2009-02-18rename CONFIG_CMD_ENV to CONFIG_CMD_SAVEENVMike Frysinger
The CONFIG_CMD_ENV option controls enablement of the `saveenv` command rather than a generic "env" command, or anything else related to the environment. So, let's make sure the define is named accordingly. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-02-18disable imls command if no flash is definedValeriy Glushkov
Default CONFIG_CMD_IMLS must be disabled when CONFIG_SYS_NO_FLASH is defined Signed-off-by: Valeriy Glushkov <gvv@lstec.com>
2009-02-18API: Improve glue mid-layer of the API demo application.Rafal Jaworowski
- Extend ub_dev_read() and ub_dev_recv() so they return the length actually read, which allows for better control and error handling (this introduces additional error code API_ESYSC returned by the glue mid-layer). - Clean up definitions naming and usage. - Other minor cosmetics. Note these changes do not touch the API proper, so the interface between U-Boot and standalone applications remains unchanged. Signed-off-by: Rafal Jaworowski <raj@semihalf.com>
2009-02-18API: Only output test data when reading was successful.Rafal Jaworowski
Signed-off-by: Rafal Czubak <rcz@semihalf.com>
2009-02-18API: Provide syscall entry point for the ARM architecture.Rafal Jaworowski
Signed-off-by: Rafal Czubak <rcz@semihalf.com> Acked-by: Rafal Jaworowski <raj@semihalf.com>
2009-02-18API: Use stack pointer as API signature search hint in the glue layer.Rafal Jaworowski
De-hardcode range in RAM we search for the API signature. Instead use the stack pointer as a hint to narrow down the range in which the signature could reside (it is malloc'ed on the U-Boot heap, and is hoped to remain in some proximity from stack area). Adjust PowerPC code in API demo to the new scheme. Signed-off-by: Rafal Czubak <rcz@semihalf.com> Signed-off-by: Rafal Jaworowski <raj@semihalf.com>
2009-02-17TQM8260: fix locations of kernel and ramdisk images in flashWolfgang Denk
After introducing redundant environment the kernel images was overlapping with environment. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-02-1683xx: Add eSDHC support on 8379 EMDS boardAndy Fleming
Signed-off-by: Andy Fleming <afleming@freescale.com>
2009-02-1685xx: Add eSDHC support for 8536 DSAndy Fleming
2009-02-16Add support for the Freescale eSDHC found on 8379 and 8536 SoCsAndy Fleming
This uses the new MMC framework Some contributions by Dave Liu <daveliu@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2009-02-16Add MMC FrameworkAndy Fleming
Here's a new framework (based roughly off the linux one) for managing MMC controllers. It handles all of the standard SD/MMC transactions, leaving the host drivers to implement only what is necessary to deal with their specific hardware. This also hooks the infrastructure into the PowerPC board code (similar to how the ethernet infrastructure now hooks in) Some of this code was contributed by Dave Liu <daveliu@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2009-02-16Eliminated arch-specific mmc header requirementAndy Fleming
The current MMC infrastructure relies on the existence of an arch-specific header file. This isn't necessary, and a couple drivers were forced to implement dummy files to meet this requirement. Instead, we move the stuff in those header files into a more appropriate place, and eliminate the stubs and the #include of asm/arch/mmc.h Signed-off-by: Andy Fleming <afleming@freescale.com>
2009-02-16Convert mmc_init to mmc_legacy_initAndy Fleming
This is to get it out of the way of incoming MMC framework Signed-off-by: Andy Fleming <afleming@freescale.com>
2009-02-16Eliminate support for using MMC as memoryAndy Fleming
MMC cards are not memory, so we stop treating them that way. Signed-off-by: Andy Fleming <afleming@freescale.com>
2009-02-1632bit BUg fix for DDR2 on 8572Poonam_Aggrwal-b10812
This errata fix is required for 32 bit DDR2 controller on 8572. May also be required for P10XX20XX platforms Signed-off-by: Poonam_Agarwal-b10812 <b10812@lc1106.zin33.ap.freescale.net>
2009-02-16TQM85xx: Fix a couple warnings in TQM8548 buildAndy Fleming
The ecm variable in sdram.c was being declared for all 8548, but only used by specific 8548 boards, so we make that variable require those specific boards, too The nand code was using an index "i" into a table, and then re-using "i" to set addresses for each upm. However, then it relied on the old value of i still being there to enable things. Changed the second "i" to "j" Signed-off-by: Andy Fleming <afleming@freescale.com>
