2014-02-19Prepare v2014.04-rc1v2014.04-rc1Tom Rini
2014-02-19kbuild,tegra124: add dummy obj- for KbuildMasahiro Yamada
In Kbuild, every makefile must have non-empty obj- or obj-y. Otherwise, built-in.o will not be created and the link stage will fail. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19cosmetic: FIT: fix a strange commentMasahiro Yamada
There is a strange comment in fit_image_load(). This function can be used for loading Kernel Image, FDT as well as ramdisk. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2014-02-19Move CONFIG_DISPLAY_CPUINFO to MakefileMasahiro Yamada
If the whole code is surrounded by #ifdef(CONFIG_ ) .. #endif, it should be moved to Makefile. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19Move #ifdef(CONFIG_DISPLAY_CPUINFO) from caller to calleeMasahiro Yamada
- When CONFIG_DISPLAY_CPUINFO is not enabled, print_cpuinfo() should be defined as an empty function in a header, include/common.h - Remove #ifdef CONFIG_DISPLAY_CPUINFO .. #endif from caller, common/board_f.c and arch/arm/lib/board.c - Remove redundant prototypes in arch/arm/lib/board.c, arch/arm/include/asm/arch-am33x/sys_proto.h and board/nokia/rx51/rx51.h, keeping the one in include/common.h - Add #ifdef CONFIG_DISPLAY_CPUINFO to the func definition where it is missing Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19configs: Delete unused CONFIG_SYS_64BIT_{VSPRINTF, STRTOUL}Masahiro Yamada
2014-02-19configs: Delete obsolete macro, CONFIG_SYS_GBL_DATA_SIZEMasahiro Yamada
CONFIG_SYS_GBL_DATA_SIZE is not used any more. The size of struct "global_data" is automatically calculated by asm-offsets. (See lib/asm-offsets.c) GENERATED_GBL_DATA_SIZE should be used instead of CONFIG_SYS_GBL_DATA_SIZE. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19dts: generate multiple device tree blobsMasahiro Yamada
It is convenient to have all device trees on the same SoC compiled. It allows for later easy repackaging without the need to re-run the make file. - Build device trees with the same SoC under arch/$(ARCH)/dts - Copy the one specified by CONFIG_DEFAULT_DEVICE_TREE or DEVICE_TREE=... to dts/dt.dtb Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19dts: move device tree sources to arch/$(ARCH)/dts/Masahiro Yamada
Unlike Linux Kernel, U-Boot historically had *.dts files under board/$(VENDOR)/dts/ and *.dtsi files under arch/$(ARCH)/dts/. I think arch/$(ARCH)/dts dicretory is a better location to store both *.dts and *.dtsi files. For example, before this commit, board/xilinx/dts directory had both Microblaze dts (microblaze-generic.dts) and ARM dts (zynq-*.dts), which are totally unrelated. This commit moves *.dts to arch/$(ARCH)/dts/ directories, allowing us to describe nicely mutiple DTBs generation in the next commit. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19dts: re-write dts/Makefile more simply with KbuildMasahiro Yamada
Useful rules in scripts/Makefile.lib allows us to easily generate a device tree blob and wrap it in assembly code. We do not need to parse a linker script to get output format and arch. This commit deletes ./u-boot.dtb since it is a copy of dts/dt.dtb. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19kernel-doc: fix some errorsMasahiro Yamada
- Delete fs.xml from DOCBOOKS to fix an error. Commit e3ff797c added fs.xml to DOCBOOKS but missed to add doc/DocBook/fs.tmpl. - Fix the location of include guard in include/linker_lists.h. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reported-by: Abraham Varricatt <abraham.varricatt@vvdntech.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-02-19kernel-doc: update kernel-doc related files to Linux v3.13Masahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-02-19kernel-doc: move kernel-doc tools to scripts/Masahiro Yamada
tools/kernel-doc/docproc.c and tools/kernel-doc/kernel-doc are files imported from Linux Kernel. They originally resided under scripts/ directory in Linux Kernel. This commit moves them to the original location. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-02-19.gitignore: drop include/asm from ignored file listMasahiro Yamada
Commit bb02c536 stopped creaing a symbolic link include/asm. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19tools/env: cross-compile fw_printenv without setting HOSTCCMasahiro Yamada
fw_printenv is a program which mostly runs on the target Linux. Before switching to Kbuild, we needed to set HOSTCC at the command line like this: make HOSTCC=<your CC cross-compiler> env Going forward we can cross compile it by specifying CROSS_COMPILE: make CROSS_COMPILE=<your cross-compiler prefix> env This looks more natural. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2014-02-19kbuild: Do not generate .*.su files at the top directoryMasahiro Yamada
