mx6slevk board is a development board from Freescale based on the mx6 solo-lite
processor.
For details about mx6slevk, please refer to:
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=IMX6SLEVK&parentCode=i.MX6SL&fpsp=1
mx6 solo-lite is another member of the mx6 series.
For more information about mx6 solo-lite, please visit:
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=i.MX6SL&nodeId=018rH3ZrDRB24A
Instead of having the same PAD control definition in each MX6 variant pin file,
place it into a common location.
The ARM errata 742230 - "ARM errata: DMB operation may be faulty" is
claimed for Cortex-A9 (r1p0..r2p2). Though i.MX6 uses a newer revision
than r2p2, we are seeing a reboot failure on i.MX6 SMP build that can be
fixed by applying the workaround for this errata. So for safety, let's
define CONFIG_ARM_ERRATA_742230 to enable the workaround on i.MX6.
Snow is missing a TMU node, and with TMU support this is not allowed, so it
fails to boot. Add it.
The current code is causing errors like this on my toolchains:
/usr/x86_64-pc-linux-gnu/armv7a-cros-linux-gnueabi/binutils-bin/2.22/
ld.bfd.real: failed to merge target specific data of file /usr/lib/gcc/
armv7a-cros-linux-gnueabi/4.7.x-google/libgcc.a(_divdi3.o)
Use do_div() to avoid this.
Exynos5250 supports secondary USB device boot mode. If the iROM fails
to download u-boot from the primary boot device (such as SD or eMMC),
it will try to retrieve from the secondary boot device (such as USB).
Signed-off-by: Naveen Krishna Ch <ch.naveen@samsung.com>
Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com>
They never return anything also than 0, so lets change the function
to void instead.
this is usefull when writing an UBI image which contains
and UBIFS volume (check README.nand and UBI FAQ for more details)
Signed-off-by: Eric Bénard <eric@eukrea.com>
Acked-by: Otavio Salvador <otavio@ossystems.com.br>
This makes mxc_iomux_set_input() work correctly. Previously, the
incorrect offset of IOMUXSW_INPUT_CTL caused mxc_iomux_set_input()
to write to the wrong register, possibly resulting in unexpected
behaviour.
Signed-off-by: Philip Paeps <philip@paeps.cx>
Beaver is a Tegra30 board that is nearly 100% compatible w/Cardhu.
Add a Beaver build so it can begin to be differentiated, if need be.
Signed-off-by: Tom Warren <twarren@nvidia.com>
As suggested by Stephen Warren, use tegra_get_chip() to return
the pure CHIPID for a Tegra SoC (i.e. 0x20 for Tegra20, 0x30 for
Tegra30, etc.) and rename tegra_get_chip_type() to reflect its true
function, i.e. tegra_get_chip_sku(), which returns an ID like
TEGRA_SOC_T25, TEGRA_SOC_T33, etc.
A comparison of registers between our internal NV U-Boot and
u-boot-tegra/next showed some discrepancies in the MSELECT
clock divisor programming. T20 doesn't have a MSELECT clk src reg.
T114 needs the SYSCTR0 counter initialized so the TSC can be
read by the kernel. Do it in the bootloader since it's a write-once
deal (secure/non-secure mode dependent).
Without this change, kernel fails at calling function cache_clean_flush
during kernel early boot.
Aprocryphally, intended for T114 only, so I check for a T114 SoC.
Works (i.e. dalmore 3.8 kernel now starts printing to console).
Boot script support brings TEC in line with other Tegra boards. To
enable booting a Linux kernel with initial ramdisk, also include support
for the new FIT image type.
Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
Boot script support brings Plutux in line with other Tegra boards. In
order to enable booting a Linux kernel with initial ramdisk, also add
support for the new FIT image type.
Boot script support brings Medcom-Wide in line with other Tegra boards.
In order to enable booting a Linux kernel with initial ramdisk, also add
Move the nand-controller node to the tegra20-tamonten.dtsi so that it
can be shared between all derived boards.
A start vector fix was added by AneeshV for OMAP4 (commit 0d479b53),
and caused the old monilithic Tegra builds to hang due to an undefined
instruction trap. Previously, the code needed to run on both the
AVP (ARM7TDI) and A9, and the AVP doesn't have a CP15 register.
I corrected this in commit 6d6c0bae w/#ifndef CONFIG_TEGRA, but
now that we use SPL, and boot the AVP w/o any ARMv7 code, I can
revert my change, and make Aneesh's change apply to Tegra.
Some 3rd-party flash tools use the -v (verify) option of crc32 command.
Make U-Boot aware of the T33 SKU of Tegra30, and treat it identically
to any other Tegra30.
An alternative would be to simply remove the SKU checking from
tegra_get_chip_type(); most use of the value most likely simply wants
to know the current chip, not the specific SKU. Or, the function could
be split into separate tegra_get_chip() and tegra_get_sku() for the
cases where differentiation really is required.
I wonder whether tegra_get_chip_type() should printf() whenever any
unkown chip/SKU is found, although perhaps the function is called so
early that the printf() wouldn't actually make it to the UART anyway.