2009-02-16MPC85xx: TQM8548: workaround for erratum DDR 19 and 20Wolfgang Grandegger
This patch adds the workaround for erratum DDR20 according to MPC8548 Device Errata document, Rev. 1: "CKE signal may not function correctly after assertion of HRESET". Furthermore, the bug DDR19 is fixed in processor version 2.1 and the work-around must be removed. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
2009-02-16MPC85xx: TQM8548: use cache for AG and BE variantsWolfgang Grandegger
This patch makes accesses to the system memory cachable by removing the caching-inhibited and guarded flags from the relevant TLB entries for the TQM8548_BE and TQM8548_AG modules. FYI, the Freescale MPC85* boards are configured similarly. This results in a big averall performace improvement. TFTP downloads, NAND Flash accesses, kernel boots, etc. are much faster. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
2009-02-16MPC85xx: TQM8548_AG: add 1 GiB DDR2-SDRAM configurationWolfgang Grandegger
This patch add support for the 1 GiB DDR2-SDRAM on the TQM8548_AG module. Signed-off-by: Jens Gehrlein <sew_s@tqs.de> Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
2009-02-16MPC85xx: TQM8548: fix SDRAM timing for 533 MHzWolfgang Grandegger
According to new TQM8548 timing specification: Refresh Recovery: 34 -> 53 clocks CKE pulse width: 1 -> 3 cycles Window for four activities: 13 -> 14 cycles Signed-off-by: Jens Gehrlein <sew_s@tqs.de> Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
2009-02-16MPC85xx: TQM8548: add support for the TQM8548_AG moduleWolfgang Grandegger
The TQM8548_AG is a variant of the TQM8548 module with 1 GiB memory, CAN and without PCI/PCI-X and RTC. U-Boot can be built for this module with "$ make TQM8548_AG_config". Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
2009-02-16MPC85xx: TQM8548: add support for the TQM8548_BE moduleWolfgang Grandegger
The TQM8548_BE is a variant of the TQM8548 module with NAND and CAN interface. With NAND support, the image is significantly larger and TEXT_BASE is adjusted accordingly. U-Boot can be built for this module with "$ make TQM8548_BE_config". Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
2009-02-16MPC85xx: TQM85xx: make standard PCI/PCI-X configurableWolfgang Grandegger
The TQM8548_AG module does not have the standard PCI/PCI-X interface connected but just the PCI Express interface . So far it was not possible to disable it without disabling the complete PCI interface (CONFIG_PCI) including PCI Express. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
2009-02-16MPC85xx: TQM85xx: fix flash protection for boot loaderWolfgang Grandegger
As the reset vector is located at 0xfffffffc, all flash sectors from the beginning of the U-Boot binary to 0xffffffff must be protected. On the TQM8548-AG having small sectors at the end of the flash it happened that the last two sector were not protected and an "erase all" left an un-bootable system behind: Bank # 2: CFI conformant FLASH (32 x 16) Size: 32 MB in 270 Sectors AMD Standard command set, Manufacturer ID: 0xEC, Device ID: 0x257E Erase timeout: 8192 ms, write timeout: 1 ms FFFA0000 E RO FFFC0000 RO FFFE0000 RO FFFE4000 RO FFFE8000 RO FFFEC000 RO FFFF0000 RO FFFF4000 RO FFFF8000 E FFFFC000 The same bug seems to be in drivers/mtd/cfi_flash.c:flash_init() and many board BSPs as well. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
2009-02-1686xx: Update CPU info output on bootupPeter Tyser
- Update style of 86xx CPU information on boot to more closely match 85xx boards - Fix detection of 8641/8641D - Use strmhz() to display frequencies - Display L1 information - Display L2 cache size - Fixed CPU/SVR version output == Before == Freescale PowerPC CPU: Core: E600 Core 0, Version: 0.2, (0x80040202) System: Unknown, Version: 2.1, (0x80900121) Clocks: CPU:1066 MHz, MPX: 533 MHz, DDR: 266 MHz, LBC: 133 MHz L2: Enabled Board: X-ES XPedite5170 3U VPX SBC == After == CPU: 8641D, Version: 2.1, (0x80900121) Core: E600 Core 0, Version: 2.2, (0x80040202) Clock Configuration: CPU:1066.667 MHz, MPX:533.333 MHz DDR:266.667 MHz (533.333 MT/s data rate), LBC:133.333 MHz L1: D-cache 32 KB enabled I-cache 32 KB enabled L2: 512 KB enabled Board: X-ES XPedite5170 3U VPX SBC Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-02-1686xx: Update Global Utilities structurePeter Tyser
