The support for DaVinci DM* SoCs has been dropped a while ago. There's
still a lot of leftover code in mach-davinci though. Entirely remove
certain files and modify the common code to no longer reference
unsupported chips.
Note: all DaVinci platforms supported in u-boot now define SOC_DA8XX
but not all define SOC_DA850 (e.g. omapl138). We can safely remove
all ifdefs for the former, but let's leave the ones for the latter.
Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com>
The support for DaVinci DM* SoCs has been dropped. The ifdefs in the
musb_hcd driver are no longer needed. Remove them.
The support for DaVinci DM* SoCs has been dropped. The code that used
to be relevant to dm644x is no longer needed. Remove it.
The support for DaVinci DM* boards has been dropped a while ago. The
code for all those PHYs is no longer used and they have their own
proper PHY drivers in drivers/net/phy anyway. Remove all dead code.
The boards with SoCs from the DaVinci DM* family used to come with
different PHYs that needed special support implemented in mach-davinci.
Since the support for these chips has long been removed, we can now
drop this unnused code from the emac driver.
- Misc MMC, FPGA bridge, general SoCFPGA fixes
- DaVinci updates
- Fix in kwbimage (return code checking) (Young Xiao)
- Misc updates to Turris Omnia (Marek)
There are a few functions defined in the header file, but they are
not referenced by any Davinci code. In order to make a general
function in the future with static function declarations, this
patch will remove the references all together.
There is a delay function that was commented out. This patch
re-enables it, because it will be needed for da850 ohci support.
- Various btrfs fixes
- Various TI platform fixes
- Other fixes (cross build, taurus update, Kconfig help text)
The btrfs implementation methods .ls(), .size() and .read() returns 1 on
failure, but the command handlers expect values <0 on failure.
For example if given a nonexistent path, the load command currently
returns success, and hush scripting does not work.
Fix this by setting return values of these methods to -1 instead of 1 on
failure.
Signed-off-by: Marek Behún <marek.behun@nic.cz>
When CROSS_BUILD_TOOLS is set, set HOSTCFLAGS to CFLAGS otherwise CC
will be used with HOSTCFLAGS which seems wrong
Signed-off-by: Fabrice Fontaine <fontaine.fabrice@gmail.com>
The card detect pin was incorrectly using IRQ_TYPE_LEVEL_LOW
instead of GPIO_ACTIVE_LOW when reading the state of the CD pin.
Without this patch, MMC1 won't be detected.
This is the same patch submitted to linux-omap, but I was hoping
to get it applied to U-Boot without having to wait for the
linux adoption and then backporting.
Fixes: 5448ff33f281 ("ARM: DTS: Resync Logic PD SOM-LV 37xx
devkit with Linux 4.18-RC4")
The DM* family of SOCs is no longer supported. We now support the
omap-l138 lcdk board and Lego EV3 platform. Reflect those changes
in the README.
Reviewed-by: Sekhar Nori <nsekhar@ti.com>
Add am335x-pocketbeagle to CONFIG_OF_LIST in am335x_evm_defconfig.
Signed-off-by: Vagrant Cascadian <vagrant@debian.org>
Add device-tree files from linux 5.1-rc7 needed to complete support
for PocketBeagle.
Transition to the IOPAD macros as used in Linux in which the pin mux
mode is specified using a dedicated parameter while also dropping the
related MUX_MODEx macros that are no longer needed. This transition
will allow us to keep both Linux and U-Boot DTS in sync more easily.
While at it also align the file name of the include file itself and
update any references accordingly.
Signed-off-by: Andreas Dannenberg <dannenberg@ti.com>
Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
- at91sam9g20-taurus.dts: use labels
- cleanup taurus port to compile clean with
current mainline again. SPL has no serial
output anymore, so it fits into SRAM.
TI-SCI firmware will only respond to messages when the
TI_SCI_FLAG_REQ_ACK_ON_PROCESSED flag is set. Most messages
already do this, set this for the ones that do not.
Signed-off-by: Andrew F. Davis <afd@ti.com>
Tested-by: Alejandro Hernandez <ajhernandez@ti.com>
Acked-by: Nishanth Menon <nm@ti.com>
commit 95f4bbd581cf ("lib: fdt: Allow LZO and GZIP DT compression in U-Boot")
introduced Kconfig option for gzip in U-Boot, but help text
says gzip for SPL, which is wrong. Fix this.
common.h already includes uuid.h
Other filesystem drivers don't do this.
The existing comments where confusing read and write. The comment for
fs_write() had:
"@addr: The address to read into"
So let's rework the comments and format them in Sphinx style.
Switch from using the high priority DMSC transmit message queue used
by the secure R5 MCU island boot context to the low priority message
queue. While the change in priority is irrelevant for the current boot
architecture it however gives us access to a deeper message queue that
will allow us to buffer more messages. This is an important aspect when
sending several messages without requesting and waiting for a response
in a row which is a communication scheme used during core shutdown for
example. See AM654 TISCI User Guide for additional details.
In commit ad6054f1fe128f797b6eb2964afca6674b584785 where support for the
Sancloud BeagleBone Enhanced (BBE) was added, new conditional
configuration of either MII pin muxing or RGMII pin muxing is done
depending on the board type. However, the old call to set up MII pin
muxing was not removed.
