2015-07-07Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
2015-07-07armv7: better comment in start.SPavel Machek
Fix big/small letters in comment. Signed-off-by: Pavel Machek <pavel@denx.de> Tested-by: Marek Vasut <marex@denx.de>
2015-07-07gpio: lpc32xx: Use priv_data instead of platdataAxel Lin
The LPC32XX GPIO driver platdata currently contains GPIO state information, which should go into priv_data. Thus rename lpc32xx_gpio_platdata to lpc32xx_gpio_priv and convert to use dev_get_priv() instead. Signed-off-by: Axel Lin <axel.lin@ingics.com> Tested-by: Albert ARIBAUD <albert.aribaud@3adev.fr>
2015-06-29Prepare v2015.07-rc3v2015.07-rc3Tom Rini
2015-06-30mtd, spi: Check if flash pointer is usedHeiko Schocher
If flash pointer is used free it, before probing a new flash and storing it in flash. Signed-off-by: Heiko Schocher <hs@denx.de> Tested-by: Jagannadh Teki <jteki@openedev.com> Reviewed-by: Jagannadh Teki <jteki@openedev.com>
2015-06-30spi, sf: Use offset and size in sf cmd from mtdpartitionHeiko Schocher
With this patch, it is possible to get the offset and size information from the mtdpartiton setting in "mtdparts", similiar to the "nand" commandos. => sf sf - SPI flash sub-system Usage: sf probe [[bus:]cs] [hz] [mode] - init flash device on given SPI bus and chip select sf read addr offset|partition len - read `len' bytes starting at `offset' to memory at `addr' sf write addr offset|partition len - write `len' bytes from memory at `addr' to flash at `offset' sf erase offset|partition [+]len - erase `len' bytes from `offset' `+len' round up `len' to block size sf update addr offset|partition len - erase and write `len' bytes from memory at `addr' to flash at `offset' => for example "env" is defined in mtdparts: => sf read 13000000 env device 0 offset 0xd0000, size 0x10000 SF: 65536 bytes @ 0xd0000 Read: OK zynq-uboot> mtdparts add nor0 0x10000@0x0 env zynq-uboot> sf erase env 0x10000 SF: 65536 bytes @ 0x0 Erased: OK zynq-uboot> sf write 0x100 env device 0 offset 0x0, size 0x10000 SF: 65536 bytes @ 0x0 Written: OK zynq-uboot> sf read 0x40000 env device 0 offset 0x0, size 0x10000 SF: 65536 bytes @ 0x0 Read: OK Signed-off-by: Heiko Schocher <hs@denx.de> Tested-by: Jagannadh Teki <jteki@openedev.com> Reviewed-by: Jagannadh Teki <jteki@openedev.com>
2015-06-30mtd, nand: Move common functions from cmd_nand.c to common placeHeiko Schocher
Move common functions from cmd_nand.c (for calculating offset and size from cmdline paramter) to common place, so they could used from other commands which use mtd partitions. For onenand the arg_off_size() is left in common/cmd_onenand.c. It should use now the common arg_off() function, but as I could not test onenand I let it there ... Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Scott Wood <scottwood@freescale.com> Reviewed-by: Jagannadh Teki <jteki@openedev.com>
2015-06-30mtd, spi: Add MTD layer driverDaniel Schwierzeck
Add MTD layer driver for spi, original patch from: http://git.denx.de/?p=u-boot/u-boot-mips.git;a=commitdiff;h=bb246819cdc90493dd7089eaa51b9e639765cced Changes from Heiko Schocher against this patch: - Remove compile error if not defining CONFIG_SPI_FLASH_MTD: LD drivers/mtd/spi/built-in.o drivers/mtd/spi/sf_probe.o: In function `spi_flash_mtd_unregister': /home/hs/abb/imx6/u-boot/drivers/mtd/spi/sf_internal.h:168: multiple definition of `spi_flash_mtd_unregister' drivers/mtd/spi/sf_params.o:/home/hs/abb/imx6/u-boot/drivers/mtd/spi/sf_internal.h:168: first defined here drivers/mtd/spi/sf_ops.o: In function `spi_flash_mtd_unregister': /home/hs/abb/imx6/u-boot/drivers/mtd/spi/sf_internal.h:168: multiple definition of `spi_flash_mtd_unregister' drivers/mtd/spi/sf_params.o:/home/hs/abb/imx6/u-boot/drivers/mtd/spi/sf_internal.h:168: first defined here make[1]: *** [drivers/mtd/spi/built-in.o] Fehler 1 make: *** [drivers/mtd/spi] Fehler 2 - Add a README entry. - Add correct writebufsize, to fit with Linux v3.14 MTD, UBI/UBIFS sync. Note (From Jagan): For testing raw mtd parition erase/read/write operations using cmd_sf, sf_mtd should be required to register the spi flash device to MTD layer but the sf_mtd_info ops were not required until and unless if we use any flash filesystem layer say for example UBI. Due to this the foot-print got increased ~290bytes in non-UBI case here that should be acceptible. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Signed-off-by: Heiko Schocher <hs@denx.de> Tested-by: Jagannadh Teki <jteki@openedev.com> Reviewed-by: Jagannadh Teki <jteki@openedev.com>
