2014-03-22sandbox: Enable CONFIG_CMD_LZMADEC in sandbox.hPatrice Bouchand
As Simon Glass requested it, here's a patch that enables CONFIG_CMD_LZMADEC in sandbox. Signed-off-by: Patrice Bouchand <pbfwdlist@gmail.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-22Add lzmadec commandPatrice Bouchand
I needed to be able to uncompress lzma files. I did this command based on unzip command and propose it if it could help. Signed-off-by: Patrice Bouchand <pbfwdlist@gmail.com> Changed to work with sandbox Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-17sandbox: config: Enable cros_ec emulation and related itemsSimon Glass
Enable the Chrome OS EC emulation for sandbox along with LCD, sound expanded GPIOs and a few other options to make this work correctly. Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Che-Liang Chiou <clchiou@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-17sandbox: Add implementation of spi_setup_slave_fdt()Simon Glass
This function is needed when CONFIG_OF_SPI is defined. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-17sandbox: Add options to clean up temporary filesSimon Glass
When jumping from one sandbox U-Boot to another in sandbox, the RAM buffer is preserved in the jump by using a temporary file. Add an option to tell the receiving U-Boot to remove this file when it is no longer needed. Similarly the old U-Boot image is left behind in this case. We cannot delete it immediately since gdb cannot then find its debug symbols. Delete it just before exiting. Together these changes ensure that temporary files are removed both for memory and U-Boot. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-17sandbox: Allow Ctrl-C to work in sandboxSimon Glass
It is useful for Cltl-C to be handled by U-Boot as it is on other boards. But it is also useful to be able to terminate U-Boot with Ctrl-C. Add an option to enable signals while in raw mode, and make this the default. Add an option to leave the terminal cooked, which is useful for redirecting output. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-17sandbox: Deal with conflicting getenv() for SDLSimon Glass
Unfortunately SDL requires getenv() to operate, since it wants to figure out the display type. U-Boot has its own getenv() and they conflict. As a work-around use #define to resolve the conflict. A better but more complex solution might be to rename some U-Boot symbols at link time. SDL audio is not functional at present, likely due to a related issue. Note: Vic Yank wrote a script for this, filed in crbug.com/271125. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-17sound: Move Samsung-specific code into its own fileSimon Glass
The i2s code is in fact Samsung-specific, but there might be other implementation. Move this code into its own file. This makes it slightly more obviously how to adjust the code to support another SoC, when someone takes this task on. Also drop non-FDT support, since it isn't used on Exynos 5. Tested-by: Che-Liang Chiou <clchiou@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-17sandbox: Add LCD driverSimon Glass
Add a simple LCD driver which uses SDL to display the image. We update the image regularly, while still providing for reasonable performance. Adjust the common lcd code to support sandbox. For command-line runs we do not want the LCD to be displayed, so add a --show_lcd option to enable it. Tested-by: Che-Liang Chiou <clchiou@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-17sandbox: Add a simple sound driverSimon Glass
Add a sound driver for sandbox, which uses SDL. Tested-by: Che-Liang Chiou <clchiou@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-17sandbox: Add SDL library for LCD, keyboard, audioSimon Glass
SDL (Simple DirectMedia Layer - see www.libsdl.org) is a library which provides simple graphics and sound features. It works under X11 and also with a simple frame buffer interface. It is ideally suited to sandbox U-Boot since it fits nicely with the low-level feature set required by U-Boot. For example, U-Boot has its own font drawing routines, its own keyboard processing and just needs raw sound output. We can use SDL to provide emulation of these basic functions for sandbox. This significantly expands the testing that is possible with sandbox. Add a basic SDL library which we will use in future commits. Tested-by: Che-Liang Chiou <clchiou@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-17sandbox: Add -j option to indicate a jump from a previous U-BootSimon Glass
