Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
Support bootdelay=0 in abortboot for the CONFIG_AUTOBOOT_KEYED case
similar to the CONFIG_ZERO_BOOTDELAY_CHECK support for the
!CONFIG_AUTOBOOT_KEYED case.
Do this by reversing the loop so we do at least one iteration before
checking for timeout.
Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk>
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
Generic i386 reset - #define made redundant by weak function
CONFIG_SC520 is now used for conditional compile
Reset function specific to AMD SC520 microcontroller - Is more of a
'hard reset' that the triple fault.
Requires CONFIG_SYS_RESET_SC520 to be defined in config
I would have liked to add this to a new file (cpu/i386/sc520/reset.c)
but ld requires that a object file in a library arhive MUST contain
at least one function which does not override a weak function (and is
called from outside the object file) in order for that object file to
be extracted from the archive. This would be the only function on the
new file, and hence, will never get linked in.
Moved from interrupts.c to cpu.c and made into a weak function to
allow vendor specific override
Vendor specific CPU reset (like the AMD SC520 MMCR reset) can now be
added to the vendor specific code without the need to remember to
#undef usage of the generic method and if you forget to include your
custom reset method, you will always get the default.
This allows for future tidy ups and functionality that will require
set_vector ()
Brings i386 in line with other CPUs with a reset vector and frees up reset.c
for CPU reset functions
Right now this is only used by keymile.
Signed-off-by: Gary Jennejohn <garyj@denx.de>
This patch extracts the identical config options for the
keymile boards mgcoge, mgsuvd and kmeter1 in a new
common config file keymile-common.h.
Check the presence of the PIGGY on the keymile boards mgcoge,
mgsuvd and kmeter1. If the PIGGY is not present, dont register
this Ethernet device.
Acked-by: Ben Warren <biggerbadderben@gmail.com>
This patch adds support for the kmeter1 board from Keymile,
based on a Freescale MPC8360 CPU.
- serial console on UART 1
- 256 MB DDR2 RAM
- 64 MB NOR Flash
- Ethernet RMII Mode over UCC4
- PHY SMSC LAN8700
Add a do_div() wrapper, lldiv(). The new inline function doesn't modify
the dividend and returns the result of division, so it is useful
in complex expressions, i.e. "return(a/b)" -> "return(lldiv(a,b))"
Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com>
Error with CONFIG_NAND_LEGACY in common/cmd_nand.c:
With current code "nand read.jffs2s" (read and skip bad blocks) is always interpreted as
"nand read.jffs2" (read and fill bad blocks with 0xff). This is because ".jffs2" is
tested before ".jffs2s" and only the first two characters are compared.
Correction:
Test for ".jffs2s" first and compare the first 7 characters.
This patch renames NAND_MAX_CHIPS to CONFIG_SYS_NAND_MAX_CHIPS and
changes the default from 8 to 1 for the legacy and the new MTD
NAND layer. This allows to remove all NAND_MAX_CHIPS definitions
in the board config files because none of the boards use multi
chip support (NAND_MAX_CHIPS > 1) so far. The bamboo and the DU440
define
#define NAND_MAX_CHIPS CONFIG_SYS_MAX_NAND_DEVICE
but that's bogus and did not work anyhow.
Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
We load the secondary stage u-boot image from NAND to
system memory by nand_load, but we did not flush d-cache
to memory, nor invalidate i-cache before we jump to RAM.
When the system has cache enabled and the TLB/page attribute
of system memory is cacheable, it will cause issues.
- 83xx family is using the d-cache lock, so all of d-cache
access is cache-inhibited. so you can't see the issue.
- 85xx family is using d-cache, i-cache enable, partial
cache lock. you will see the issue.
This patch fixes the cache issue.
Signed-off-by: Dave Liu <daveliu@freescale.com>
Enable nand lock, unlock and status of lock feature.
Not every device and platform requires this, hence,
it is under define for CONFIG_CMD_NAND_LOCK_UNLOCK
Nand unlock and status operate on block boundary instead
of page boundary. Details in:
http://www.micron.com/products/partdetail?part=MT29C2G24MAKLAJG-6%20IT
Intial solution provided by Vikram Pandita <vikram.pandita@ti.com>
Includes preliminary suggestions from Scott Wood
Signed-off-by: Nishanth Menon <nm@ti.com>
Rather than putting the function prototype for board_nand_init() in the one
place where it gets called, put it into nand.h so that every place that also
defines it gets the prototype. Otherwise, errors can go silently unnoticed
such as using the wrong return value (void rather than int) when defining
the function.
- Add subpage write support
- Add onenand_oob_64/32 ecclayout
This has been missing and without it UBI has some incompatibilies issues
with the current (>= 2.6.27) Linux kernel version. vid_hdr_offset is
placed differently (2048 instead of 512) without this fix.
Add missing markbad function
If not, it's hang when it entered the mtd->mark_bad().
Update OneNAND command to support bad block awareness.
Also change the OneNAND command style to better match the
NAND version.
Acked-by: Kyungmin Park <kyungmin.park@samsung.com>
The version (ver_id) was not stored in the onenand_chip structure and
because of this the continuous locking scheme could be enabled on some
chips.
Sync with OneNAND kernel codes
in systems which are configured without flash
Update CHANGELOG
The x86 based version of Darwin behaves the same quirky way as the powerpc
Darwin, so only check HOSTOS when setting up Darwin workarounds.
The code in fdt_resize() to extend the fdt size to end on a page boundary
is wrong for fdt's not located at an address aligned on a page boundary.
What's even worse, the code would make actualsize shrink rather than grow
if (blob & 0xfff) was bigger than the amount of padding added by ALIGN(),
causing fdt_add_mem_rsv to fail.
Fix it by aligning end address (blob + size) to a page boundary instead.
For aligned fdt's this is equivalent to what we had before.
The recvfrom() function takes a socklen_t, not an int.