This may result in misconfiguration of the pin muxing for the BBE or
duplicate configuration for other boards and so we remove this obsolete
call.
Signed-off-by: Paul Barker <paul.barker@sancloud.co.uk>
Restart operation never exists and reset operation never
makes the watchdog expire immediately but expire_now operation
does.
Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
Upcoming sysfw (2019.03) will not open the channelized firewalls during
init, it only going to do so in response to the channel configuration
message.
Remove the channel state checks done before the channel configuration and
move it after the configuration for warning purposes.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com>
Reviewed-by: Grygorii Strashko <grygorii.strashko@ti.com>
An earlier commit converted the TISCI receive timeouts to be specified
in ms rather than us however it failed to take this change into account
when passing the actual timeout to be used when invoking the mailbox
receive API. This leads to the actual timeout to be 1,000 times shorter
than expected and as a result certain TISCI operations would fail.
Fix the issue by converting the timeout declared in ms to us on the fly
as expected by the respective API.
Fixes: fd6b40b1ba20 ("firmware: ti_sci: Add support for NAVSS resource management")
Update the mmc maintainer from Jaehoon to me.
Cc: Jaehoon Chung <jh80.chung@samsung.com>
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Currently packet data is wrongly extracted when metadata is NULL.
Fix it and negate the if check.
Signed-off-by: Keerthy <j-keerthy@ti.com>
Reviewed-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Pull request for UEFI sub-system for v2019.07-rc2
This pull request provides error fixes for the handling of GPT partitions
and for the UEFI subsystem.
This options will be enabled by default by CZ.NIC shipped U-Boot. Enable
them in defconfig.
Add support for the gpio command and driver for the I2C connected
pca9538 controller, to be able to determine if SFP module is present in
the Turris Omnia router.
The twsi_wait function reads the control register for interrupt flag,
and if interrupt flag is present, it immediately reads status register.
On our device this sometimes causes bad value being read from status
register, as if the value was not yet updated.
My theory is that the controller does approximately this:
1. sets interrupt flag in control register,
2. sets the value of status register,
3. causes an interrupt
In U-Boot we do not use interrupts, so I think that it is possible that
sometimes the status register in the twsi_wait function is read between
points 1 and 2.
The bug does not appear if I add a small delay before reading status
register.
Wait 100ns (which in U-Boot currently means 1 us, because ndelay(i)
function calls udelay(DIV_ROUND_UP(i, 1000))) before reading the status
register.
Cc: Mario Six <mario.six@gdsys.cc>
Cc: Baruch Siach <baruch@tkos.co.il>
There is a Factory RESET button on the back side of the Turris Omnia
router. When user presses this button before powering the device up and
keeps it pressed, the microcontroller prevents the main CPU from booting
and counts how long the RESET button is being pressed (and indicates
this by lighting up front LEDs).
The idea behind this is that the user can boot the device into several
Factory RESET modes.
This patch adds support for U-Boot to read into which Factory RESET mode
the user booted the device. The value is an integer stored into the
omnia_reset environment variable. It is 0 if the button was not pressed
at all during power up, otherwise it is the number identifying the
Factory RESET mode.
This patch also changes bootcmd to a special hardcoded value if Factory
RESET button was pressed during device powerup. This special bootcmd
value sets the colors of all the LEDs on the front panel to green and
then tries to load the rescue image from the SPI flash memory and boot
it.
The regdomain environment variable is set according to value read from
EEPROM. This has to be done in board_late_init, after the environment
variables are read from SPI. Select CONFIG_BOARD_LATE_INIT in Kconfig
for the Turris Omnia target.
Since board watchdog is now unified and not handled in board files,
remove the unnecessary includes.
Unify the way how Omnia and Mox print board information (RAM size and
serial number).
Refactor RAM size reading from EEPROM in preparation for next patch.
This driver is required for Turris Omnia to read ethernet addresses.
Move the dependency from turris_omnia_defconfig to Kconfig.
Refactor code which accesses the microcontroller and EEPROM via I2C.
If SCSI is enabled, U-Boot should try to boot also from SCSI device on
Turris Omnia.
The I2C dependencies are defined in include/configs/turris_omnia.h,
because Turris Omnia won't boot correctly without I2C support.
Move these dependencies to Kconfig, so that they are selected if Turris
Omnia is selected as target.
These are not needed if MMC and SCSI DM drivers are used.
Enable AHCI, SCSI and SATA for compliance with the driver model
migration.
Add XHCI_HOST and XHCI_MVEBU to defconfig, so that user's can by default
boot from USB on Turris Omnia.
The i2c slave disabling is done by mvtwsi driver and is not needed here.
Acked-by: Heiko Schocher <hs@denx.de>
EVP_VerifyFinal would return one of three values:
1 if the data is verified to be correct;
0 if it is incorrect;
-1 if there is any failure in the verification process.
The varification in unpatched version is wrong, since it ignored
the return value of -1.
The bug allows a malformed signature to be treated as a good
signature rather than as an error. This issue affects the
signature checks on DSA ans ECDSA keys used with SSL/TLS.
This issue is similar to CVE-2008-5077, CVE-2009-0021,
CVE-2009-0025, CVE-2009-0046 ~ CVE-2009-0049.
Signed-off-by: Young Xiao <92siuyang@gmail.com>
