- add support for Altera Nios-32 CPU
- add support for Nios Cyclone Development Kit (DK-1C20)
* Patch by Steven Scholz, 29 Sep 2003:
- A second parameter for bootm overwrites the load address for
"Standalone Application" images.
- bootm sets environment variable "filesize" to the resulting
(uncompressed) data length for "Standalone Application" images
when autostart is set to "no". Now you can do something like
if bootm $fpgadata $some_free_ram ; then
fpga load 0 $some_free_ram $filesize
fi
* Patch by Denis Peter, 25 Sept 2003:
add support for the MIP405 Rev. C board
add support for Zephyr Engineering ZPC.1900 board
* Patch by Anders Larsen, 23 Sep 2003:
add CMD_PORTIO to CFG_CMD_NONSTD (commands in question are only
implemented for the x86 architecture)
fix pll_pci_to_mem_multiplier table for MPC8245
* Patch by Anders Larsen, 22 Sep 2003:
enable timed autoboot on PXA
* Patch by David Müller, 22 Sep 2003:
- add $(CFLAGS) to "-print-libgcc-filename" so compiler driver
returns correct libgcc file path
- "latency" reduction of busy-loop waiting to improve "U-Boot" boot
time on s3c24x0 systems
* Patch by Jon Diekema, 19 Sep 2003:
- Add CFG_FAULT_ECHO_LINK_DOWN option to echo the inverted Ethernet
link state to the fault LED.
- In NetLoop, make the Fault LED reflect the link status. The link
status gets updated on entry, and on timeouts.
allow mkimage to build and run on Cygwin-hosted systems
* Patch by Frank Müller, 18 Sep 2003:
use bi_intfreq instead of bi_busfreq to compute fec_mii_speed in
cpu/mpc8xx/fec.c
* Patch by Pantelis Antoniou, 16 Sep 2003:
add tool to compute fileds in the PLPRCR register for MPC86x
* Make fatload set filesize environment variable
fix potential buffer overlow problem
* enable basic / medium / high-end configurations for PPChameleonEVB
board; fix NAND code
* enable TFTP client code to specify to the server the desired
timeout value (see RFC-2349)
is set
is set
Cleanup for submitted patches.
- Fixes for MPC8266 default config
- Allow eth_loopback_test() on 8260 to use a subset of the FCC's
- update README (SHOW_BOOT_PROGRESS values for cmd_nand.c and
env_common.c)
- sbc8260 tweaks
- adjust "help" output
- fix spelling errors
- set GD_FLG_DEVINIT flag only after device function pointers
are valid
- Allow CFG_ALT_MEMTEST on systems where address zero isn't
writeable
- enable 3.rd UART (ST-UART) on PXA(XScale) CPUs
- trigger watchdog while waiting in serial driver
Minor cleanup of comments
priority; configure critical interrupts to be handled like external
interrupts
go back to 66 MHz for stability
- add description for missing CFG_CMD_* entries in the README file
- sacsng tweaks:
include/configs/sacsng.h:
+ Support extra bootp options like: 2nd DNS and send hostname
+ Enabling ping and irq command
+ Adding defines for a bunch of misc configrabled options
(patches for these options will be coming)
+ Adding watchdog support, but it isn't enabled yet.
board/sacsng/sacsng.c:
+ Suppressing unneeded output when the quiet environment
is non-zero.
+ show_boot_progress() now accepts any negative number as a
failure code.
+ show_boot_progress() flashes the error code 5 times, and
then resets the board to retry the boot from the top
* Patch by Gleb Natapov, 14 Sep 2003:
enable watchdog support for all MPC824x boards that have a watchdog
* On MPC5200, restrict FEC to a maximum of 10 Mbps to work around the
"Non-octet Aligned Frame" errors we see at 100 Mbps
* Patch by Sharad Gupta, 14 Sep 2003:
fix SPR numbers for upper BAT register ([ID]BAT[4-7][UL])
update configuration for PPChameleonEVB board
various changes to VCMA9 board specific files
* Add I2C support for MGT5100 / MPC5200
Changed default memory option on MPC8266ADS to NOT be Page Based
Interleave, since this doesn't work very well with the standard
16MB DIMM
* Patch by George G. Davis, 12 Sep 2003:
fix Makefile settings for sk98 driver
