2008-10-1874xx/7xx/86xx: Rename flush_data_cache to flush_dcache to match 85xx versionKumar Gala
2008-10-18Expose command table search for sub-commandsKumar Gala
Sub-command can benefit from using the same table and search functions that top level commands have. Expose this functionality by refactoring find_cmd() and introducing find_cmd_tbl() that sub-command processing can call. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-10-18mgsuvd, mgcoge: added BOOTCOUNT feature.Heiko Schocher
2008-10-18mgcoge, mgsuvd: added support for the IVM EEprom.Heiko Schocher
The EEprom contains some Manufacturerinformation, which are read from u-boot at boot time, and saved in same hush shell variables. Signed-off-by: Heiko Schocher <hs@denx.de>
2008-10-18hush: add showvar command for hush shell.Heiko Schocher
This new command shows the local variables defined in the hush shell: => help showvar showvar - print values of all hushshell variables showvar name ... - print value of hushshell variable 'name' Also make the set_local_var() and unset_local_var () no longer static, so it is possible to define local hush shell variables at boot time. If CONFIG_HUSH_INIT_VAR is defined, u-boot calls hush_init_var (), where boardspecific code can define local hush shell variables at boottime. Signed-off-by: Heiko Schocher <hs@denx.de>
2008-10-18I2C: adding new "i2c bus" Command to the I2C Subsystem.Heiko Schocher
With this Command it is possible to add new I2C Busses, which are behind 1 .. n I2C Muxes. Details see README. Signed-off-by: Heiko Schocher <hs@denx.de>
2008-10-18mgcoge, mgsuvd: add board specific I2C deblocking mechanism.Heiko Schocher
As documented in doc/I2C_Edge_Conditions, adding a board specific deblocking mechanism via CFG_I2C_INIT_BOARD for the mgcoge and mgsuvd board. This code was originally written by Keymile in association with Anatech and Atmel in 1998. The Code toggels the SCL until the SCA line goes to HIGH (max. 16 times). And after this, a start condition is sent. This is another approach to deblock the I2C Bus. The soft I2C driver actually sends 9 clocks with SDA High, and then a stop at the end, to deblock the I2C Bus. Maybe we should use the approach from Keymile as the new standard? Signed-off-by: Heiko Schocher <hs@denx.de>
2008-10-18soft_i2c: Add CFG_I2C_INIT_BOARD optionHeiko Schocher
This patch adds the option for a boardspecific I2C deblocking mechanism for the soft i2c driver. Signed-off-by: Heiko Schocher <hs@denx.de>
2008-10-18mgcoge, mgsuvd: add DTT (LM75) support.Heiko Schocher
2008-10-18lm75: Make the LM75 MULTI_BUS compatible.Heiko Schocher
2008-10-18lm75: fix Codingstyle issues.Heiko Schocher
2008-10-18mgcoge, mgsuvd: added EEprom support.Heiko Schocher
2008-10-18mgcoge, mgsuvd: add I2C support.Heiko Schocher
2008-10-18soft_i2c: prevent compiler warnings if driver does not use CPU Pins.Heiko Schocher
This patch fixes the following warnings, when using the soft_i2c driver using no CPU pins on MPC82xx or MPC8xx systems: soft_i2c.c: In function 'send_reset': soft_i2c.c:93: warning: unused variable 'immr' soft_i2c.c: In function 'send_start': soft_i2c.c:124: warning: unused variable 'immr' soft_i2c.c: In function 'send_stop': soft_i2c.c:146: warning: unused variable 'immr' soft_i2c.c: In function 'send_ack': soft_i2c.c:171: warning: unused variable 'immr' soft_i2c.c: In function 'write_byte': soft_i2c.c:196: warning: unused variable 'immr' soft_i2c.c: In function 'read_byte': soft_i2c.c:244: warning: unused variable 'immr' Signed-off-by: Heiko Schocher <hs@denx.de>
2008-10-18i2c: add CONFIG_I2C_MULTI_BUS for soft_i2c and mpc8260 i2c driver.Heiko Schocher
2008-10-18mgcoge: fix Coding Style issues.Heiko Schocher
2008-10-18I2C: add new command i2c reset.Heiko Schocher
If I2C Bus is blocked (see doc/I2C_Edge_Conditions), it is not possible to get out of this, until the complete Hardware gets a reset. This new commando calls again i2c_init (and that calls i2c_init_board if defined), which will deblock the I2C Bus. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-10-18mgsuvd, mgcoge: move this 2 boards in one dir.Heiko Schocher
There are some more extensions, which are for both boards and some more boards from this manufacturer will follow soon. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-10-18hwmon: Add LM63 supportDirk Eibach
This patch adds support for the National LM63 temperature sensor with integrated fan control. It's used on the GDSys Neo board (405EP) which will be submitted later. Signed-off-by: Dirk Eibach <eibach@gdsys.de> Acked-by: Stefan Roese <sr@denx.de>
2008-10-18Add Red Black Tree supportKyungmin Park
Now it's used at UBI module. Of course other modules can use it. If you want to use it, please define CONFIG_RBTREE Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2008-10-18CONFIG_EFI_PARTITION: Added support for EFI partition in cmd_ext2fs.crichardretanubun