Without this workaround, you will see a lot of ".*.su" files at the top directory after building with a compiler which supports "-fstack-usage" option. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19board: sandburst: delete FORCEBUILDMasahiro Yamada
We had switched to Kbuild, so we do not need to delete sandburst board files at every build. U-Boot conventional build system did not check the update of command line option, -DBUILDUSER. Kbuild can handle it nicely and re-builds object files when command line options are changed. (The file ".*.cmd" stores the information how the file was generated at the previous build.) Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19kbuild: check clean source and generate Makefile for out-of-tree buildMasahiro Yamada
For out-of-tree build - Check if the source tree is clean - Create a Makefile in the output directory Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19kbuild: support simultaneous board configuration and "make all"Masahiro Yamada
This commit fixes two problems: [1] We could not do board configuration and "make all" in one command line. For example, the following did not work as we expect: $ make sandbox_config all Configuring for sandbox board... make: Nothing to be done for `all'. [2] mixed-target build did not work with -j option For example, the following did not work: $ make -j8 sandbox_config u-boot Makefile:481: *** "System not configured - see README". Stop. make: *** [u-boot] Error 2 make: *** Waiting for unfinished jobs.... Configuring for sandbox board... Going forward, we can do $ make -j8 sandbox_config all This is the same as $ make sandbox_config $ make -j8 Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19kbuild: use scripts/Makefile.cleanMasahiro Yamada
This commit refactors cleaning targets such as clean, clobber, mrpropper, distclean with scripts/Makefile.clean. By using scripts/Makefile.clean, we can recursively descend into subdirectories and delete generated files there. We do not need add a big list of generated files to the "clean" target. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19Makefile: refactor tools-all targetsMasahiro Yamada
- Move "easylogo", "gdb" tagets to tools/Makefile - Delete "gdbtools" target (same as "gdb") Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19Makefile: Do not pass MTD_VERSION from the top MakefileMasahiro Yamada
$(MTD_VERSION) is used in tools/env/Makefile If you specify a variable at a command line like: $ make MTD_VERSION=old env or specify it thru an envrionment variable like: $ export MTD_VERSION=old $ make env it is inherited to the sub-make too. We do not need to pass it from the top Makefile explicitely. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19kbuild: refactor Makefile and spl/Makefile moreMasahiro Yamada
This commit refactors rules of directory descending and defines u-boot-dirs and u-boot-all-dirs. (We will need u-boot-all-dirs when using scripts/Makefile.clean) Additionally, rename LIBS-y to libs-y. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19examples: move api/ and standalone/ entry to examples/MakefileMasahiro Yamada
2014-02-19kbuild: change the top Makefile to more Kbuild-ish structureMasahiro Yamada
This commit changes the top Makefile to handle various targets nicely. Make targets are divided into four categories: - mixed-targets We can call a configuration target and build targets at one command line like follows: $ make <board_name>_config u-boot They are handled one by one. - config targets <board_name>_config - no-dot-config-targets Targets we can run without board configuration such as clean, mrproper, distclean, TAGS, %docs, etc. - build targets The other target which need board configuration. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19Makefile: remove a cleaning target "tidy"Masahiro Yamada
Before this commit, "make tidy" did "make clean" + delete "*.depend*" files. But, we do not have "*.depend*" files any more, which means "make tidy" is the same as "make clean". This commit removes the redandant target "tidy". Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19kbuild: generate {spl, tpl}-autoconf.mk only when it is necessaryMasahiro Yamada