In order to support the 'go' command we allow the jumping U-Boot to pass its filename to the new U-Boot image. This can then be used to delete that image if required. Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Che-Liang Chiou <clchiou@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-17sandbox: Add os_jump_to_image() to run another executableSimon Glass
For some tests it is useful to be able to run U-Boot again but pass on the same memory contents. Add a function to achieve this. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-17cros_ec: Implement I2C pass-throughSimon Glass
The Chrome EC has a feature where you can access its I2C buses through a pass-through arrangement. Add a command to support this, and export the function for it also. Reviewed-by: Vadim Bendebury <vbendeb@google.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-17sandbox: Plumb in Chrome OS EC emulationSimon Glass
Add board code to set up the Chrome OS EC on startup. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-17cros_ec: sandbox: Add Chrome OS EC emulationSimon Glass
Add a simple emulation of the Chrome OS EC for sandbox, so that it can perform various EC tasks such as keyboard handling. Reviewed-by: Vadim Bendebury <vbendeb@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-17cros_ec: Correct comparison between signed and unsigned numbersSimon Glass
Due to signed/unsigned comparison, '< sizeof(struct)' does not do the right thing, since if ec_command() returns a -ve number we will consider this be success. Adjust all comparisons to avoid this problem. This error was found with sandbox, which gives a segfault in this case. On ARM we may instead silently fail. We should also consider turning on -Wsign-compare to catch this sort of thing in future. Reviewed-by: Andrew Chew <achew@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Vadim Bendebury <vbendeb@chromium.org> Tested-by: Andrew Chew <achew@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Jimmy Zhang <jimmzhang@nvidia.com>
2014-03-17cros_ec: spi: Add support for EC protocol version 3Randall Spangler
Protocol version 3 will be attempted first; if the EC doesn't support it, u-boot will fall back to the old protocol version (2). Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Randall Spangler <rspangler@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-17cros_ec: Add base support for protocol v3Simon Glass
Protocol v2 was shipped with snow, link and spring. Protocol v3 is for pit and is targetted at SPI operation. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-17cros_ec: Clean up multiple EC protocol supportRandall Spangler
Version 1 protocols (without command version) were already no longer supported in cros_ec.c. This removes some dead code from the cros_ec_i2c driver. Version 2 protcols (with command version) are now called protocol_version=2, instead of cmd_version_is_supported=1. A subsequent change will introduce protocol version 3 for SPI. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Randall Spangler <rspangler@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-17cros_ec: Sync up with latest Chrome OS EC versionSimon Glass
The EC messages have been expanded and some parts have been renamed. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-17cros_ec: Move #ifdef to permit flash region accessSimon Glass
Flash region access is not tied to having commands, so adjust the #ifdef to reflect this. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-17cros_ec: Support systems with no EC interruptSimon Glass
Some systems do not have an EC interrupt. Rather than assuming that the interrupt is always present, and hanging forever waiting for more input, handle the missing interrupt. This works by reading key scans only until we get an identical one. This means the EC keyscan FIFO is empty. Tested-by: Che-Liang Chiou <clchiou@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-17cros_ec: Drop old EC version support from EC driverVadim Bendebury
There is no need to support old style EC moving forward. Ultimately we should get rid of the check_version() API. For now just return error in case the EC does not seem to support the new API. Reviewed-by: Vadim Bendebury <vbendeb@google.com> Tested-by: Vadim Bendebury <vbendeb@google.com> Signed-off-by: Vadim Bendebury <vbendeb@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-17cros_ec: Add a function for decoding the Chrome OS EC flashmapSimon Glass
In order to talk to the EC properly we need to be able to understand the layout of its internal flash memory. This permits emulation of the EC for sandbox, and also software update in a system with a real EC. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-17cros_ec: Move EC interface into common libraryVadim Bendebury
