Use smaller fields in the Tegra pinmux structures in order to pack the
data tables into a smaller space. This saves around 1-3KB for the SPL
and around 3-8KB for the main build of U-Boot, depending on the board,
which SoC it uses, and how many pinmux table entries there are.
In order to pack PMUX_FUNC_* into a smaller space, don't hard-code the
values of PMUX_FUNC_RSVD* to values which require 16 bits to store them,
but instead let their values be assigned automatically, so they end up
fitting into 8 bits.
Signed-off-by: Tom Warren <twarren@nvidia.com>
Combine the Tegra USB header file into one header file for all SoCs.
Use ifdef to account for the difference, especially Tegra20 is quite
different from newer SoCs. This avoids duplication, mainly for
Tegra30 and newer devices.
Signed-off-by: Stefan Agner <stefan@agner.ch>
On Tegra30 and later, the PTS (parallel transceiver select) and STS
(serial transceiver select) are part of the HOSTPC1_DEVLC_0 register
rather than PORTSC1_0 register. Since the reset configuration
usually matches the intended configuration, this error did not show
up on Tegra30 devices.
Also use the slightly different bit fields of first USB, (USBD) on
Tegra20 and move those definitions to the Tegra20 specific header
file.
Clear the forced powerdown bit in the UTMIP_PLL_CFG2_0 register
which brings USB2 in UTMI mode to work. This was clearly missing
since the forced powerdown bit is set in reset by default for all
USB ports.
Jetson TK1 is an NVIDIA Tegra124 reference board, which shares much of
its design with Venice2.
This renames all the pinmux pins, drive groups, and functions so they
have a prefix which matches the type name. These lists are also auto-
generated using scripts that were also used to generate the kernel
pinctrl drivers. This ensures that the lists are consistent between the
two.
The entries in tegra124_pingroups[] are all updated to remove the columns
which are no longer used.
All affected code is updated to match.
There are differences in the set of drive groups. I have validated this
against the TRM. There are differences order of pin definitions in
pinmux.c; these previously had significant mismatches with the correct
order:-( I adjusted a few entries in pinmux-config-venice2.h since the
set of legal functions for some pins was updated to match the TRM.
two.
The entries in tegra114_pingroups[] are all updated to remove the columns
This introduces a few changes to pin/group/function naming and the set of
available functions for each pin. The new values now exactly match the
TRM; the chip documentation. I adjusted a few entries in
pinmux-config-dalmore.h due to this.
two.
The entries in tegra30_pingroups[] are all updated to remove the columns
TRM; the chip documentation. I adjusted one entry in
pinmux-config-cardhu.h due to this.
This renames all the Tegra20 pinmux pins and functions so they have a
The entries in tegra20_pingroups[] are all updated to remove the columns
Clean up the naming of pinmux-related objects:
* Refer to drive groups rather than pad groups to match the Linux kernel.
* Ensure all pinmux API types are prefixed with pmux_, values (defines)
are prefixed with PMUX_, and functions prefixed with pinmux_.
* Modify a few type names to make their content clearer.
* Minimal changes to SoC-specific .h/.c files are made so the code still
compiles. A separate per-SoC change will be made immediately following,
in order to keep individual patch size down.
Remove a few unused functions from the pinmux header. They aren't
currently used, and removing them prevents any new usage from appearing.
This will ease moving to just pinmux_config_table() and
padgrp_config_table() in the future.
Much of arch/arm/cpu/tegra*-common/pinmux.c is identical. Remove the
duplication by creating pinmux-common.c for all the identical code.
This leaves:
* arch/arm/include/asm/arch-tegra*/pinmux.h defining only the names of
the various pins/pin groups, drive groups, and mux functions.
* arch/arm/cpu/tegra*-common/pinmux.c containing only the lookup table
stating which pin groups support which mux functions.
The code in pinmux-common.c is semantically identical to that in the
various original pinmux.c, but had some consistency and cleanup fixes
applied during migration.
I removed the definition of struct pmux_tri_ctlr, since this is different
between SoCs (especially Tegra20 vs all others), and it's much simpler to
deal with this via the new REG/MUX_REG/... defines. spl.c, warmboot.c,
and warmboot_avp.c needed updates due to this, since they previously
hijacked this struct to encode the location of some non-pinmux registers.
Now, that code simply calculates these register addresses directly using
simple and obvious math. I like this method better irrespective of the
pinmux code cleanup anyway.
Tegra's "APB misc" register region contains various miscellaneous
registers and the Tegra pinmux registers. Some code that touches the
misc registers currently uses struct pmux_tri_ctlr, which is intended to
be a definition of pinmux registers, rather than struct apb_misc_pp_ctrl,
which is intended to be a definition of the miscellaneous registers.
Convert all such code to use struct apb_misc_pp_ctrl, since struct
pmux_tri_ctlr goes away in the next patch.
This requires adding a missing field definition to struct
apb_misc_pp_ctrl, and moving the header into a more common location.
pinmux_init() is a board-level function, not a pinmux driver function.
Move the prototype to a board header rather than the driver header.