Before this commit, {spl,tpl}-autoconf.mk was always generated at the top Makefile even if SPL(TPL) build was not selected. This commit moves the build rule of {spl,tpl}-autoconf.mk from the top Makefile to spl/Makefile. It prevents unnecessary {spl,tpl}-autoconf.mk from being generated. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19kbuild: move include directives of board configuration filesMasahiro Yamada
This commit changes the location of include directives of board configuration files. The purpose of this change is: - Slim down $(TOPDIR)/config.mk - Prevent $(TOPDIR)/Makefile from including the same configuration file twice - Do not include include/config.mk multiple times because ARCH, CPU, BOARD, VENDOR, SOC are exported Before this commit: - include/autoconf.mk was included from $(TOPDIR)/Makefile and $(TOPDIR)/config.mk (This means $(TOPDIR)/Makefile included include/autoconf.mk twice) - include/{spl,tpl}-autoconf.mk was included from $(TOPDIR)/config.mk - include/config.mk was included from $(TOPDIR)/Makefile and $(TOPDIR)/config.mk (This means $(TOPDIR)/Makefile included include/config.mk twice) After this commit: - include/autoconf.mk is included from $(TOPDIR)/Makefile and $(TOPDIR)/scripts/Makefile.build - include/{spl,tpl}-autoconf.mk is included from $(TOPDIR)/spl/Makefile and $(TOPDIR)/scripts/Makefile.build - include/config.mk is included from $(TOPDIR)/config.mk and $(TOPDIR)/spl/Makefile Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19kbuild: convert some make rules to Kbuild styleMasahiro Yamada
We can get Kbuild-ish log style like this: GEN include/autoconf.mk GEN include/autoconf.mk.dep We do not need XECHO any more. And also change checkstack target like Linux Kernel. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19kbuild: move some lines to more suitable placeMasahiro Yamada
2014-02-19kbuild: delete temporary build scriptsMasahiro Yamada
We had switched to Kbuild. We do not need old build scripts any more. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19kbuild: use Linux Kernel build scriptsMasahiro Yamada
Now we are ready to switch over to real Kbuild. This commit disables temporary scripts: scripts/{Makefile.build.tmp, Makefile.host.tmp} and enables real Kbuild scripts: scripts/{Makefile.build,Makefile.host,Makefile.lib}. This switch is triggered by the line in scripts/Kbuild.include -build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build.tmp obj +build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build obj We need to adjust some build scripts for U-Boot. But smaller amount of modification is preferable. Additionally, we need to fix compiler flags which are locally added or removed. In Kbuild, it is not allowed to change CFLAGS locally. Instead, ccflags-y, asflags-y, cppflags-y, CFLAGS_$(basetarget).o, CFLAGS_REMOVE_$(basetarget).o are prepared for that purpose. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2014-02-19kbuild: import more build scripts from Linux v3.13 tagMasahiro Yamada
This commit imports build scripts from Linux Kernel v3.13 as they are. I know they include some trailing spaces but I am intentionally keeping them untouched. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19Makefile: rename scripts/Makefile.build to scripts/Makefile.build.tmpMasahiro Yamada
Some build scripts including scripts/Makefile.build will be imported from Linux Kernel in the next commit. We need to adjust them for U-Boot in the following commits. To make it easier for reviewers to track the modification, this commit renames scripts/Makefile.build to scripts/Makefile.build.tmp beforehand. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19kbuild: add dummy obj-y to create built-in.oMasahiro Yamada
We are going to switch over to Kbuild in upcoming commits. Each makefile must have non-empty obj- or obj-y to generate built-in.o on Kbuild. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19kbuild: change out-of-tree buildMasahiro Yamada
This commit changes the working directory where the build process occurs. Before this commit, build process occurred under the source tree for both in-tree and out-of-tree build. That's why we needed to add $(obj) prefix to all generated files in makefiles like follows: $(obj)u-boot.bin: $(obj)u-boot Here, $(obj) is empty for in-tree build, whereas it points to the output directory for out-of-tree build. And our old build system changes the current working directory with "make -C <sub-dir>" syntax when descending into the sub-directories. On the other hand, Kbuild uses a different idea to handle out-of-tree build and directory descending. The build process of Kbuild always occurs under the output tree. When "O=dir/to/store/output/files" is given, the build system changes the current working directory to that directory and restarts the make. Kbuild uses "make -f $(srctree)/scripts/Makefile.build obj=<sub-dir>" syntax for descending into sub-directories. (We can write it like "make $(obj)=<sub-dir>" with a shorthand.) This means the current working directory is always the top of the output directory. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2014-02-19Makefile: move some flags to examples makefilesMasahiro Yamada
