2005-10-13 | Cleanup for GCC-4.x | Wolfgang Denk | |
2005-10-13 | Add documentation for Open Firmware Flat Tree and usage. | Wolfgang Denk | |
Patch by Pantelis Antoniou, 13 Oct 2005 | |||
2005-10-13 | Add missing files for Pantelis Antoniou's patch | Wolfgang Denk | |
Patch by Pantelis Antoniou, 04 Sep 2005 | |||
2005-10-13 | Merge with /home/sr/git/u-boot | Wolfgang Denk | |
2005-10-13 | Add support for OF flat tree for the STXtc board. | Wolfgang Denk | |
2005-10-13 | Support passing of OF flat trees to the kernel. | Wolfgang Denk | |
2005-10-10 | Fix problem in ppc4xx eth-driver without ethaddr (only without | Stefan Roese | |
CONFIG_NET_MULTI set) Patch by Stefan Roese, 10 Oct 2005 | |||
2005-10-09 | Add support for NetSilicon NS7520 processor. | Wolfgang Denk | |
Patch by Art Shipkowski, 12 May 2005 Cleanup. | |||
2005-10-09 | Add support for AP1000 board. | Wolfgang Denk | |
Patch by James MacAulay, 07 Oct 2005 | |||
2005-10-09 | Eliminate hard-coded address of Ethernet transfer buffer on at91rm9200 | Wolfgang Denk | |
Patch by Anders Larsen, 07 Oct 2005 The Atmel errata #11 states that the transfer buffer descriptor table must be aligned on a 16-word boundary. As it turned out, this is insufficient - it seems the table must be aligned on a boundary at least as large as the table itself (in Linux this is not an issue - the table is aligned on a PAGE_SIZE (4096) boundary). | |||
2005-10-09 | Fixed compilation for ARM when using a (standard) hard-FP toolchain | Wolfgang Denk | |
Patch by Anders Larsen, 07 Oct 2005 | |||
2005-10-09 | Cleanup warnings for cpu/arm720t & cpu/arm1136 files. | Wolfgang Denk | |
sed the linker scripts, rather than pre-process them. Patch by Peter Pearse, 07 Oct 2005 | |||
2005-10-08 | Fix gzip bmp support (test if malloc fails, warning when truncated). | Stefan Roese | |
Increase CFG_VIDEO_LOGO_MAX_SIZE on HH405 board. Patch by Stefan Roese, 08 Oct 2005 | |||
2005-10-06 | Update make target for ARM supported boards. | Wolfgang Denk | |
Use lowlevel_init() instead of platformsetup() [rename]. Patch by Peter Pearse, 06 Oct 2005 | |||
2005-10-06 | Fix booting from serial dataflash on AT91RM9200 | Wolfgang Denk | |
Patch by Peter Menzebach, 29 Aug 2005 | |||
2005-10-06 | Add JFFS2 support for TRAB board | Wolfgang Denk | |
Patch by Martin Krause, 25 Aug 2005 | |||
2005-10-06 | Remove unnecessary dependency of netconsole on CONFIG_NET_MULTI | Wolfgang Denk | |
Patch by Marcus Hall, 24 Aug 2005 | |||
2005-10-06 | Fix the machine-id of the Cogent csb637 board | Wolfgang Denk | |
Patch by Anders Larsen, 05 Oct 2005 | |||
2005-10-06 | Complete support for the KwikByte KB920x boards | Wolfgang Denk | |
2005-10-05 | Set the AT91RM9200 clock to asynchronous mode | Wolfgang Denk | |
Patch by Anders Larsen, 03 May 2005 | |||
2005-10-05 | Set the AT91RM9200 clock to synchronous mode | Wolfgang Denk | |
Patch by Anders Larsen, 29 Apr 2005 | |||
2005-10-05 | Add support for Cogent csb637 | Wolfgang Denk | |
2005-10-05 | Fix dm9161.c initialization | Wolfgang Denk | |
2005-10-05 | * Move dm9161.c and lxt972.c into cpu/arm920t/at91rm9200 | Wolfgang Denk | |
Patch by Anders Larsen, 29 Apr 2005 * Fix problems introduced by Patch by Steven Scholz, 02 Mar 2005 (8e2be51de8dd03c1ce4d06cbb18ad06133d47cd5) | |||
2005-10-05 | Fix device partition intialization for SystemACE disks. | Wolfgang Denk | |
Patch by Stephen Williams, 28 Apr 2005 | |||
2005-10-05 | Added support for KwikByte KB920x boards (based on AT91RM9200) | Wolfgang Denk | |
