The fdtdec_pci_get_bdf() function returns the bus, device, function
triplet of a PCI device by parsing the "reg" property according to the
PCI device tree binding.
Signed-off-by: Thierry Reding <treding@nvidia.com>
Add the fdt_get_resource() and fdt_get_named_resource() functions which
can be used to parse resources (memory regions) from an FDT. A helper to
compute the size of a region is also provided.
Given a device tree node, a property name and an index, the new function
fdt_get_string_index() will return in an output argument a pointer to
the index'th string in the property's value.
The fdt_get_string() is a shortcut for the above with the index being 0.
Given a device tree node and a property name, the new fdt_find_string()
function will look up a given string in the string list contained in the
property's value and return its index.
Given a device tree node and a property name, the fdt_count_strings()
function counts the number of strings found in the property value.
Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com>
Reviewed-by: York Sun <yorksun@freescale.com>
Enable blob commands for platforms having SEC 4.0 or greater
for secure boot scenarios
Freescale's SEC block has built-in Blob Protocol which provides
a method for protecting user-defined data across system power
cycles. SEC block protects data in a data structure called a Blob,
which provides both confidentiality and integrity protection.
Encapsulating data as a blob
Each time that the Blob Protocol is used to protect data, a
different randomly generated key is used to encrypt the data.
This random key is itself encrypted using a key which is derived
from SoC's non volatile secret key and a 16 bit Key identifier.
The resulting encrypted key along with encrypted data is called a blob.
The non volatile secure key is available for use only during secure boot.
During decapsulation, the reverse process is performed to get back
the original data.
Commands added
blob enc - encapsulating data as a cryptgraphic blob
blob dec - decapsulating cryptgraphic blob to get the data
Commands Syntax
blob enc src dst len km
Encapsulate and create blob of data $len bytes long
at address $src and store the result at address $dst.
$km is the 16 byte key modifier is also required for
generation/use as key for cryptographic operation. Key
modifier should be 16 byte long.
blob dec src dst len km
Decapsulate the blob of data at address $src and
store result of $len byte at addr $dst.
By default, PAMU's (IOMMU) are enabled in case of secure boot.
Disable/bypass them once the control reaches the bootloader.
For non-secure boot, PAMU's are already bypassed in the default
SoC configuration.
Hardware accelerated support for SHA-1 and SHA-256 has been added.
Hash command enabled along with hardware accelerated support for
SHA-1 and SHA-256 for platforms which have CAAM block.
Enable CAAM in platforms supporting the hardware block.
SHA-256 and SHA-1 accelerated using SEC hardware in Freescale SoC's
The driver for SEC (CAAM) IP is based on linux drivers/crypto/caam.
The platforms needto add the MACRO CONFIG_FSL_CAAM inorder to
enable initialization of this hardware IP.
SEC registers can be of type Little Endian or big Endian depending upon
Freescale SoC. Here SoC defines the register type of SEC IP.
So update acessor functions with common SEC acessor functions to take care
both type of endianness.
Freescale SEC controller has been used for mpc8xxx. It will be used
for ARM-based SoC as well. This patch moves the CCSR defintion of
SEC to common include
U-boot binary size has been increased from 512KB to 768KB.
So update CONFIG_RESET_VECTOR_ADDRESS to reflect the same for
P1010 SPI Flash Secure boot target.
[York Sun: Modified subject to P1010RDB]
The ipu display insists on having a lower_margin smaller
then 2. If this is not the case it will attempt to force
it and adjust the pixclk accordingly. This multiplies pixclk
in Hz with the width and height, since this is typically
a * 10^7 * b * 10^2 * c * 10^2 this will overflow the
uint_32 and make things even worse. Since this is a
bootloader and the adjustment is neglectible, just force
it to two and warn about it.
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
- fix debug pixel clk display and add unit
- fix some comments
Add a block to avoid a build error with the variable declaration.
Enable the option on sandbox to prevent an error being introduced in
future.
Currently uboot wrongly uses 25mV / step for dcdc3, this is a copy and paste
error introduced when adding the axp152_mvolt_to_target during review of the
axp152.c driver. This results in u-boot setting Vddr to 2.3V instead of 1.5V.
