These two functions were called only from ehci_submit_async(), therefore
dissolve them as part of ehci_submit_async() to get rid of all those static
variables.
This avoids cache-alignment warnings shown in console
when a usb command is entered.
Whenever X bytes of unaligned buffer is invalidated, arm core
invalidates X + Y bytes as per the cache line size and throws
these warnings.
Signed-off-by: Puneet Saxena <puneets@nvidia.com>
Building usb for Blackfin boards fails as we get linux/compiler.h
included which expands the "noinline" inside of the attribute and
we get attribute(attribute(noinline)).
Explicitly use the helper define to avoid this.
Without this patch, boot shows this messages upon NAND detection:
NAND: ONFI flash detected
ONFI param page 0 valid
ONFI flash detected
128 MiB
With this patch, its back to the U-Boot "standard":
NAND: 128 MiB
Tested on x600 (SPEAr600).
Cc: Amit Virdi <amit.virdi@st.com>
Cc: Vipin Kumar <vipin.kumar@st.com>
Cc: Scott Wood <scottwood@freescale.com>
Acked-by: Amit Virdi <amit.virdi@st.com>
Signed-off-by: Scott Wood <scott@tyr.buserror.net>
if priv->bank >= MAX_BANK, priv should be freed before returning ENODEV.
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
- Fix NAND_CMD_READID command for ONFI detect.
- Add NAND_CMD_PARAM command to read the ONFI parameter page.
Acked-by: Scott Wood <scottwood@freescale.com>
current U-Boot shows on startup (for example on the enbw_cmc
board) the following printfs from the nand subsystem:
Flash: 2 MiB
NAND: Bad block table found at page 65472, version 0x01
Bad block table found at page 65408, version 0x01
nand_read_bbt: Bad block at 0x000002980000
nand_read_bbt: Bad block at 0x000003240000
128 MiB
MMC: davinci: 0
remove them to debug output, so it shows with this patch:
Flash: 2 MiB
NAND: 128 MiB
MMC: davinci: 0
In function nand_write_skip_bad(),for YAFFS filesystem part,
write_oob() will return 0 when success, so when rval equals 0,
it should continue to write the next page, and no break.
Signed-off-by: Wentao, Liu <wentao.liu@intel.com>
Acked-by: Lei Wen <leiwen@marvell.com>
GOT is now handled the way the main u-boot.lds does it. Without this,
the boot hangs when built with newer GCC (since 4.6). Older toolchains
hid the issue by converting -fpic to -fPIC.
A use for this is to read, modify, erase, and write an entire block as a
single unit, as a replacement for the biterr command. This way gives
more flexibility in that you can also test multiple bit errors, errors
in the ECC, etc.
The patch that added parallel builds broke MAKEALL -l, so this
fixes that. At the same time, it improves the termination so
that it shuts down the build threads if you cancel the build.
Lastly, it removes a bunch of debug code.
Signed-off-by: Andy Fleming <afleming@freescale.com>
Tested-by: Wolfgang Denk <wd@denx.de>
pdnb3 and scpu are explicitly on LIST_ixp, even though they are
also specified in boards.cfg as having cpu ixp. This means that
they will be built twice when doing ./MAKEALL ixp, or ./MAKEALL arm.
This was pointless before, but actually breaks things if you launch
both builds at the same time, as they overwrite each other.
All arches init this the same way, so move the logic into the core
net code to avoid duplicating it everywhere else.
Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
This field gets read in one place (by "bdinfo"), and we can replace
that with getenv("ipaddr"). After all, the bi_ip_addr field is kept
up-to-date implicitly with the value of the ipaddr env var.
Requires:
--ignore CONSIDER_KSTRTO
Signed-off-by: R Sricharan <r.sricharan@ti.com>
CC: Aneesh V <aneesh@ti.com>
CC: Tom Rini <trini@ti.com>
Acked-by: Aneesh V <aneesh@ti.com>
As originally reported against beagleboard we currently have the
following error message reported in SPL:
U-Boot SPL 2012.04-00020-gb8310b9-dirty (Apr 25 2012 - 18:49:57)
Texas Instruments Revision detection unimplemented
OMAP SD/MMC: 0
timed out in wait_for_bb: I2C_STAT=1000
reading u-boot.img
The reason for above message is that when booting from MMC, I2C needs to
be initialized to talk with the TWL4030. On OMAP3 I2C is only
initalized in SPL if CONFIG_SPL_BOARD_INIT is set.
Cc: Thomas Weber <weber@corscience.de>
Cc: Steve Sakoman <sakoman@gmail.com>
Original patch for Beagleboard is:
Signed-off-by: Peter Meerwald <p.meerwald@bct-electronic.com>
Extended to cover all other boards:
With older toolchains it is possible to not fit entirely into the 45KB
that we had assigned to SPL. Adjust to allow for 8KB of stack (which
should be more than required) and 54KB of text/data.
Cc: Vaibhav Hiremath <hvaibhav@ti.com>
Cc: Nagendra T S <nagendra@mistralsolutions.com>
Cc: Ilya Yanok <yanok@emcraft.com>
Acked-by: Vaibhav Hiremath <hvaibhav@ti.com>
In warm reset conditions on OMAP36xx/AM/DM37xx the rom code
incorrectly sets the DPLL4 clock input divider to /6.5 which
is an invalid value unless the input clock is 13MHz. When a JTAG
emulator is attached, a warm reset is necessary after the emulator
gains control of the process. This results in a loss of serial
output due to the invalid DPLL4 settings.
