Also, remove all calls to eth_init() in boards that use MACB
Update CHANGELOG
r12 is used for accessing the GOT not r14. Fix this in the
comment.
We were missing 8641HPCN_36BIT and MPC8536DS_36BIT.
Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
Fix following warnings:
$ ./MAKEALL EVB64260 P3G4 ZUMA
Configuring for EVB64260 board...
mpsc.c: In function 'mpsc_putchar_early':
mpsc.c:121: warning: dereferencing type-punned pointer will break strict-aliasing rules
mpsc.c:127: warning: dereferencing type-punned pointer will break strict-aliasing rules
ehci_submit_async() doesn't really zero out the QH transfer overlay (as the EHCI
specification suggests) which leads to the controller seeing the "token" field
as the previous call has left it, i.e.:
- if a timeout occured on the previous call (Active bit left as 1), controller
incorrectly tries to complete a previous transaction on a newly programmed
endpoint;
- if a halt occured on the previous call (Halted bit set to 1), controller just
ignores the newly programmed TD(s) and the function then keeps returning error
ad infinitum.
This turned out to be caused by the wrong orger of the arguments to the memset()
call in ehci_alloc(), so the allocated TDs weren't cleared either.
While at it, stop needlessly initializing the alternate next TD pointer in the
QH transfer overlay...
Acked-by: Remy Bohmer <linux@bohmer.net>
The console_buffer size is declared in common/main.c as
-- char console_buffer[CONFIG_SYS_CBSIZE + 1];
so this extern definition is wrong.
Signed-off-by: Remy Bohmer <linux@bohmer.net>
- Also modified the code to use io accessors.
Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com>
Signed-off-by: Dipen Dudhat <dipen.dudhat@freescale.com>
Acked-by: Kumar Gala <galak@kernel.crashing.org>
On P2020RDB eTSEC2 is connected to Vitesse VSC8221 PHY via SGMII.
Current TBI PHY settings for SGMII mode cause link problems on
this platform, link never comes up.
Fix this by making TBI PHY settings configurable and add a working
configuration for P2020RDB.
Signed-off-by: Felix Radensky <felix@embedded-sol.com>
Acked-by: Andy Fleming <afleming@freescale.com>
Acked-by: Peter Tyser <ptyser@xes-inc.com>
Tested-by: Peter Tyser <ptyser@xes-inc.com>
Use a slighly larger value of CLK_CTRL for DDR at 667MHz
which fixes random crashes while linux booting.
Applicable for both NAND and NOR boot.
Signed-off-by: Sandeep Gopalpet <sandeep.kumar@freescale.com>
Because the variable was getting defined twice.
Commit 460c2ce3 "MPC5200: workaround data corruption for unaligned
local bus accesses" fixed the problem for MPC5200 only, but MPC512x is
affected as well, so apply the same fix here, too.
Cc: Detlev Zundel <dzu@denx.de>
Acked-by: Detlev Zundel <dzu@denx.de>
The MPC5200 has a nasty problem that will cause silent data corruption
when performing unaligned 16 or 32 byte accesses when reading from the
local bus - typically this affects reading from flash. The problem can
be easily shown:
=> md fc0c0000 10
fc0c0000: 323e4337 01626f6f 74636d64 3d72756e 2>C7.bootcmd=run
fc0c0010: 206e6574 5f6e6673 00626f6f 7464656c net_nfs.bootdel
fc0c0020: 61793d35 00626175 64726174 653d3131 ay=5.baudrate=11
fc0c0030: 35323030 00707265 626f6f74 3d656368 5200.preboot=ech
=> md fc0c0001 10
fc0c0001: 65636801 00000074 0000003d 00000020 ech....t...=...
fc0c0011: 0000005f 00000000 00000074 00000061 ..._.......t...a
fc0c0021: 00000000 00000064 00000065 00000035 .......d...e...5
fc0c0031: 00000000 00000062 0000003d 0000006f .......b...=...o
=> md.w fc0c0001 10
fc0c0001: 0000 3701 0000 6f74 0000 643d 0000 6e20 ..7...ot..d=..n
fc0c0011: 0000 745f 0000 7300 0000 6f74 0000 6c61 ..t_..s...ot..la
This commit implements a workaround at least for the most blatant
problem: using memcpy() from NOR flash. We rename the assembler
routine into __memcpy() and provide a wrapper, which will use a
byte-wise copy loop for unaligned source or target addresses when
reading from NOR flash, and branch to the optimized __memcpy()
in all other cases, thus minimizing the performance impact.
