path: root/CHANGELOG
2007-07-05Minor coding style cleanup. Update CHANGELOG.Wolfgang Denk
2007-07-04Minor coding style cleanup. Rebuild CHANGELOG file.Wolfgang Denk
2007-06-22Coding stylke cleanup; rebuild CHANGELOGWolfgang Denk
2007-06-20Coding style cleanup. Refresh CHANGELOG.Wolfgang Denk
2007-06-06Coding Style cleanup; generate new CHANGELOG file.Wolfgang Denk
2007-05-16Minor Coding Style cleanup, update CHANGELOG.Wolfgang Denk
2007-05-16Coding Style Cleanup, new CHANGELOGWolfgang Denk
2007-05-05Coding stylke cleanup; update CHANGELOG.Wolfgang Denk
2007-05-05Add STX GP3 SSA board to MAKEALL script; update CHANGELOG.Wolfgang Denk
2007-05-05Make "file" command happy with some config.mk files; update CHANGELOGWolfgang Denk
2007-05-03Update board configuration for STX GP3SSA board:Wolfgang Denk
Enable hush shell, environment in flash rather in EEPROM, more user-friendly default environment, etc. The simple EEPROM environment can be selected easily in the board config file. Signed-off-by: Wolfgang Denk <wd@denx.de>
2007-04-20Cleanup compiler warnings, update CHANGELOGWolfgang Denk
2007-04-18Clenaup, update CHANGELOGWolfgang Denk
2007-04-18Update CHANGELOGWolfgang Denk
2007-04-18Cleanup, update CHANGELOGWolfgang Denk
Sigend-off-by: Wolfgang Denk <wd@denx.de>
2007-04-18Merge with /home/wd/git/u-boot/custodian/u-boot-avr32; code cleanup.Wolfgang Denk
2007-04-14Update CHANGELOGWolfgang Denk
2007-04-11Update CHANGELOGWolfgang Denk
2007-04-04Minor coding style cleanup.Wolfgang Denk
2007-04-04Minor cleanup.Wolfgang Denk
2007-03-22Code cleanup / re-insert previous Copyright entries.Wolfgang Denk
2007-03-21Code cleanup. Update CHANGELOGWolfgang Denk
2007-03-08Minor cleanupWolfgang Denk
2007-02-27Minor code cleanup.Wolfgang Denk
2007-01-30LPC2292 SODIMM port coding style cleanup.Wolfgang Denk
2007-01-19Minor code cleanup.Wolfgang Denk
2007-01-16Raname solidcard3 into sc3; add redundant env for sc3Wolfgang Denk
2007-01-15Merge with /home/hs/SC3/u-bootWolfgang Denk
Some code cleanup.
2007-01-10Update CHANGELOGWolfgang Denk
2007-01-07Prepare for release 1.2.0v1.2.0U-Boot-1_2_0Wolfgang Denk
2006-12-22Minor code cleanup; update CHANGELOG.Wolfgang Denk
2006-11-30Code cleanup.Wolfgang Denk
2006-11-30Code cleanup. Update CHANGELOG.Wolfgang Denk
2006-11-27Merge with /home/sr/git/u-boot/denx-alpr-merge-testWolfgang Denk
2006-11-27Update CHANGELOGWolfgang Denk
2006-11-27Minor code cleanup. Update CHANGELOG.Wolfgang Denk
2006-11-27Merge with /home/stefan/git/u-boot/denxStefan Roese
2006-11-20Update CHANGELOGWolfgang Denk
2006-11-12Update CHANGELOGWolfgang Denk
2006-11-02Release U-Boot 1.1.6v1.1.6U-Boot-1_1_6Wolfgang Denk
2006-10-28Update CHANGELOG.Wolfgang Denk
2006-10-26Fix TSEC driver: avoid crashes if PHY is not attachedBen Warren
to a TSEC (e.g. a switch is connected via RMII) or if the PHY is defective/incorrectly configured. Signed-off-by: Ben Warren <bwarren@qstreams.com>
2006-10-26Code cleanup.Wolfgang Denk
2006-10-25Fix Makefile for "CHANGELOG" targetWolfgang Denk
Merge with /home/sr/git/u-boot/4xx-idcr
2006-10-24Switch to automatically generated CHANGELOG file.Wolfgang Denk
(use "make CHANGELOG" to update it from time to time)
2006-10-24Fix bug in PPC440 NAND driver cpu/ppc4xx/ndfc.cStefan Roese
Patch by Stefan Roese, 24 Oct 2006
2006-10-23Fix sequoia separate object direcory building problems.Marian Balakowicz
2006-10-20Cleanup compile warnings. Prepare for release 1.1.5v1.1.5U-Boot-1_1_5Wolfgang Denk
2006-10-20Fix compile problem in include/configs/ep82xxm.hWolfgang Denk
(must have never been tested before!)