This patch fixes the issue by resetting the DPLL4 clock input
divider to /1 when the input clock is not 13MHz. AM/DM37x TRM
section 3.5.3.3.3.2.1 specifies that the /6.5 setting is only
used when the input clock is 13MHz.
Signed-off-by: Matt Porter <mporter@ti.com>
For OMAP4 boards, such as the panda-es, that have 1GB of memory the linux
kernel fails to locate the device tree blob on boot. The reason being is that
u-boot is copying the DT blob to the upper part of RAM when booting the kernel
and the kernel is unable to access the blob. By setting the fdt_high variable
to either 0xffffffff (to prevent the copy) or 0xac000000 (704MB boundary
of memory for OMAP4) the kernel is able to locate the DT blob and boot.
Based upon following patch by Dirk Behme set the fdt_high variable to allow
booting with device tree on OMAP4 boards.
"7e9603e i.mx6q: configs: Add fdt_high and initrd_high variables"
Cc: Sricharan R <r.sricharan@ti.com>
Cc: Sandeep Paulraj <s-paulraj@ti.com>
Cc: Tom Rini <trini@ti.com>
Signed-off-by: Jon Hunter <jon-hunter@ti.com>
Booting up these cores (dsp / ivahd / cortex-m3) is bad without
firmware running on them, and they will hang preventing any kind
of sleep transitions later on with the kernel.
Signed-off-by: Tero Kristo <t-kristo@ti.com>
Acked-by: R Sricharan <r.sricharan@ti.com>
If this is done in the bootloader, the FS-USB will later be stuck into
intransition state, which will prevent the device from entering idle.
If uart2 is enabled during boot, spurious wifi chip transmission will
hang the module and it is impossible to recover from this situation
without hard reset. This will prevent any l4_per domain idle
transitions.
This patch changes the default mpurate variable from 500 to auto on
all IGEP boards, with this the default rate is autoselected.
Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com>
Based on commit cf073e49bc3502be1b48a0e3faf0cde9edbb89db for beagleboard
Using the new env import command it is possible to use plain text files instead
of script-images. Plain text files are much easier to handle.
E.g. If your boot.scr contains the following:
setenv dvimode 1024x768-16@60
run loaduimage
run mmcboot
you could create a file named uEnv.txt and use that instead of boot.scr:
dvimode=1024x768-16@60
uenvcmd=run loaduimage; run mmcboot
The variable uenvcmd (if existent) will be executed (using run) after uEnv.txt
was loaded. If uenvcmd doesn't exist the default boot sequence will be started,
therefore you could just use
as uEnv.txt because loaduimage and mmcboot is part of the default boot sequence
This is needed for upcoming Toradex Colibri T20 upstream support.
Signed-off-by: Lucas Stach <dev@lynxeye.de>
Signed-off-by: Tom Warren <twarren@nvidia.com>
This enables the standard keyboard on Seaboard.
All tegra boards will use these options by default.
Add support for internal matrix keyboard controller for Nvidia Tegra
platforms. This driver uses the fdt decode function to obtain its key
codes.
Support for the Ctrl modifier is provided. The left and right ctrl keys are
dealt with in the same way.
This uses the new keyboard input library (drivers/input/input.c) to decode
keys and handle most of the common input logic. The new key matrix library
is also used to decode (row, column) key positions into key codes.
The intent is to make this driver purely about dealing with the hardware.
Key detection before the driver is loaded is supported. This key will be
picked up when the keyboard driver is initialized.
Modified by Bernie Thompson <bhthompson@chromium.org> and
Simon Glass <sjg@chromium.org> for device tree, input layer, key matrix
and various other things.
Seaboard uses a QUERTY keyboard. We add key codes for this to
enable key scanning to work.
The Tegra keyboard controller provides a simple interface to a matrix
keyboard.
Add funcmux support for the default keyboard mapping.
Matrix keyboards require a key map to be set up, and must also deal with
key ghosting.
Create a keyboard matrix management implementation which can be leveraged
by various keyboard drivers. This includes code to read the keymap from
the FDT and perform debouncing.
Signed-off-by: Bernie Thompson <bhthompson@chromium.org>
Add a module which understands converting key codes (or scan codes)
to ASCII characters. It includes FIFO support and can call back to
drivers to read new characters when its FIFO is empty.
Keycode maps are provided for un-modified, shift and ctrl keys.
The plan is to use this module where such mapping is required.
We want to able to decode Linux fdt keymaps, so bring part of this
enormous header file over to U-Boot.
Sometimes we don't need a full cell for each value. This provides
a simple function to read a byte array, both with and without
copying it.
This enables LP0 to support suspend / resume on Seaboard.
This adds timings for T20 and T25 Seaboards, using the bindings found here:
http://patchwork.ozlabs.org/patch/132928/
We supply both full speed options for normal running, and half speed options
for testing / development.
Add tegra_i2c_get_dvc_bus_num() to obtain the I2C bus number of DVC bus.
This allows us to talk to the PMU.
Add a definition of the memory controller node according to the bindings
here:
Set Seaboard to optimal memory settings based on the SOC in use (T20 or T25).
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
Signed-off-by: Jimmy Zhang <jimmzhang@nvidia.com>
