Building the compression code in lib_generic/ with -O2 rather than -Os
gives a nice speed boost without too much code size increase.
The latest version of U-Boot got a bit fatter in the BSS section which
caused overflows in the RAM region, so increase the monitor size.
The SPI flash layer is much stricter about sector usage than the eeprom
layer we used to use, so update the env settings to better match the
sector alignment of the flashes we use.
Signed-off-by: Vivi Li <vivi.li@analog.com>
The debug tools that interface with the other side of the JTAG console
got much slower when generalizing things, so bump up the default timeout
value on the U-Boot side to cope. Hopefully at some point we can improve
the debug tools to speed things back up.
This script is similar to the netconsole script, but instead works with
the JTAG console device driver that exists on Blackfin parts.
All drivers need to be converted to CONFIG_NET_MULTI.
This patch converts the dm9000 driver.
Signed-off-by: Thomas Smits <ts.smits@gmail.com>
Signed-off-by: Remy Bohmer <linux@bohmer.net>
This patch adds a egiga driver for the Marvell Kirkwood SoC's.
Contributors:
Yotam Admon <yotam@marvell.com>
Michael Blostein <michaelbl@marvell.com
Reviewed-by: Ronen Shitrit <rshitrit@marvell.com>
Acked-by: Stefan Rose <sr@denx.de>
Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
Different flavours of DaVinci SOC's have differences in their EMAC IP
This patch does the following
1) Updates base addresses for DM365
2) Updates MDIO frequencies for DM365 and DM646x
3) Update EMAC wrapper registers for DM365 and DM646x
Patch applies to u-boot-net git. the EMAC driver itself
will be updated shortly to add support for DM365 and DM646x
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
udelay(1) loop counter.
From 584b5fbd4abfc43f920cc1c329633e03816e28be Mon Sep 17 00:00:00 2001
From: Richard Retanubun <RichardRetanubun@RuggedCom.com>
Date: Wed, 20 May 2009 18:26:01 -0400
Subject: [PATCH] Standardize the use of MCFFEC_TOUT_LOOP as a udelay(1) loop counter.
Signed-off-by: Richard Retanubun <RichardRetanubun@RuggedCom.com>
The problem is that BOOTP_SIZE uses ETHER_HDR_SIZE which is 14 bytes.
If sending a VLAN tagged frame (when env variable vlan is set) this
should be VLAN_ETHER_HDR_SIZE=18 which is what NetSetEther returns.
Signed-off-by: Norbert van Bolhuis <nvbolhuis@aimvalley.nl>
Added CONFIG_NET_MULTI to all Davinci boards
Removed all calls to Davinci network driver from board code
Added cpu_eth_init() to cpu/arm926ejs/cpu.c
Removed pointless #ifdefs
Moved functions around in file in preparation for switch to newer API
This driver has been renamed davinci_emac.c
Chips supported:-
1. 88E6161 6 port gbe swtich with 5 integrated PHYs
2. 88E6165 6 port gbe swtich with 5 integrated PHYs
2. 88E6132 3 port gbe swtich with 2 integrated PHYs
Platform specific configuration supported for:-
default or router port vlan configuration
led_init configuration
mdip/n polarity reversal configuration
Note: This driver is supported and tested against
kirkwood egiga interface
Contributors:
Reviewed by: Ronen Shitrit <rshitrit@marvell.com>
Signed-off-by: Zach LeRoy <zleroy@xes-inc.com>
Acked-by: Kumar Gala <galak@kernel.crashing.org>
All the Blackfin linker scripts were duplicated across the board dirs with
no difference save from the semi-often used ENV_IS_EMBEDDED option. So
unify all of them in the lib_blackfin/ dir and for the few boards that
need to embedded the environment directly, add a LDS_BOARD_TEXT define for
them to customize via their board config file. This is much simpler than
forcing them to duplicate the rest of the linker script.
The BF51xF parts have an internal SST SPI flash, so make sure the driver is
enabled by default so we can access it.
The Blackfin port was using asm/blackfin-config-{pre,post}.h to setup
common Blackfin board defines. The common method now is to use config.h,
so convert blackfin-config-post.h to that. Rename the still Blackfin
specific blackfin-config-pre.h to config-pre.h so the naming conventions
at least line up.
Allow boards to easily override the root= and default bootcmd, allow
people to tweak the file used in default bootcmds at runtime via one env
var, and add a stock nandboot command.
Signed-off-by: Hoan Hoang <hnhoan@i-syst.com>
Newer Blackfin parts can an on-chip ROM that can boot LDRs over SPI flashes,
so add a new 'spibootldr' command to take advantage of it.
For the most part, the Blackfin processor boots files in the LDR format
rather than binary/ELF files. So we want to export the environment as a
raw blob to the LDR utility so it can embed it at the right location.
The Linux kernel has some helper rules which allow you to quickly produce
some of the intermediary files from C source. Specifically, you can
create .i files which is the preprocessed output and you can create .s
files which is the assembler output. This is useful when you are trying
to track down header/macro expansion errors or inline assembly errors.
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
The $(SUBDIRS) variable is only declared when U-Boot has been configured,
but it gets used all the time. In the non-configured case, it is used to
generate a helpful error message, but it needs to be set properly for that
to occur.
With our Blackfin boards, we like to build the compression routines with
-O2 as our tests show a pretty good size/speed tradeoff. For the rest of
U-Boot though, we want to stick with the default -Os as that is mostly
control code. So in our case, we would add a line like so to the board
specific config.mk file:
CFLAGS_lib_generic += -O2
Now all files under lib_generic/ will have -O2 appended to their build.
Update CHANGELOG, fix minor coding stylke issue. Update Makefile.
This reverts commit ca9c8a1e10fac01e6a1129f82a7ce18bd818fa43,
which causes compile warnings ("large integer implicitly truncated
to unsigned type") on all systems that use this driver. The warning
results from passing long constants (TX_CFG, RX_CFG) into
smc911x_set_mac_csr() which is declared to accept "unsigned
character" arguments only.
Being close to a release, with nobody available to actually test the
code or the suggested fixes, it seems better to revert the patch.
Add defines similar to those already used for the the 86xx architecture.
This will ease sharing of PCI code between the 85xx and 86xx
architectures.
The following changes were made to sync up the DMA code between the 85xx
and 86xx architectures which will make it easier to break out common
8xxx DMA code:
85xx:
- Don't set STRANSINT and SPCIORDER fields in SATR register. These bits
only have an affect when the SBPATMU bit is set.
- Write 0xffffffff instead of 0xfffffff to clear errors in the DMA
status register. We may as well clear all 32 bits of the register...
86xx:
- Add CONFIG_SYS_MPC86xx_DMA_ADDR define to address DMA registers
- Add clearing of errors in the DMA status register when initializing
the controller
- Clear the channel start bit in the DMA mode register after a transfer
Break out DMA structures for the Freescale MPC85xx and MPC86xx cpus to
reduce a large amount of code duplication
On MPC8569MDS board, UCC6 and UCC8 can be configured to work at SGMII mode via
UEM on PB board. Since MPC8569 supports up to 4 Gigabit Ethernet ports, we
disable UEC6 and UEC8 by default.
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
