe/IxNpeMicrocode.c which still
sufferes from licensing issues. Blame Intel.]
Patch by Stefan Roese, 18 May 2006
Patch by Stefan Roese, 15 May 2006
(needed because of differences in the PCMCIA hardware).
Patch by Stefan Roese, 10 May 2006
Patch by John Otken, 08 May 2006
Problems have been seen in the linux kernel's smc91x network driver
due to improper bus timings. The latest 2.6 OMAP kernels currently
have a workaround, but this fix belongs in u-boot.
Patch by Kevin Hilman, 13 Oct 2005
Patch by Hiroki Kaminaga, 11 Mar 2006
- Fix OMAP support that omap5912osk compiles in current source tree
- Update with code from "http://omap.spectrumdigital.com/osk5912"
to fix problems with DDR initialization
- Fix timer setup
- Use CFI flash driver and support complete 32MB of onboard flash
- Add "print_cpuinfo()" and "checkboard()" functions to display
CPU (with frequency) and Board infos