Tested on lite5200b and TQM5200S.
ATAG_VIDEOLFB is not used anywhere.
The belowing warning is occurred due to this ATAG.
[ 0.000000] Ignoring unrecognised tag 0x54410008
This patch fixed it.
Acked-by: Martin Krause <Martin.Krause@tqs.de>
UBI: initialise update marker
The in kernel copy of a volume's update marker is not initialised from the
volume table. This means that volumes where an update was unfinnished will
not be treated as "forbidden to use". This is basically that the update
functionality was broken.
Signed-off-by: Peter Horton <zero@colonel-panic.org>
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
Since I haven't been actively maintaining these boards for a long while,
keeping myself as their maintainer makes no sense.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Ensure that date is called only with LC_ALL=C locale set to make dates
locale neutral thus preventing lurking of non-ASCII characters into
U-Boot binary.
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
Changed LANG= into LC_ALL= as suggested by Mike Frysinger <vapier@gentoo.org>
Orion5x MPP and GPIO setting code had writel arguments
the wrong way around. Fixed and tested.
Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
Signed-off-by: Terry Lv <r65388@freescale.com>
Fix commit message and code formatting.
The ARM ABI requires that the stack be aligned to 8 bytes as it is noted
in Procedure Call Standard for the ARM Architecture:
http://infocenter.arm.com/help/topic/com.arm.doc.ihi0042d/index.html
Unaligned SP also causes the problem with variable-length arrays
allocation when VLA address becomes less than stack pointer during
aligning of this address, so the next 'push' in the stack overwrites
first 4 bytes of VLA.
Signed-off-by: Vitaly Kuzmichev <vkuzmichev@mvista.com>
Tested on tx25(mx25), imx27lite(mx27), qong(mx31) and trab(s3c2400)
Tested-by: Wolfgang Denk <wd@denx.de>
Move it inside the #ifdef CONFIG_NET_MULTI to avoid
eth.c:64: warning: 'eth_mac_skip' defined but not used
messages from a number of old, non-CONFIG_NET_MULTI boards.
TFTP'ing a file of size 1747851 bytes with CONFIG_IP_DEFRAG and
CONFIG_TFTP_BLOCKSIZE set to 4096 fails with a timeout, because
the last fragment is not taken into account. This patch fixes
IP fragments having less than 8 bytes of payload.
Signed-off-by: Stephane Fillod <stephane.fillod@grassvalley.com>
Acked-by: Alessandro Rubini <rubini@gnudd.com>
messages from anumber of old, non-CONFIG_NET_MULTI boards.
Cc: Ben Warren <biggerbadderben@gmail.com>
Commit 37566090 "compiler.h: unify system ifdef cruft here" added both
a "#include <errno.h>" and a "extern int errno;" to include/compiler.h
which is causing build warnings for some systems, for example for the
"netstar" board:
In file included from /home/wd/git/u-boot/work/lib/crc32.c:15:
include/compiler.h:28: warning: function declaration isn't a prototype
The declaration of "errno" should be redundant, as <errno.h> is
supposed to provide a correct declaration, so drop it.
Cc: Mike Frysinger <vapier@gentoo.org>
The push / pop instructions used in this file are available only with
more recent tool chains:
cache.S: Assembler messages:
cache.S:133: Error: bad instruction `push {r0,r1,r2,lr}'
cache.S:160: Error: bad instruction `pop {r1,r2,r3,pc}'
cache.S:164: Error: bad instruction `push {r0,r1,r2,lr}'
cache.S:191: Error: bad instruction `pop {r1,r2,r3,pc}'
Change push/pop into stmfd/ldmfd instructions to support older
versions of binutils as well.
