These numbers will be reused by SPL.
board_eth_init can be also called in cases where CMD_NET
is not enabled.
For saving content of memory via tftp to file.
Extend max kernel image size. Gunzip is checking
this value. If kernel is larger, message below is shown.
Uncompressing Kernel Image ... Error: inflate() returned -5
GUNZIP: uncompress, out-of-mem or overwrite error -
must RESET board to recover
Zynq common configuration is placed in zynq-common.h
not zynq_common.h.
Enable dcache.
icache is already enabled by default.
Typo: The correct value is 1 not 2.
Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
KMSUGP1 is from a u-boot perspective (almost) identical to KMNUSA.
The only difference is that the PCIe reset is connected to Kirkwood pin
MPP7_PEX_RST_OUTn, we use a dedicated config flag KM_PCIE_RESET_MPP7.
Such pin should theoretically be handled by the PCIe subsystem
automatically, but this turned out not to be the case.
So simply configure this PIN as a GPIO and issue a pulse manually.
Signed-off-by: Gerlando Falauto <gerlando.falauto@keymile.com>
Cc: Karlheinz Jerg <karlheinz.jerg@keymile.com>
Cc: Valentin Longchamp <valenting.longchamp@keymile.com>
Cc: Holger Brunck <holger.brunck@keymile.com>
Acked-by: Valentin Longchamp <valentin.longchamp@keymile.com>
Add set_fdthigh subcommand to "subbootcmds" (release) so to set "fdt_high"
This is necessary on Kirkwood so that the FDT does not get relocated
above the memory limit that the kernel cannot access
(that is the memory part reserved for the switch).
This was tested on NUSA1, where it is necessary, and on ETER1, where it
doesn't seem to hurt.
We want the scripts to also work with older versions of u-boot, where:
a) set_fdthigh is not defined (will be default env for newer u-boots)
b) the fdt will not be available
For this reason, we use "set_fdthigh" to tell whether we are running
a newer (FDT-aware) u-boot or not.
So if "set_fdthigh" runs successfully or arch != arm we try loading
the fdt; otherwise we proceed normally.
Notice how, contrary to release mode, set_fdthigh will _not_ be part of
subbootcmds for develop and ramfs, but will be executed as part of
"tftpfdt".
Since this is only needed for kirkwood cards, and it prevents the kernel
from booting on QorIQ (though it seemed to work on ETER1), we change
its definition in the default env for powerpc so that the value is only
set on ARM.
Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
This consists of:
a) Defining the addresses, enabling fdtsupport [arm]
b) Defining "cramfsloadfdt" [arm,powerpc => common]
c) Adding the FDT address to bootm [arm,powerpc => common]
d) Defining "tftpfdt" in ramfs-,develop- [arm,powerpc >= common]
This should work with 3.10 kernels, whether loaded through TFTP
(with rootfs either through NFS or TFTP-ramfs) or from the NAND.
The machid was left unchanged, this should keep compatibility with both
older and newer kernels.
miiphy_read and miiphy_write are returning 0 on success.
This is needed for board specific additional environment variables.
E.g. the mgcoge3un has this additional "waitforne" variable.
We now use 256MB RAM instead of 128MB. We can use the same config file
as kmnusa.
CONFIG_BOOTCOUNT_LIMIT is used on all boards from this board series. So
remove this unneeded define.
This patch is here because of:
"arm: keep all sections in ELF file"
(sha1: 47ed5dd031d7d2c587e6afd386e79ccec1a1b7f7)
Our tools expect to have elf with only LOAD header.
Without this fix also PHDR, INTERP and DYNAMIC headers
are available in ELF.
The reason is enabling tftpput command where
tftp shorcut stops to work for tftpboot.
Cc: Scott Wood <scottwood@freescale.com>
Cc: David Feng <fenghua@phytium.com.cn>
Acked-by: Scott Wood <scottwood@freescale.com>
The entries in config.mk were needed so that U-Boot could be built
with an old version of the Raspberry Pi Foundation's toolchain. Without
them, the build would error out with:
...-ld: error: .../libgcc.a(_bswapsi2.o) uses VFP register arguments,
u-boot does not
However, none of the 3 toolchains in the latest version of their
tools.git, nor the Ubuntu/Linaro ARM compilers in at least Ubuntu Quantal
or Saucy, need these options set in order to compile a working U-Boot.
Hence, remove the options for simplicity.
Reported-by: Tom Rini <trini@ti.com>
Reviewed-by: Andreas Färber <afaerber@suse.de>
U-Boot names the Raspberry Pi board rpi_b. This means that the common
expression for DTB filename ${soc}-${board}.dtb expands to
bcm2835-rpi_b.dtb. However, the DTB generated by the Linux kernel is
bcm2835-rpi-b.dtb. Set $fdtfile in U-Boot's environment so that scripts
look for the correct DTB filename.
An alternative would be to rename the U-Boot board to rpi-b. However,
that change would be far more invasive, and end up affecting users (i.e
they'd have to change their U-Boot build commands).
The implementation of oc_serial_setbrg() for CONFIG_SYS_NIOS_FIXEDBAUD and
!CONFIG_SYS_NIOS_FIXEDBAUD are very similar.
Add a baudrate variable and set it to either CONFIG_BAUDRATE or gd->baudrate.
Then we can unify the code for both cases.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
Fix build error due to missing include of serial.h and a trivial typo.
Use setbits/clrbits macro instead of readl/writel function.
(Suggested by Wolfgang)
Signed-off-by: Inha Song <ideal.song@samsung.com>
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
This patch fixed that cfg value is set to wrong value.
