2006-12-24Fix cfi failure with Spansion Flash (Spansion Flash Devices have a different ↵Stefano Babic
offset to go into CFI mode)
2006-12-22[PATCH] Fix sequoia flash autodetection (finally correct)Stefan Roese
Now 32MByte and 64MByte FLASH is know to work and other configurations should work too. Signed-off-by: Stefan Roese <sr@denx.de>
2006-12-22Minor code cleanup; update CHANGELOG.Wolfgang Denk
2006-12-20Fix to make the baudrate changes immediate for the MCF52x2 family.Bartlomiej Sieka
2006-12-20Preliminary support for the iDMR board (ColdFire).Bartlomiej Sieka
2006-12-08automatic update mechanismAndrei Safronov
2006-11-30Code cleanup.Wolfgang Denk
2006-11-30Merge with http://opensource.freescale.com/pub/scm/u-boot-83xx.gitWolfgang Denk
2006-11-30Code cleanup. Update CHANGELOG.Wolfgang Denk
2006-11-29[PATCH] [MPC52xx] Use IPB bus frequency for SOC peripheralsGrant Likely
The soc node of the mpc52xx needs to be loaded with the IPB bus frequency, not the XLB frequency. This patch depends on the previous patches for MPC52xx device tree support Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Sylvain Munaut <tnt@246tNt.com>
2006-11-29[PATCH] Add support for Prodrive P3M750 & P3M7448 (P3Mx) boardsStefan Roese
This patch adds support for the Prodrive P3M750 (PPC750 & MV64460) and the P3M7448 (MPC7448 & MV64460) PMC modules. Both modules are quite similar and share the same board directory "prodrive/p3mx" and the same config file "p3mx.h". Signed-off-by: Stefan Roese <sr@denx.de>
2006-11-29[PATCH] common/cmd_elf.c: Enable loadaddr as parameter in bootvx commandStefan Roese
In the bootvx command the load address was only read from the env variable "loadaddr" and not optionally passed as paramter as described in the help. This is fixed with this patch. The behaviour is now the same as in the bootelf command. Signed-off-by: Stefan Roese <sr@denx.de>
2006-11-29[PATCH] include/ppc440.h minor error affecting interruptsStefan Roese
Fixed include/ppc440.c for UIC address Bug Corrects bug affecting the addresses for the universal interrupt controller UIC2 and UIC3 on the PPC440 Epx, GRx, and SPE chips. Signed-off-by: Jeff Mann <mannj@embeddedplanet.com> Signed-off-by: Stefan Roese <sr@denx.de>
2006-11-29Make fsl-i2c not conflict with SOFT I2CJoakim Tjernlund
2006-11-29Fix I2C master address initialization.Joakim Tjernlund
2006-11-28Merge http://www.denx.de/git/u-bootKim Phillips
2006-11-28Assign maintainers for mpc8349emds and mpc8360emdsKim Phillips
Dave for mpc8360emds, and me for mpc8349emds.
2006-11-28Eliminate gcc 4 'used uninitialized' warnings in drivers/qe/uccf.cKim Phillips
give initial values for reg_num, shift, p_cmxucr in ucc_set_clk_src since they are passed by reference to ucc_get_cmxucr_reg and assigned.