I verified that the modified source code generates exactly the same
binary code.
Cc: Sandeep Paulraj <s-paulraj@ti.com>
Cc: Tom Rix <tom@bumblecow.com>
CONFLICT (rename/add): Rename
board/davinci/da830evm/Makefile->board/ti/tnetv107xevm/Makefile
in 89b765c7f6ddfde07ba673dd4adbeb5da391a81b.
board/ti/tnetv107xevm/Makefile added in HEAD
But files were identical, so no problem.
This patch adds support for the LaCie ED Mini V2 product
which is based on the Marvell Orion5x SoC.
This patch provides access to the 16550-compatible
serial device of the Orion5x SoC.
This patch adds support for the Marvell Orion5x SoC.
It has no use alone, and must be followed by a patch
to add Orion5x support for serial, then support for
the ED Mini V2, an Orion5x-based product from LaCie.
Acked-by: Tom <Tom@bumblecow.com>
This patch adds support for the Samsung Goni board (S5PC110 SoC)
When set to PULL_NONE, gpio_set_pull function is returned without write the register.
Part of this patch is by: Mikhail Kshevetskiy.
Stack must be aligned to 8 bytes on PXA (possibly all armv5te) for LDRD/STRD
instructions. In case LDRD/STRD is issued on an unaligned address, the behaviour
is undefined.
The issue was observed when working with the NAND code, which was rendered
disfunctional. Also, the vsprintf() function had serious problems with printing
64bit wide long longs. After aligning the stack, this wrong behaviour is no
longer present.
Tested on:
Marvell Littleton PXA310 board
Toradex Colibri PXA320 board
Aeronix Zipit Z2 PXA270 handheld
Voipac PXA270 board
Provides initial support for TI OMAP-L138/DA850 SoC devices on
a Logic PD EVM board.
Provides:
Initial boot and configuration.
Support for i2c.
UART support (console).
Signed-off-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
Acked-by: Ben Gardiner <bengardiner@nanometrics.ca>
Reviewed-by: Wolfgang Denk <wd@denx.de>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
DA850/OMAP-L138 is a new SoC from Texas Instruments
(http://focus.ti.com/docs/prod/folders/print/omap-l138.html).
This SoC is similar to DA830/OMAP-L137 in many aspects. Hence
rename the da830 specific files and folders to da8xx to
accommodate DA850/OMAP-L138.
TI's DA850/OMAP-L138 platform is similar to DA830/OMAP-L137
in many aspects. So instead of repeating the same code in
multiple files, move the common code to a different file
and call those functions from the respective da830/da850
files.
Acked-by: Nick Thompson <nick.thompson@ge.com>
Pandora has a capacitor connected as backup battery, which allows
retaining RTC for some time while main battery is removed. Enable backup
battery charge function to charge that capacitor.
Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
I have updated this patch based on the comments [1] by Wolfgang Denk and
removed unused variables.
[1][http://lists.denx.de/pipermail/u-boot/2010-May/071728.html]
Reduce the number of reads per byte transferred on the BUF register from 2 to 1 and
take advantage of the TX buffer in the SPI module. On LogicPD OMAP-L138 EVM,
SPI read throughput goes up from ~0.8Mbyte/s to ~1.3Mbyte/s. Tested with a 2Mbyte image file.
Remove unused variables in the spi_xfer() function.
Signed-off-by: Delio Brignoli <dbrignoli@audioscience.com>
Tested-by: Ben Gardiner <bengardiner@nanometrics.ca>
This patch adds support for the EMIF4 interface
available in the AM35x processors.
Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com>
Signed-off-by: Sanjeev Premi <premi@ti.com>
This patch adds basic support for the AM3517EVM.
It includes:
- Board files (.c and .h)
- Default configuration file
- Updates for Makefile
Consolidated SDRC related functions into one file - sdrc.c
And also replaced sdrc_init with generic memory init
function (mem_init), this generalization of omap memory setup
is necessary to support the new emif4 interface introduced in AM3517.
initialized for CS1
The patch makes sure that size for SDRC CS1 gets calculated
only when the CS1 SDRC is initialized.
