U-Boot does not currently build for PXA platforms with USB support
enabled:
usb.c:46: error: 'UP2OCR' undeclared (first use in this function)
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Cc: Markus Klotzbuecher <mk@denx.de>
Edited commit message.
Commit 574b319512 introduced a subtle bug by mixing a list of tests
for "dev_desc->type" and "dev_desc->if_type" into one switch(), which
then mostly did not work because "dev_desc->type" cannot take any
"IF_*" type values. A later fix in commit 8ec6e332ea changed the
switch() into testing "dev_desc->if_type", but at this point the
initial test for unknown device types was completely lost, which
resulted in output like that for IDE ports without device attached:
Device 1: Model: Firm: Ser#:
Type: # 1F #
Capacity: not available
This patch re-introduces the missing test for unknown device types.
Cc: Stefan Roese <sr@denx.de>
Cc: Detlev Zundel <dzu@denx.de>
Tested-by: Stefan Roese <sr@denx.de>
This patch fixes a problem in the CPU frequency calculation. Without it
a 798MHz CPU is displayed as 368.503 MHz. And with it it's 798 MHz.
Signed-off-by: Detlev Zundel <dzu@denx.de>
The 'inline' is conflicting with the semantic of 'weak' attribute and with the
way the show_boot_progress() function is used.
Also gcc 4.4 is complaining about it:
main.c:51: error: inline function 'show_boot_progress' cannot be declared weak
Signed-off-by: Emil Medve <Emilian.Medve@Freescale.com>
cpu/mpc8260/cpu.c used to use do_fixup_by_path_u32() to update the
clock frequencies in the device tree, using a CPU path
"/cpus/OF_CPU", with OF_CPU beind defined in the board config file.
However, this does not work when one board config file (here:
MPC8260ADS.h) is intended to be used for several diffrent CPUs and
therefor contains a generic definition like "cpu@0", as the device
trees that will then be loaded will contain specific names like
"PowerPC,8272@0".
We switch to using do_fixup_by_prop_u32() instead, so we can search
for device_type="cpu", as it is done in other architectures, too.
Acked-by: Heiko Schocher <hs@denx.de>
Tested-by: Heiko Schocher <hs@denx.de>
Add CONFIG_SYS_MONITOR_LEN macro to apollon board config.
CONFIG_SYS_MONITOR_LEN defines the U-Boot image size.
and is used by OneNAND ipl when reading U-Boot image.
Signed-off-by: Rohit Hagargundgi <h.rohit at samsung.com>
Acked-by: Kyungmin Park <kyungmin.park@samsung.com>
This will make CONFIG_NET_MULTI the only net driver configuration and
we'll be able to remove this option.
The pin which was used in preliminary versions of the board for ide
reset is really connected to the rtc clock.
This patch adds, under tools folder, a new command called imls. Its
goal is the same of UBoot's imls but it can be used as Linux shell
command. It reads from raw mtd partition and prints the list of the
stored images.
Signed-off-by: Marco Stornelli <marco.stornelli@gmail.com>
Fix some issues introduced from commit:
2f70c49e5b9813635ad73666aa30f304c7fdeda9
suggested by Mike Frysinger.
- added some comment for the env_id variable in common_cmd_nvedit.c
- moved some variables in fn scope instead of file scope
- NetInitLoop now static void
Acked-by: Ben Warren <biggerbadderben@gmail.com>
Cc: Sascha Hauer <s.hauer@pengutronix.de>
I never acked a patch that adds me as phycore i.MX31 maintainer nor was
it me who pushed the patches, so remove myself from the maintainer list
so that other people do not longer wait for my ack.
AFEB9260 uses PA10, PA11 for ETX2 and ETX3.
Also, due to extarnal pull-up on IRQ line, Micrel PHY ID is 1 after reset sequence,
not 0.
Signed-off-by: Sergey Lapin <slapin@ossfans.org>
We don't know what state the ethernet PHY is in when starting up, so make
sure we set it to a sane state. This fixes troubles seen when Linux boots
up, configures the PHY is a non-default state, and then the system reboots
into U-Boot which previously expected a reset state only.
Signed-off-by: Graf Yang <graf.yang@analog.com>
The BF527-EZKIT settings for storing the environment in SPI flash wasn't
using the correct sector settings for the SPI flash part that is actually
on the board.
When the clock functions were changed to use cached values (and thereby
avoiding expensive math functions), early serial debug broke because the
baud programming is called before external memory is available.
When dropping jump block support, the assumption was that all bootroms
supported entry point redirection via the EVT1 register. Unfortunately,
this turned out to be incorrect for the oldest Blackfin parts (BF533-0.2
and older and BF561). No one really noticed earlier because these parts
usually are booted by bypassing the bootrom entirely, and older BF533
parts are not supported at all (too many anomalies).
