Ignore defconfig and tools/fdtgrep.
Add PCI IRQ routing information in the board device tree and enable
writing PIRQ routing table and MP table.
Intel Bayley Bay board is a BayTrail based board. Add this board
with existing baytrail fsp support.
This commit adds the microcode blob for BayTrail-I B0 stepping,
CPUID signature 30671h.
BayTrail FSP Gold4 release adds one UPD parameter to control IGD
enable/disable.
On Intel BayTrail SoC, there is a legacy UART (I/O 0x3f8) integrated
into the SoC which is enabled by the FSP. Remove the smsc47x superio
initialization codes.
We should not set up kernel screen_info when the vesa parameters are
insane, otherwise kernel will panic.
Add a cpu1 node to the device tree and enable the MP initialization
on QEMU targets (i440fx and q35).
When running SMP configuration on QEMU (tcg mode, no kvm), there is
a busy loop in start_aps(), calling udelay(), that waits for APs to
show up online. However, there is a chance that VCPU1 will be timeout
waiting, IOW the secondary VCPUs haven't started their execution yet.
This patch adds a 'pause' instruction in __udelay() only for QEMU
target, to give other VCPUs a chance to run. When QEMU sees the
'pause' instruction, it will yeild the execution to other CPUs.
Signed-off-by: Miao Yan <yanmiaobest@gmail.com>
Correct two typos and mention how pci bus will be probed.
On some platforms pci devices behind bridge need to be probed (eg:
a pci uart on recent x86 chipset) before relocation. Remove such
limitation so that dm pci can be used before relocation.
This patch replaces not existing addr_uboot environment variable by
loadaddr at get_uboot_net and burn_uboot_xxx commands. Otherwise these
commands are broken.
Signed-off-by: Vitaly Andrianov <vitalya@ti.com>
Acked-by: Nishanth Menon <nm@ti.com>
Add USB XHCI support for ls2085rdb platform
Signed-off-by: Nikhil Badola <nikhil.badola@freescale.com>
Reviewed-by: York Sun <yorksun@freescale.com>
Add USB XHCI support for ls2085qds platform
Define base address of both usb xhci controllers in lsch3 config
in the format (IMMR + offset) for LS2085A
Define CONFIG_SYS_CACHELINE_SIZE for LS2085A which is required by
USB XHCI stack for alignment
By default the bstopre value has been set to 0x100, used to be 1/4
value of refint. Modern DDR has increased the refresh time. Adjust
to 1/4 of refresh interval dynamically. Individual board can still
override this value in board ddr file, or to use auto-precharge.
Signed-off-by: York Sun <yorksun@freescale.com>
Signed-off-by: Horia Geantă <horia.geanta@freescale.com>
Acked-by: Ruchika Gupta<ruchika.gupta@freescale.com>
HW coherency won't work properly for CAAM write transactions
if AWCACHE is left to default (POR) value - 4'b0001.
It has to be programmed to 4'b0010.
For platforms that have HW coherency support:
-PPC-based: the update has no effect; CAAM coherency already works
due to the IOMMU (PAMU) driver setting the correct memory coherency
attributes
-ARM-based: the update fixes cache coherency issues,
since IOMMU (SMMU) driver is not programmed to behave similar to PAMU
Fixes: b9eebfade974c ("fsl_sec: Add hardware accelerated SHA256 and SHA1")
Reviewed-by: Aneesh Bansal <aneesh.bansal@freescale.com>
Reviewed-by: Mingkai Hu <Mingkai.Hu@freescale.com>
Use fdt_setprop_u32() instead of fdt_setprop().
Fixes: 0181937fa371a ("crypto/fsl: Add fixup for crypto node")
The patch will initialize PCIe controller on EP mode
1. Setup bar:
bar0 32bit 4K for specific configuration
bar1 32bit 8K for MSIX
bar2 64bit 4K for descriptor of memory
bar4 64bit 1M for DMA memory test
2. Setup iATU:
iATU inbound 0-3 to map bar transaction to memory address
started at CONFIG_SYS_PCI_EP_MEMORY_BASE
iATU outbound 0 to map 4G memory space
Signed-off-by: Minghuan Lian <Minghuan.Lian@freescale.com>
PCIe extends device's configuration space to 4k and provides
extended capability. The patch adds function to find them.
The code is ported from Linux PCIe driver.
MC firware version 8.0.0 contains new command flags. This patch
contains modifications in FLIB files to support the new command flags.
Signed-off-by: Itai Katz <itai.katz@freescale.com>
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
The sampling of the oscillator can be done in multiple modes for
generating the entropy value. By default, this is set to von
Neumann. This patch changes the sampling to raw data, since it
has been discovered that the generated entropy has a better
'quality'.
Signed-off-by: Alex Porosanu <alexandru.porosanu@freescale.com>
The entropy delay (the length in system clocks of each
entropy sample) for the RNG4 block of CAAM is dependent
on the frequency of the SoC. By elaborate methods, it
has been determined that a good starting value for all
platforms integrating the CAAM IP is 3200. Using a
higher value has additional benefit of speeding up
the process of instantiating the RNG, since the entropy
delay will be increased and instantiation of the RNG
state handles will be reattempted by the driver. If the
starting value is low, for certain platforms, this can
lead to a quite lengthy process.
This patch changes the starting value of the length of
the entropy sample to 3200 system clocks.
In addition to this change, the attempted entropy delay
values are now printed on the console upon initialization
of the RNG block.
