2010-10-26include/asm-offsets.h: automatically generate assembler constantsWolfgang Denk
A recurrent issue is that certain C level constructs like sizeof() or offsetof() cannot be used in assembler files, which is inconvenient when such constructs are used in the definition of macro names etc. To avoid duplication of such definitions (and thus another cause of problems), we adapt the Linux way to automatically generate the respective definitions from the respective C header files. In Linux, this is implemented in include/linux/kbuild.h, Kbuild, and arch/*/kernel/asm-offsets.c; we adapt the code from the Linux v2.6.36 kernel tree. We also copy the concept of the include/generated/ directory which can be used to hold other automatically generated files as well. We start with an architecture-independent lib/asm-offsets.c which generates include/generated/generic-asm-offsets.h (included by include/asm-offsets.h, which is what will be referred to in the actual source code). Later this may be extended by architecture-specific arch/*/lib/asm-offsets.c files that will generate a include/generated/asm-offsets.h. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-26Merge branch 'master' of git://git.denx.de/u-boot-blackfinWolfgang Denk
2010-10-26Merge branch 'master' of git://git.denx.de/u-boot-ppc4xxWolfgang Denk
2010-10-26Merge branch 'master' of git://git.denx.de/u-boot-i2cWolfgang Denk
2010-10-26ARM: Use consistent assembler syntaxGray Remlin
Signed-off-by: Gray Remlin <g_remlin@rocketmail.com> Acked-by: Heiko Schocher <hs@denx.de>
2010-10-25Blackfin: adi boards: set compiled size limitsMike Frysinger
2010-10-25Blackfin: bf527-ezkit-v2: move to boards.cfgMike Frysinger
Now that the boards.cfg file supports options to mkconfig, we can move the bf527-ezkit-v2 target out of the Makefile and into boards.cfg. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-25ppc4xx: Add Io and IoCon 405EP board supportDirk Eibach
Board support for the Guntermann & Drunck CATCenter Io. Board support for the Guntermann & Drunck IoCon. Signed-off-by: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Stefan Roese <sr@denx.de>
2010-10-25Merge branch 'master' of ssh://gemini/home/wd/git/u-boot/masterWolfgang Denk
2010-10-25ARMV7: OMAP: I2C driver: Fix bug found in 37XX testingSteve Sakoman
On OMAP36/37XX the standard on chip pullups are not sufficient to ensure proper i2c operation without external pullups or switching to high speed mode and enabling special on chip pullups. This is an issue for Beagle xM, which does not have external pullups on the expansion board i2c lines. The issue manifests itself as an AL (arbitration lost) error when probing for a non-existent device (i.e. on a Beagle xM with no expansion boards attached). This issue does not occur on expansion boards that include pullups or on Overo 37XX COM's since they include pull-ups. This patch fixes the issue by checking for the AL bit in the i2c_probe function. Signed-off-by: Steve Sakoman <steve.sakoman@linaro.org>
2010-10-24hcu4, hcu5: fix out of tree buildingWolfgang Denk
Out of tree building of the Netstal hcu4 and hcu5 boards failed like that: Assembler messages: Fatal error: can't create /work/wd/tmp-ppc/board/netstal/hcu4/../common/fixed_sdram.o: No such file or directory Assembler messages: Fatal error: can't create /work/wd/tmp-ppc/board/netstal/hcu4/../common/nm_bsp.o: No such file or directory make[1]: *** [/work/wd/tmp-ppc/board/netstal/hcu4/../common/fixed_sdram.o] Error 2 Adapt (and simplify) the respective Makefiles. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Niklaus Giger <niklaus.giger@netstal.com>
2010-10-24MPC8315ERD: fix build errorWolfgang Denk
Commit 29c6fbe "MPC5121: Add USB EHCI support" renamed CONFIG_SYS_MPC8xxx_USB_ADDR into CONFIG_SYS_FSL_USB_ADDR but missed to update arch/powerpc/cpu/mpc83xx/cpu_init.c, resulting in: cpu_init.c: In function 'cpu_init_f': cpu_init.c:332: error: 'CONFIG_SYS_MPC8xxx_USB_ADDR' undeclared (first use in this function) cpu_init.c:332: error: (Each undeclared identifier is reported only once cpu_init.c:332: error: for each function it appears in.) make[1]: *** [/work/wd/tmp-ppc/arch/powerpc/cpu/mpc83xx/cpu_init.o] Error 1 Fix this. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Kim Phillips <kim.phillips@freescale.com>
2010-10-24VoVPN-GW_100MHz: drop unsupported board configurationWolfgang Denk