Because it didn't read the related register.
Driver for non-standard on-chip UART, instantiated in the ARC (Synopsys)
FPGA Boards such as ARCAngel4/ML50x
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Cc: Mischa Jonker <mjonker@synopsys.com>
Cc: Francois Bedard <fbedard@synopsys.com>
Cc: Tom Rini <trini@ti.com>
Add a README to the board which lists the commands required to enable
booting from the eMMC boot partitions found on the board.
Cc: Lokesh Vutla <lokeshvutla@ti.com>
Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com>
The open and close mmc sub-commands implement a hard-coded set of values
specific to the SMDK5250 platform. Remove these commands as what they
did can be done instead with a series of mmc dev / bootpart / bootbus
commands instead now.
Cc: Amar <amarendra.xt@samsung.com>
Acked-by: Jaehoon Chung <jh80.chung@samsung.com>
Add a bootbus sub-command to the mmc command to allow for setting
the boot_bus_width, reset_boot_bus_width and boot_mode fields of
BOOT_BUS_WIDTH (EXT_CSD[177]).
Add a partconf sub-command to the mmc command to allow for setting
the boot_ack, boot_partition and partition_access fields of
PARTITION_CONFIG (formerly BOOT_CONFIG, EXT_CSD[179]). Part of this
requires changing the check for 'part' from an strncmp to a strcmp, like
the rest of the sub-commands.
Cc: Andy Fleming <afleming@gmail.com>
Cc: Pantelis Antoniou <panto@antoniou-consulting.com>
Rename 'bootpart' to 'bootpart-resize' to better reflect what this
command is for.
We use the switch CONFIG_SUPPORT_EMMC_BOOT today to enable some
additional features of the eMMC boot partitions. Add support for being
told that we have booted from one of these partitions to the spl
framework and implement this on TI OMAP/related.
As per the below commit
"mmc: sdhci: add the quirk for broken r1b response"
(sha1: 3a6383207be3f71b39004e64464a6e99290b16fa)
need to add quirk SDHCI_QUIRK_BROKEN_R1B, when the
response type is R1b.
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
Acked-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
This patch corrects the divider value written to CLKDIV register.
Since SDCLKIN is divided inside controller by the DIVRATIO value set
in the CLKSEL register, we need to use the same output clock value to
calculate the CLKDIV value.
as per user manual: cclk_in = SDCLKIN / (DIVRATIO + 1)
Input parameter to mmc_clk is changed to dwmci_host, since
we need the same to read DWMCI_CLKSEL register.
This improves the read timing values for channel 0 on SMDK5250
from 0.288sec to 0.144sec
Signed-off-by: Rajeshwari S Shinde <rajeshwari.s@samsung.com>
U-Boot currently sets MMC cards' RCA register to 0. This value is
reserved according to the specification. Use a value of 1 instead, just
like the Linux kernel.
Now that the designware ethernet driver uses phylib we need to turn it
on here.
Up until now this driver only worked with data cache disabled.
To make it work with enabled data cache following changes were required:
* Flush Tx/Rx buffer descriptors their modification
* Invalidate Tx/Rx buffer descriptors before reading its values
* Flush cache for data passed from CPU to GMAC
* Invalidate cache for data passed from GMAC to CPU
Cc: Vipin Kumar <vipin.kumar@st.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Shiraz Hashim <shiraz.hashim@st.com>
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Cc: Amit Virdi <amit.virdi@st.com>
Cc: Sonic Zhang <sonic.zhang@analog.com>
With this change driver will benefit from existing phylib and thus
custom phy functionality implemented in the driver will go away:
* Instantiation of the driver is now much shorter - 2 parameters
instead of 4.
* Simplified phy management/functoinality in driver is replaced with
rich functionality of phylib.
* Support of custom phy initialization is now done with existing
"board_phy_config".
Note that after this change some previously used config options
(driver-specific PHY configuration) will be obsolete and they are simply
substituted with similar options of phylib.
For example:
* CONFIG_DW_AUTONEG - no need in this one. Autonegotiation is enabled
by default.
* CONFIG_DW_SEARCH_PHY - if one wants to specify attached phy
explicitly CONFIG_PHY_ADDR board config option has to be used, otherwise
automatically the first discovered on MDIO bus phy will be used
I believe there's no need now in "doc/README.designware_eth" because
user only needs to instantiate the driver with "designware_initialize"
whose prototype exists in "include/netdev.h".
In "common/Makefile" "miiphyutil.o" gets built if any of the following
items enabled:
* CONFIG_PHYLIB
* CONFIG_MII
* CONFIG_CMD_MII
So it's possible to not define CONFIG_MII or CONFIG_CMD_MII and still
use functions like "miiphy_get_dev_by_name".
In its turn "miiphy_get_dev_by_name" traverses "mii_devs" list which is
not initialized because "miiphy_init" never got called.
Cc: Rob Herring <rob.herring@calxeda.com>
Driver "init" function might be called multiple times.
On every "init" Tx/Rx buffer descriptors are initialized: "descs_init"
-> "{tx|rx}_descs_init".
In its turn those init functions set MAC's "{tx|rx}desclistaddr" to
point on the first buffer descriptor in the list.
So CPU to start operation from the first buffer descriptor as well after
every "init" we have to reset "{tx|rx}_currdescnum".
Cc: Vineet Gupta <vgupta@synopsys.com>
AXS101 is a new generation of devlopment boards from Synopsys that houses
ASIC with ARC700 and lots of DesignWare peripherals:
* DW APB UART
* DW Mobile Storage (MMC/SD)
* DW I2C
* DW GMAC
