2007-05-05 | Coding stylke cleanup; update CHANGELOG. | Wolfgang Denk | |
Signed-off-by: Wolfgang Denk <wd@denx.de> | |||
2007-05-05 | Add STX GP3 SSA board to MAKEALL script; update CHANGELOG. | Wolfgang Denk | |
2007-05-05 | Make "file" command happy with some config.mk files; update CHANGELOG | Wolfgang Denk | |
2007-05-03 | Update board configuration for STX GP3SSA board: | Wolfgang Denk | |
Enable hush shell, environment in flash rather in EEPROM, more user-friendly default environment, etc. The simple EEPROM environment can be selected easily in the board config file. Signed-off-by: Wolfgang Denk <wd@denx.de> | |||
2007-04-20 | Cleanup compiler warnings, update CHANGELOG | Wolfgang Denk | |
2007-04-18 | Clenaup, update CHANGELOG | Wolfgang Denk | |
2007-04-18 | Update CHANGELOG | Wolfgang Denk | |
2007-04-18 | Cleanup, update CHANGELOG | Wolfgang Denk | |
Sigend-off-by: Wolfgang Denk <wd@denx.de> | |||
2007-04-18 | Merge with /home/wd/git/u-boot/custodian/u-boot-avr32; code cleanup. | Wolfgang Denk | |
2007-04-14 | Update CHANGELOG | Wolfgang Denk | |
2007-04-11 | Update CHANGELOG | Wolfgang Denk | |
2007-04-04 | Minor coding style cleanup. | Wolfgang Denk | |
2007-04-04 | Minor cleanup. | Wolfgang Denk | |
2007-03-22 | Code cleanup / re-insert previous Copyright entries. | Wolfgang Denk | |
2007-03-21 | Code cleanup. Update CHANGELOG | Wolfgang Denk | |
2007-03-08 | Minor cleanup | Wolfgang Denk | |
2007-02-27 | Minor code cleanup. | Wolfgang Denk | |
2007-01-30 | LPC2292 SODIMM port coding style cleanup. | Wolfgang Denk | |
2007-01-19 | Minor code cleanup. | Wolfgang Denk | |
2007-01-16 | Raname solidcard3 into sc3; add redundant env for sc3 | Wolfgang Denk | |
2007-01-15 | Merge with /home/hs/SC3/u-boot | Wolfgang Denk | |
Some code cleanup. | |||
2007-01-10 | Update CHANGELOG | Wolfgang Denk | |
2007-01-07 | Prepare for release 1.2.0v1.2.0U-Boot-1_2_0 | Wolfgang Denk | |
2006-12-22 | Minor code cleanup; update CHANGELOG. | Wolfgang Denk | |
2006-11-30 | Code cleanup. | Wolfgang Denk | |
2006-11-30 | Code cleanup. Update CHANGELOG. | Wolfgang Denk | |
2006-11-27 | Merge with /home/sr/git/u-boot/denx-alpr-merge-test | Wolfgang Denk | |
2006-11-27 | Update CHANGELOG | Wolfgang Denk | |
2006-11-27 | Minor code cleanup. Update CHANGELOG. | Wolfgang Denk | |
2006-11-27 | Merge with /home/stefan/git/u-boot/denx | Stefan Roese | |
2006-11-20 | Update CHANGELOG | Wolfgang Denk | |
2006-11-12 | Update CHANGELOG | Wolfgang Denk | |
2006-11-02 | Release U-Boot 1.1.6v1.1.6U-Boot-1_1_6 | Wolfgang Denk | |
2006-10-28 | Update CHANGELOG. | Wolfgang Denk | |
2006-10-26 | Fix TSEC driver: avoid crashes if PHY is not attached | Ben Warren | |
to a TSEC (e.g. a switch is connected via RMII) or if the PHY is defective/incorrectly configured. Signed-off-by: Ben Warren <bwarren@qstreams.com> | |||
2006-10-26 | Code cleanup. | Wolfgang Denk | |
2006-10-25 | Fix Makefile for "CHANGELOG" target | Wolfgang Denk | |
Merge with /home/sr/git/u-boot/4xx-idcr | |||
2006-10-24 | Switch to automatically generated CHANGELOG file. | Wolfgang Denk | |
(use "make CHANGELOG" to update it from time to time) | |||
2006-10-24 | Fix bug in PPC440 NAND driver cpu/ppc4xx/ndfc.c | Stefan Roese | |
Patch by Stefan Roese, 24 Oct 2006 | |||
2006-10-23 | Fix sequoia separate object direcory building problems. | Marian Balakowicz | |
2006-10-20 | Cleanup compile warnings. Prepare for release 1.1.5v1.1.5U-Boot-1_1_5 | Wolfgang Denk | |
2006-10-20 | Fix compile problem in include/configs/ep82xxm.h | Wolfgang Denk | |
(must have never been tested before!) | |||
2006-10-20 | MCC200: Fix uninitialized variable problem in LCD driver | Wolfgang Denk | |
2006-10-20 | Update CHANGELOG | Stefan Roese | |
2006-10-20 | Add board/cpu specific NAND chip select function to 440 NDFC | Stefan Roese | |
Based on idea and implementation from Jeff Mann Patch by Stefan Roese, 20 Oct 2006 | |||
2006-10-20 | Merge with /home/sr/git/u-boot/440epx-boot-msg | Wolfgang Denk | |
2006-10-18 | Update CHANGELOG | Wolfgang Denk | |
2006-10-18 | Make 4xx bootup message shorter on 440EPx/GRx platforms | Stefan Roese | |
Patch by Stefan Roese, 18 Oct 2006 | |||
2006-10-17 | Add monitor functions for indirect access to PPC440 DCR's | Stefan Roese | |
Patch by Leonid Baryudin, 12 Oct 2006 |