The 100MHz configuation of the VoVPN-GW has never been supported, so drop it now. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-10-24lite5200b_PM: fix compile warningWolfgang Denk
Fix warning: icecube.c: In function 'lite5200b_wakeup': icecube.c:83: warning: format '%08lx' expects type 'long unsigned int', but argument 2 has type 'void (*)(void)' Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-10-23MAKEALL: drop non-existent i386 configMike Frysinger
2010-10-23ARM: fix relocation support for onenand device.Enric Balletbo i Serra
We also have to relocate the onenand command table manually, otherwise onenand command don't work. Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com>
2010-10-23MVBLM7: make TSEC2 work again.Andre Schwarz
SICRH has been misconfigured, i.e. TSEC2 clock + D[0:3] are GPIOs. Fix this to be RGMII signals again. Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de>
2010-10-23hwconfig: Utilize getenv_f before relocation to allow for larger bufferKumar Gala
Since we use hwconfig in cases before relocation (like getting DDR params on FSL PPC systems), we can have strings that exceed the early small (32 byte) buffer size that getenv will handle. So we explicitly allocate our own buffer on the stack and use if to handle getting the hwconfig env string. We currently utilize a string length of 128 bytes. This allows us to get rid of boot messages like: env_buf too small [32] Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-23env_flash: Disable debug print statementsPeter Tyser
With debug the follow is printed: => saveenv Saving Environment to Flash... Data to save 0x18000 Data (start 0xfff48000, len 0x18000) saved at 0x7fe63f20 Protect off FFF40000 ... FFF5FFFF Un-Protected 1 sectors Erasing Flash... . done Erased 1 sectors Writing to Flash... Restoring the rest of data to 0xfff48000 len 0x18000 done Protected 1 sectors => Without debug: => saveenv Saving Environment to Flash... Un-Protected 1 sectors Erasing Flash... . done Erased 1 sectors Writing to Flash... done Protected 1 sectors => Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-10-23Merge branch 'for-wd-master' of git://git.denx.de/u-boot-pxaWolfgang Denk
2010-10-23Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
2010-10-23Merge branch 'master' of git://git.denx.de/u-boot-videoWolfgang Denk
2010-10-23Merge branch 'master' of git://git.denx.de/u-boot-usbWolfgang Denk
2010-10-23Merge branch 'master' of git://git.denx.de/u-boot-shWolfgang Denk
2010-10-23a4m072: add CONFIG_SYS_FLASH_BANKS_SIZES defineIlya Yanok
This patch adds CONFIG_SYS_FLASH_BANKS_SIZES define to make use of new cfi_flash driver ability to detect flash chips that are bigger than a corresponding address window (we have such situation on some revs of a4m072). Signed-off-by: Ilya Yanok <yanok@emcraft.com>
2010-10-23cfi_flash: handle 'chip size exceeds address window' situationIlya Yanok
On some boards we have flash mapped high in the address space with considerably small window (say 0xFE000000 and 32MB). When we install bigger chip (say 64MB) on such a board strange things happen (flash_write() doesn't work at all, for ex). That's because cfi_flash driver doesn't care about window size at all. Of course, cleanest solution would probably be to just extend address window to be able to map the whole flash but for legacy/compatibility reasons some people prefer just truncate the flash size and never use the upper part. This patch adds an option for cfi_flash driver to handle this situation properly. To achieve this we add the new function cfi_flash_bank_size() which can be provided by the board code and weak-aliased to default implementation that returns value from the CONFIG_SYS_FLASH_BANKS_SIZES array if it's defined or 0 otherwise (the last case is added for compatibility). If non-zero flash bank size is provided and detected chip size is bigger than provided address window size the warning will be displayed and flash chip will be truncated. Signed-off-by: Ilya Yanok <yanok@emcraft.com> Changed cfi_flash_bank_size() return type to unsigned long to match caller function. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-10-22ehci-hcd.c: fix hanging under higher loadWolfgang Denk