This commit fixes this.
With the introduction of CONFIG_LOCALVERSION support we cannot build
tools without having a config file (as we won't know our PLAIN_VERSION
until then).
Reported-by: Otavio Salvador <otavio@ossystems.com.br>
'u-boot-arm/master'
The SoCDK uses EMAC1, not EMAC0. This patch fixes the issue.
Cc: Chin Liang See <clsee@altera.com>
Cc: Dinh Nguyen <dinguyen@altera.com>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Cc: Tom Rini <trini@ti.com>
Cc: Pavel Machek <pavel@denx.de>
Add MAINTAINERS entry.
Signed-off-by: Pavel Machek <pavel@denx.de>
Commit 832472 "tools: socfpga: Add socfpga preloader signing
to mkimage" added tools/socfpga.c which relies on htole32,
le32toh and friends. While compiler.h includes these protypes
for linux from endian.h, it doesn't do so for FreeBSD. Hence
include <sys/endian.h> for FreeBSD.
CC: Tom Rini <trini@ti.com>
Cc: Andreas Bießmann <andreas.devel@googlemail.com>
Cc: Bo Shen <voice.shen@atmel.com>
Signed-off-by: Bo Shen <voice.shen@atmel.com>
Cc: Joe Hershberger <joe.hershberger@gmail.com>
Update readme file for Keystone II EVM boards to actual sources.
Also correct some typos. For now the Edison evaluation board is
added, README for K2E is mostly the same, so update README to
contain information also for K2E evm. Rename file to README as
it contains information for all keystone evm boards.
Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
The K2HK and K2E boards support SPL by default, so add
CONFIG_SPL option. Also export CONFIG_ARM, CONFIG_ARCH_KEYSTONE
and TARGET_K2*_EVM options to spl/.config as they are the same.
So now it's convinient to build gph images using only two commands:
make k2hk_evm_defconfig
make u-boot-spi.gph
Acked-By: Murali Karicheri <m-karicheri2@ti.com>
Signed-off-by: Murali Karicheri <m-karicheri2@ti.com>
We need to set the 'BE' flag here for things to work right.
Since on powerpc phys_size_t can be unsigned long long, this printout
line can result in a not nice compile warning.
Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
The lines COL (collision detect) and CRS (carrier sense) needs to be connected
and muxed to the CPSW MAC for a proper function in half-duplex Mode of the
interface.
Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
Fix the spelling of "configs".
Signed-off-by: York Sun <yorksun@freescale.com>
CC: Masahiro Yamada <yamada.m@jp.panasonic.com>
Acked-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
A SPL/TPL enabled target would was not recognized as
such by BSD sed, since it relies on a GNU extension.
Instead of or-ing just spell out both matches.
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
remove the seldomly used EXT2 support because the U-Boot binary will
not fit into the 512KiB flash otherwise.
Signed-off-by: David Müller <d.mueller@elsoft.ch>
fix broken SPI access by adding/activating BOARD_EARLY_INIT_F
functionality and calling spi_init_f() from there.
A number of network related files were imported from the LiMon
project; these contain a somewhat unclear license statement:
Copyright 1994 - 2000 Neil Russell.
(See License)
I analyzed the source code of LiMon v1.4.2 which was used for this
import. It does not contain any "License" file, but the top level
directory contains a file "COPYING", which turns out to be GPL v2
of June 1991. So it is legitimate to conclude that the LiMon derived
files are also to be released under GPLv2. Mark them as such.
Fix typo of commit d4e53f063dd25e071444b87303573e7440deeb89.
i2c2 pullup resisters are controlled by bit 0 of CONTROL_PROG_IO1.
It's value after reset is 0x00100001.
In order to clear bit 0, original code write 0xfffffffe to
CONTROL_PROG_IO1 and toggle almost all default values.
Original code affect following:
* disable i2c1 pullup resisters
* increase far end load setting for many modules
* setup invalid SC/LB combination
Signed-off-by: Alexander Kochetkov <al.kochet@gmail.com>
CC: Steve Kipisz <s-kipisz2@ti.com>
These boards have been orphaned for more than 6 months.