2015-06-30defconfig: ls1021a: Add OF_CONTROL and DM supportHaikun Wang
PI and QSPI only work when boot from QSPI on ls1021a. This patch only enable options in qspi boot defconfig. Signed-off-by: Haikun Wang <haikun.wang@freescale.com> Tested-by: Haikun Wang <haikun.wang@freescale.com> Signed-off-by: Jagan Teki <jteki@openedev.com>
2015-06-30arm: ls102xa: Enable Driver Model SPI for ls1021atwrHaikun Wang
Enable Driver Model SPI for ls1021atwr board. DSPI and QSPI only be enabled when boot from QSPI. DSPI and QSPI are compatible under Driver Model SPI. Signed-off-by: Haikun Wang <Haikun.Wang@freescale.com> Tested-by: Review Code-CDREVIEW <CDREVIEW@freescale.com> Tested-by: Haikun Wang <haikun.wang@freescale.com> Reviewed-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2015-06-30arm: ls102xa: Enable Driver Model SPI for ls1021aqdsHaikun Wang
Enable Driver Model SPI for ls1021aqds board. DSPI and QSPI is enabled only when boot from QSPI. DSPI and QSPI are compatible under Driver Model SPI. Signed-off-by: Haikun Wang <Haikun.Wang@freescale.com> Tested-by: Haikun Wang <haikun.wang@freescale.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2015-06-30dm: ls1021aqds: dts: Use "spi_dataflash" driver instead of "spi_flash_std" ↵Haikun Wang
for DSPI flash The type of DSPI flash on ls1021aqds is AT45DB021, it has specail commands and page-size. Use the special spi flash driver instead of "spi_flash_std" driver. Signed-off-by: Haikun Wang <haikun.wang@freescale.com> Tested-by: Haikun Wang <haikun.wang@freescale.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com>
2015-06-30dm: sf: Add Atmel DataFlash spi flash driverHaikun Wang
Atmel DataFlash chips have commands different from common spi flash commands. Atmel DataFlash also have special page-size. This driver add support for accessing Atmel DataFlash. It is based on the Driver Model. Example: => sf probe 1:0 SPI DataFlash: Detected AT45DB021B with page size 264 Bytes, erase size 264 Bytes, total 264 KiB, revision d => sf erase 0 42000 SF: 270336 bytes @ 0x0 Erased: OK => mw.l 82000000 45444342 20000 => sf write 82000000 0 42000 SF: 270336 bytes @ 0x0 Written: OK => sf read 83000000 0 42000 SF: 270336 bytes @ 0x0 Read: OK => cmp.b 82000000 83000000 42000 Total of 270336 byte(s) were the same Signed-off-by: Haikun Wang <haikun.wang@freescale.com> Tested-by: Haikun Wang <haikun.wang@freescale.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Chakra Divi <cdivi@openedev.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2015-06-28Merge git://git.denx.de/u-boot-marvellTom Rini
2015-06-28db-88f6820-gp.h: Load data blobs into lower memoryKevin Smith
By default on this platform, u-boot loads data into high memory in the range of 0x7Fxxxxxx, which generates a data abort when the kernel tries to read it. Config the u-boot environment to load the device tree and initrd image into lower memory to make them accessible to the kernel. Signed-off-by: Kevin Smith <kevin.smith@elecsyscorp.com> Acked-by: Stefan Roese <sr@denx.de>
2015-06-28mv-common.h: Include support for device treesKevin Smith
2015-06-28Revert "sunxi/nand: Add support to the SPL for loading u-boot from internal ↵Ian Campbell
NAND memory" This reverts commit f76eba38b3eda905ff3bdc18dd1240d3dcbc6e5a. This patch did not have a full and proper copyright/S-o-b chain. Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Conflicts: include/configs/sun6i.h include/configs/sun8i.h
2015-06-25a3m071: Add needed dependency on LIB_RANDJoe Hershberger
Boards using link-local need lib rand. When link-local is moved to Kconfig, this dependency will be described there. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2015-06-25common: Add the CMD_ENV_EXISTS config to KconfigJoe Hershberger