Added support for CONFIG_EFI_PARTITION to ext2 commands. Signed-off-by: Richard Retanubun <RichardRetanubun@RugggedCom.com>
2008-10-18Add support for CONFIG_EFI_PARTITION (GUID Partition Table)richardretanubun
The GUID (Globally Unique Identifier) Partition Table (GPT) is a part of EFI. See http://en.wikipedia.org/wiki/GUID_Partition_Table Based on linux/fs/partitions/efi.[ch] Signed-off-by: Richard Retanubun <RichardRetanubun@RugggedCom.com>
2008-10-18FIT: output image load address for type 'firmware', fix message while thereBartlomiej Sieka
Now that the auto-update feature uses the 'firmware' type for updates, it is useful to inspect the load address of such images. Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2008-10-18Automatic software update from TFTP serverBartlomiej Sieka
The auto-update feature allows to automatically download software updates from a TFTP server and store them in Flash memory during boot. Updates are contained in a FIT file and protected with SHA-1 checksum. More detailed description can be found in doc/README.update. Signed-off-by: Rafal Czubak <rcz@semihalf.com> Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2008-10-18flash: factor out adjusting of Flash address to the end of sectorBartlomiej Sieka
The upcoming automatic update feature needs the ability to adjust an address within Flash to the end of its respective sector. Factor out this functionality to a new function flash_sect_roundb(). Signed-off-by: Rafal Czubak <rcz@semihalf.com> Signed-off-by: Bartlomiej Sieka <tur@semihalf.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-10-18net: Make TFTP server timeout configurableBartlomiej Sieka
There are two aspects of a TFTP transfer involving timeouts: 1. timeout waiting for initial server reply after sending RRQ 2. timeouts while transferring actual data from the server Since the upcoming auto-update feature attempts a TFTP download during each boot, it is undesirable to have a long delay when the TFTP server is not available. Thus, this commit makes the server timeout (1.) configurable by two global variables: TftpRRQTimeoutMSecs TftpRRQTimeoutCountMax TftpRRQTimeoutMSecs overrides default timeout when trying to connect to a TFTP server, TftpRRQTimeoutCountMax overrides default number of connection retries. The total delay when trying to download a file from a non-existing TFTP server is TftpRRQTimeoutMSecs x TftpRRQTimeoutCountMax milliseconds. Timeouts during file transfers (2.) are unaffected. Signed-off-by: Rafal Czubak <rcz@semihalf.com> Signed-off-by: Bartlomiej Sieka <tur@semihalf.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-10-18net: express the first argument to NetSetTimeout() in millisecondsBartlomiej Sieka
Enforce millisecond semantics of the first argument to NetSetTimeout() -- the change is transparent for well-behaving boards (CFG_HZ == 1000 and get_timer() countiing in milliseconds). Rationale for this patch is to enable millisecond granularity for network-related timeouts, which is needed for the upcoming automatic software update feature. Summary of changes: - do not scale the first argument to NetSetTimeout() by CFG_HZ - change timeout values used in the networking code to milliseconds Signed-off-by: Rafal Czubak <rcz@semihalf.com> Signed-off-by: Bartlomiej Sieka <tur@semihalf.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-10-18Adds two more ethernet interface to 83xxrichardretanubun
Added as a convenience for other platforms that uses MPC8360 (has 8 UCC). Six eth interface is chosen because the platform I am using combines UCC1&2 and UCC3&4 as 1000 Eth and the other four UCCs as 10/100 Eth. Signed-off-by: Richard Retanubun <RichardRetanubun@RugggedCom.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-10-18Change UEC PHY interface to RGMII on MPC8568MDSHaiying Wang
Change UEC phy interface from GMII to RGMII on MPC8568MDS board Because on MPC8568MDS, GMII interface is only recommended for 1000Mbps speed, but RGMII interface can work at 10/100/1000Mbps, and RGMII interface works more stable. Now both UEC1 and UEC2 can work properly under u-boot. It is also in consistent with the kernel setting for 8568 UEC phy interface. Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-10-15Merge branch 'master' of git://git.denx.de/u-boot-mpc83xxWolfgang Denk
2008-10-15Fix compiler warning in lib_ppc/board.cHeiko Schocher
Fix compiler warning introduced by commit 0f8cbc18 Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-10-14mpc83xx: wait till UPM completes the write to arraySelvamuthukumar
Reference manual states that MxMR[MAD] increment is the indication of write to UPM array is complete. Honour that. Also, make the dummy write explicit. also fix the comment. Signed-off-by: Selvamuthukumar <selva.muthukumar@e-coninfotech.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-10-14Remove unwanted ';' at end of define.Selvamuthukumar