2009-02-1686xx: Reset updatePeter Tyser
Update the 86xx reset sequence to try executing a board-specific reset function. If the board-specific reset is not implemented or does not succeed, then assert #HRESET_REQ. Using #HRESET_REQ is a more standard reset procedure than the previous method and allows all board peripherals to be reset if needed. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-02-16fsl-ddr: Allow system to boot if we have more than 4G of memoryKumar Gala
Previously if we >=4G of memory and !CONFIG_PHYS_64BIT we'd report an error and hang. Instead of doing that since DDR is mapped in the lowest priority LAWs we setup the DDR controller and the max amount of memory we report back is what we can map (CONFIG_MAX_MEM_MAPPED) Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Becky Bruce <beckyb@kernel.crashing.org>
2009-02-16mpc85xx: Add support for the P2020Srikanth Srinivasan
Added various p2020 processor specific details: * SVR for p2020, p2020E * immap updates for LAWs and DDR on p2020 * LAW defines related to p2020 Signed-off-by: Srikanth Srinivasan <srikanth.srinivasan@freescale.com> Signed-off-by: Travis Wheatley <Travis.Wheatley@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-02-1685xx: print boot header info to distinquish 36-bit addr map on MPC8572 DSKumar Gala
Added some info that is printed out when we boot to distiquish if we built MPC8572DS_config vs MPC8572DS_36BIT_config since they have different address maps. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-02-16Fixup SGMII PHY ids in the device treeAndy Fleming
The device tree's PHY addresses need to be fixed up if we're using the SGMII Riser Card. The 8572, 8536, and 8544 DS boards were modified to call this function. Code idea taken from Liu Yu <yu.liu@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2009-02-16Make some minor whitespace changes to eliminate line-wrappingAndy Fleming
2009-02-16Add eth_get_dev_by_indexAndy Fleming
This allows code to iterate through the ethernet devices Signed-off-by: Andy Fleming <afleming@freescale.com>
2009-02-1685xx: Fix bug in device tree setup in 36-bit physical confgKumar Gala
In the 36-bit physical config for MPC8572DS when need the start address of memory and it size to be kept in phys_*_t instead of a ulong since we support >4G of memory in the config and ulong cant represent that. Otherwise we end up seeing the memory node in the device tree reporting back we have memory starting @ 0 and of size 0. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-02-1685xx: Fix address map for 36-bit config of MPC8572DSKumar Gala
When we introduced the 36-bit config of the MPC8572DS board we had the wrong PCI MEM bus address map. Additionally, the change to the address map exposes a small issue in our dummy read on the ULI bus. We need to use the new mapping functions to handle that read properly in the 36-bit config. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-02-1685xx: Fix how we map DDR memoryKumar Gala
Previously we only allowed power-of-two memory sizes and didnt handle >2G of memory. Now we will map up to CONFIG_MAX_MEM_MAPPED and should properly handle any size that we can make in the TLBs we have available to us Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-02-16fsl-ddr: ignore memctl_intlv_ctl setting if only one DDR controllerKumar Gala
If we only have one controller we can completely ignore how memctl_intlv_ctl is set. Otherwise other levels of code get confused and think we have twice as much memory. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-02-1685xx: Format cpu freq printing to handle 8 coresKumar Gala
Only print 4 cpu freq per line. This way when we have 8 cores its a bit more readable. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-02-15Merge branch 'master' of git://git.denx.de/u-boot-usbWolfgang Denk
2009-02-15Merge branch 'master' of git://git.denx.de/u-boot-i2cWolfgang Denk
2009-02-15USB: Remove LUN number from CDBAbraham, Thomas
The LUN number is not part of the Command Descriptor Block (CDB) for scsi inquiry, request sense, test unit ready, read capacity and read10 commands. This patch removes the LUN number information from the CDB. Signed-off-by: Thomas Abraham <t-abraham@ti.com> Signed-off-by: Remy Bohmer <linux@bohmer.net>
