path: root/CHANGELOG
2006-03-12Fix cleanup for netstart board.LABEL_2006_03_12_0025Wolfgang Denk
Remove build results from repository
2006-03-11Some code cleanup for GCC 4.xWolfgang Denk
2006-03-11Update CHANGELOGWolfgang Denk
2006-03-07Add support for Intel Monahans CPU on Zylonite and Delta boardsWolfgang Denk
(This is Work in Progress!)
2006-03-07Add support for TQM8260-AI boards.Wolfgang Denk
2006-03-06Minor code cleanupWolfgang Denk
2006-03-06Merge the new NAND code (testing-NAND brach); see doc/README.nandWolfgang Denk
Rewrite of NAND code based on what is in 2.6.12 Linux kernel Patch by Ladislav Michl, 29 Jun 2005 [Merge with /home/tur/nand/u-boot]
2006-03-04Add lowboot target to mcc200 boardStefan Roese
Patch by Stefan Roese, 4 Mar 2006
2006-03-02Merge with /home/sr/git/u-boot/cfi-flash-fixWolfgang Denk
2006-03-02Make CFG_NO_FLASH work on ARM systemsWolfgang Denk
Patch by Markus Klotzbuecher, 27 Feb 2006
2006-03-01Fix problem with flash_get_size() from CFI driver updateStefan Roese
Patch by Stefan Roese, 1 Mar 2006
2006-02-28Update mcc200 config: Disable PCI and DoC, use 133 MHz IPB clock,Wolfgang Denk
use hush shell.
2006-02-28Merge with Stefan Roese's branch with CFI driver fixesWolfgang Denk
2006-02-28Convert mcc200 to use common CFI flash driverStefan Roese
Patch by Stefan Roese, 28 Feb 2006
2006-02-28Major CFI-FLASH driver update:Stefan Roese
* Add env-variable "unlock" to handle initial state of sectors (locked/unlocked). Only the U-Boot image and it's environment is protected, all other sectors are unprotected (unlocked) if flash hardware protection is used (CFG_FLASH_PROTECTION) and the environment variable "unlock" is set to "yes". Patch by Stefan Roese, 28 Feb 2006 * Update drivers/cfi_flash.c: - find_sector() called in both versions of flash_write_cfiword() Patch by Peter Pearse, 27th Feb 2006 * CFI support for a x8/x16 AMD/Spansion flash configured in x8 mode Patch by Jose Maria Lopez, 16 Jan 2006 * Add support for AMD/Spansion Flashes in flash_write_cfibuffer Patch by Alex Bastos and Thomas Schaefer, 2005-08-29 * Changes/fixes for drivers/cfi_flash.c: We *should* check if there are any error bits if the previous call returned ERR_OK (Otherwise we will have output an error message in flash_status_check() already.) The original code would only check for error bits if flash_status_check() returns ERR_TIMEOUT. Patch by Marcus Hall, 23 Aug 2005 * Changes/fixes for drivers/cfi_flash.c: - Add CFG_FLASH_PROTECT_CLEAR on drivers/cfi_flash.c - Prohibit buffer write when buffer_size is 1 on drivers/cfi_flash.c Patch by Sangmoon Kim, 19 Aug 2005 * Fixes for drivers/cfi_flash.c: - Fix wrong timeout value usage in flash_status_check() - Round write_tout up when converting to msec in flash_get_size() - Remove clearing flash status at the end of flash_write_cfibuffer() which sets Intel 28F640J3 flash back to command mode on CSB472 Patch by Tolunay Orkun, 02 July 2005
2006-02-24Merge with /home/wd/git/u-boot/testing-NAND/ to add new NAND handling.Bartlomiej Sieka
2006-02-22Merge with /home/hs/PanDacom/u-boot-devWolfgang Denk
2006-02-21Add GIT version information (commid ID) to untagged U-Boot versionsWolfgang Denk
As done in the linux kernel, the U-Boot version (U_BOOT_VERSION) of all unreleased (untagged) U-Boot images will be automatically extended upon compiletime with a part of the GIT commit ID and possibly with "dirty" if uncommited changes are detected. Here an example for the resulting version: "U-Boot 1.1.4-g3457ac18-dirty" The version is now maintained in the toplevel Makefile and the version headers are autogenerated. Patch by Stefan Roese, 9 Feb 2006
2006-02-21Merge with /home/sr/git/u-bootWolfgang Denk
2006-02-20[Patch] Add basic support for the SMMACO4 Board from PanDaCom.Heiko Schocher
2006-02-08Convert CPCI750 to use common CFI flash driverStefan Roese
Patch by Reinhard Arlt, 8 Feb 2006
2006-02-07Various changes to esd HH405 board specific filesStefan Roese
Patch by Matthias Fuchs, 07 Feb 2006
2006-02-07Update default environment for INKA4x00 board.Wolfgang Denk
2006-01-29Cleanup U-Boot boot messages on ARM.Wolfgang Denk