Make sure we recurse through serial_putc() rather than bang on the UART
transmit register directly to avoid hardware overflows when using \n.
Update CHANGELOG.
lowlevel_init.S is not used any more so remove it.
As consequence, we also don't have to generate u-boot.lds
but can use a static version as before.
This also fixes the out-of-tree build problem introduced
with commit f0a2c7b4 "at91: add support for the PM9263 board"
Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
Signed-off-by: Manikandan Pillai <mani.pillai@ti.com>
The Beagle Rev C boards pull UART2 from an alternate set of balls.
Signed-off-by: Steve Sakoman <steve@sakoman.com>
Blocks compressed with zlib dont have the full gzip header.
Without this patch, block compressed with zlib cannot be readed!
Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@uam.es>
Separate gunzip in
gunzip: Find the end of the header and call zunzip.
zunzip: Inflate gunzip block without header.
UBI fs blocks can be compresed in lzo, zlib or no-compression. The
current implementation of u-boot supported all the compressions but
there was a bug in the implementation of the zlib blocks.
UBIFS's Zlib blocks do not have header but they were compressed using
gunzip, a function used to decompress gunzip files/sectors with a
header.
This patch adds a new function zunzip that uncompress a zlib block with
no header.
Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu>
Let CONFIG_SYS_HZ to have value of 1000 effectively fixing all users of
get_timer.
Changes since original version:
* Set PTV=2 (divisor 8) for boards using 12MHz timer clock source to
improve timer resolution.
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
Remove remaining legacy NAND defines for Beagle, EVM, Overo and Pandora.
The function display_board_info() displays incorrect
silicon revision - based on the return value from
function get_cpu_rev().
This patch fixes the problem.
Signed-off-by: Sanjeev Premi <premi@ti.com>
The board-types defined in struct omap3_sysinfo seem to be
unused. The function display_board_info() is passed
board type as an argument; which is ignored.
This patch removes all uses of board-type, related definitions
and functions.
Use the functions print_cpuinfo() and checkboard() to
display the cpu and board specific information.
These functions reuse content from the existing function
display_board_info() - which has been removed.
Also, updated the existig OMAP3 configurations to
define:
- CONFIG_DISPLAY_CPUINFO
- CONFIG_DISPLAY_BOARDINFO
With this patch non-uniform NOR FLASH chips (chips with multiple erase
regions) can be exported via the cfi-mtd layer and therefor used by UBI.
We select the largest sector size as erasesize. The cfi driver will make
sure that the smaller sectors are handled correctly.
Fix bug in drawing long version/info strings:
U-Boot version string like
"U-Boot 2009.03-05647-g7c51e06 (Apr 23 2009 - 12:40:00) MPC83XX"
is long and doesn't wrap around correctly while drawing
beside the logo. Such long strings partially overwrite
the logo. This patch is an attempt to fix it.
Get rid of these warnings:
cmd_ext2.c:247: warning: format '%ld' expects type 'long int', but argument 2 has type 'int'
cmd_ext2.c:248: warning: format '%lX' expects type 'long unsigned int', but argument 3 has type 'int'
because legacy NAND support is deprecated converting to current
NAND interface. !This just compile, because I have no more the
hardware to test it.
If the memory used to copy the link_make is "dirty" the string wont
be ended with NULL, throwing out multiple memory bugs.
Add basic error handling to fread() function calls. This prevents
compililation warnings such as:
bmp_logo.c: In function ‘main’:
bmp_logo.c:71: warning: ignoring return value of ‘fread’, declared with
attribute warn_unused_result
This prevents the compilation warning:
ncb.c: In function 'main':
ncb.c:32: warning: ignoring return value of ‘write’, declared with
With this patch the NAND and OneNAND devices are registered in the MTD
subsystem and can then be referenced by the mtdcore code (e.g.
get_mtd_device_nm()). This is needed for the new "ubi part" command
syntax without the flash type parameter (nor|nand|onenand).
This patch removes this compilation warning when CONFIG_MTD_PARTITIONS is
defined:
nand_base.c: In function 'nand_release':
nand_base.c:2922: warning: implicit declaration of function 'del_mtd_partitions'
This patch removes the now unnecessary flash type parameter from the
"ubi part" command. Currently the user has to define the type of flash
he will be using UBI on. Example:
=> ubi part nor partition1
With this patch this type parameter is not needed anymore. The user can
now select the partition directly without the flash type paramter.
Example:
=> ubi part partition1
This breaks backward compatibility right now because of the change in the
command syntax. But UBI support is still quite fresh and the advantage of
this new command is syntax big enough for this change. Additionally the
code is much cleaner now.
CC: Kyungmin Park <kyungmin.park@samsung.com>