Patch by Matt ?? <kb9200_dev@kwikbyte.com>, 27 Apr 2005 | |||
2005-10-05 | Add support for S29GL064M-R3 flash chip on xsengine board | Wolfgang Denk | |
Patch by Kurt Stremerch, 18 Apr 2005 | |||
2005-10-05 | E500 update: repoint IVPR to RAM when code is relocated | Wolfgang Denk | |
Patch by Kylo Ginsberg, 13 Apr 2005 | |||
2005-10-04 | Fix loop end test in lib_generic/string.c:strswab() | Wolfgang Denk | |
Patch by Andrew Dyer, October 10, 2005 Signed-off-by: Andrew Dyer <amdyer@gmail.com> | |||
2005-10-04 | Update ARM Integrator boards: | Wolfgang Denk | |
Correct addessing errors in platform files. Split off common core module data from Integrator header files to include/armcoremodule.h. Patch by Peter Pearse, 04 Oct 2005 | |||
2005-10-04 | Make sure only supported compiler options are used | Wolfgang Denk | |
Import "cc-option" shell function from kernel and use it to get the correct ARM GCC options for individual CPUs Patch by Peter Pearse, 30 Jun 2005 | |||
2005-10-04 | Fix 440GR to print correct cpu revision | Stefan Roese | |
Patch by Stefan Roese, 4 Oct 2005 | |||
2005-10-03 | Merge with /home/wd/git/u-boot/master | Wolfgang Denk | |
2005-10-03 | Change board message on AMCC Yosemite & Yellowstone to common style | Stefan Roese | |
Patch by Stefan Roese, 3 Oct 2005 | |||
2005-09-30 | Fix compiler warning | Wolfgang Denk | |
2005-09-29 | Fix FEC PHY addresses for TQM85xx boards | Wolfgang Denk | |
2005-09-28 | Fix uninitialized variable problem in hush shell | Wolfgang Denk | |
Patch by Lars Rostock, 26 Sep 2005 | |||
2005-09-26 | Undo change of f6e20fc6ca... to include/configs/trab.h | Wolfgang Denk | |
(Must have been an accident?) | |||
2005-09-26 | Add support for AT91RM9200 OHCI Controller. | Wolfgang Denk | |
Patch by Eric Benard, 07 Apr 2005 | |||
2005-09-26 | Update ARM mach-types.h | Wolfgang Denk | |
2005-09-26 | Add support for MP2USB board. | Wolfgang Denk | |
2005-09-26 | Add board support for armadillo HT1070 | Wolfgang Denk | |
Patch by Rowel Atienza, 06 Apr 2005 | |||
2005-09-26 | Second Ethernet address enabled for MPC885ADS and MPC8272ADS. | Wolfgang Denk | |
Patch by Vitaly Bordug, 30 Mar 2005 | |||
2005-09-26 | Add iopset command on mpc8xx | Wolfgang Denk | |
Patch by Daniel Eisenhut, 25 Mar 2005 | |||
2005-09-26 | Add support for MII in eepro100 driver. | Wolfgang Denk | |
Patch by Gleb Natapov, 21 Mar 2005 | |||
2005-09-26 | Fixes to the Lubbock (PXA 25x) support: | Wolfgang Denk | |
- Resolve the FIXME with respect to saving the u-boot environment. - Make the default load address land in real memory. - Fix lan91c96 SMC_{in,out}{b,w,l}() macros Patch by David Brownell, 10 Mar 2005 | |||
2005-09-25 | Add Barco Streaming Video Card (SVC) and Sample Compress Network (SCN) board | Wolfgang Denk | |
Patch by Marc Leeman, 04 Mar 2005 | |||
2005-09-25 | Cleanup | Wolfgang Denk | |
2005-09-25 | OMAP242x H4 board update | Wolfgang Denk | |
- fix for ES2 differences. - switch to using the cfi_flash driver. - fix SRAM build address. - fix for GP device operation. - unlock SRAM for GP devices. - display more device information. - fix potential deadlock in omap24xx_i2c driver. - fix DLL load values to match dpllout*1 operation. - fix 2nd chip select init for combo DDR device. - add support for CFI Intel 28F256L18 on H4 board. Patch by Richard Woodruff, 03 Mar 2005 | |||
2005-09-25 | Fix formating in include/asm-arm/arch-at91rm9200/AT91RM9200.h | Wolfgang Denk | |
Patch by Steven Scholz, 02 Mar 2005 |