This patch solves a problem with USB hanging under higher load on a i.MX31 board. It falls into class of typical USB problems and fixes: if you don't understand the real cause, add a delay somewhere. The problem appeared after introduction of ELF relocation, which results in smaller code, which appears to run faster (probably because it fits better in the cache); turning off the instruction cache, adding debug printf()s and increasing the delay have all been found to make the problem go away. Moving the original "udelay(1)" up in the code to it's new place made the problem appear much less frequently. Increasing the delay to 2 microseconds then made the code run reliably in all (hour-long) tests. To be on the safe side, we set it to 5 microseconds here. Signed-off-by: Heiko schocher <hs@denx.de> Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Remy Bohmer <linux@bohmer.net> Cc: Stefano Babic <sbabic@denx.de>
2010-10-22usb_storage: constify us_direction lookup tableMike Frysinger
2010-10-22usb: musb: constify a bitMike Frysinger
These ep and root hub structures need not be writable. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-22USB: fix Queue Element Transfer Descriptor changesWolfgang Denk
Commit 3ed1607 "USB: sync Queue Element Transfer Descriptor against EHCI spec" added an "__attribute__ ((aligned (32)))" to the declaration of struct qTD, as used for example in the Linux kernel as well. However, it turns out that this attribute causes errors in "usb start" (like "ERROR: NOT USB_CONFIG_DESC 7b" and similar). Drop the attribute again. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Dan Lykowski <lykowdk@gmail.com> Cc: Remy Bohmer <linux@bohmer.net> Cc: Stefano Babic <sbabic@denx.de>
2010-10-22ehci-pci: print hccr, hcor and hc_lenghtFlorian Fainelli
It is useful to know the EHCI-PCI hccr, hcor and hc_lenght to make sure it was successfully registered, and at the correct location. Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2010-10-22XPedite5500 board supportJohn Schmoller
Initial support for Extreme Engineering Solutions XPedite5500 - a P2020-based PMC/XMC single board computer. Signed-off-by: John Schmoller <jschmoller@xes-inc.com> Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-22xes: Add POST support for 8xxx boardsPeter Tyser
Add memory and I2C posts to the XPedite517x/520x/537x board families. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-22mpc86xx: Add generic POST word read/write supportPeter Tyser
The PIC's TFRR register doesn't affect hardware and is generally unused, so use as storage for the POST word. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-22post/i2c: Add ability to ignore I2C devicesPeter Tyser
Add the ability to not report an I2C POST error for a set of given I2C addresses on bootup. This is useful for cases when a device may or may not be present, and neither case is considered an error. For example: - Some form factors such as XMC and Compact PCI Express have an I2C EEPROM whose address changes based on geographical address. Eg installed in one slot its EEPROM address is, 0x50, in another its 0x51, etc. This allows multiple devices to have their EEPROMs present on the same I2C bus. Thus the I2C devices present for an XMC or CPCIe card depend on if and where other cards are installed in the same system. - Some cards have optional I2C devices. Eg one hardware build configuration has different I2C devices than another and software can't determine if the optional device should be present or not. - Some cards have optional daughtercards with I2C devices on them. - I2C EEPROMs address range depends on their size. Its possible to support differently size EEPROMs by only probing the EEPROM's base address and ignoring the other addresses that are impacted by its size. A new CONFIG_SYS_POST_I2C_IGNORES define has been added which specifies a list of I2C addresses for the I2C POST to ignore. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Acked-by: Heiko Schocher <hs@denx.de> Acked-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-22post/i2c: Rename I2C_ADDR_LIST to CONFIG_SYS_POST_I2C_ADDRSPeter Tyser
2010-10-22post/i2c: Don't probe address 0Peter Tyser