To match the U-Boot user interface on ARM platforms to the U-Boot standard (as on PPC platforms), some messages with debug character are removed from the default U-Boot build. Enable DEBUG for lib_arm/board.c to enable debug messages. New CONFIG_DISPLAY_CPUINFO and CONFIG_DISPLAY_BOARDINFO options. Patch by Stefan Roese, 24 Jan 2006
2006-01-18Fix various compiler warnings on ppc4xx builds (ELDK 4.0)Stefan Roese
Patch by Stefan Roese, 18 Jan 2006
2006-01-18Add VGA support (CT69000) to CPCI750 board.Stefan Roese
Insert missing __le32_to_cpu() for filesize in ext2fs_read_file(). Patch by Reinhard Arlt, 30 Dec 2005
2006-01-18PMC405 and CPCI405: Moved configuration of pci resources into config file.Stefan Roese
PMC405 and CPCI2DP: Added firmware download and booting via pci. Patch by Matthias Fuchs, 20 Dec 2005
2006-01-13Fix 28F256J3A support on PM520 boardWolfgang Denk
(without bank-switching only 32 MB can be accessed)
2006-01-11Update CHANGELOG.Wolfgang Denk
2005-12-29Add support for 28F256J3A flah (=> 64 MB) on PM520 boardWolfgang Denk
2005-12-19Fix compiler problem with at91rm9200dk board.Wolfgang Denk
Patch by Eugen Bigz, 19 Dec 2005
2005-12-16Merge with /home/sr/git/u-bootv1.1.4U-Boot-1_1_4Wolfgang Denk
2005-12-16MPC5200: Set PCI retry counter to 0 = infinite retry;Wolfgang Denk
The default of 255 is too short for slow devices. Patch by Martin Nykodym, 12 Dec 2005
2005-12-15Changes to Yellowstone & Yosemite 440EP/GR eval boards:Stefan Roese
- Changed GPIO setup to enable another address line in order to address 64M of FLASH. - Added function sdram_tr1_set to auto calculate the tr1 value for the DDR. Patch by Steven Blakeslee, 12 Dec 2005
2005-12-14Merge with /home/m8/git/u-bootWolfgang Denk
2005-12-06Change port configuration for O2DNT (CODEC1 on PSC1)Marian Balakowicz
2005-12-06Fix DPRAM offset/size for MPC8541/8555.Wolfgang Denk
Simplify TQM85xx Makefile handling.
2005-12-04Fix data overflow (typo?) in rtc/ds1302.cWolfgang Denk
2005-12-04Code cleanup, especially MIPS for GCC 4.xWolfgang Denk
2005-12-01Fix U-Boot compilation for MIPS boards using ELDK 4.0Wolfgang Denk
2005-12-01Merge with /home/sr/git/u-bootWolfgang Denk
2005-12-01Adjust TQM834x PHY addresses for latest hardware revision.Wolfgang Denk
2005-12-01Increase malloc arena on TQM5200 board to 256 kB.Wolfgang Denk
With 64 kb uniform flash sector size the old value of 128 kB was too small.
2005-11-30Fix miiphy global data initialization (problem on 4xx boards when noMarian Balakowicz
ethaddr is assigned). Initialization moved from miiphy_register() to eth_initialize(). Based on initial patch for 4xx platform by Matthias Fuchs.
2005-11-30Add support for TQM8541/8555 boards, TQM85xx support reworked:Stefan Roese
- Support for TQM8541/8555 boards added. - Complete rework of TQM8540/8560 support. - Common TQM85xx code now supports all current TQM85xx platforms (TQM8540/8541/8555/8560). - DDR SDRAM size detection added. - CAS latency default values can be overwritten by setting "serial#" to e.g. "ABC0001 casl=25" -> CAS latency 2.5 will be used. If problems are detected with this non default CAS latency, the defualt values will be used instead. - FLASH size detection added. - Moved FCC ethernet driver initialization behind TSEC driver init -> TSEC is first device. Patch by Stefan Roese, 30 Nov 2005
2005-11-29Add support for AMCC 440SP, add support for AMCC Luan 440SP eval board.Stefan Roese
Patch by John Otken, 23 Nov 2005
2005-11-27Changed PPC44x startup message (cpu info, speed...) to common style:Stefan Roese
On PPC44x platforms, the startup message generated in "cpu.c" only comprised the ppc type and revision but not additional informations like speed etc. Those speed infos where printed in the board specific code. This new implementation now prints all CPU infos in the common cpu specific code. No board specific code is needed anymore and therefore removed from all current 44x implementations. Patch by Stefan Roese, 27 Nov 2005
2005-11-25Remove unnnecessary #include <linux/types.h> from include/asm-*/u-boot.hWolfgang Denk
2005-11-25Allow use of include/image.h and include/asm-*/u-boot.h in proprietary code.Wolfgang Denk
The COPYING file was extended to make clear that these files can be used in non-GPL code, too.