2006-11-28mpc83xx: Miscellaneous code style fixesTimur Tabi
Implement various code style fixes and similar changes. Signed-off-by: Timur Tabi <timur@freescale.com>
2006-11-28[PATCH] Enable the IceCube/lite5200 variants to pass a device tree to Linux.Stefan Roese
This patch adds the code and configuration necessary to boot with an arch/powerpc Linux kernel. Signed-off-by: Grant Likely <grant.likely@gmail.com> Acked-by: Jon Loeliger <jdl@freescale.com>
2006-11-28[PATCH] PPC4xx: 440SP Rev. C detection addedStefan Roese
2006-11-28[PATCH] nand: Fix patch merge problemStefan Roese
2006-11-27Merge with /home/sr/git/u-boot/denx-alpr-merge-testWolfgang Denk
2006-11-27Update CHANGELOGWolfgang Denk
2006-11-27Merge with /home/sr/git/u-boot/4xx-enetWolfgang Denk
2006-11-27Merge with /home/sr/git/u-boot/nand-envWolfgang Denk
2006-11-27Merge with /home/sr/git/u-boot/nand-timeoutWolfgang Denk
2006-11-27Merge with /home/sr/git/u-boot/denx-ofWolfgang Denk
2006-11-27[PATCH] 4xx_enet.c: Correct the setting of zmiifer registerStefan Roese
Patch below corrects the setting of the zmiifer register, it was overwritting the register rather than ORing the settings. Signed-off-by: Neil Wilson <NWilson@airspan.com> Signed-off-by: Stefan Roese <sr@denx.de>
2006-11-27[PATCH] Select NAND embedded environment from board configurationStefan Roese
The current NAND Bootloader setup forces the environment variables to be in line with the bootloader. This change enables the configuration to be made in the board include file instead so that it can be individually enabled. Signed-off-by: Nick Spence <nick.spence@freescale.com> Signed-off-by: Stefan Roese <sr@denx.de>
2006-11-27[PATCH] nand_wait() timeout fixesStefan Roese
Two fixes for the nand_wait() function in drivers/nand/nand_base.c: 1. Use correct timeouts. The original timeouts in Linux source are 400ms and 20ms not 40s and 20s 2. Return correct error value in case of timeout. 0 is interpreted as OK. Signed-off-by: Rui Sousa <rui.sousa@laposte.net> Signed-off-by: Stefan Roese <sr@denx.de>
2006-11-27[PATCH] Allow CONFIG_OF_FLAT_TREE to boot a non-arch/powerpc kernelStefan Roese
This patch allows an arch/ppc kernel to be booted by just passing 1 or 2 arguments to bootm. It removes the getenv("disable_of") test that used to be used for this purpose. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Jon Loeliger <jdl@freescale.com>
2006-11-27Minor code cleanup. Update CHANGELOG.Wolfgang Denk
2006-11-27[PATCH] 4xx: Fix problem with board specific reset code (now for real)Stefan Roese
2006-11-27[PATCH] alpr: remove unused board specific flash driverStefan Roese
2006-11-27[PATCH] 4xx: Fix problem with board specific reset codeStefan Roese
2006-11-27[PATCH] Remove testing 4xx enet PHY setupStefan Roese
2006-11-27[PATCH] Update Prodrive ALPR board support (440GX)Stefan Roese
2006-11-27Merge with /home/stefan/git/u-boot/denxStefan Roese
2006-11-27Merge with /home/sr/git/u-boot/denxWolfgang Denk
2006-11-23Updates for TQM5200 modules:Wolfgang Denk
- fix off-by-one error in board/tqm5200/cam5200_flash.c error message - simplify "udate" definitions
2006-11-22[PATCH] PPC4xx start.S: Fix for processor errataStefan Roese
Fixed cpu/ppc4xx/start.S for 440EPx Errata: further corrects PPC440EPx errata 1.12: 440_33 by moving patch up in code. Signed-off-by: Jeff Mann <mannj@embeddedplanet.com> Signed-off-by: Stefan Roese <sr@denx.de>
2006-11-20[PATCH] Update AMCC Sequoia config file to support 64MByte NOR FLASHStefan Roese
2006-11-20Update CHANGELOGWolfgang Denk
2006-11-20Merge with /home/sr/git/u-boot/cfi-updateWolfgang Denk
2006-11-13[PATCH] CFI driver AMD Command Set Top boot geometry reversal, etc. [Updated]Stefan Roese
* Adds support for AMD command set Top Boot flash geometry reversal * Adds support for reading JEDEC Manufacturer ID and Device ID * Adds support for displaying command set, manufacturer id and device ids (flinfo) * Makes flinfo output to be consistent when CFG_FLASH_EMPTY_INFO defined * Removes outdated change history (refer to git log instead) Signed-off-by: Tolunay Orkun <listmember@orkun.us> Signed-off-by: Stefan Roese <sr@denx.de>
2006-11-12Update CHANGELOGWolfgang Denk
2006-11-12Merge with /home/tur/proj/v38b/u-bootWolfgang Denk
2006-11-11Disable the watchdog in the default config for the V38B board.Bartlomiej Sieka
2006-11-11Change the GPIO pin multiplexing configuration for V38B. The USB GPIO pinBartlomiej Sieka
group is enabled for USB earlier (in cpu_init_f() instead of usb_lowlevel_init()).