The rtfrqmax & rtfrqmin set the bounds of the expected frequency of the
oscillator, when SEC runs at its maximum frequency. For certain platforms
(f.i. T2080), the oscillator is very fast and thus if the SEC runs at
a lower than normal frequency, the ring oscillator is incorrectly detected
as being out of bounds.
This patch effectively disables the maximum frequency check, by setting a
high enough maximum allowable frequency for the oscillator. The reasoning
behind this is that usually a broken oscillator will run too slow
(i.e. not run at all) rather than run too fast.
To improve eTSEC performance on LS1021A Rev2.0,
snooping of all transmit frames from memory and
all transmit BD memory accesses in enabled.
Signed-off-by: Alison Wang <alison.wang@freescale.com>
On LS1021A Rev2.0, OCRAM's security level needs to be changed to
non-secure access for SD boot. This patch will allow OCRAM
access permission as R/W in SPL.
Bootrom will put cpus into WFE state when boot cpu release cpus, so
target cpu cannot correctly go to spin state.
Add 'sev' to wakeup non-boot cpu that hold on bootrom space, let target
cpu can fall into u-boot spin table.
Signed-off-by: Wang Dongsheng <dongsheng.wang@freescale.com>
Program the external regulator to switch off voltage in deep sleep.
Signed-off-by: Chenhui Zhao <chenhui.zhao@freescale.com>
Acked-by: Alison Wang <alison.wang@freescale.com>
Signed-off-by: Tang Yuantian <Yuantian.Tang@freescale.com>
Enable bootscript support in secure boot for establishing
chain of trust on LS1021atwr.
Signed-off-by: Gaurav Rana <gaurav.rana@freescale.com>
strncpy is safer than strcpy, use it to instead of strcpy.
Signed-off-by: Zhao Qiang <B45475@freescale.com>
when using printf, the parameter type need to be compatible
type, so transform them to compatible type
For ls1021a, Reserve secure code in to memory in case OCRAM
is needed by other usage.
Signed-off-by: Zhuoyu Zhang <Zhuoyu.Zhang@freescale.com>
This function is called from esdhc_send_cmd so we need it available to
everyone.
Fix:
undefined reference to `spi_flash_free'
undefined reference to `spi_flash_probe'
CC: Stefan Roese <sr@denx.de>
Cc: Markus Niebel <Markus.Niebel@tq-group.com>
1. Add USDHC, I2C, UART, 74LV, USB, QSPI support.
2. Support SPL
3. CONFIG_MX6UL_14X14_EVK_EMMC_REWORK is introduced, this board default
supports sd for usdhc2, but can do hardware rework to make usdhc2 support
emmc.
Boot Log:
U-Boot SPL 2015.07-rc3-00124-g35d727b (Jul 20 2015 - 18:40:59)
reading u-boot.img
reading u-boot.img
U-Boot 2015.07-rc3-00124-g35d727b (Jul 20 2015 - 18:40:59 +0800)
CPU: Freescale i.MX6UL rev1.0 792 MHz (running at 396 MHz)
CPU: Commercial temperature grade (0C to 95C)CPU: Thermal invalid data, fuse: 0x0
- invalid sensor device
Reset cause: POR
Board: MX6UL 14x14 EVK
I2C: ready
DRAM: 512 MiB
MMC: FSL_SDHC: 0, FSL_SDHC: 1
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: CPU Net Initialization Failed
No ethernet found.
Hit any key to stop autoboot: 0
Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
i.MX6UL's DRAM space starts from 0x80000000, same to i.MX6SX, so use
same address with i.MX6SX.
1. Define two structures mx6ul_iomux_ddr_regs and mx6ul_iomux_grp_regs.
2. Add a new function mx6ul_dram_iocfg to configure dram io.
3. Refactor MMDC1 macro, discard "#ifdef CONFIG_MX6SX". Since
only mmdc0 channel exists on i.MX6SX/UL, redefine MMDC1 macro support
runtime check, but not hardcoding #ifdef macros.
4. Introduce mx6ul-ddr.h, which includes the register address for DRAM
IO configuration.
DRAM space starts from 0x80000000 for i.MX6UL, so need to
fix LOADADDR, SYS_TEXT_BASE.
i.MX6UL does not have GPIO6/7, so do not include them for i.MX6UL.
PAD_CTL_SPEED_LOW for i.MX6SX/UL is (0 << 6)
Signed-off-by: Ye.Li <B37916@freescale.com>
1.Update WDOG settings.
2.No need to gate/ungate all PFDs for i.MX6UL.
i.MX6UL features an Cortex-A7 core, it does not have PL310 as other i.MX6
chips. To Cortex-A7 core, If D-Cache is enabled, L2 Cache is enabled.
There is on specific switch for on/off L2 Cache, so default select
SYS_L2CACHE_OFF.
1. Add enet, uart, i2c, ipg clock support for i.MX6UL.
2. Correct get_periph_clk, it should account for
MXC_CCM_CBCDR_PERIPH_CLK2_PODF_MASK.
3. Refactor get_mmdc_ch0_clk to make all i.MX6 share one function,
but not use 'ifdef'.
4. Use CONFIG_FSL_QSPI for enable_qspi_clk, but not #ifdef CONFIG_MX6SX.
5. Use CONFIG_PCIE_IMX for pcie clock settings, use CONFIG_CMD_SATA for
sata clock settings. In this way, we not need "#if defined(CONFIG_MX6Q)
|| defined....", only need one CONFIG_PCIE_IMX in header file.
Since i.MX6UL use A7 core, but not A9 core, we do not need
the erratas for i.MX6UL.