This command needs to exist in the Kconfig so that it can be moved from the config_cmd_default.h. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2015-06-25common: Fix comment for saveenv in KconfigJoe Hershberger
The help for this was simply copied from another command. Update it to reflect the command. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2015-06-25mtd: spi: Add the SPI_FLASH config to KconfigJoe Hershberger
This config needs to be available in the Kconfig to allow it to be removed from arch defaults. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2015-06-25mmc: bcm2835_sdhci: Restore original delay behaviorMarek Vasut
Patch 33fe2fb8df01647f97a7bce96a1c7781a7f6d253 titled "mmc: bcm283x: Remove get_timer_us() from mmc driver" incorrectly replaced ad-hoc get_timer_us() function with a plain get_timer(). The get_timer() operates in mSec units instead of uSec though, which caused very slow operation of the driver. Restore the original behavior of the driver, but avoid get_timer_us() and use timer_get_us() instead. The later is part of the standard API. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Jakub Kiciński <moorray3@wp.pl> Cc: Stephen Warren <swarren@wwwdotorg.org> Tested-by: Jakub Kicinski <kubakici@wp.pl>
2015-06-19Merge git://git.denx.de/u-boot-usbTom Rini
2015-06-19siemens,am33x,thuban: rename dxr2 to thubanHeiko Schocher
Update new naming scheme. Signed-off-by: Samuel Egli <samuel.egli@siemens.com> Acked-by: Heiko Schocher <hs@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-06-19siemens,am33x,rastaban: add rastaban configHeiko Schocher
rastaban is a draco version with more flash, more RAM and faster CPU. Number of partitions is the same but rootfs partition is different. Signed-off-by: Samuel Egli <samuel.egli@siemens.com> Acked-by: Heiko Schocher <hs@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-06-19README: Describe CONFIG_SYS_NO_FLASHChris Packham
Unlike most configuration options defining this actually disables support for a feature (parallel flash). Eventually the logic behind this should probably be flipped so that '#ifndef CONFIG_SYS_NO_FLASH' becomes '#ifdef CONFIG_HAS_PARALLEL_FLASH' but for now lets document the existing behaviour. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de>
2015-06-19ARM: BeagleBoard-X15: Enable VTT regulatorLokesh Vutla
BeagleBoard-X15 uses a vtt regulator for DDR3 termination and this is controlled by gpio7_11. Configuring gpio7_11. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-06-19am43xx_evm: add eth boot supportMugunthan V N
add cpsw ethernet boot mode support to download spl and u-boot.img via tftp protocol. Also adding a seperate config for ethernet boot mode as the default build falcon mode and environment on MMC is defined for ethernet boot mode environment should be set to nowhere. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-06-19am43xx_evm: add usb host boot supportMugunthan V N
While booting via usb host mode, ROM uses DMA to copy MLO over USB so ARM internal RAM cannot be used. Adding USB host boot support by introducing new config target which sets SPL_TEXT_BASE to OCMC ram. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-06-19am43xx: Update CONFIG_SPL_TEXT_BASETom Rini
With 1.2 silicon this is now the documented starting usable point for downloading images to (and corrects a problem with peripheral booting with prior silicon). Prior silicon is OK using this address as well. Signed-off-by: Tom Rini <trini@konsulko.com> Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
2015-06-19ARM: DRA7: Change configuration to prevent DDR reset control from EMIFNishanth Menon
