The Polaris board is based on the TrizepsIV module of
Keith & Koep (http://www.keith-koep.com).
Due to change in the usb_board_init() prototype, the USB for
the TrizepsIV was not correctly initialized.
Removed dummy print from usb_board_stop().
This patch looks okay on u-boot-net.git/next branch
but when it was merged to u-boot.git/master the last line is missing
Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
Acked-by: Ben Warren <biggerbadderben@gmail.com>
This patch adds support for esd gmbh MEESC board.
The MEESC is based on an Atmel AT91SAM9263 SoC.
Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu>
update against linux v2.6.30
To enable CAN init, CONFIG_CAN has to be defined in the board config file
and at91_can_hw_init() has to be called in the board specific code.
CAN is available on AT91SAM9263 and AT91CAP9 SoC.
Correct define typo (. -> ,)
Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net>
Add support for Freescale's i.MX31 PDK board (a.k.a. 3 stack board).
This patch assumes that some other program performs the actual
NAND boot.
Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com>
Acked-by: Fabio Estevam <fabioestevam@yahoo.com>
Signed-off-by: HeungJun, Kim <riverful.kim@samsung.com>
CC: Dirk Behme <dirk.behme@googlemail.com>
NAND module should not modify EMIF registers unrelated to CS2
that is used for NAND, i.e. do not modify EWAIT config register
or registers for other Chip Selects.
Without this patch, EMIF configurations made in board_init()
will be invalidated.
Signed-off-by: Thomas Lange <thomas@corelatus.se>
Cc: Peter Pearse <peter.pearse@arm.com>
Kirkwood family controllers are highly integrated SOCs
based on Feroceon-88FR131/Sheeva-88SV131/arm926ejs cpu core.
SOC versions supported:-
1) 88F6281-A0 define CONFIG_KW88F6281_A0
2) 88F6192-A0 define CONFIG_KW88F6192_A0
Other supported features:-
1) get_random_hex() fucntion
2) PCI Express port initialization
3) NS16550 driver support
Contributors:
Yotam Admon <yotam@marvell.com>
Michael Blostein <michaelbl@marvell.com
Reviewed-by: Ronen Shitrit <rshitrit@marvell.com>
Acked-by: Stefan Rose <sr@denx.de>
This patch is required for Kirkwood SoC support
may be used by other ARM architectures
Signed-off-by: Matthias Ludwig <mludwig@ultratronik.de>
On the boards at91sam9260ek, at91sam9263ek and afed9260, the rstc register was
set to 0 after being set to 500 ms for the PHY reset.
Do backup the old reset length and restore it after the MACB initialisation.
Signed-off-by: Sedji Gaouaou <sedji.gaouaou@atmel.com>
Signed-off-by: Stelian Pop <stelian@popies.net>
This patch adds a SPI driver for the Marvell Kirkwood SoC's.
Because of the reset_cpu is soc specific, should be move to soc
And read reset value from SYS_ID register instead of hard code
this patch also supports s3c6410
Acked-by: Peter Pearse <peter.pearse@arm.com>
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
UART hardware on i.MX27 is the same as on the i.MX31 so we just
need to provide the driver with correct address of the registers.
This patch adds generic code to support Freescale's i.MX27 SoCs.
This patch adds the NAND SPL framework needed to boot i.MX31 boards
from NAND.
It has been tested on a i.MX31 PDK board with large page NAND. Small
page NANDs should work as well, but this has not been tested.
Note: The i.MX31 NFC uses a non-standard layout for large page NANDs,
whether this is compatible with a particular setup depends on how
the NAND device is programmed by the flash programmer (e.g. JTAG
debugger).
The patch is based on the work by Maxim Artamonov.
Signed-off-by: Maxim Artamonov <scn1874@yandex.ru>
Currently CONFIG_ONENAND_IPL is used in a number of #ifdef's
in start.S. In preparation for adding support for NAND SPL
the macro CONFIG_PRELOADER is introducted and replaces the
CONFIG_ONENAND_IPL in start.S.
the lowlevel init sequence is the same so unify it
this will allow you to store use it for the env and to boot directly U-Boot from
The PM9261 board is based on the AT91SAM9261-EK board.
Here is the page on Ronetix website:
http://www.ronetix.at/starter_kit_9261.html
Signed-off-by: Ilko Iliev <iliev@ronetix.at>
optimize a few the RAM init
move PSRAM init to pm9263.c
this will allow us after to make the nor lowlevel_init generic
The way the ALL variable is used allows for config.mk's to add more
targets themselves without having to clutter up the top level Makefile.
The SPI flash define is named CONFIG_SF_DEFAULT_SPEED, not
CONFIG_SF_DEFAULT_HZ, so fix the typos in the Blackfin boards.
Building the compression code in lib_generic/ with -O2 rather than -Os
gives a nice speed boost without too much code size increase.
The latest version of U-Boot got a bit fatter in the BSS section which
caused overflows in the RAM region, so increase the monitor size.
The SPI flash layer is much stricter about sector usage than the eeprom
layer we used to use, so update the env settings to better match the
sector alignment of the flashes we use.
Signed-off-by: Vivi Li <vivi.li@analog.com>
The debug tools that interface with the other side of the JTAG console
got much slower when generalizing things, so bump up the default timeout
value on the U-Boot side to cope. Hopefully at some point we can improve
the debug tools to speed things back up.
This script is similar to the netconsole script, but instead works with
the JTAG console device driver that exists on Blackfin parts.
All drivers need to be converted to CONFIG_NET_MULTI.
This patch converts the dm9000 driver.
Signed-off-by: Thomas Smits <ts.smits@gmail.com>
Signed-off-by: Remy Bohmer <linux@bohmer.net>
This patch adds a egiga driver for the Marvell Kirkwood SoC's.
Contributors:
Different flavours of DaVinci SOC's have differences in their EMAC IP
This patch does the following
1) Updates base addresses for DM365
2) Updates MDIO frequencies for DM365 and DM646x
3) Update EMAC wrapper registers for DM365 and DM646x
Patch applies to u-boot-net git. the EMAC driver itself
will be updated shortly to add support for DM365 and DM646x
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
