2006-06-30 | Fix CHANGELOGLABEL_2006_06_30_2020 | Wolfgang Denk | |
2006-06-30 | Merge with /home/m8/git/u-boot | Wolfgang Denk | |
2006-06-30 | Fix CONFIG_440_GX define usage. | Marian Balakowicz | |
2006-06-30 | Remove autogenerated bmp_logo.h file. | Marian Balakowicz | |
2006-06-30 | Merge: Add support for AMCC 440SPe CPU based eval board (Yucca). | Marian Balakowicz | |
2006-06-30 | Add support for AMCC 440SPe CPU based eval board (Yucca). | Marian Balakowicz | |
2006-06-30 | Call serial_initialize() before first debug() is used. | Marian Balakowicz | |
2006-06-26 | Cleanup trab board for GCC-4.x | Wolfgang Denk | |
2006-06-20 | Merge with /home/hs/U-Boot/u-boot-dev | Wolfgang Denk | |
2006-06-19 | Add support for wrPPMC7xx/74xx boards | Heiko Schocher | |
Patch from Richard Danter, 12 Aug 2005 | |||
2006-06-19 | Merge with ssh://atlas/home/wd/git/u-boot/work | Wolfgang Denk | |
2006-06-19 | Merge with ssh://fifi/home/wd/git/u-boot/master | Wolfgang Denk | |
2006-06-16 | Add support for gth2 board | Wolfgang Denk | |
Patch by Thomas Lange, Aug 11 2005 | |||
2006-06-16 | Add support for CONFIG_SERIAL_MULTI on MPC5xxx | Wolfgang Denk | |
Patch by Martin Krause, 8 Jun 2006 This patch supports two serial consoles on boards with a MPC5xxx CPU. The console can be switched at runtime by setting stdin, stdout and stderr to the desired serial interface (serial0 or serial1). The PSCs to be used as console port are definded by CONFIG_PSC_CONSOLE and CONFIG_PSC_CONSOLE2. See README.serial_multi for details. | |||
2006-06-16 | Bugfix in I2C initialisation on S3C2400. | Wolfgang Denk | |
If the bus is blocked because of a previously interrupted transfer, up to eleven clocks are generated on the I2CSCL line to complete the transfer and to free the bus. With this fix pin I2CSCL (PG6) is really configured as GPIO so the clock pulses are really generated. Patch by Martin Krause, 04 Apr 2006 | |||
2006-06-16 | Fix DDR6 errata on TQM834x boards | Wolfgang Denk | |
Patch by Thomas Waehner, 07 Mar 2006 | |||
2006-06-16 | Remove obsolete flash driver board/tqm5200/flash.c | Wolfgang Denk | |
Patch by Martin Krause, 11 Jan 2006 | |||
2006-06-16 | Update configuration for CMC-PU2 board | Wolfgang Denk | |
Patch by Martin Krause, 17 Nov 2005 | |||
2006-06-16 | Add support for PS/2 keyboard on TQM85xx board | Wolfgang Denk | |
Patch by Martin Krause, 07 Nov 2005 Tested on a STK85XX baseboard. Make sure the PS/2 controller has been programmed. Jumper Settings: X66 1-2, 9-10; X61 2-3 | |||
2006-06-16 | Fix TRAB channel switching delay for trab_fkt.bin standalone applikation | Wolfgang Denk | |
Patch by Martin Krause, 08 Nov 2005 In tsc2000_read_channel() the delay after setting the multiplexer to a temperature channel is increased from 1,5 ms to 10 ms. This is to allow the multiplexer inputs to stabilize after huge steps of the input signal level. | |||
2006-06-16 | Adjust TQM5200 make targets | Wolfgang Denk | |
Make the automatic CS configuration the default. The dedicated configurations CONFIG_TQM5200_AA, CONFIG_TQM5200_AB and CONFIG_TQM5200_AC are removed. "TQM5200_config" is now the default for STK52XX.200 base boards. On a STK52XX.100 base board "TQM5200_STK100_config" must be used. Patch by Martin Krause, 07 Nov 2005 | |||
2006-06-16 | Fix setting of environment variable "ver" on trab board | Wolfgang Denk | |
The environment variable "ver" is now set before do_auto_update() is called, so that "ver" can be used in USB update scripts. Patch by Martin Krause, 27 Oct 2005 | |||