According to the I2C specification device address 0 is the "general call address", ie a broadcast address. The I2C specification states that the format of a general call uses at least 2 bytes, which U-Boot's probing routine does not adhere to. Not probing device address 0 will prevent possible issues with devices that accept general calls. Additionally, this change shouldn't reduce POST coverage since each I2C device should still be accessed via its own, unique address. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Acked-by: Heiko Schocher <hs@denx.de> Acked-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-22post/i2c: Clean up detection logicPeter Tyser
The logic previously used in the I2C post was a bit convoluted. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Acked-by: Heiko Schocher <hs@denx.de> Acked-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-22post/i2c: General clean upPeter Tyser
- Clean up ifdeffery - Update coding style No functional change should have occurred. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Acked-by: Heiko Schocher <hs@denx.de> Acked-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-22xes: Make X-ES board names more genericPeter Tyser
Some U-Boot images for X-ES boards support multiple products in the same family. For example, the XPedite5370, XPedite5371, and XPedite5372 are similar enough that one U-Boot image can work on all 3 cards. To make it clear that a U-Boot image can work on boards of the same family, rename the boards with the least significant digit of 'x'. While we're at it, change the board config file and make targets to be lowercase. Also change the default uImage and fdt filenames to "board.uImage" and "board.dtb" to be more generic. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-22xes: Add board_flash_wp_on()John Schmoller
Add board_flash_wp_on() to check a pca9557 gpio pin to see if non-volatile memory write protection is enabled. Previously, write protected NOR flashes would fail initialization which resulted in a bootup error such as: ... DTT: 53 C local / 64 C remote (adt7461@4c) DTT: 54 C local (ds1621@48) FLASH: Executed from FLASH1 POST memory PASSED FLASH: ## Unknown FLASH on Bank 1 - Size = 0x00000000 = 0 MB ## Unknown FLASH on Bank 2 - Size = 0x00000000 = 0 MB *** failed *** ### ERROR ### Please RESET the board ### With this patch, NOR flash initialization is skipped: ... DTT: 53 C local / 64 C remote (adt7461@4c) DTT: 54 C local (ds1621@48) FLASH: Executed from FLASH1 POST memory PASSED FLASH: Uninitialized - Write Protect On L2: 1024 KB enabled NAND: 1024 MiB ... Note that flash related commands such as flinfo and saveenv will error out when flash write protection is enabled. Signed-off-by: John Schmoller <jschmoller@xes-inc.com> Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-22xes: Consolidate checkboard()John Schmoller
Create a common checkboard() function to support all X-ES's Freescale boards. Also, add a get_board_derivative() function which reads hardware strapping resistors to determine what model a board is. This allows one U-Boot image to support multiple boards. Signed-off-by: John Schmoller <jschmoller@xes-inc.com> Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-22pci: Add ability to re-enumerate PCI busesJohn Schmoller
Add a new 'pci enum' command which re-enumerates the PCI buses. This command is enabled via the CONFIG_CMD_PCI_ENUM define and can be useful in boards with FPGAs connected via PCI/PCIe, boards that support PCI hot-plugging, or during PCI debug. Also enable the 'pci enum' command for X-ES's Freescale-based boards. Signed-off-by: John Schmoller <jschmoller@xes-inc.com> Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Acked-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Wolfgang Denk <wd@denx.de>
2010-10-22xes: Use common PCI initialization codePeter Tyser
Common Freescale code for PCI initialization now exists, so migrate X-ES boards to use it. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-22corenet_ds: Update CONFIG_SYS_GBL_DATA_SIZE to deal with growth in gd_tKumar Gala
The recent change the env code added an additional 32 bytes into gd_t and that causes to grow pass the previous CONFIG_SYS_GBL_DATA_SIZE size. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-22PXA: Remove "xsengine" boardMarek Vasut
This board is broken and it's not possible to repair it. Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
2010-10-22PXA: Remove "wepep250" boardMarek Vasut
This board is broken and impossible to repair without deep knowledge or availability of the hardware. Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
