2006-09-01 | Remove the board/netstar/crcit binary from git repository. | Marian Balakowicz | |
2006-09-01 | Fix tools/updater build error. | Marian Balakowicz | |
2006-09-01 | tools/easylogo/easylogo.c | Marian Balakowicz | |
2006-08-25 | Update for MCC200 / PRS200 boards: | Wolfgang Denk | |
- auto-adjust console device for Linux. - fix typos. | |||
2006-08-25 | Merge with /home/tur/proj/fo300/u-boot | Wolfgang Denk | |
2006-08-24 | Updates for MCC200 / PRS200 boards: | Wolfgang Denk | |
- support for configurations with SDRAM or DDR memory, - support for highboot and lowboot - adjusting environment definitions | |||
2006-08-22 | Add a fix for a buggy USB device on the FO300 board. | Bartlomiej Sieka | |
2006-08-18 | Minor cleanup | Wolfgang Denk | |
2006-08-18 | Add support for WTK FO300 board (TQM5200 based). | Marian Balakowicz | |
2006-08-18 | Merge with /home/raj/git/u-boot | Wolfgang Denk | |
2006-08-18 | Merge with git+ssh://fifi/home/wd/git/u-boot/master | Wolfgang Denk | |
2006-08-18 | Fix TQM834x hang. | Rafal Jaworowski | |
2006-08-17 | Cleanup debug code for yucca board. | Wolfgang Denk | |
2006-08-17 | MCC200: restrict addressable flash space to 32 MB | Wolfgang Denk | |
2006-08-17 | Add debug console on COM12 for MCC200 board | Wolfgang Denk | |
2006-08-14 | Update for SC520 board. | Wolfgang Denk | |
Patch by David Updegraff, 02 Dec 2005 | |||
2006-08-14 | Fixed common.h spelling error. | Wolfgang Denk | |
Patch by Cory Tusar, 30 Nov 2005 | |||
2006-08-14 | Fix typo. | Wolfgang Denk | |
Patch by Andreas Engel, 28 Nov 2005 | |||
2006-08-14 | Fix fatload command on FAT32 formatted partitions. | Wolfgang Denk | |
Patch by Joachim Jaeger, 18 Nov 2005 | |||
2006-08-14 | Fix drivers/dm9000.c when configured in 32 bit mode. | Wolfgang Denk | |
Patch by Eric Benard, 17 Nov 2005 | |||
2006-08-13 | Merge with /home/sr/git/u-boot/denx | Wolfgang Denk | |
2006-08-11 | Merge with /home/raj/git/u-boot | Wolfgang Denk | |
2006-08-11 | Fix preboot message on TQM85xx after switching to hush parser. | Wolfgang Denk | |
2006-08-11 | Adapt TQM85xx ramdisk address to Linux kernel memory map | Wolfgang Denk | |
2006-08-11 | Fix PCI-Express on PPC440SPe rev. A. | Rafal Jaworowski | |
2006-08-10 | Merge with /home/raj/git/u-boot | Wolfgang Denk | |
2006-08-10 | Add support for PCI-Express on PPC440SPe (Yucca board). | Rafal Jaworowski | |
2006-08-10 | Fix compiler warning for TRAB board. | Wolfgang Denk | |
Patch by Martin Krause, 07 Aug 2006 | |||
2006-08-07 | Merge with /home/tur/proj/usb_sticks/u-boot | Wolfgang Denk | |
2006-08-07 | Fix control-c handing in CONFIG_CMDLINE_EDITING | Stefan Roese | |
Properly pass break code back from readline. Patch by Roger Blofeld, 31 Jul 2006 | |||
2006-08-07 | Add commandline history support to all AMCC eval boards | Stefan Roese | |
Patch by Stefan Roese, 07 Aug 2006 | |||
2006-08-07 | Add Macronix MXLV320T flash support for AMCC Bamboo | Stefan Roese | |
2006-08-07 | Change "mii info" to not print an error upon missing PHY at address | Stefan Roese | |
2006-08-03 | Prevent USB commands from working when USB is stopped. | Bartlomiej Sieka | |
2006-08-02 | Add rudimentary handling of alternate settings of USB interfaces - to fix | Bartlomiej Sieka | |
problems with some USB storage devices. Some code readability improvements. | |||
2006-07-28 | PPC440 DDR setup: Set SDRAM0_CFG0[PMU]=0 for best performance | Stefan Roese | |
AMCC suggested to set the PMU bit to 0 for best performace on the PPC440 DDR controller. Please see doc/README.440-DDR-performance for details. Patch by Stefan Roese, 28 Jul 2006 | |||
2006-07-27 | Merge with /home/sr/git/u-boot/denx | Wolfgang Denk | |
2006-07-27 | AMCC bamboo (440EP) U-Boot image reduced to 384kbyte | Stefan Roese | |
Please see doc/README.bamboo for details. Patch by Stefan Roese, 27 Jul 2006 | |||
2006-07-27 | Fix CONFIG_CMDLINE_EDITING implementation | Stefan Roese | |
2006-07-26 | Fix preboot message on TQM5200 after switching to hush parser. | Wolfgang Denk | |
2006-07-23 | MCC200: set default configuration to low_boot DDR, | Wolfgang Denk | |
and support for configurable options high_boot and/or SDRAM. | |||
2006-07-22 | Add support for 256 MB SDRAM on CPU87 | Wolfgang Denk | |
Patch by Josef Wagner, 25 Nov 2005 | |||
2006-07-22 | Add configuration for cam5200 board (based on TQM5200S). | Wolfgang Denk | |
2006-07-21 | Code cleanup | Wolfgang Denk | |
2006-07-21 | Code cleanup. | Wolfgang Denk | |
2006-07-21 | More code cleanup | Wolfgang Denk | |
2006-07-21 | Disabled kvme080 board in MAKEALL because of build problems. | Wolfgang Denk | |
2006-07-21 | Update NetStar board | Wolfgang Denk | |
Patch by Ladislav Michl, 03 Nov 2005 | |||
2006-07-21 | Make code better readable. | Wolfgang Denk | |
Patch by Ladislav Michl, 14 Sep 2005 |
