This patch add support for the Trizeps IV module (520Mhz).
This patch adds support for multiple serial ports to the PXA target.
FFUART, BTUART and STUART are supported.
Code is broken for PXA270 due to "invalid lvalue in assignment".
This patch fix it in pxa-regs.h
Signed-off-by: Jason Jin <Jason.jin@freescale.com>
Stop using inline string functions on MIPS as other ARCHs do so,
since the optimized inline asm versions are not small.
This change is triggered by a following MIPS build error:
common/libcommon.a(exports.o)(.text+0xdc): In function `jumptable_init':
common/exports.c:32: undefined reference to `strcmp'
make: *** [u-boot] Error 1
Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com>
This patches contains several bugfixes and cleanups in the latest upstream:
- Don't include linux/config.h
- Remove buggy inline version of memscan.
- Merge with Linux 2.6.11-rc3.
- Fix undefined reference to strcpy in binfmt_misc caused by gcc 3.4.
- Goodbye mips64. 31704 lines of code bite the dust.
- Replace extern inline with static inline.
- Fix return value of strncpy.
- Remove a bunch more "$1" clobbers.
Fix incorrect blob address calculation in do_bootm_linux() that prevents
booting the kernel from a multi-file image (kernel + initrd + blob).
Also, make minor updates to the U-Boot's output and to the coding style.
Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
o add drivers/sil680.c to support the Sil680 IDE-controller.
o drivers/Makefile: add sil680.o.
Signed-off-by: Gary Jennejohn <garyj@denx.de>
Boards with CONFIG_OF_LIBFDT enabled are not able to boot old-style
kernels using the board info structure (instead of passing a device tree)
This change allows the old style booting to be used if the fdt argument
was not passed to 'bootm'.
Acked-by: Kim Phillips <kim.phillips@freescale.com>
Affects boards: icecube (lite5200), jupiter, motionpro, tqm5200
Tested on: lite5200b
Note: the fixup functions have not been moved to a common place. This
patch is targeted for immediate merging as in solves a build issue, but
the final name/location of the fixups is still subject to debate. I
propose to merge this now, and move the fixups in the next merge window
to be usable by all targets.
Given the path to a node, fdt_find_and_setprop() allows a property value
to be set directly.
The RTC on the M1575 ULI chipset requires a dummy read before
we are able to talk to the RTC. We accomplish this by adding a
second memory region to the PHB the ULI is on and read from it.
The second region is added to maintain compatiabilty with Linux's
view of the PCI memory map.
pcie is now differentiated from pci. Add 8641 bus-range updates.
Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
The 440EPx has a problem when the PCI_CACHE_LINE_SIZE register is
set to non-zero, because it doesn't support MRM (memory-read-
multiple) correctly. We now added the possibility to configure
this register in the board config file, so that the default value
of 8 can be overridden.
Here the details of this patch:
o drivers_pci_auto.c: introduce CFG_PCI_CACHE_LINE_SIZE to allow
board-specific settings. As an example the sequoia board requires 0.
Idea from Stefan Roese <sr@denx.de>.
o board/amcc/sequoia/init.S: add a TLB mapping at 0xE8000000 for the
PCI IO-space. Obtained from Stefan Roese <sr@denx.de>.
o include/configs/sequoia.h: turn CONFIG_PCI_PNP back on and set
CFG_PCI_CACHE_LINE_SIZE to 0.
The old code had a loop limit overflow bug which caused a semi-
infinite loop for small packets, because in "i<len-8", "i" was signed,
but "len" was unsigned, and "len-8" became a huge number for small
values of "len".
This is a workaround which replaces broken commit 8f1bc284.
This reverts commit 9468e680.
Commit 16e23c3f5da removing allocation of PCSRBAR is sufficient.
The TFTP OACK code trusts that the incoming packet is formated as
ASCII text and can be processed by string functions. It also has a
loop limit overflow bug where if the packet length is less than 8, it
ends up looping over *all* of memory to find the 'blksize' string.
This patch solves the problem by forcing the packet to be null
terminated and using strstr() to search for the sub string.
this had slipped through the cracks, since the sbc board was added
after I wrote the original patch to remove all these symbols, and
before it was merged.
to get rid of a *lot* of compiler warnings.
..because it caused compiler errors and there seems to be no
board maintainer to take care of this.
<ed.swarthout@freescale.com>
The problem is pciauto_setup_device() getting called from fsl_pci_init.c
is allocating memory space it doesn't need.
Signed-off-by: Ed Swarthout <ed.swarthout@freescale.com>
Signed-off-by: Andy Fleming <afleming@freescale.com>
Restore CONFIG_EXTRA_ENV_SETTINGS definition which contains the
correct consoledev needed for linux boot.
Standardize on fdt{file,addr} var to hold dtb file name.
Set PCI inbound memory region from CFG_MEMORY_{BUS,PHYS}.
The L2 cache size is 512KB for 8568, print out the correct informaiton.
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
if a board/$(VENDOR)/common/Makefile exists, build it.
also add the first such case, board/freescale/common/Makefile, to
handle building board-shared EEPROM, PIXIS, and MDS-PIB code, as
dictated by board configuration.
thusly get rid of alternate build dir errors such as:
FATAL: can't create /work/wd/tmp/u-boot-ppc/board/freescale/mpc8360emds/../common/pq-mds-pib.o: No such file or directory
by putting the common/ mkdir command in its proper place (the common
Makefile). Common bits from existing individual board Makefiles have
been removed.
TFTP does not work anymore after multicast tftp
patch was applied on little endian systems.
This patch fix it.
The logic to check if there is a correct MAC address in the DM9000
EEPROM, added in the last patch, is wrong. Now the MAC address is
always taken from the environment, even if a suitable MAC is present
in the EEPROM.
Fix the following warnings:
- usb.c:xx: warning: function declaration isn't a prototype
- usb_ohci.c:xxx: warning: passing argument 1 of '__fswab32' makes integer
from pointer wihtout a cast
Signed-off-by: Martin Krause <martin.krase@tqs.de>
CPU physical address space was being wasted by allocating a
PCSRBAR PCI inbound region to it's memory space.
As a rule, PCSRBAR should be left alone since it does not affect
transactions from self and other masters may have changed it.
This patch fixes the "type qualifiers ignored on fuction return tpye"
warning for include/s3c2410.h
Signed-off-by: Martin Krause <martin.krause@tqs.de>
omap2420h4 switched to cfi, so remove old (already disabled) flash.c
and flash_probe() calls in env_flash.c.
Signed-off-by: Dirk Behme <dirk.behme@gmail.com>
and make some minor corrections to the FDT part of the README.
define there own I/O functions.
(Needed for the pcs440ep board).
- The default I/O Functions are again 8 Bit accesses.
- Added CONFIG_CMD_IDE for the pcs440ep Board.
As experienced on lwmon5, on some boards the POST memory test can
corrupt the global data buffer (bd). This patch fixes this issue
by checking and limiting this area.
Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
Since this RTC POST test is taking quite a while to complete
it's only initiated upon special keypress same as the complete
memory POST.
This patch adds support for the 2nd EEPROM (AT24C128) on the lwmon5
board. Now the "eeprom" command can be used to read/write from/to this
device. Additionally a new command was added "eepromwp" to en-/disable
the write-protect of this 2nd EEPROM.
The 1st EEPROM is not affected by this write-protect command.
This patch adds support for the matrix keyboard on the lwmon5 board.
Since the implementation in the dsPCI is kind of compatible with the
"old" lwmon board, most of the code is copied from the lwmon
board directory.