2006-06-16 | Fix wrong usage of udelay() in led_blink() on trab board | Wolfgang Denk | |
2006-06-16 | Fix udelay bug in vfd.c for trab board | Wolfgang Denk | |
2006-06-16 | Disable JFFS2 support for trab board | Wolfgang Denk | |
2006-06-16 | Change mtdparts definition on trab board to match current flash map | Wolfgang Denk | |
2006-06-14 | Fix memory init problems on MCC200 board | Wolfgang Denk | |
2006-06-14 | Fix IxEthDB.h to compile again | Stefan Roese | |
Patch by Stefan Roese, 14 Jun 2006 | |||
2006-06-13 | Minor cleanup for PCS440EP board | Stefan Roese | |
Patch by Stefan Roese, 13 Jun 2006 | |||
2006-06-10 | Merge with /home/hs/U-Boot/u-boot-dev | Wolfgang Denk | |
2006-06-10 | Merge with http://www.psyent.com/git/uboot (NIOS2 - Scott McNutt) | Wolfgang Denk | |
2006-06-09 | Fix U-Boot enviroenment sector protection on MCC200 board | Wolfgang Denk | |
2006-06-08 | Nios II - Add Altera EP1C20, EP1S10 and EP1S40 boards | Scott McNutt | |
Patch by Scott McNutt, 08 Jun 2006 | |||
2006-06-08 | Nios II - Add EPCS Controller bootrom work-around | Scott McNutt | |
-When booting from an epcs controller, the epcs bootrom may leave the slave select in an asserted state causing soft reset hang. This patch ensures slave select is negated at reset. Patch by Scott McNutt, 08 Jun 2006 | |||
2006-06-08 | Update PK1C20 board | Scott McNutt | |
-Update base addresses for standard configuration -Eliminate use of CACHE_BYPASS in board code Patch by Scott McNutt, 08 Jun 2006 | |||
2006-06-08 | Nios II - Fix I/O Macros and mini-app stubs | Scott McNutt | |
-Fix asm/io.h macros -Eliminate use of CACHE_BYPASS in cpu code -Eliminate assembler warnings -Fix mini-app stubs and force no small data Patch by Scott McNutt, 08 Jun 2006 | |||
2006-06-07 | Minor cleanup for PCS440EP board | Wolfgang Denk | |
2006-06-06 | Update PCS440EP port to fit into one flash device (incl. environment) | Stefan Roese | |
Patch by Stefan Roese, 06 Jun 2006 | |||
2006-06-02 | Minor cleanup | Wolfgang Denk | |
2006-06-02 | Merge with /home/sr/git/u-boot/denx | Wolfgang Denk | |
2006-06-02 | Fix examples/Makefile; some build targets were lost | Wolfgang Denk | |
2006-06-02 | Add support for PCS440EP board | Stefan Roese | |
Patch by Stefan Roese, 02 Jun 2006 | |||
2006-06-02 | Fix watchdog handling in CFI flash driver | Wolfgang Denk | |
Just use udelay() when waiting for status changes which will implicitely trigger the watchdog. | |||
2006-05-30 | Fix PCI to memory window size problems on PM82x boards | Wolfgang Denk | |
We use the "automatic" mode that was used for the MPC8266ADS and MPC8272 boards. Eventually this should be used on all boards?] Patch by Wolfgang Grandegger, 17 Jan 2006 | |||
2006-05-30 | Correct GPIO setup (UART1/IRQ's) on yosemite & yellowstone | Wolfgang Denk | |
Patch by Stefan Roese, 29 May 2006 | |||
2006-05-30 | * Update Intel IXP4xx support | Wolfgang Denk | |
- Add IXP4xx NPE ethernet MAC support - Add support for Intel IXDPG425 board - Add support for Prodrive PDNB3 board - Add IRQ support Patch by Stefan Roese, 23 May 2006 [This patch does not include cpu/ixp/npe/IxNpeMicrocode.c which still sufferes from licensing issues. Blame Intel.] | |||
2006-05-18 | Fix problem in PVR detection for 440GRLABEL_2006_05_19_1133 | Stefan Roese | |
Patch by Stefan Roese, 18 May 2006 | |||
2006-05-17 | Fix gcc 3.4.x AFLAGS setting for m68k platform. | Marian Balakowicz | |
2006-05-17 | Enable autoboot for M5271EVB board. | Marian Balakowicz | |
2006-05-15 | Merge with /home/sr/git/u-boot/denx | Wolfgang Denk | |
