Add two missing Kconfig options for Novena and drop the SPL
from the Novena config.
Cc: Sean Cross <xobs@kosagi.com>
Cc: Fabio Estevam <fabio.estevam@freescale.com>
The magic bit toucher needs to be updated to reflect the new board Kconfig structure
Signed-off-by: Zoltan HERPAI <wigyori@uid0.hu>
Acked-by: Hans de Goede <hdegoede@redhat.com>
Add support for the 2 ehci controllers found on the sun6i (A31) soc.
Acked-by: Ian Campbell <ijc@hellion.org.uk>
Add proper Kconfig options to select the usb Vbus gpio-s, besides moving to
Kconfig being the right thing to do, an added advantage of this is that it
allows for boards without Vbus gpio-s.
Enable the SPL now that we've all the necessary bits in place.
Without this the cache will only work in write-through mode, and as soon as
it is put in write-back mode things break.
Add full support for dram initialization, using a fixed clock and autodetection
of the memory organization (numbers of channels, bus-width, etc.).
This is based on dram_sun6i.c and dram.h from u-boot in the Allwinner A31 SDK,
extended with extra initialization sequences and the autodetect algorithm
from boot0.
In preparation for adding sun6i dram support.
Not used atm, for future use (e.g. PSCI).
Add clock_init_safe and clockset_pll5 functions, as these are needed for
SPL support resp. DRAM init (which is needed for SPL too).
Also add some extra clock register constant defines.
The A31 uses the AXP221 pmic for various voltages.
Signed-off-by: Oliver Schinagl <oliver@schinagl.nl>
Changes in v2:
-Rebase
Changes in v3:
-Add support for all dldo and aldo-s
-Add Kconfig option to select building AXP221 and to select voltage of
dldo and aldo-s
Changes in v4:
-Add axp221_setbits helper function
-Use symbolic names for enabled bits in CTRL1 - CTRL3 registers
The A31 uses a new push-pull two wire interface, which features higher
transfer speeds (upto 6 MHz) in theory. While the hardware can burst 8
bytes each time, this driver will only see very little use and thus is
limited to single byte transmission only.
This is a MIME GnuPG-signed message. If you see this text, it means that
your E-mail or Usenet software does not support MIME signed messages.
The Internet standard for MIME PGP messages, RFC 2015, was published in 1996.
To open this message correctly you will need to install E-mail or Usenet
software that supports modern Internet standards.
Move CONFIG_DEFAULT_DEVICE_TREE from board config
directly to defconfig.
This patch removes compilation warning:
include/configs/zynq_zybo.h:24:0: warning: "CONFIG_DEFAULT_DEVICE_TREE"
redefined [enabled by default]
#define CONFIG_DEFAULT_DEVICE_TREE zynq-zybo
Commit 2e07c249a67e (kconfig: arm: introduce symbol for ARM CPUs)
collected the default values of CONFIG_SYS_CPU into arch/arm/Kconfig.
This commit moves "armv8" to there for consistency.
Acked-by: Georges Savoundararadj <savoundg@gmail.com>
This commit adds "select CPU_V7" for some new boards that were not
covered by commit 2e07c249a67e
(kconfig: arm: introduce symbol for ARM CPUs).
Redundant "SYS_CPU" defines and "string" directives should be removed.
There is no board with CPU "arm_intcm".
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
The Makefiles call the respective interpreter explicitly, but this makes
it easier to use the scripts manually.
(This commit follows commit 06ed5c2bfaca of Linux Kernel)
mcc200 and prs200 are old and have no maintainer. Remove the boards.
This also removes the mcc200 specific 1bpp BMP support from
common/lcd.c
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Cc: York Sun <yorksun@freescale.com>
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
This implies that all the km_kirkwood boards and their variants now are
using the generic board init sequence.
Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
When DEBUG is set, output memory region used for malloc().
Signed-off-by: Thierry Reding <treding@nvidia.com>
size_t is the canonical type to represent variables that contain a size.
Use it instead of signed integer. Physical addresses can be larger than
32-bit, so use a more appropriate type for them as well. phys_addr_t is
a type that is 32-bit on systems that use 32-bit addresses and 64-bit if
the system is 64-bit or uses a form of physical address extension to use
a larger address space on 32-bit systems. Using these types the same API
can be implemented on a wider range of systems.
Remove two gratuituous blank lines, uses u32 (instead of int) as the
type for values that will be written to a register, moves the beginning
of the variable declaration section to a separate line (rather than the
one with the opening brace) and keeps the function signature on a single
line where possible.
This reverts commit 1e96220a5687efae2aed45ce56e143336c40d0a7.
Remove duplicated vxworks.h header.
The same change was done by
"ARM: prevent compiler warnings from bootm.c"
(sha1: 8d196e52b58d1e50a80c2f5067b201cda521c75c)
CONFIG_UNIPHIER_SERIAL has been moved to Kconfig and
it is defined in ./.config but not in spl/.config,
so pin_init() should be called from the normal image
so that UART works correctly.
This commit merges
arch/arm/cpu/armv7/uniphier/ph1-*/board_postclk_init.c
to
arch/arm/cpu/armv7/uniphier/board_postclk_init.c
Because PH1-Pro4 does not have the BCU block, add __weak to
bcu_init().
In the current implementation of the boot sequence of UniPhier
platform, 32KB temporary RAM is available before relocation.
The malloc area and the stack shares the 32KB area.
With CONFIG_SYS_MALLOC_F_LEN set to 0x7000 (28KB), only 0x1000 (4KB)
is left for the stack. In some use cases, the system hangs up
with stack over-flow.
Even with driver-model UART enabled, the malloc area of 0x2000 (8KB)
should be enough.
The function sg_set_pinsel is useful for switching I/O pins
but it can be only used in C code. This commit adds a simple
macro that is available in asm code.
FAT-formated USB storage device access is available.
Support EHCI host driver used on Panasonic UniPhier platform.
Since Device Tree is not supported on UniPhier yet, the base address
of USB cores are passed from board files (platdevice.c).
TODO for me:
Move the base address to device trees.
This commit adds register defines of MIO (Media I/O) block
of UniPhier platform. This file is necessary to control
the reset signals of the USB cores.
These IO pins are necessary for port power control and
over current detect.
If a support card is attached to the main board, the on-board
SMSC9118 LAN controller is available. It must be kept in reset
state for a while on start-up.
When the board is kicked via a debbuger rather than pushing the
hardware reset button, on-board chips are not reset; in this case
the reset signals should be asserted by software.
The same bit-field macros are defined in include/linux/serial_reg.h
so let's include it and delete duplicated defines.
Also, remove unnecessary inclusion of <common.h>.
Add a defconfig and Kconfigury for the Digilent ZYBO board.
Signed-off-by: Peter Crosthwaite <crosthwaite.peter@gmail.com>
Acked-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
This patch adds config support needed for ZYBO target and has
been tested on Rev. B ZYBO hardware.
Signed-off-by: Tinghui Wang <steven.wang@digilentinc.com>
[PC changes:
* Dropped boards.cfg change (rebase conflict)
* Dropped custom u-boot env
* Added DTS
* Misc forward-porting changes
Signed-off-by: Peter Crosthwiate <crosthwaite.peter@gmail.com>
It's a Zynq board similar in design to the currently supported ones.
512MB of RAM and UART1 is used.
The latest Xilinx tools generate ps7_init files that are explicitly
available under GPL. Change the makefile to allow drop in of those files
for building the SPL.
Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com>
Acked-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
Reviewed-and-tested-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