Add a common library for obtaining access to the Chrome OS EC. This is used by boards which need to talk to the EC. Reviewed-by: Vadim Bendebury <vbendeb@google.com> Tested-by: Vadim Bendebury <vbendeb@google.com> Signed-off-by: Vadim Bendebury <vbendeb@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-17cros_ec: Add a function for reading a flash map entrySimon Glass
A flash map describes the layout of flash memory in terms of offsets and sizes for each region. Add a function to read a flash map entry from the device tree. Reviewed-by: Che-Liang Chiou <clchiou@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-17cros_ec: Add an enum for the number of flash regionsSimon Glass
Add an enum for the number of flash regions so we can keep track of all the possible regions. Reviewed-by: Randall Spangler <rspangler@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-17sandbox: dts: Add display and keyboard to sandboxSimon Glass
Add an LCD display and keyboard to the sandbox device tree so that these features can be used. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-17sandbox: Use os functions to read host device treeSimon Glass
At present we use U-Boot's filesystem layer to read the sandbox device tree, but this is problematic since it relies on a temporary feauture added there. Since we plan to implement proper block layer support for sandbox, change this code to use the os layer functions instead. Also use the new fdt_create_empty_tree() instead of our own code. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-17sandbox: Increase memory size to 32MBSimon Glass
The current 4MB size is a little small for some tests, so increase it. Reviewed-by: Hung-ying Tyan <tyanh@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-17Use a const pointer for map_to_sysmem()Simon Glass
This function does not actually change the pointer contents, so use const so that functions which have a const pointer do not need to cast. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-17mtd: spi: Fix page size for S25FL032P,S25FL064PMarek Vasut
The commit 6af8dc3ebccb3b1e4b2e479315e49545e7f53150 broke support for S25FL032P and S25FL064P by carelessly removing the code handling special page size for these two SPI NOR flashes and unifying the code under the assumption that Extended JEDEC ID of 0x4d00 always implies 512b page size. Add special case handling for these two SPI NOR flashes. Signed-off-by: Marek Vasut <marex@denx.de> Reviewed-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-03-17spi: atmel_dataflash: Simplify AT91F_SpiEnable implementationAxel Lin
Refactor the code a bit to make it better in readability. Remove the comments because now the intention of the code is pretty clear. Signed-off-by: Axel Lin <axel.lin@ingics.com> Reviewed-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-03-17sf: ops: Squash the malloc+memset comboJagannadha Sutradharudu Teki
Squash the malloc()+memset() combo in favor of calloc(). Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Acked-by: Marek Vasut <marex@denx.de>
2014-03-17sf: Squash the malloc+memset comboMarek Vasut
Squash the malloc()+memset() combo in favor of calloc(). Signed-off-by: Marek Vasut <marex@denx.de> Reviewed-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-03-17sf: Add S25FL128S_256K IDsMarek Vasut
Add IDs for this new chip. Signed-off-by: Marek Vasut <marex@denx.de> Reviewed-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-03-17sf: Fix entries for S25FL256S_256K and S25FL512S_256KMarek Vasut
Both of these chips have 256kB big sectors, thus the _256K suffix, compared to their _64K counterparts, which have 64kB sectors. Also, they have four times less sectors than their _64K counterparts. Signed-off-by: Marek Vasut <marex@denx.de> Tested-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-03-14sh: ecovec: correct romImage address in commentBaruch Siach
romImage is set by CONFIG_ECOVEC_ROMIMAGE_ADDR to 0xA0040000. Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-03-14sh: fix PFC registers definition for SH772{2, 3, 4}Baruch Siach
Add missing port X data register, and fix the offset of ports Y and Z. Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-03-13Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-03-13Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-03-13usb: dfu: add static alt num count in dfu_config_entities()Przemyslaw Marczak