Currently this is not creating any problem. But it will result in compilation error when used as below. printf("CFG_SDRAM_CFG2 - %08x\n", CFG_SDRAM_CFG2); Signed-off-by: Selvamuthukumar <selva.muthukumar@e-coninfotech.com> continuation of the theme based on git grep "^#define CFG_.*;$" include/ Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-10-14ARM DaVinci: Add maintainer information for SFFSDR board.Hugo Villeneuve
Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com>
2008-10-14api: fix type mismatchMatthias Fuchs
This patch fixes a type mismatch and thus removes a compiler warning when compiling with CONFIG_API on powerpc. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2008-10-14cmd_i2c: Fix help for CONFIG_I2C_CMD_TREE && !CONFIG_I2C_MULTI_BUSPeter Tyser
Original code displayed: => help i2c i2c i2c speed [speed] - show or set I2C bus speed i2c md chip address[.0, .1, .2] [# of objects] - read from I2C device ... Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-10-14Update CHANGELOGWolfgang Denk
2008-10-14Do not init SATA when disabled on 8536DS.Jason Jin
SGMII and SATA share the serdes on MPC8536 CPU, When SATA disabled and the driver still try to access the SATA registers, the cpu will hangup. This patch try to fix this by reading the serdes status before the SATA initialize. Signed-off-by: Jason Jin <Jason.jin@freescale.com> Acked-by: Andy Fleming <afleming@freescale.com>
2008-10-14fsl_diu: fix alignment error that caused malloc corruptionNikita V. Youshchenko
When aligning malloc()ed screen_base, invalid offset was added. This not only caused misaligned result (which did not cause hardware misbehaviour), but - worse - caused screen_base + smem_len to be out of malloc()ed space, which in turn caused breakage of futher malloc()/free() operation. This patch fixes screen_base alignment. Also this patch makes memset() that cleans framebuffer to be executed on first initialization of diu, not only on re-initialization. It looks correct to clean the framebuffer instead of displaying random garbage; I believe that was disabled only because that memset caused breakage of malloc/free described above - which no longer happens with the fix described above. Signed-off-by: Nikita V. Youshchenko <yoush@debian.org>
2008-10-14api: Fix building with CONFIG_APIMatthias Fuchs
This patch fixes building with CONFIG_API and CONFIG_USB_STORAGE. USB_MAX_STOR_DEV is defined in include/usb.h, but needed in api/api_storage.c. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2008-10-14Remove unused CFG_EEPROM_PAGE_WRITE_ENABLE referencesPeter Tyser
2008-10-14Remove CFG_EEPROM_PAGE* dependencies for temperature sensorsPeter Tyser
The checks for CFG_EEPROM_PAGE_WRITE_ENABLE and CFG_EEPROM_PAGE_WRITE_BITS in various temperature sensor drivers are not necessary Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-10-14cmd_spi: remove broken signed casting for displayMike Frysinger
Since we're working with unsigned data, you can't apply a signed pointer cast and then attempt to print the result. Otherwise you get wrong output when the sign bit is set like "0xFF" incorrectly extended to "0xFFFFFFFF". Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-10-14strings cmd: drop old CONFIG_CFG_STRINGS defineMike Frysinger
We don't need CONFIG_CFG_STRINGS anymore now that we have the define CONFIG_CMD_STRINGS and Makefile control. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-10-14Fix the NAND size overflow issue.Jason Jin
When the total size of all NAND devices exceeds 4 GiB, the size will overflow. This patch tries to fix this. Note that we still have a problem when a single NAND device is bigger than 4 GiB: then the overflow would actually happen earlier, i. e. when storing the size in nand_info[].size, as nand_info[].size is an "u_int32_t". Signed-off-by: Jason Jin <Jason.jin@freescale.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-10-14Merge branch 'master' of git://git.denx.de/u-boot-netWolfgang Denk
2008-10-14Merge branch 'master' of git://git.denx.de/u-boot-shWolfgang Denk
2008-10-13AX88180: new gigabit network driverLouis Su
Signed-off-by: Louis Su <louis@asix.com.tw> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-10-13enable 10/100M at VSC8601 at tsec driverAndre Schwarz
Currently VSC8601 doesn't link with 10/100M partners if the EEPROM/Strapping is not set up. Setting the auto-neg register fixes this. Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-10-13net: ne2000: Divided a function of NE2000 driverNobuhiro Iwamatsu
get_prom function was used __attriute__ , but it is not enable. ax88796.o does not do link besides ne2000.o. When ld is carried out, get_prom function of ax88796.c is ignored. This problem is a thing by specifications of ld. I checked and test this patch on SuperH and MIPS. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