2009-02-15Added usbtty_configured() check. Fixed attribute(packed) warnings.Atin Malaviya
V3: Fixed line-wrap problem due to user error in mail! Added usb_configured() checks in usbtty_puts() and usbtty_putc() to get around a hang when usb is not connected and the user has set up multi-io (setenv stdout serial,usbtty etc). Got rid of redundant __attribute__((packed)) directives that were causing warnings from gcc. Signed-off-by: Atin Malaviya <atin.malaviya@gmail.com> Signed-off-by: Remy Bohmer <linux@bohmer.net>
2009-02-14i.MX31: Start the I2C clock on driver initialisationGuennadi Liakhovetski
i.MX31 powers on with most clocks running, so, after a power on this explicit clock start up is not required. However, as Linux boots it disables most clocks to save power. This includes the I2C clock. If we then soft reboot from Linux the I2C clock stays off. This breaks the phycore, which has its environment in I2C EEPROM. Fix the problem by explicitly starting the clock in I2C driver initialisation routine. Signed-off-by: Guennadi Liakhovetski <lg@denx.de> Ack-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-02-12i2c.h: drop i2c_reg_{read, write} hack for Blackfin partsMike Frysinger
The Blackfin i2c driver has been rewritten thus the special ifdefs in the common code are no longer needed. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-02-12Merge branch 'master' of git://git.denx.de/u-boot-ppc4xxWolfgang Denk
2009-02-1282xx, mgcoge: fix compile errorHeiko Schocher
With actual u-boot compiling the mgcoge port fails, because since commit ba705b5b1a97b47388ed48858bef6bf7b6bfcd56 it is necessary to define CONFIG_NET_MULTI. Seems to me the mgcoge port is the only actual existing 8260 port who uses CONFIG_ETHER_ON_SCC, so no other 8260 port needed to be fixed. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-02-12ppc4xx: Add README entry for CONFIG_PCI_DISABLE_PCIEDirk Eibach
Signed-off-by: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Stefan Roese <sr@denx.de>
2009-02-12ppc4xx: Fix initialization of the SDRAM_CODT registerCarolyn Smith
This fixes the initialization of the SDRAM_CODT register in the ppc4xx DDR2 initialization code. It also removes use of the SDRAM_CODT_FEEDBACK_RCV_SINGLE_END and SDRAM_CODT_FEEDBACK_DRV_SINGLE_END #define's since they are reserved bits. Signed-off-by: Carolyn Smith <carolyn.smith@tektronix.com> Signed-off-by: Stefan Roese <sr@denx.de>
2009-02-12ppc4xx: Fix problem with board_eth_init() vs cpu_eth_init() on AMCC boardsStefan Roese
Some AMCC eval boards do have a board_eth_init() function calling pci_eth_init(). These boards need to call cpu_eth_init() explicitly now with the new eth_init rework. Signed-off-by: Stefan Roese <sr@denx.de>
2009-02-12ppc4xx: Autocalibration can set RDCC to over aggressive value.Adam Graham
The criteria of the AMCC SDRAM Controller DDR autocalibration U-Boot code is to pick the largest passing write/read/compare window that also has the smallest SDRAM_RDCC.[RDSS] Read Sample Cycle Select value. On some Kilauea boards the DDR autocalibration algorithm can find a large passing write/read/compare window with a small SDRAM_RDCC.[RDSS] aggressive value of Read Sample Cycle Select value "T1 Sample". This SDRAM_RDCC.[RDSS] Read Sample Cycle Select value of "T1 Sample" proves to be to aggressive when later on U-Boot relocates into DDR memory and executes. The memory traces on the Kilauea board are short so on some Kilauea boards the SDRAM_RDCC.[RDSS] Read Sample Cycle Select value of "T1 Sample" shows up as a potentially valid value for the DDR autocalibratiion algorithm. The fix is to define a weak default function which provides the minimum SDRAM_RDCC.[RDSS] Read Sample Cycle Select value to accept for DDR autocalibration. The default will be the "T2 Sample" value. A board developer who has a well defined board and chooses to be more aggressive can always provide their own board specific string function with the more aggressive "T1 Sample" value or stick with the default minimum SDRAM_RDCC.[RDSS] value of "T2". Also put in a autocalibration loop fix for case where current write/read/compare passing window size is the same as a prior window size, then in this case choose the write/read/compare result that has the associated smallest RDCC T-Sample value. Signed-off-by: Adam Graham <agraham@amcc.com> Signed-off-by: Stefan Roese <sr@denx.de>
