* Make fatload set filesize environment variable
fix potential buffer overlow problem
* enable basic / medium / high-end configurations for PPChameleonEVB
board; fix NAND code
* enable TFTP client code to specify to the server the desired
timeout value (see RFC-2349)
is set
is set
Cleanup for submitted patches.
- Fixes for MPC8266 default config
- Allow eth_loopback_test() on 8260 to use a subset of the FCC's
- update README (SHOW_BOOT_PROGRESS values for cmd_nand.c and
env_common.c)
- sbc8260 tweaks
- adjust "help" output
- fix spelling errors
- set GD_FLG_DEVINIT flag only after device function pointers
are valid
- Allow CFG_ALT_MEMTEST on systems where address zero isn't
writeable
- enable 3.rd UART (ST-UART) on PXA(XScale) CPUs
- trigger watchdog while waiting in serial driver
Minor cleanup of comments
priority; configure critical interrupts to be handled like external
interrupts
go back to 66 MHz for stability
- add description for missing CFG_CMD_* entries in the README file
- sacsng tweaks:
include/configs/sacsng.h:
+ Support extra bootp options like: 2nd DNS and send hostname
+ Enabling ping and irq command
+ Adding defines for a bunch of misc configrabled options
(patches for these options will be coming)
+ Adding watchdog support, but it isn't enabled yet.
board/sacsng/sacsng.c:
+ Suppressing unneeded output when the quiet environment
is non-zero.
+ show_boot_progress() now accepts any negative number as a
failure code.
+ show_boot_progress() flashes the error code 5 times, and
then resets the board to retry the boot from the top
* Patch by Gleb Natapov, 14 Sep 2003:
enable watchdog support for all MPC824x boards that have a watchdog
* On MPC5200, restrict FEC to a maximum of 10 Mbps to work around the
"Non-octet Aligned Frame" errors we see at 100 Mbps
* Patch by Sharad Gupta, 14 Sep 2003:
fix SPR numbers for upper BAT register ([ID]BAT[4-7][UL])
update configuration for PPChameleonEVB board
various changes to VCMA9 board specific files
* Add I2C support for MGT5100 / MPC5200
Changed default memory option on MPC8266ADS to NOT be Page Based
Interleave, since this doesn't work very well with the standard
16MB DIMM
* Patch by George G. Davis, 12 Sep 2003:
fix Makefile settings for sk98 driver
add burn-in tests for TRAB board
* Enable instruction cache on MPC5200 board
- allow for longer timeouts for USB mass storage devices
* Patch by Denis Peter, 11 Sep 2003:
- fix USB data pointer assignment for bulk only transfer.
- prevent to display erased directories in FAT filesystem.
* Change output format for NAND flash - make it look like for other
memory, too
add FAT support for IDE, SCSI and USB
* Patches by Gleb Natapov, 2 Sep 2003:
- cleanup of POST code for unsupported architectures
- MPC824x locks way0 of data cache for use as initial RAM;
this patch unlocks it after relocation to RAM and invalidates
the locked entries.
* Patch by Gleb Natapov, 30 Aug 2003:
new I2C driver for mpc107 bridge. Now works from flash.
* Patch by Dave Ellis, 11 Aug 2003:
- JFFS2: fix typo in common/cmd_jffs2.c
- JFFS2: fix CFG_JFFS2_SORT_FRAGMENTS option
- JFFS2: remove node version 0 warning
- JFFS2: accept JFFS2 PADDING nodes
- SXNI855T: add AM29LV800 support
- SXNI855T: move environment from EEPROM to flash
- SXNI855T: boot from JFFS2 in NOR or NAND flash
* Patch by Bill Hargen, 11 Aug 2003:
fixes for I2C on MPC8240
- fix i2c_write routine
- fix iprobe command
- eliminates use of global variables, plus dead code, cleanup.
(tested with USB memory sticks only)
* Avoid flicker on TRAB's VFD
* Add PCI support for SL8245 board
* Support IceCube board configurations with 1 x AMD AM29LV065 (8 MB)
or 1 x AM29LV652 (two LV065 in one chip = 16 MB);
Run IPB at 133 Mhz; adjust the MII clock frequency accordingly
* Set BRG_CLK on PM825/826 to 64MHz (VCO_OUT / 4, instead of 16 MHz)
to allow for more accurate baudrate settings
(error now 0.7% at 115 kbps, instead of 3.5% before)
* Patch by Andreas Mohr, 4 Sep 2003:
Fix a lot of spelling errors