Thanks to this multiple call of function dfu_config_entities() gives continuous dfu alt numbering until call dfu_free_entities(). This allows to store dfu entities in multiple variables. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Acked-by: Łukasz Majewski <l.majewski@samsung.com> Tested-by: Heiko Schocher <hs@denx.de> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-03-13Trats/Trats2: Update Tizen partitions layout and dfu entitiesPrzemyslaw Marczak
Changes: - update partitions layout - update dfu entities to be consistent with Tizen images for trats/trats2 Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Acked-by: Łukasz Majewski <l.majewski@samsung.com> cc: Piotr Wilczek <p.wilczek@samsung.com> cc: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-03-13arm: exynos: Squash bogus warnings in pinmuxMarek Vasut
Squash these warnings in pinmux.c found with GCC 4.8: /arch/arm/cpu/armv7/exynos/pinmux.c: In function 'exynos_pinmux_config': /arch/arm/cpu/armv7/exynos/pinmux.c:687:28: warning: 'count' may be used uninitialized in this function [-Wmaybe-uninitialized] for (i = start; i < start + count; i++) { ^ /arch/arm/cpu/armv7/exynos/pinmux.c:663:16: note: 'count' was declared here int i, start, count; ^ /arch/arm/cpu/armv7/exynos/pinmux.c:687:28: warning: 'start' may be used uninitialized in this function [-Wmaybe-uninitialized] for (i = start; i < start + count; i++) { ^ /arch/arm/cpu/armv7/exynos/pinmux.c:663:9: note: 'start' was declared here int i, start, count; ^ /arch/arm/cpu/armv7/exynos/pinmux.c:689:19: warning: 'bank' may be used uninitialized in this function [-Wmaybe-uninitialized] s5p_gpio_cfg_pin(bank, i, GPIO_FUNC(0x2)); ^ /arch/arm/cpu/armv7/exynos/pinmux.c:662:24: note: 'bank' was declared here struct s5p_gpio_bank *bank; ^ /arch/arm/cpu/armv7/exynos/pinmux.c: In function 'exynos_pinmux_config': /arch/arm/cpu/armv7/exynos/pinmux.c:687:28: warning: 'count' may be used uninitialized in this function [-Wmaybe-uninitialized] for (i = start; i < start + count; i++) { ^ /arch/arm/cpu/armv7/exynos/pinmux.c:663:16: note: 'count' was declared here int i, start, count; ^ /arch/arm/cpu/armv7/exynos/pinmux.c:687:28: warning: 'start' may be used uninitialized in this function [-Wmaybe-uninitialized] for (i = start; i < start + count; i++) { ^ /arch/arm/cpu/armv7/exynos/pinmux.c:663:9: note: 'start' was declared here int i, start, count; ^ /arch/arm/cpu/armv7/exynos/pinmux.c:689:19: warning: 'bank' may be used uninitialized in this function [-Wmaybe-uninitialized] s5p_gpio_cfg_pin(bank, i, GPIO_FUNC(0x2)); ^ /arch/arm/cpu/armv7/exynos/pinmux.c:662:24: note: 'bank' was declared here struct s5p_gpio_bank *bank; ^ Note that the warning is bogus, the function can never be called with invalid 'peripheral' argument. GCC just cannot analyze this. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Naveen Krishna Chatradhi <ch.naveen@samsung.com> Cc: Akshay Saraswat <akshay.s@samsung.com> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@ti.com> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Rajeshwari S Shinde <rajeshwari.s@samsung.com> Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-03-12kbuild: delete *.pyc files by "make distclean"Masahiro Yamada
The tools "buildman" and "patman" are written in Python. When we run them, "*.pyc" files are created under tools/buildman, tools/patman directories. They should be cleaned up by "make distclean". Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-03-12kbuild: delete SPLTREE and TPLTREEMasahiro Yamada
These variable are no longer used. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-03-12kbuild: rename OBJTREE to objtreeMasahiro Yamada
Prior to Kbuild, $(OBJTREE) was used for pointing to the top of build directory with absolute path. In Kbuild style, $(objtree) is used instead. This commit renames OBJTREE to objtree and delete the defition of OBJTREE. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-03-12kbuild: rename SRCTREE to srctreeMasahiro Yamada
Prior to Kbuild, $(TOPDIR) or $(SRCTREE) was used for pointing to the top of source directory. (No difference between the two.) In Kbuild style, $(srctree) is used for instead. This commit renames SRCTREE to srctree and deletes the defition of SRCTREE. Note that SRCTREE in scripts/kernel-doc, scripts/docproc.c, doc/DocBook/Makefile should be keep. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-03-12kbuild: rename TOPDIR to stctreeMasahiro Yamada
Prior to Kbuild, $(TOPDIR) or $(SRCTREE) was used for pointing to the top of source directory. (No difference between the two.) In Kbuild style, $(srctree) is used instead. This commit renames TOPDIR to srctree and delete the defition of TOPDIR. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
