group is enabled for USB earlier (in cpu_init_f() instead of
usb_lowlevel_init()).
- add watchdog support
- enable GPIO_WKUP_7 pin for input
- code cleanup
* remove warnings when compiling ethaddr.c
* adjust linker script (fixes a crash resulting from incorrect
definition of __u_boot_cmd_start)
- Some MarelV38B code cleanup.
MPC5XXX_WU_GPIO_DATA macro to MPC5XXX_WU_GPIO_DATA_O (per MPC5200 User's
Manual). Replace the uses of MPC5XXX_WU_GPIO_DATA with
MPC5XXX_WU_GPIO_DATA_O for affected boards.
- Add defintions for some MPC5XXX GPIO pins.
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
Use MACH_TYPE_NETSTAR and MACH_TYPE_VOICEBLUE defines instead of
numbers in code.
chpart, nboot and NAND subsystem related commands now accept also partition
name to specify offset.
Make sure the string passed as variable name does not contain a '='
character. This not only prevents the common error or typing
"setenv foo=bar" instead of "setenv foo bar", but (more importantly)
also closes a backdoor which allowed to delete write-protected
environment variables, for example by using "setenv ethaddr=".
When passing the -g option to gcc, gcc automatically selects a
suitable --g<format> option to pass on to the assembler.
Thus, there's no point in forcing a specific debug option on the
assembler using the -Wa mechanism.
Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
to a TSEC (e.g. a switch is connected via RMII) or
if the PHY is defective/incorrectly configured.
Signed-off-by: Ben Warren <bwarren@qstreams.com>
Add atstk1002_config target to Makefile and move the AVR32 section
down below Blackfin so that it doesn't end up in the middle of
MIPS.
Drop the autogenerated linker script thing for now. Will have to
revisit how to handle chips with different flash and RAM layout
later.
If a Multi-Image file contains a third image we try to use it as a
device tree. The device tree image is assumed to be uncompressed in the
image file. We automatically allocate space for the device tree in memory
and provide an 8k pad to allow more than a reasonable amount of growth.
Additionally, a device tree that was contained in flash will now automatically
get copied to system memory as part of boot. Previously an error was
reported if one tried to boot a device tree that was in flash.
Merge with /home/sr/git/u-boot/4xx-idcr
(use "make CHANGELOG" to update it from time to time)
Patch by Stefan Roese, 24 Oct 2006
(Conflicts between Jon Loeliger's and Matthew McClintock's tree
were resolved by in favour of Jon's version.)
Patch by Haavard Skinnemoen, 12 Sep 2006
Patch by Haavard Skinnemoen, 06 Sep 2006
This patch adds support for the ATSTK1000 with the ATSTK1002 CPU
daughterboard.
ATSTK1000 is a full-featured development board for AT32AP CPUs. It
has two ethernet ports, a high quality QVGA LCD panel, a loudspeaker,
and connectors for USART, PS/2, VGA, USB, MMC/SD cards and
CompactFlash cards. For more information, please see this page:
http://www.atmel.com/dyn/products/tools.asp?family_id=682
The ATSTK1002 is a daughterboard for the ATSTK1000 supporting the
AT32AP7000 chip.
This is a first attempt at creating a common serial driver for Atmel
chips. For now, it supports the AT32AP7000 AVR32 chip, but it should
be possible to support AT91RM9200 and other ARM-based chips with some
minor modifications.
There's nothing fundamentally AVR32-specific in this driver, but it
does use some features which are currently only defined for the
AT32AP CPU port:
* pm_get_clock_freq: Obtain the clock frequency of a given domain
* gd->console_uart: A "struct device" containing information about
register mappings, gpio resources and clocks associated with the
UART device.
For more information about these features, please see the "AT32AP
CPU" patch.
This patch adds support for the AT32AP CPU family and the AT32AP7000
chip, which is the first chip implementing the AVR32 architecture.
The AT32AP CPU core is a high-performance implementation featuring a
7-stage pipeline, separate instruction- and data caches, and a MMU.
For more information, please see the "AVR32 AP Technical Reference":
http://www.atmel.com/dyn/resources/prod_documents/doc32001.pdf
In addition to this, the AT32AP7000 chip comes with a large set of
integrated peripherals, many of which are shared with the AT91 series
of ARM-based microcontrollers from Atmel. Full data sheet is
available here:
http://www.atmel.com/dyn/resources/prod_documents/doc32003.pdf
Patch by Haavard Skinnemoen, 6 Sep 2006 16:23:02 +0200
This patch adds common infrastructure code for the Atmel AVR32
architecture. See doc/README.AVR32 for details.
Patch by Haavard Skinnemoen, 30 Aug 2006
In config.mk, -Wa,-gstabs is unconditionally appended to AFLAGS no
matter what the target's preferred debugging format is. This patch
simply replaces -gstabs with -g, so that the default debugging format
for the architecture is used.
Based on patch by Haavard Skinnemoen, 29 Aug 2006 11:20:39 +0200
Replace private IMMAP I2C structures with generic reg block
and allow 86xx to have multiple I2C device busses.
Introduced COFIG_FSL_I2C to select the common FSL I2C driver.
And removed hard i2c path from a few u-boot.lds scipts too.
Minor whitespace cleanups along the way.