For consistency with other SoCs, modify Tegra20's enum pmux_func to:
* Remove PMUX_FUNC values that aren't real
* Use the same PMUX_FUNC_RSVD[1-4] values, and ensure (RSVD1 & 3)==0;
this will be assumed by pinmux_set_func() in a future patch.
Unfortunately, PMUX_FUNC_RSVD is still used in the pin macros. Use a
private define inside the driver to prevent this from causing compilaton
errors. This will be cleaned up when the pin tables are re-written in a
later patch in this series.
This field isn't used anywhere, so remove it. Note that PIN() macros are
left unchanged for now, to avoid many diffs to them; later commits will
completely rewrite them just one time.
Add CONFIG_SYS_GENERIC_BOARD to use common/board_[fr].c for kzm9g.
Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp>
Acked-by: Heiko Schocher <hs@denx.de>
This is regression of commit 2035d77d i2c: sh_i2c: Update to new CONFIG_SYS_I2C framework
Before commit 2035d77d, i2c probe command works properly on kzm9g board.
KZM-A9-GT# i2c probe
Valid chip addresses: 0C 12 1D 32 39 3D 40 60
After commit 2035d77d, i2c probe command does not work.
Valid chip addresses: 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 10 11 12 13 14 15 16 17 18 19 1A 1B 1C 1D 1E 1F 20 21 22 23 24 25 26 27 28 29 2A 2B 2C 2D 2E 2F 30 31 32 33 34 35 36 37 38 39 3A 3B 3C 3D 3E 3F 40 41 42 43 44 45 46 47 48 49 4A 4B 4C 4D 4E 4F 50 51 52 53 54 55 56 57 58 59 5A 5B 5C 5D 5E 5F 60 61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 71 72 73 74 75 76 77 78 79 7A 7B 7C 7D 7E 7F
sh_i2c_probe() calls sh_i2c_read(), but read length is 0. So acutally it does not read device at all. This patch prepares dummy buffer and read data into it.
Commit d016dc42cedbf6102e100fa9ecb58462edfb14f8 changed the layout of BCH8 SW
on omap3 boards. We need to adopt the ecc layout for the nand_spl_simle
driver to avoid wrong ecc errors.
Signed-off-by: Andreas Bießmann <andreas.biessmann@corscience.de>
Cc: Thomas Weber <thomas.weber@corscience.de>
Commit 890880583d84607e36b52a785a96b167728bbf73 introduced EEPROM parsing and
board detection but faild to return a valid tricorder_eeprom struct for backup
case. When pressing S200 while reading EEPROM we ignore the value. We
returned falsely a tricorder_eeprom struct with uninitialized data which is
just garbage.
Initialize it by zeroing the whole structure.
During switch to device tree, commit 1ecab0f has removed this code.
INFORM4 and INFORM5 registers are used by TRATS2 first stage bootloader for
providing recovery. For normal operation, those two must be cleared out.
This error emerges when one force reset from u-boot's command line for
three times.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
Acked-by: Minkyu Kang <mk7.kang@samsung.com>
In some use cases, SPL linker script was not updated even when
it should be.
For instance,
$ make tricoder_config all
[ build complete ]
... modify include/configs/tricoder.h
$ make
spl/u-boot-spl.lds should be updated in this case, but it wasn't.
To fix this problem, linker scripts generation should be handled
by $(call if_changed_dep,...) rather than by $(call if_changed,...).
Reported-by: Andreas Bießmann <andreas.devel@googlemail.com>
Tested-by: Andreas Bießmann <andreas.devel@googlemail.com>
arch/arm/cpu/arm926ejs/mxs/Makefile
include/configs/trats.h
include/configs/trats2.h
include/mmc.h
This patch add gicv3 support to uboot armv8 platform.
Changes for v2:
- rename arm/cpu/armv8/gic.S with arm/lib/gic_64.S
- move smp_kick_all_cpus() from gic.S to start.S, it would be
implementation dependent.
- Each core initialize it's own ReDistributor instead of master
initializeing all ReDistributors. This is advised by arnab.basu
<arnab.basu@freescale.com>.
Signed-off-by: David Feng <fenghua@phytium.com.cn>
The conditional is using a variable that is not defined.
Signed-off-by: Rommel G Custodio <sessyargc+u-boot@gmail.com>
When flush the d$ with set/way instruction, it need calculate the way's
offset = log2(Associativity); but in current uboot's code, it use below
formula to calculate the offset: log2(Associativity * 2 - 1), so finally
it cannot flush data cache properly.
Signed-off-by: Leo Yan <leoy@marvell.com>
For ARMv8, U-boot has been running at EL3 with cache and MMU enabled.
Without proper setup for EL2, cache and MMU are both disabled (out of
reset). Before switching, we need to flush the dcache to make sure the
data is in the main memory.
Signed-off-by: York Sun <yorksun@freescale.com>
Acked-by: David.Feng <fenghua@phytium.com.cn>
Get rid of double VF610_PAD_DDR_A15__DDR_A_15 iomux configuration.