DRA7/AM57xx devices can be operated in many different configurations. When the SoC is supposed to support a configuration where low power mode state may involve the SoC completely powered off and DDR is in self refresh, SoC EMIF controller should not be the master of the reset signal and an external entity might be in control of things. The default configuration of Linux on TI evms involve not powering off the voltage rails (due to various reasons including reliability concerns) and must not allow DDR reset to be controlled by EMIF. On platforms where external entity might control the reset signal, this configuration will be a "dont care". Fixes: 536d87470869 ("ARM: DRA7: Update DDR IO registers") Tested-by: Keerthy <j-keerthy@ti.com> Acked-by: Brad Griffis <bgriffis@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-06-19ti: omap4: remove CONFIG_SPL_EXT_SUPPORT from ti_omap4_common.h since it is ↵Guillaume GARDET
now in ti_armv7_common.h Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr> Cc: Tom Rini <trini@konsulko.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-06-19ti: armv7: enable EXT support in SPL (using ti_armv7_common.h)Guillaume GARDET
Tested on Pandaboard (rev. A3) and Beagleboard xM (rev. B). Compilation tested on TI armv7 boards and OMAP boards from other vendors. Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr> Cc: Tom Rini <trini@konsulko.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-06-19arm, am33xx: update for siemens am335x based boardsHeiko Schocher
updates for the siemens am335x based boards: - draco: add delay for DDR3 configuration - change MTD partition layout and add a possibility to redefine MTD layout in board header. - move ubi support to common header file - draco: improve dtb naming - draco: set CONFIG_SYS_CBSIZE to 1024 - add generic env based led Leds can now be defined in Environment - add generic env based dfu button Which gpio is used for the dfu button can be defined through the Environment - set MACH_TYPE only if defined - draco: increase CPU freq to 300MHz - Add time command to siemens am33xx boards - DDR3: increase default tRFC - draco: enable pullup for DFU and ERST pin - change print format DDR3 Signed-off-by: Samuel Egli <samuel.egli@siemens.com> Acked-by: Heiko Schocher <hs@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Heiko Schocher <hs@denx.de>
2015-06-19common: cmd_part: start and size sub-commands introductionPaul Kocialkowski
This introduces the part start and part size sub-commands. The purpose of these is to store the start block and size of a partition in a variable, given the device and partition number. This allows reading raw data that fits a single partition more easily. For instance, this could be used to figure out the start block and size of a kernel partition when a partition table is present, given the partition number. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Acked-by: Stephen Warren <swarren@nvidia.com> [trini: Change "%lx" to LBAF] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-06-19common: cmd_part: Proper alignmentPaul Kocialkowski
This fixes a misaligned declaration. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2015-06-19keystone2: use correct EFUSE_BOOTROM fileds to configure speedVitaly Andrianov
The get_max_arm_speed() and get_max_dev_speed() used wrong register fields to get the maximum speeds. This commit fixes the bug. Signed-off-by: Vitaly Andrianov <vitalya@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-06-19usb: kbd: Disable idle input reports when we do not need themHans de Goede
When we're polling and thus handling key-repeat in software, make sure to disable idle reports, some keyboards may have these enabled by default messing up our software keyrepeat. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-06-19usb: ehci: Properly deal with data toggle for interrupt endpointsHans de Goede
Without this we loose every other interrupt packet. We never noticed this because with keyboards the packets which we were loosing would normally be key release packets. But now that we do keyrepeat in software instead of relying on the hid idle functionality, missing a release will result in key repeat triggering. This commit fixes this. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-06-19usb.h: Always declare usb function prototypesHans de Goede