This commit moves some flags which are used under examples/ directory only. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19Makefile: move some flags to spl/MakefileMasahiro Yamada
Some flags are used for SPL (and TPL) build only. This commit moves them from config.mk to spl/Makefile. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19Makefile: move more stuff to top MakefileMasahiro Yamada
2014-02-19Makefile: refactor include path settingsMasahiro Yamada
This commit merges commonly-used header include paths to UBOOTINCLUDE and NOSTDINC_FLAGS variables, which are placed at the top Makefile. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19Makefile: move more flags to the top MakefileMasahiro Yamada
Before this commit, most of compiler flags were defined in config.mk. But it is redundant because config.mk is included from all recursive make. This commit moves many complier flags to the top Makefile and export them. And we use new vaiarables to store them: KBUILD_CPPFLAGS, KBUILD_CFLAGS, KBUILD_AFLAGS. This will allow us to switch more smoothly to Kbuild. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19kbuild: Use Kbuild.includeMasahiro Yamada
This commit adjusts some files to use Kbuild.include. - Use cc-option defined in Kbuild.include (Delete cc-option in config.mk) - Use cc-version defined in (Delete cc-version in config.mk) - Move binutils-version and dtc-version to Kbuild.include by analogy to cc-version This commit also adds srctree (same as SRCTREE) to use Kbuild scripts. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19kbuild: import Kbuild.include from linux v3.13 tagMasahiro Yamada
2014-02-19Makefile: move BFD_ROOT_DIR to tools/gdb/MakefileMasahiro Yamada
BFD_ROOT_DIR is used only in tools/gdb/Makefile Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19Makefile: move some variable definitions to the top MakefileMasahiro Yamada
This commit moves some variable definitions from config.mk to the top Makefile: - HOSTCC, HOSTCFLAGS, HOSTLDFLAGS - AS, LD, CC, CPP, etc. - SHELL (renamed to CONFIG_SHELL) I'd like to slim down config.mk file because it is included from all recursive make. It is redundant to re-define the variables every time descending into sub directories. We should rather define them at the top Makefile and export them. U-Boot makefiles has been used "SHELL" variable to store shell chosen for the user, whereas Linux Kernel uses "CONFIG_SHELL". We should never use "SHELL" variable because it is a special variable for GNU Make. Changing SHELL may cause unpredictable side effects whose root cause is usually difficult to find. We should use a generic variable name "CONFIG_SHELL". We should not use the syntax as follows either: rm -f $(obj)tools/env/{fw_printenv,fw_setenv} This depends on "bash" although GNU Make generally invokes "sh" to run the each rule. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19Makfile: move suffix rules to Makefile.buildMasahiro Yamada
This commit moves suffix rules from config.mk to scripts/Makefile.build, which will allow us to switch smoothly to real Kbuild. Note1: post/lib_powerpc/fpu/Makefile has its own rule to compile C sources. We need to tweak it to keep the same behavior. Note2: There are two file2 with the same name: arch/arm/lib/crt0.S and eamples/api/crt0.S. To keep the same build behavior, examples/api/Makefile also has to be treaked. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19nand-spl: Use scripts/Makefile.buildMasahiro Yamada
2014-02-19examples: Use scripts/Makefile.buildMasahiro Yamada
2014-02-19board: samsung: refactor host programsMasahiro Yamada
Some Samsung boards have their own tools under board/samsung/<board>/tools/. This commit refactor more makefiles with "hostprogs-y". Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19tools: convert makefiles to kbuild styleMasahiro Yamada
Before this commit, makefiles under tools/ directory were implemented with their own way. This commit refactors them by using "hostprogs-y" variable. Several C sources have been added to wrap other C sources to simplify Makefile. For example, tools/crc32.c includes lib/crc32.c Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