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
This patch contains several changes required for second Ethernet
(enet1/RMII1) port on vf610
- ANADIG PLL5 control definitions required for Ethernet RMII1 clock
- Secondary Ethernet (enet1) MAC RMII1 base address definition
- RMII1 iomux definitions
- VF610_PAD_PTA6__RMII0_CLKOUT iomux definition required for
internal (e.g. crystal-less) Ethernet clocking.
[stefan@agner.ch: regrouped patch]
Add CCM_CCGR0_UART0_CTRL_MASK clock definition and add TX/RX iomux
definitions for UART0 (aka. SCI0).
The anadig_reg structure started at the wrong offset (fixed by adding
reserved_0x000[4]), was missing some reserved field required for
alignment purpose (reserved_0x094[3] between pll4_denom and pll6_ctrl)
and further contained a too short reserved field causing further miss-
alignment (reserved_0x0C4[7]). Also, rename all the reserved fields
and using a memory offset based scheme for.
Discovered and tested by temporarily putting the following debug
instrumentation into board_init():
struct anadig_reg *anadig = (struct anadig_reg *)ANADIG_BASE_ADDR;
printf("&anadig->pll3_ctrl=0x%p\n", &anadig->pll3_ctrl);
printf("&anadig->pll5_ctrl=0x%p\n", &anadig->pll5_ctrl);
After Kbuild introduction, the CROSS_COMPILE environment variable has been
set to some default value (prefix arm-linux-).
This shall be removed since it breaks building u-boot for native arm target
(like qemu ARM).
Moreover not all compilers have arm-linux- prefix.
Additionally the u-boot cross compiles with CROSS_COMPILE= set explicitly-
e.g.:
CROSS_COMPILE=/ .... /arm-v7a-linux-gnueabi- make
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Acked-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
Since MX6 is Cortex-A9 r2p10, enable software workaround
for errata 794072 and 761320.
Signed-off-by: Nitin Garg <nitin.garg@freescale.com>
Full cache line writes to the same memory region from at least two
processors might deadlock the processor. Exists on r1, r2, r3
revisions.
Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
A short loop including a DMB instruction might cause a denial of
service on another processor which executes a CP15 broadcast operation.
Exists on r1, r2, r3, r4 revisions.
Acked-by: Dirk Behme <dirk.behme@de.bosch.com>
When SoC first boots up, we should invalidate the cache but not flush it.
We can use the same function for invalid and flush mostly, with a wrapper.
Invalidating large cache can ben slow on emulator, so we postpone doing
so until I-cache is enabled, and before enabling D-cache.
CC: David Feng <fenghua@phytium.com.cn>
If D-cache is enabled, we need to flush it, and invalidate i-cache before
jumping to the new location. This should be done right after relocation.
Move setting for MAIR and TCR to cache_v8.c, to avoid conflict with
sub-architecture.
Avoids "could not find output section .gnu.hash" ld.bfd errors on openSUSE.
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Cc: Tom Rini <trini@ti.com>
Signed-off-by: Andreas Färber <afaerber@suse.de>
Clock Manager driver will be called to reconfigure all the
clocks setting based on user input. The input are passed to
Preloader through handoff files
Signed-off-by: Chin Liang See <clsee@altera.com>
CC: Pavel Machek <pavel@denx.de>
Cc: Dinh Nguyen <dinguyen@altera.com>
Acked-by: Pavel Machek <pavel@denx.de>
We've run into a non-trivial conversion to CONFIG_SYS_GENERIC_BOARD so
we'll postpone this notice until right after v2014.04 is out.
This reverts commit 36c4b1d98059244c34ec3327d9cc9f3c552fd01b.
This patch adds the groundwork for generating signed BootStream, which
can be used by the HAB library in i.MX28. We are adding a new target,
u-boot-signed.sb , since the process for generating regular non-signed
BootStream is much easier. Moreover, the signed bootstream depends on
external _proprietary_ _binary-only_ tool from Freescale called 'cst',
which is available only under NDA.
To make things even uglier, the CST or HAB mandates a kind-of circular
dependency. The problem is, unlike the regular IVT, which is generated
by mxsimage, the IVT for signed boot must be generated by hand here due
to special demands of the CST. The U-Boot binary (or SPL binary) and IVT
are then signed by the CST as a one block. But here is the problem. The
size of the entire image (U-Boot, IVT, CST blocks) must be appended at
the end of IVT. But the size of the entire image is not known until the
CST has finished signing the U-Boot and IVT. We solve this by expecting
the CST block to be always 3904B (which it is in case two files, U-Boot
and the hand-made IVT, are signed in the CST block).
arch/arm/cpu/arm926ejs/mxs/mxsimage.mx23.cfg
arch/arm/cpu/arm926ejs/mxs/mxsimage.mx28.cfg
This reverts commit 53e6b14e037c9f72e6d03244c32d8d597e2e0234.
Patch does not merge anymore with u-boot-arm and must be rebased.
This change enables automatically uuid generation by command gpt.
In case of updating partitions layout user don't need to care about
generate uuid manually.
Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com>
Cc: Piotr Wilczek <p.wilczek@samsung.com>
Cc: Stephen Warren <swarren@nvidia.com>
Cc: Lukasz Majewski <l.majewski@samsung.com>
Cc: trini@ti.com