The KVM and Xen hypervisors for the Cortex-A15 virtualization
implementation need to be entered in HYP mode. Should the primary
board firmware already enter HYP mode (Calxeda firmware does that),
we should not deliberately drop back to SVC mode.
Since U-boot does not use the MMU, running in HYP mode is just fine.
Signed-off-by: Andre Przywara <andre.przywara@linaro.org>
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
This target wants to check full SPL size, BSS included.
Remove CONFIG_SPL_MAX_SIZE definition and instead define
CONFIG_SPL_MAX_FOOTPRINT.
Remove SPL-related ASSERT() in arch/arm/cpu/u-boot.lds
as this file is never used for SPL builds.
Rewrite the ASSERT() in arch/arm/cpu/u-boot-spl.lds
to separately test image (text,data,rodata...) size,
BSS size, and full footprint each against its own max,
and make Tegra boards check full footprint.
Also, output section mmutable is not used in SPL builds.
Remove it.
Finally, update README regarding the (now homogeneous)
semantics of CONFIG_SPL_[BSS_]MAX_SIZE and add the new
CONFIG_SPL_MAX_FOOTPRINT macro.
Reported-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
Rework the waiting for transfer completion loop condition
to continue waiting until both Transfer Complete and DMA End
interrupts occur. Checking of DLA bit in Present State register
looks not needed in addition to interrupts status checking,
so it can be removed from the condition. Also, DMA Error
condition is added to the list of data errors, checked in the loop.
Signed-off-by: Andrew Gabbasov <andrew_gabbasov@mentor.com>
The cache should invalidate the read buffer for
the SD card interface after the transfer complete,
not command-complete.
Tested-by: Andrew Gabbasov <Andrew_Gabbasov@mentor.com>
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
Commit 3ebd1cbc introduced compiler-generated __bss_start
and __bss_end__ and commit c23561e7 rewrote all __bss_end__
as __bss_end. Their merge caused silent and harmless but
potentially bug-inducing clashes between compiler- and linker-
generated __bss_end symbols.
Make __bss_end and __bss_start compiler-only, and create
__bss_base and __bss_limit for linker-only use.
The glitch in the SPI clock line, which commit 3cea335c34 (spi: mxc_spi: Fix spi
clock glitch durant reset) solved, is back now and itwas re-introduced by
commit d36b39bf0d (spi: mxc_spi: Fix ECSPI reset handling).
Actually the glitch is happening due to always toggling between slave mode
and master mode by configuring the CHANNEL_MODE bits in this reset function.
Since the spi driver only supports master mode, set the mode for all channels
always to master mode in order to have a stable, "glitch-free" SPI clock line.
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
When swi instruction is executed, it is expected to get message
"software interrupt" in console and dump registers and reboot, as
do_software_interrupt() in arch/arm/lib/interrupts.c.
But, actually it causes data abort accessing wrong address in get_bad_stack_swi
macro in arch/arm/cpu/v7/start.S.
This patch fixes this problem.
The same mistake in arch/arm/cpu/{arm1136,arm1176,pxa}/start.S.
Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp>
This enables the device tree library on the Integrator platforms
so we can pass a device tree when booting.
As this board has NAND and supports YAFFS2, add CONFIG_MD_NAND_YAFFS
Cc: David Müller <d.mueller@elsoft.ch>
Acked-by: David Müller <d.mueller@elsoft.ch>
drivers/video/exynos_fb.c
ext3 should not be used on SD cards, so use ext4 instead.
Cc: Sricharan R <r.sricharan@ti.com>
The processor is hopefully running with M(ega)Hz and not with m(illi)Hz.
Signed-off-by: Manfred Huber <man.huber@arcor.de>
The previous timings were done on the internal-only A1 board which has
different DDR part than all later revs. The timings need a slight
adjustment to be correct in all cases with later revs.
This board is from a u-boot point of view a mixture between kmnusa and
a standard km_kirkwood board. We have our u-boot environment in the spi
NOR flash, but we have a direct connection between the kirkwood and the
piggy. A FPGA is connected via the PCIe interface. So we only have to
select the specific features in the board setup.
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
cc: Valentin Longchamp <valentin.longchamp@keymile.com>
cc: Prafulla Wadaskar <prafulla@marvell.com>
Acked-By: Prafulla Wadaskar <prafulla@marvell.com>
Switch from 1-bit ecc to 4-bit ecc.
commit 9660e442 cosmetic: s/BOARD_LATE_INIT/CONFIG_BOARD_LATE_INIT
removes BOARD_LATE_INIT and uses CONFIG_BOARD_LATE_INIT instead.
Therefore we have to use this define.
Acked-by: Prafulla Wadaskar <prafulla@marvell.com>
If CONFIG_NAND_ECC_BCH is set use 4-bit error correction code instead of
the 1-bit error correction code on the NAND device.
Signed-off-by: Gerlando Falauto <gerlando.falauto@keymile.com>
Acked-by: Scott Wood <scottwood@freescale.com>
The conversion of mx31pdk to SPL NAND fixed the boot issue, but we start seeing
resets in loop, which prevents us from reaching the U-boot prompt.
Until the proper fix can be identified, disable watchdog, so that mx31pdk
can be functional again.