There is no harm in declaring the function prototypes even if nothing implements them, and when CONFIG_DM_USB=y the various usb functions are available regardless of any controller drivers being enabled. This fixes compile warnings due to missing prototypes on ARCHs where the ARCH Kconfig always enables CONFIG_DM_USB and various usb drivers. One could argue that in the case of no controllers CONFIG_DM_USB should not be set, but this problem is typically seen during bringup of boards which do actually have usb controllers. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-06-18CPCI4052: Remove CONFIG_SYS_LONGHELPTom Rini
With the change to make sure that CONFIG_CMD_NET is enabled this board no longer fits into the linker script: powerpc-linux-ld.bfd: section .resetvec loaded at [fffffffc,ffffffff] overlaps section .u_boot_list loaded at [ffffff58,00000723] powerpc-linux-ld.bfd: u-boot: section .resetvec lma 0xfffffffc adjusted to 0x724 powerpc-linux-ld.bfd: u-boot: section `.resetvec' can't be allocated in segment 0 LOAD: .data.init .text .rodata .reloc .data .u_boot_list .resetvec powerpc-linux-ld.bfd: final link failed: File truncated Drop CONFIG_SYS_LONGHELP to free up space. Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2015-06-18spl: spl_mmc: MMC boot mode provisions checksPaul Kocialkowski
This allows using only one of either raw or fs mode for SPL mmc boot, without the need to have provisions for the other. In particular, a device may have U-Boot installed on a file system on the mmc, without ever needing to read U-Boot from raw memory. Thus, there is no reason to provide a sector or partition for raw mode. This allows this behaviour and still provides a robust fallback mechanism in case provisions for both modes are defined. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2015-06-18spl: spl_mmc: Minor cosmeticsPaul Kocialkowski
This switches some printf calls to puts and avoids a test repetition. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2015-06-18tools/env/fw_env.h: Correct include orderPeter Robinson
When building tools-only (or env) we need to be sure that we do use <linux/kconfig.h> and do not use <generated/autoconf.h>. This will fix problems such as running 'make defconfig' or 'make sandbox_config' and then 'make tools-only'. Based on the responses below to the thread add linux/kconfig.h higher in the includes and drop the now unneeded autoconf.h lower down to ensure the default environment is included correctly http://lists.denx.de/pipermail/u-boot/2015-June/216849.html Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-06-18fix: samsung: common: autoboot.cmd: Correct itbcfg definitionŁukasz Majewski
This fix is necessary to avoid booting the default ITB configuration. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
2015-06-18mmc_write.c: Make mmc_berase do 32bit safe 64bit mathTom Rini
We want to see if the requested start or total block count are unaligned. We discard the whole numbers and only care about the remainder. Update the code to use div_u64_rem here and add a comment. Cc: Hans de Goede <hdegoede@redhat.com> Cc: Pantelis Antoniou <pantelis.antoniou@konsulko.com> Cc: Bernhard Nortmann <bernhard.nortmann@web.de> Reported-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@konsulko.com> Tested-by: Bernhard Nortmann <bernhard.nortmann@web.de> Reviewed-by: Hans de Goede <hdegoede@redhat.com>
2015-06-18board/BuR/tseries: remove lpj= from environment-variableHannes Petermaier
since we have now various processor-speeds it isn't useful anymore to preinitialize kernels-delay loop. Rather we want the kernel to calibrate it on every boot. This wastes around 80ms boottime but is compatible to all CPU-speeds. Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at>
2015-06-18board/BuR/common: support timer5 for pwm-backlightHannes Petermaier
in future we support yet another b&r am335x based board, where Timer 5 is wired to backlight-driver. So we introduce a new driver-type '2' to setup timer5 instead timer6. Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at> Reviewed-by: Simon Glass <sjg@chromium.org>
